Old 09-12-2012, 13:16   #17071 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,226
X2-00 Flash.
Selected FlashSettings : Manual
FlashFile verify disabled
Files Set for Flashing :
MCU : rm618__08.35.mcusw
PPM : rm618__08.35.ppm_c
CNT : rm618__08.35.image_c_059F9L3
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
--- Insert cable and charger or press phone's power button! ---
Connection opened successfully
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID:       000000000000000022000509200C0000
CPU ID :       BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID:        00005361
PUBLIC ID:     00000000001B79844176E2D26E22803844BD535D
ASIC MODE ID:  00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID:        DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg  ,  Rev : 2.1  Ver : 12.8.0
Processing RAWLOADER...
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg  ,  Rev : 2.1  Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done! :)
TIME : Boot time : 00:00:01
Reopening the connection...
Waiting for response: 30
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : E9700989029D9E899915F781B1582048E042A738
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 359037044509270
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : D:\Infinitybox\BEST\Backup\Cert\359037044509270_CRT_2nd.rpl
   ===Flashing [MCU]===
Erase : Processing rm618__08.35.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm618__08.35.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [ISA+DYNSW]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [UPDAPP]
Total writen 511 blocks
TIME : Write time : 00:00:05
MCU Write done
ADL: Request programm status
NAND status : 00000002 / 00000002 / 00000000
   ===Flashing [PPM]===
Erase : Processing rm618__08.35.ppm_c
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm618__08.35.ppm_c
Total writen 114 blocks
TIME : Write time : 00:00:01
PPM Write done
   ===Flashing [CNT]===
Erase : Processing rm618__08.35.image_c_059F9L3
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm618__08.35.image_c_059F9L3
Total writen 339 blocks
TIME : Write time : 00:00:03
CNT Write done
ADL: Close_Session
Content: 000300000000020000000200000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:12
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia X2-00
Software Info:     V 08.35 09-01-12 RM-618 (c) Nokia
IMEI:  359037044509270
PPM version :   V 08.35 09-01-12 RM-618 (c) Nokia             C
Product code:  059F9L3
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Resetting LifeTimer
Reset Done!
Checking User Certificates...
Total - 39 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Elapsed: 00:01:49
Connect phone on selected interface...
Phone found!
Series 40 Device detected!
read info...  - Ok
Software ver : V 08.35 09-01-12 RM-618 (c) Nokia
PPM     :      V 08.35 09-01-12 RM-618 (c) Nokia             C
CNT     :      Content: c_059F9L3 V 08.35 09-01-12 RM-618 (c) Nokia
Product SN   :     45569CAAH
Product code :     059F9L3
Base Prd.code:     0591975
Module code  :     0204519
Long Prod.SN :     0
Hardware info=======
HWID  : 1004
Batery: 3700 mV
CMT BT: 2.31-SP2.31
LCDVer: SEIKO
Lock info ===========
IMEI spNet : 3A 95 30 07 44 05 29 07
IMEI svNet : 33 95 30 07 44 05 29 47 F1
Conf key     : 0000000000000000
Provider key : 2440700000000000
Country      : Finland
Operator     : NOKIA (Open)
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
CRT308 Backup Created
SDD key status : Ok
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SL3 phone ,  SP_CODE_LEN : 15
User Code : 12345
MMC pwd  : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Phone disconected!
The Following User Says Thank You to mbiborna For This Useful Post:
Old 09-12-2012, 13:16   #17072 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,226
Sorry dabble post remove.
Old 09-12-2012, 15:28   #17073 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
registered to: nadoui
Phone found!
Series 60 Device detected!
read info... - Ok
Connected phone - Nokia 5230
Software ver : V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia
IMEI : 353791040725076
Ape Ver : V 20.0.005
APE Var : V 20.0.005V 20.0.005 20.0.005.462.01
APE ADSP: 256
DSP Ver : simon_ICPR72_10w05
APE Test: rm588_ENO_x_09wk43v0.050
PPM :
CNT : 20.0.005_001_U462
Product SN : 022C243AA
Product code : 059C0S1
Base Prd.code: 0584528
Module code : 0204359
Long Prod.SN : 0
HWID : 0512
Retu : 16
Tahvo : 22
Batery: 3965 mV
APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
APE HW: 256
IMEI spNet : 3A 35 97 01 04 27 05 07
IMEI svNet : 33 35 97 01 04 27 05 17 F1
Provider key : 2080100000000000
Country : France
Operator : Orange F
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
SDD key status : Ok
SimLock status : Ok
User code : Crypted
UserDataExLevel : Low [Gallery] , FullFlash method
Done!
Using F-bus count...
Sending code 424386095811862 Level : 7 to SimLock Server...
Simlock Server Answer: Unlock code Accepted!
Done!
Phone disconected!
The Following User Says Thank You to Nadoui For This Useful Post:
Old 09-12-2012, 15:36   #17074 (permalink)
Nadoui's Avatar
Member: 1202782
Sonork: 100.1608261
Thanks Meter: 634
Phone found!
read info... - Ok
APE ADSP: 256
PPM :
Long Prod.SN : 0
HWID : 0512
Retu : 16
Tahvo : 22
Batery: 3965 mV
APE HW: 256
Country : France
Operator : Orange F
Blocks : 2
LOCK STATUS :
BLK : 1
Lock1:Close
BLK : 2
Lock1:Close
LOCKS : Closed
SDD key status : Ok
SimLock status : Ok
User code : Crypted
Done!
Done!
Phone disconected!
Old 09-13-2012, 05:05   #17075 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
card found: S/N C0B4:0118
registered to: Akramjon
Phone found!
read info... - Ok
Backup Certificates now...
Backup CRT308 data...
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
Check communication with phone....
Reboot....
EM0 ID: 00005361
PUBLIC ID: 2707C885106B45B41658F1BB3FE22EC2D49BEFAE
ASIC MODE ID: 00
FLIC : 003000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 84CDC75F79F52BBAE46EA3A70C9240861412C480
ADL: Reading certificates...
IMEI : 353769040792403
Cert Read done!
ADL: Reading certificates done!
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
Swap data collected to 0589851.pc
RPL saved : c:\InfinityBox\BEST\Backup\Cert\353769040792403.rp l
All done, Disconnecting
Elapsed: 00:00:10
Core : v1.47 , FlashEngine : v1.5
Check FlashFiles, Please, wait...
MCU : rm586__09.69.mcusw
PPM : rm586__09.69.ppm_i
CNT : rm586__09.69.image_i_bg_black
Check files done...
EM0 ID: 00005361
ASIC MODE ID: 00
FLIC : 003000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\353769040792403_CR T.rpl
Erase : Processing rm586__09.69.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm586__09.69.mcusw
Total writen 466 blocks
TIME : Write time : 00:00:04
MCU Write done
NAND status : 00000000 / 00000000 / 00000000
Erase : Processing rm586__09.69.ppm_i
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm586__09.69.ppm_i
Total writen 91 blocks
TIME : Write time : 00:00:00
PPM Write done
Erase : Processing rm586__09.69.image_i_bg_black
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm586__09.69.image_i_bg_black
Total writen 202 blocks
TIME : Write time : 00:00:02
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:09
Reboot phone now...
Connected phone - Nokia 2710c-2
Software Info: V 09.69 22-03-11 RM-586 (c) Nokia
IMEI: 353769040792403
PPM version : V 09.69 22-03-11 RM-586 (c) Nokia I
Product code: 0589841
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 34 certs
Done!
Elapsed: 00:00:41
Phone found!
read info... - Ok
Phone disconected!
The Following User Says Thank You to Namangan For This Useful Post:
Old 09-13-2012, 09:10   #17076 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 539
MOTOROLA WX390 UNLOCKED
module v4.38
Device: Motorola-WX390
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A203:A001
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.21D45FE7 .[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D9BDC36B].rpl
New firmware found (v.4.38, database date: 26.08.2012):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 21D45FE7
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 6BC3BDD9
code offset: 00020000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 27G
provider: M390X-2BALZA1
customization: CJ27SK7A
customization: XJ27SK7A
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->00006F54
error: can not recalculate address range, allowed offset is too small: 00006F54
error: can't calculate security area (sec info, hash)
identification header detected
customization: XJ27SI71
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
max address is too big, should be recalculated: 08BF8000->08BF4004
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX390_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_21D45FE7_D9BDC36B_20120913-104518.B0X.bin
Finished, time used: 5 min 18 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-13-2012, 11:32   #17077 (permalink)
Member: 530721
Thanks Meter: 157
Thanks to Infinity
Old 09-13-2012, 12:24   #17078 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Phone found!
read info... - Ok
SL2 Simlock read ... ok
WMDRM read ... ok
ADL not support backup mode, rpl reading impossible
RPL saved : c:\InfinityBox\BEST\Backup\Cert\354863023222360_SI M.rpl
Elapsed: 00:00:01
Phone found!
read info... - Ok
MCU : RM-247_30.101_prd.core.fpsx
PPM : RM-247_30.101_002.1_prd.language.fpsx
PPM2 : RM-247_30.101_098.1_prd.customer.fpsx
CNT : RM-247_30.101_100.1_prd.uda.fpsx
Check files done...
-> SWversion check skipped : Manual mode selected
WMDRM read ... ok
RPL saved : c:\InfinityBox\BEST\Backup\Cert\354863023222360_SI M_2nd.rpl
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Batery valtage : 3743 mV
-> Batery voltage less, than 3,8V (3743mV). Continue at user risk
Reboot....
Req APE info
ASIC ID: 008815D3
ASIC MODE ID: 00
PUBLIC ID: 5FA2E038DB39674A96E7631F98FC09716B071B24
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
Send APE loader...
Use STn8815_2nd.fg , Rev : 2.0 Ver : 10.50.0
APE loader sent
APE FLID : B1002000 , NAND , APE
Send APE algo...
Use STn8815_STNFMS_alg.fg , Rev : 2.0 Ver : 10.50.0
APE algo sent
Initialize UpdateServer...
UpdateServer initialized
Processing Slave part
Req CMT info
ASIC ID: 000000010000022600010006400C192101031103
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0300010E24700052D65C05745E6B30BEE333E81D
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Send CMT loader...
Use RAPIDOv11_2nd.fg , Rev : 2.0 Ver : 10.50.0
CMT loader sent
CMT FLID : 2C7E0001 , NOR , CMT
Send CMT algo...
Use RAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 10.50.0
CMT algo sent
ADL : CMT select : already on adl
ADL : CMT PapubKeys req Ok
ADL : CMT CRT check Ok
ADL : APE PapubKeys req Ok
ADL : APE CRT check Ok
Flash prepare done
TIME : Boot time : 00:00:07
ADL : phone is in flash mode
Erase : Processing RM-247_30.101_prd.core.fpsx
Partitioning....
Partitioning APE Ok...
Erasing....
Erasing CMT Ok...
Erasing APE Ok...
TIME : Erase time : 00:00:45
Write : Processing RM-247_30.101_prd.core.fpsx
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [DSP0]
APE: Writing Hash CERT [X-LOADER]
APE: Writing Hash CERT [KEYS]
APE: Writing Hash CERT [PRIMAAPP]
APE: Writing Hash CERT [SOS*UPDAPP]
APE: Writing Hash CERT [SOS+XZIP]
APE: Writing Hash CERT [PASUBTOC]
APE: Writing Hash CERT [PAPUBKEYS]
APE: Writing Hash CERT [SOS+CORE]
APE: Writing Hash CERT [SOS+ROFS1]
Total writen 3317 blocks
TIME : Write time : 00:02:05
MCU Write done
Erase : Processing RM-247_30.101_002.1_prd.language.fpsx
Erasing....
Erasing APE Ok...
Write : Processing RM-247_30.101_002.1_prd.language.fpsx
APE: Writing Hash CERT [SOS+ROFS2]
Total writen 603 blocks
TIME : Write time : 00:00:07
PPM Write done
===Flashing [PPM2]===
Erase : Processing RM-247_30.101_098.1_prd.customer.fpsx
Erasing....
Erasing APE Ok...
Write : Processing RM-247_30.101_098.1_prd.customer.fpsx
APE: Writing Hash CERT [SOS+ROFS3]
Total writen 2 blocks
PPM Write done
Erase : Processing RM-247_30.101_100.1_prd.uda.fpsx
Erasing....
Erasing APE Ok...
Write : Processing RM-247_30.101_100.1_prd.uda.fpsx
Total writen 411 blocks
CNT Write done
ADL : Close CMT session
ADL : Close APE session
Content : 0000000000000000008E955F
ADL : Reboot
Flashing done!
Total flash time : 00:03:05
Reboot phone now...
Connected phone - Nokia N96-1
Software Info: V ICPR72_09w13.3 15-09-09 RM-247 (c) Nokia
IMEI: 354863023222360
Ape Version: 30.101
Product code: 0567372
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:04:11
Phone found!
read info... - Ok
Old 09-13-2012, 12:25   #17079 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
MCU : rm470__13.10.mcusw
PPM : rm470__13.10.ppm_i
CNT : rm470__13.10_ISM_018.image_i_bg_black
Check files done...
ASIC ID: 000000030000022600010007600C192102011104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000C34
EM1 ID: 00000C30
PUBLIC ID: 11000210267B0E49C37E951059120FBE8C7ADF7E
ASIC MODE ID: 00
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0
FLIC : 00400098
Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6
IMEI : 355364044285535
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\355364044285535_CR T.rpl
Erase : Processing rm470__13.10.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm470__13.10.mcusw
CMT: Writing Hash CERT [LDSP]
Total writen 218 blocks
TIME : Write time : 00:00:06
MCU Write done
Erase : Processing rm470__13.10.ppm_i
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm470__13.10.ppm_i
Total writen 52 blocks
PPM Write done
Erase : Processing rm470__13.10_ISM_018.image_i_bg_black
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:07
Write : Processing rm470__13.10_ISM_018.image_i_bg_black
Total writen 205 blocks
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:21
Reboot phone now...
Connected phone - Nokia 6700 classic
Software Info: V 13.10 16-06-10 RM-470 (c) Nokia
IMEI: 355364044285535
PPM version : V 13.10 16-06-10 RM-470 (c) Nokia I
Product code: 0571191
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 34 certs
Done!
Elapsed: 00:02:14
Phone found!
read info... - Ok
Phone disconected!
Old 09-13-2012, 12:29   #17080 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Phone found!
read info... - Ok
WMDRM read ... ok
Reboot....
ASIC ID: 000000030000022600010007600C192102031104
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 20100104A2DE0344D2C6C65C8FC8EE42C7E8A5E7
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
FLIC : 00500020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8
IMEI : 351685056027173
Cert Read done!
ADL: Close_Session
Content: 0003000000000C0000000C00000000
ADL: Reboot
Swap data collected to 059K4H0.pc
RPL saved : D:\InfinityBox\BEST\Backup\Cert\351685056027173.rp l
Elapsed: 00:00:22
Phone found!
read info... - Ok
Core : v1.50 , FlashEngine : v1.7
MCU : rm745_081.003_prd.core.fpsx
PPM : rm745_081.003_05.01_Russian_prd.rofs2.fpsx
PPM2 : rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx
CNT : rm745_081.003_U001.000_prd.uda.fpsx
APE : rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
Check files done...
WMDRM read ... ok
ADL req restart
Batery valtage : 3700 mV
-> Batery voltage less, than 3,8V (3700mV). Continue at user risk
Reboot....
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00500020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
RPL saved : D:\InfinityBox\BEST\Backup\Cert\351685056027173_2n d.rpl
Erase : Processing rm745_081.003_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:03
Write : Processing rm745_081.003_prd.core.fpsx
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 415 blocks
TIME : Write time : 00:00:14
MCU Write done
NAND status : 0000000C / 0000000C / 00000000
Erase : Processing rm745_081.003_05.01_Russian_prd.rofs2.fpsx
Erasing....
Erasing Ok...
Write : Processing rm745_081.003_05.01_Russian_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 200 blocks
PPM Write done
Erase : Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
PPM Write done
Erase : Processing rm745_081.003_U001.000_prd.uda.fpsx
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:04
Write : Processing rm745_081.003_U001.000_prd.uda.fpsx
Total writen 37 blocks
CNT Write done
===Flashing [APE]===
Erase : Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
Erasing....
Erasing Ok...
Write : Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx
CMT: Writing Hash CERT [SOS*ENO]
Total writen 10 blocks
APE Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:34
Reboot phone now...
Connected phone - Nokia C5-00
Software Info: V ICPR82_11w16.3.6 03-10-11 RM-745 (c) Nokia
IMEI: 351685056027173
Ape Version: 081.003
Product code: 059K4H0
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:00:54
Phone found!
read info... - Ok
Phone disconected!
Old 09-13-2012, 12:32   #17081 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
C7 done
MCU : RM-675_111.040.1511_79u_prd.core.fpsx
PPM : RM-675_111.040.1511_04.01_Russian_79u_prd.rofs2.fpsx
PPM2 : RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx
CNT : RM-675_111.040.1511_U01.01_79u.uda.fpsx
APE : rm675_ENO_v_0.0514_APEONLY.fpsx
Check files done...
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 0F800203A35A5440110D5A6829148EFD88D59718
ASIC MODE ID: 00
FLIC : 006800EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
IMEI : 355960043986005
Cert Read done!
RPL saved : D:\InfinityBox\BEST\Backup\Cert\355960043986005_CR T_2nd.rpl
Erase : Processing RM-675_111.040.1511_79u_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:02
Write : Processing RM-675_111.040.1511_79u_prd.core.fpsx
CMT: Writing Hash CERT [SOS+DECOMP]
CMT: Writing Hash CERT [SOS+IVE3A]
Total writen 519 blocks
MCU Write done
NAND status : 00000003 / 00000003 / 00000000
Erase : Processing RM-675_111.040.1511_04.01_Russian_79u_prd.rofs2.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-675_111.040.1511_04.01_Russian_79u_prd.rofs2.fpsx
Total writen 227 blocks
PPM Write done
Erase : Processing RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-675_111.040.1511_C00.01_79u_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+IVE3B]
Total writen 4 blocks
PPM Write done
Erase : Processing RM-675_111.040.1511_U01.01_79u.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-675_111.040.1511_U01.01_79u.uda.fpsx
Total writen 867 blocks
TIME : Write time : 00:00:28
CNT Write done
Erase : Processing rm675_ENO_v_0.0514_APEONLY.fpsx
Erasing....
Erasing Ok...
Write : Processing rm675_ENO_v_0.0514_APEONLY.fpsx
Total writen 20 blocks
APE Write done
ADL: Close_Session
Content: 000300000000030000000300000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:55
Reboot phone now...
Connected phone - Nokia C7-00
Software Info: V 79_sr1_12w18.5 27-07-12 RM-675 (c) Nokia
IMEI: 355960043986005
Ape Version: 111.040.1511
Product code: 059D7K9
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:01:31
Phone found!
read info... - Ok
Old 09-13-2012, 13:16   #17082 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Phone found!
read info... - Ok
WMDRM read ... ok
Reboot....
EM0 ID: 00000C34
EM1 ID: 00000C30
PUBLIC ID: 1FF00107BA630E4917A7D50A77A0CDFE8B8033CB
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
IMEI : 352696040598053
Cert Read done!
ADL: Close_Session
Content: 000300000000010000000100000000
ADL: Reboot
Swap data collected to 0570920.pc
RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696040598053.rp l
Elapsed: 00:00:12
Check files done...
BootRom : Verify Error
Try again...
-> Error answer from BootRom
-> Boot fail...
Flashing failed...
Check files done...
EM0 ID: 00000C34
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400098
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\352696040598053_CR T.rpl
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
NAND status : 00000001 / 00000001 / 00000000
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
PPM Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:05
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:19
Reboot phone now...
IMEI: 352696040598053
Product code: 0570920
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 34 certs
Done!
Elapsed: 00:01:56
Phone found!
read info... - Ok
Phone disconected!
Old 09-13-2012, 14:04   #17083 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
C5-03 flashing Done with infinity best tool....
Core : v1.51 , FlashEngine : v1.8
Selected FlashSettings : FullFlash
MCU : RM-697_22.0.007_prd.core.C00
PPM : RM-697_22.0.007_prd.rofs2.V20
PPM2 : RM-697_22.0.007_C01_prd.rofs3.fpsx
CNT : RM697_719_014_U001.uda.fpsx
Check files done...
EM0 ID: 00001040
EM1 ID: 00001060
PUBLIC ID: 2B100117AEDC03449A406CD7AC7B571FDEB1F037
ASIC MODE ID: 00
FLIC : 004000EC
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:04
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 78E50A8766EC9CD99D190EEA9676987905B09588
IMEI : 359331047147760
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\359331047147760_CR T.rpl
Erase : Processing RM-697_22.0.007_prd.core.C00
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing RM-697_22.0.007_prd.core.C00
Total writen 443 blocks
TIME : Write time : 00:00:21
MCU Write done
Erase : Processing RM-697_22.0.007_prd.rofs2.V20
Erasing....
Erasing Ok...
Write : Processing RM-697_22.0.007_prd.rofs2.V20
Total writen 77 blocks
PPM Write done
Erase : Processing RM-697_22.0.007_C01_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing RM-697_22.0.007_C01_prd.rofs3.fpsx
Total writen 6 blocks
PPM Write done
Erase : Processing RM697_719_014_U001.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing RM697_719_014_U001.uda.fpsx
Total writen 24 blocks
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:29
Reboot phone now...
Connected phone - Nokia C5-03
Software Info: V ICPR82_11w25.7 05-12-11 RM-697 (c) Nokia
IMEI: 359331047147760
Ape Version: V 22.0.007
Product code: 059C507
Checking...
Read Info Done!
SwUpgradeSet...OK!
Product code update...
Set phone to Normal mode...
Done!
Elapsed: 00:01:12
GSM007
Old 09-13-2012, 16:44   #17084 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 539
MOTOROLA WX181 UNLOCKED
module v4.38
Device: Motorola-WX181
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:4158:A00C
status: 01
Boot Done
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: [standard] type (05)
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
version: 564
provider: M181X-CARGAP5
customization: CM56DD10
customization: XM56DD10
TCL-ID is present
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 0827D124->0826B790
done
original imei: 0000197025E3C6
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20120913-180452.B0X.bin
Finished, time used: 2 min 27 sec
Old 09-13-2012, 18:18   #17085 (permalink)
Azhar Nazeer's Avatar
Member: 862582
Sonork: 100.1604840
Thanks Meter: 71
Nokia X1-01 Flash
card found: S/N +++++++++-
registered to: ----------
UFS S/N --------- boot - Ok
Phone found!
read info...  - Ok
Core : v1.42 , FlashEngine : v1.25
MCU : rm713_007.500
PPM : rm713_007.50mh
CNT : rm7130_nai07.50mh_nlt
Infineon flashing...
-> Infineon XG110 : IMEI Backup Created
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
PBL : Dynamic
Boot Ok , 01AB
SBL : Dynamic
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 00EC000000042400
FLASH ID : UNKNOW [Not In Base]
Boot Done!
File : rm713_007.500
Image : hw_b1_rm713_r07.500.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00000000 , Len : 0x00020000
Erasing, wait ...
Erase done
Write , Start : 0x00000000 , Len : 0x00006000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00800000 , Len : 0x00400000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x003F0000
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00C5D000 , Len : 0x00203000
Erasing, wait ...
Erase done
Write , Start : 0x00C5D000 , Len : 0x0019E700
Flashing , wait ...
Region flash done
Check : 423E
File : rm713_007.50mh
Image : hw_b1_rm713_007.50mh.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00100000 , Len : 0x00700000
Erasing, wait ...
Erase done
Write , Start : 0x00100000 , Len : 0x0051CC00
Flashing , wait ...
Region flash done
Check : FACF
File : rm7130_nai07.50mh_nlt
Image : hw_b1_rm7130_nai07.50mh_nlt.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00E60000 , Len : 0x00100000
Erasing, wait ...
Erase done
Write , Start : 0x00E60000 , Len : 0x000FEE00
Flashing , wait ...
Region flash done
Check : 3106
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver : V 07.50
29-11-11
RM-713
(c) Nokia
IMEI   : 35-----------------
PCode  : 059G444
FullFactorySet...OK!
SwUpgradeSet...OK!
All done!
Phone found!
read info...  - Ok
Phone disconected!
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 10.96871 seconds with 10 queries
