08-05-2012, 13:25 | #16321 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | registered to: amc_khan Connect phone on selected interface... Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm561__09.98.mcusw PPM : rm561__09.97.ppm_mena_b CNT : rm561__09.98.image_mh_blac Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 03F00006EDD40354698F0FE27787E7157F4DFAB8 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm561__09.98.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Erase : ERR1 : connection lost or data missmatch EraseFile: Error: Erasure error, Area: 1 TIME : Erase time : 00:00:00 Connect phone on selected interface... -> Error while flashing... |
08-05-2012, 13:26 | #16322 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... UFS S/N 102641 boot - Ok Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 355938044617332 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 Error finding required loader... - > USE USB cable for it ;D Error fetching data... |
08-05-2012, 13:26 | #16323 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Can't read Unique data! Repair fail...! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SL procedure started... Phone Imei: 355938044617332 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 Error finding required loader... - > USE USB cable for it ;D Error fetching data... |
08-05-2012, 13:27 | #16324 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Can't read Unique data! Repair fail...! ( SL3 phone? ) Local SX4 procedure started... Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Local SX4 procedure started... Phone Imei: 355938044617332 Use custom key... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Uploading RF/Battery tune to phone... Using : RM-243.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! |
08-05-2012, 13:27 | #16325 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:07 Upload failed Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Repair SD procedure started... Phone Imei: 355938044617332 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 Error finding required loader... - > USE USB cable for it ;D Error fetching data... |
08-05-2012, 13:28 | #16326 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Can't read Unique data! Repair fail...! Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read Uniq key data started... Phone Imei: 355938044617332 Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 Error finding required loader... - > USE USB cable for it ;D Error fetching data... |
08-05-2012, 13:28 | #16327 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Phone found! Series 60 Device detected! read info... - Ok Backup Certificates now... SLx Simlock Data read ... ok SL2 Simlock read ... ok CRT308 Backup Created Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 UFSx doesn't support New Protocol - > Use USB cable for this phone ;D SimLock Data saved... SimLock Key saved... RPL saved : D:\BEST\Backup\Cert\355938044617332_SIM.rpl Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
08-05-2012, 13:29 | #16328 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Read fail...! Connect phone on selected interface... Using : RM-243.pp Operating mode is OK, no need change... Write 166 element(s)... Writen : 166 elements Done! Elapsed: 00:00:08 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 UFSx doesn't support New Protocol - > Use USB cable for this phone ;D Repair SD procedure started... Repair fail...! Repair SD procedure started... Repair fail...! Repair SD procedure started... Repair fail...! Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Setting FlashMode Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Setting FlashMode FlashMode set Ok 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006400C192101051103 CMT EM0 ID : 00000296 CMT EM1 ID : 00000B22 CMT PUB ID : 0E90000852A90052F23CE6600EBAE0EB92DE44EA CMT MODE ID : 00 CMT R_HASH : 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID : 4B9B75103E691FF8 UFSx doesn't support New Protocol - > Use USB cable for this phone ;D Boot failed! - > If phone RAPUYAMA, RAP3Gv4 or BroadComm - Use USB cable Done! |
08-05-2012, 13:29 | #16329 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:11 Connect phone on selected interface... Connect phone on selected interface... - > UFSx : FlashMode init fail! Reconnect box Boot failed! - > If phone RAPUYAMA, RAP3Gv4 or BroadComm - Use USB cable Done! Elapsed: 00:00:34 Connect phone on selected interface... Error reset UFS #102641 Error reset UFS #102641 Error reset UFS #102641 Boot failed! - > If phone RAPUYAMA, RAP3Gv4 or BroadComm - Use USB cable Done! Elapsed: 00:00:35 Connect phone on selected interface... Phone disconected! Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 0FE1BA92D924A658E4800780FA6F4868100AC947 CFL : Reading flash certs.... CFL : Reading NPC IMEI : 355938044617332 CFL : Reading CCC CFL : Reading HWC Cert Read done! |
08-05-2012, 13:31 | #16330 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL2 Simlock read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... Swap data collected to 0550022.pc RPL saved : D:\BEST\Backup\Cert\355938044617332.rpl All done, Disconnecting Elapsed: 00:00:42 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Read Uniq key data started... - > Power Off phone, dissconnect it - > Phone was not powered Off Read fail...! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 355938044617332 - > Power Off phone, dissconnect it and connect - > Phone was not powered Off Can't read Unique data! Repair fail...! Phone disconected! Connect phone on selected interface... Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Error on 1st boot Check cable, Battery. Try again -> Error answer from BootRom Fetching failed! |
08-05-2012, 13:32 | #16331 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Connect phone on selected interface... Read fail...! Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Read Uniq key data started... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 Fetching data, wait... - > Reinsert cable and battery, press powerOn button again - > For X7, E7 - just waiting, near 1 minute - > When BEST start Search Phone - Press PowerOn if needed Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 0FE1BA92D924A658E4800780FA6F4868100AC947 CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Wait, reconneting... rap= 0E90000852A90052F23CE6600EBAE0EB92DE44EA hash= 479C6DDE3942E12C429C1D6ADED80371 key= 215A080248DCF16A9DD5BEA310721F33607C08B3 Key file updated... Done! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
08-05-2012, 13:32 | #16332 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Repair SD procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Repair SL procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok! Writing SimLock Key... Ok! Done! Local SX4 procedure started... Phone Imei: 355938044617332 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-243.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! |
08-05-2012, 13:32 | #16333 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL2 phone detected Done! Repair SD procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Repair SL procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok! Writing SimLock Key... Ok! Done! |
08-05-2012, 13:33 | #16334 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:00 Upload done Uploading RF/Battery tune to phone... Using : RM-243.pm Local SX4 procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Phone Imei: 355938044617332 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-243.pm Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 |
08-05-2012, 13:33 | #16335 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Upload done Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.2.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm - > If phone is RAPIDO - Use Dead mode for it ;D Connect phone on selected interface... Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom Error, phone reboot not done #2 (Phone was not BootUp) rap= 0E90000852A90052F23CE6600EBAE0EB92DE44EA hash= 479C6DDE3942E12C429C1D6ADED80371 key= 215A080248DCF16A9DD5BEA310721F33607C08B3 mod= B52B80CCE3B4AED2CCBA4B2F6A994700 - > You can insert data in "special.log" manually - > Or repeat procedure again Read fail...! Connect phone on selected interface... |
