08-05-2012, 13:33 | #16336 (permalink) |
No Life Poster Join Date: Nov 2007 Location: karachi pakistan
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | No any file selected, break operation Connect phone on selected interface... Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.2.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.2.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 0FE1BA92D924A658E4800780FA6F4868100AC947 CFL: Preparing for write certificates... Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok CFL: Writing Flash certs done! CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot All done, disconneting... Done! |
08-05-2012, 13:34 | #16337 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Elapsed: 00:00:33 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Repair SD procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Accepted SdRepReq (on alive SD) by user Operating mode is OK, no need change... Writing Super Dongle Key... Ok! Done! Repair SL procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Operating mode is OK, no need change... Writing SimLock Data... Ok! Writing SimLock Key... Ok! Done! Local SX4 procedure started... Phone Imei: 355938044617332 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-243.pm Setting to : 0550022 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 |
08-05-2012, 13:34 | #16338 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Upload done Processing Server SX4 Auth Checking SDD key... Check SD : Key is Ok Operating mode is OK, no need change... Connecting to server... Connection error #1 Server not found... SX4 Auth error Uploading RF/Battery tune to phone... Using : RM-243.pm Setting to : 0550022 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Local SX4 procedure started... Phone Imei: 355938044617332 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-243.pm Setting to : 0550022 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => DAMAGED - > Try "Restore CCC/HWC" option, after SX4 again Done! Elapsed: 00:00:00 Upload done Local SX4 procedure started... Phone Imei: 355938044617332 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > Try Check "Custom Keys" checkbox and repeat - > If SDD original - "Use Server Sx4" Will Write CCC/HWC keys now... Using : RM-243.rpl CCC Data found! HWC Data found! Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0E90000852A90052F23CE6600EBAE0EB92DE44EA ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.2.0 Processing RAWLOADER... 2nd boot not accepted... Alive Request not done Boot error... Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm - > If phone is RAPIDO - Use Dead mode for it ;D Connect phone on selected interface... |
08-05-2012, 13:34 | #16339 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.45 , FlashEngine : v1.40 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__03.35.mcusw PPM : 5FC9E6E8_rm607__03.35.ppm_m_c CNT : 262C5BC4_rm607__03.35.image_m_c_059B107 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.37_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357021045733073 PCcode : 059G896 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\BEST\Backup\Cert\357021045733073_XG213_CRT.rpl ===Flashing [MCU]=== File : rm607__03.35.mcusw Image : rm607__03.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:00 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:33 ===Flashing [PPM]=== File : 5FC9E6E8_rm607__03.35.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41C00000 , Len : 0x00319A48 Flashing , wait ... Region flash done, time : 00:00:03 ===Flashing [CNT]=== File : 262C5BC4_rm607__03.35.image_m_c_059B107 Image : package_m_c_059B107.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:09 Write , Start : 0x42200000 , Len : 0x00B40000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip Flashing done! Total flash time : 00:07:38 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 03.35 02-12-10 RM-607 (c) Nokia IMEI: 357021045733073 PPM version : V 03.35 02-12-10 RM-607 (c) Nokia M_C Product code: 059G896 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:48 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-05-2012, 13:49 | #16340 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 44
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | registered to: sirnavid Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-504_40.0.003_prd.core.C00 PPM : RM-504_40.0.003_prd.rofs2.V12 PPM2 : RM-504_40.0.003_C01_prd.rofs3.fpsx CNT : RM-504_32.0.007_007_000_U001.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 17E00018F49C00520D1E4608A5FEBB6240472214 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-504_40.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_prd.core.C00 Total 444 [444/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:30 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-504_40.0.003_prd.rofs2.V12 Found 1 areas to erase Erasing area 0x07360000 - 0x0935FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_prd.rofs2.V12 Total 82 [82/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:05 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-504_40.0.003_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09360000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_40.0.003_C01_prd.rofs3.fpsx Total 23 [23/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-504_32.0.007_007_000_U001.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F71FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-504_32.0.007_007_000_U001.uda.fpsx Total 25 [25/0/0] blocks to write, writing... TIME : Write time : 00:00:02 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5530 XpressMusic Software Info: V ICPR72_10w29_tube1 24-05-11 RM-504 (c) Nokia IMEI: 358304032405106 Ape Version: V 40.0.003 Product code: 0577076 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:09 Connect phone on selected interface... |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
08-05-2012, 18:36 | #16341 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | registered to: saeedullah_khan Connect phone on selected interface... Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm614__08.70.image_mc1_059H1T5 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000008221759B714B9695ED942B4019D760 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354318049359415 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 4318049359415_CRT.rpl ===Flashing [CNT]=== Erase : Processing rm614__08.70.image_mc1_059H1T5 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm614__08.70.image_mc1_059H1T5 Total writen 259 blocks TIME : Write time : 00:00:02 CNT Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Flashing done! Total flash time : 00:00:04 Reboot phone now... Reading Phone Info.... Connected phone - C3-00 Software Info: V 04.45 04-08-10 RM-614 (c) Nokia IMEI: 354318049359415 PPM version : V 04.45 04-08-10 RM-614 (c) Nokia MC1 Product code: 0594149 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:00:51 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 00000000008221759B714B9695ED942B4019D760 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 ADL: Reading certificates... Reading NPC certificate... IMEI : 354318049359415 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! ADL: Reading certificates done! ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 4318049359415.rpl All done, Disconnecting Elapsed: 00:00:13 Connect phone on selected interface... |
08-05-2012, 18:50 | #16342 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 202 registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom Looks like ASIC not supported, or HW failure Supported : RapuYama, RAP3Gv4, BroadComm, RAPIDO Core : v1.48 , FlashEngine : v1.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm834__20.28.image_m_c_059M694 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.47_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352853057100923 IMEI 2 : 352853057100931 PCcode : 059M692 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 2853057100923_352853057100931_XG213_CRT.rpl ===Flashing [CNT]=== File : rm834__20.28.image_m_c_059M694 Image : package_m_c_059M694.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:59 Write , Start : 0x424C0000 , Len : 0x00C00000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:01:22 Reboot phone now... Reading Phone Info.... Connected phone - 202 Software Info: V 20.28 22-03-12 RM-834 (c) Nokia IMEI: 352853057100923 PPM version : V 20.28 22-03-12 RM-834 (c) Nokia M_A Product code: 059M692 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:02:05 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd : Custom 2nd boot Ok, 01 2nd ready, AA Sending Algo ALG : Custom Algo sent Ok BL : Quantum_Bootloader_10.47_M1S1 Boot done! Reading CCC Reading HWC Reading NPC IMEI 1 : 352853057100923 IMEI 2 : 352853057100931 PCcode : 059M692 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.48\Backup\Cert\35 2853057100923_352853057100931_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
08-06-2012, 07:08 | #16344 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | card found: S/N 252D:0118 registered to: amc_khan Connect phone on selected interface... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... |
08-06-2012, 07:09 | #16345 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | -> Error while flashing... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b CNT : E24393CE_rm495__07.97.image_mena_a1_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing C5F02102_rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:46 Write : Processing C5F02102_rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:00:56 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.90.ppm_mena_b Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Erase : ERR1 : connection lost or data missmatch EraseFile: Error: Erasure error, Area: 1 TIME : Erase time : 00:00:31 Connect phone on selected interface... -> Error while flashing... |
08-06-2012, 07:09 | #16346 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... |
08-06-2012, 07:09 | #16347 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Verify Error Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- -> Phone not found.. -> Error while flashing... |
08-06-2012, 07:10 | #16348 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... |
08-06-2012, 07:10 | #16349 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 1240021393767D56C22643B7F2EB5EFB5BE3F963 CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... -> Error while send data to phone! Check battery, connection. Try again Connect phone on selected interface... -> Error while flashing... ,,,,,,, |
08-06-2012, 07:10 | #16350 (permalink) |
Member: 638447 Status: Offline Sonork: 100.1609504 Thanks Meter: 186 | Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Verify Error Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... Core : v1.47 , FlashEngine : v1.5 Selected FlashSettings : SafeFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : C5F02102_rm495__07.97.mcusw PPM : rm495__07.90.ppm_mena_b Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. BootRom : Verify Error Try again... -> Error answer from BootRom -> 1. Try make battery charge -> 2. Try insert charger, without pressing poweron -> 3. Try change USB port, if driver hang - restart PC Connect phone on selected interface... -> Error while flashing... |
