Old 10-04-2012, 09:06   #17266 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia C2 Flashing done
Core : v1.52 , FlashEngine : v1.8
Selected FlashSettings : FullFlash
FlashFile verify disabled
Files Set for Flashing :
MCU : rm704__03.82.mcusw
PPM : rm704__03.82.ppm_m_a
CNT : rm704__03.82.image_m_a_swhite_059C8K0
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.44_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 359029048751263
IMEI 2 : 359029048751271
PCcode : 059J4Z7
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\359029048751263_35 9029048751271_XG213_CRT.rpl
===Flashing [MCU]===
File : rm704__03.82.mcusw
Image : rm704__03.82.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:02:32
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:01:19
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm704__03.82.ppm_m_a
Image : package_m_a.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:19
Write , Start : 0x41BC0000 , Len : 0x003479DC
Flashing , wait ...
Region flash done, time : 00:00:05
===Flashing [CNT]===
File : rm704__03.82.image_m_a_swhite_059C8K0
Image : package_m_a_swhite_059C8K0.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:03:52
Write , Start : 0x421C0000 , Len : 0x00A00000
Flashing , wait ...
Region flash done, time : 00:00:26
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:06
No write data, skip
Flashing done!
Total flash time : 00:08:56
Reboot phone now...
Reading Phone Info....
Connected phone - C2-00
Software Info: V 03.82 17-10-11 RM-704 (c) Nokia
IMEI: 359029048751263
PPM version : V 03.82 17-10-11 RM-704 (c) Nokia M_A
Product code: 059J4Z7
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Product code update...
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
Set phone to Normal mode...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:09:59
GSM007
Old 10-04-2012, 09:21   #17267 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia X2-01 Flashing Done
MCU : rm709__08.65.mcusw
PPM : rm709__08.65.ppm_ma3
CNT : rm709__08.65_004.image_ma3_ctv_pk_9g521
Check files done...
-> SWversion check skipped : Manual mode selected
Backup CRT308 data...
CRT308 Backup Created
SLx Simlock Data read ... ok
SL3 Simlock Sign read ... ok
WMDRM read ... ok
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Reboot....
Waiting for communication response...
BootRom : 1st boot ok
ASIC ID: 000000000000000022000509200C0000
CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB
EM0 ID: 00005361
PUBLIC ID: 00000000003367AD6AF56A6A30565F82E16C0FA8
ASIC MODE ID: 00
ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
ROM ID: DE56D582BDDE7A3A
Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0
Processing RAWLOADER...
FLIC : 00300020
Req : XSR 1.6
Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0
Processing PASUBTOC ...
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:07
Reopening the connection...
Waiting for response: 30
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09
ADL: phone is in flash mode
Backup enabled, will read all certificates...
Reading NPC certificate...
IMEI : 358615048680121
Reading CCC certificate...
Reading HWC certificate...
Reading R&D certificate...
Reading VARIANT certificate...
Reading PARTNERC certificate...
Reading MDM_KEYS certificate...
Cert Read done!
SimLock Data saved...
SimLock Key saved...
WMDRM_PD Data saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\358615048680121.rp l
Erase : Processing rm709__08.65.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:00
Write : Processing rm709__08.65.mcusw
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [ADA]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [RAP3NAND]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [MCUSW1]
CMT: Writing Hash CERT [GENIO_INIT]
CMT: Writing Hash CERT [ISA+DYNSW]
Total writen 504 blocks
TIME : Write time : 00:00:17
MCU Write done
ADL: Request programm status
NAND status : 00000000 / 00000000 / 00000000
Erase : Processing rm709__08.65.ppm_ma3
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm709__08.65.ppm_ma3
Total writen 105 blocks
TIME : Write time : 00:00:01
PPM Write done
Erase : Processing rm709__08.65_004.image_ma3_ctv_pk_9g521
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
TIME : Erase time : 00:00:01
Write : Processing rm709__08.65_004.image_ma3_ctv_pk_9g521
Total writen 563 blocks
TIME : Write time : 00:00:12
CNT Write done
ADL: Close_Session
Content: 000300000000000000000000000000
ADL: Reboot
Flashing done!
Total flash time : 00:00:34
Reboot phone now...
Connected phone - X2-01
Software Info: V 08.65 12-05-11 RM-709 (c) Nokia
IMEI: 358615048680121
PPM version : V 08.65 12-05-11 RM-709 (c) Nokia MA3
Product code: 059G521
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:01:22
GSM007
Old 10-04-2012, 09:21   #17268 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Check files done...
WMDRM read ... ok
ADL req restart
Reboot....
EM0 ID: 00005361
ASIC MODE ID: 00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
PPM Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Reboot phone now...
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:01:22
GSM007
Old 10-04-2012, 09:44   #17269 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
card found: S/N C0B4:0118
registered to: Akramjon
Backup Certificates now...
--- Insert cable and charger or press phone's power button! ---
ASIC ID: 000000030000022600010007600C192102031104
CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB
EM0 ID: 00000C35
EM1 ID: 00000C30
PUBLIC ID: 15B0021043F4554036A067A6DD62A18BDA940F3B
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0
FLIC : 00400020
Req : XSR 1.6
Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:01
Waiting for response: 29
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
ADL: Reading certificates...
IMEI : 355970047730846
Cert Read done!
ADL: Reading certificates done!
ADL: Close_Session
ADL: Reboot
Wait, reconneting...
WMDRM read ... ok
Swap data collected to 059B9B1.pc
RPL saved : c:\InfinityBox\BEST\Backup\Cert\355970047730846.rp l
All done, Disconnecting
Elapsed: 00:00:23
Phone found!
Series 60 Device detected!
read info... - Ok
Core : v1.47 , FlashEngine : v1.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
MCU : rm645_071.005_prd.core.fpsx
PPM : rm645_071.005_05.01_Russian_prd.rofs2.fpsx
PPM2 : rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
CNT : rm645_071.005_U000.000_prd.uda.fpsx
APE : RM645_ENO_10wk48v0.001.fpsx
Check files done...
WMDRM read ... ok
ADL req restart
Batery valtage : 3638 mV
-> Batery voltage less, than 3,8V (3638mV). Continue at user risk
Reboot....
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
FLIC : 00400020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\355970047730846_2n d.rpl
Erase : Processing rm645_071.005_prd.core.fpsx
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm645_071.005_prd.core.fpsx
CMT: Writing Hash CERT [SOS+PMML]
CMT: Writing Hash CERT [SOS*UPDAPP]
CMT: Writing Hash CERT [SOS*DSP0]
CMT: Writing Hash CERT [LDSP]
CMT: Writing Hash CERT [SOS*ISASW]
CMT: Writing Hash CERT [SOS+CORE]
CMT: Writing Hash CERT [SOS+ROFS1]
Total writen 411 blocks
TIME : Write time : 00:00:15
MCU Write done
Erase : Processing rm645_071.005_05.01_Russian_prd.rofs2.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_071.005_05.01_Russian_prd.rofs2.fpsx
CMT: Writing Hash CERT [SOS+ROFS2]
Total writen 180 blocks
TIME : Write time : 00:00:06
PPM Write done
===Flashing [PPM2]===
Erase : Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx
CMT: Writing Hash CERT [SOS+ROFS3]
Total writen 2 blocks
TIME : Write time : 00:00:00
PPM Write done
Erase : Processing rm645_071.005_U000.000_prd.uda.fpsx
Erasing....
Erasing Ok...
Write : Processing rm645_071.005_U000.000_prd.uda.fpsx
Total writen 6 blocks
CNT Write done
===Flashing [APE]===
Erase : Processing RM645_ENO_10wk48v0.001.fpsx
Erasing....
Erasing Ok...
Write : Processing RM645_ENO_10wk48v0.001.fpsx
CMT: Writing Hash CERT [SOS*ENO]
Total writen 10 blocks
APE Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:24
Reboot phone now...
Connected phone - Nokia C5-00
Software Info: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
IMEI: 355970047730846
Ape Version: 071.005
Product code: 059B9B1
Checking...
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:00:41
Phone found!
read info... - Ok
Old 10-05-2012, 15:02   #17270 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia 1280 user lock Done
registered to: GSM007
UFS S/N 73225 boot - Ok
Phone found!
Series 40 Device detected!
read info... - Ok
SW ver : V 06.20 01-12-10 RM-647 (c) Nokia
IMEI : 357908040207550
PPM : V 06.20
01-12-10
RM-647
(c) Nokia
IA
PCode : 0592303
BPCode : 059F8R3
HWID : 1003
LCDVer : INLX:SERIv91
NT7542
Sl Conf : 001-01-00000000000
Sl Prof : 000000000003000-2
Sl Aux : 000B0000
Hw Sig : C81A958B1A006A87
Country : Test SIM (Open)
Operator : NOKIA (Open)
Lock info:
Block 1
L1:Open; L2:Open; L3:Open; L4:Open; L5:Open;
Block 2
Block 3
Block 4
Block 5
Block 6
Block 7
Done!
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Elapsed: 00:00:10
GSM007
Old 10-06-2012, 11:55   #17271 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
ZTE-S165 unlocked successfully
COM150 [QCUSB_COM150_1] selected
module v1.89
Device: ZTE-S165, C121
operation: SP-unlock
Phone should be Switched ON !
connecting...
Mar 02 2012
Mar 02 2012
ZTE S165 Mar 02 2012 selected..
ESN(hex) : 80C21A7F
Password accepted..
downloading mode...
waiting respon...
waiting chip ready...
unlocking in progress..
unlocking in progress 50%..
unlocking in progress 100%...
done...
Finished, time used: 16 sec
Device: ZTE-C321
Old 10-06-2012, 14:16   #17272 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia Asha 200 Flashing Done
MCU : rm761__11.81.mcusw
PPM : rm761__11.81.ppm_ma3
CNT : rm761__11.81.image_ma3_059J4L0
Check files done...
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.46_M1S1
FLASHID : 89008289
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 352415055326601
IMEI 2 : 352415055326619
PCcode : 059K925
RPL saved : c:\InfinityBox\BEST\Backup\Cert\352415055326601_35 2415055326619_2nd_XG213_CRT.rpl
File : rm761__11.81.mcusw
Image : rm761__11.81.mcusw_ebl_psi.fls
Cert sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:03
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:01:00
Erasing, wait ...
No write data, skip
File : rm761__11.81.ppm_ma3
Image : package_ma3.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00740000
Erasing, wait ...
Erase done, time : 00:00:16
Write , Start : 0x41A80000 , Len : 0x005105C8
Flashing , wait ...
Region flash done, time : 00:00:09
File : rm761__11.81.image_ma3_059J4L0
Image : package_ma3_059J4L0.image.fls
Cert sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:02:29
Write , Start : 0x421C0000 , Len : 0x00F80000
Flashing , wait ...
Region flash done, time : 00:00:46
Erasing, wait ...
Erase done, time : 00:00:05
No write data, skip
Flashing done!
Total flash time : 00:04:57
Reboot phone now...
Connected phone - Nokia 200
Software Info: V 11.81 20-08-12 RM-761 (c) Nokia
IMEI: 352415055326601
PPM version : V 11.81 20-08-12 RM-761 (c) Nokia MA3
Product code: 059K925
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 43 certs
Done!
Elapsed: 00:06:06
GSM007
Old 10-07-2012, 10:11   #17273 (permalink)
Member: 1649355
Sonork: MEHTABAIG
Thanks Meter: 2
help pls ssssssssssssssssssssssssssssssssssssssssssssss
Old 10-08-2012, 08:15   #17274 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 931
SAMSUNG S239 PHONELOCK SUCESS
Old 10-09-2012, 07:32   #17275 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia C3 flashing Doneregistered to: GSM007
Phone found!
read info... - Ok
Connected phone - C3-00
Software ver : V 07.20 29-10-10 RM-614 (c) Nokia
IMEI : 356247041368710
PPM : V 07.20 29-10-10 RM-614 (c) Nokia MA1
CNT : Content: ma1_0594111 V 07.20 29-10-10 RM-614 (c) Nokia
Product SN : 5A32AB4AI
Product code : 0594111
Base Prd.code: 0587486
Module code : 0204418
Long Prod.SN : 0
Hardware info=======
HWID : 2008
Batery: 3795 mV
CMT BT: 4217-v529
LCDVer: SEIKO
Lock info ===========
IMEI spNet : 3A 65 42 07 14 63 78 01
IMEI svNet : 33 65 42 07 14 63 78 21 F3
Conf key : 0000000000000000
Provider key : 2440700000000000
Country : Finland
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
SDD key status : Ok
CMLA Key status : Ok
SimLock status : Ok
Security status : Ok
PA_SL3 phone , SP_CODE_LEN : 15
User Code : 99699
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
MCU : rm614__08.71.mcusw
PPM : rm614__08.71.ppm_t
CNT : rm614__08.71.image_t_0594339
Check files done...
WMDRM read ... ok
ADL req restart
Reboot....
EM0 ID: 00005361
PUBLIC ID: 0000000000B25FFF9E4A1F7E54ACB6307D3F6BE6
ASIC MODE ID: 00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
TIME : Boot time : 00:00:02
ADL: Check mode
Select ASIC [C900]
PAPUBkeys : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Cert Read done!
RPL saved : c:\InfinityBox\BEST\Backup\Cert\356247041368710.rp l
Erase : Processing rm614__08.71.mcusw
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm614__08.71.mcusw
Total writen 528 blocks
TIME : Write time : 00:00:18
MCU Write done
Erase : Processing rm614__08.71.ppm_t
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm614__08.71.ppm_t
Total writen 116 blocks
PPM Write done
Erase : Processing rm614__08.71.image_t_0594339
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
Write : Processing rm614__08.71.image_t_0594339
Total writen 243 blocks
TIME : Write time : 00:00:03
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Total flash time : 00:00:25
Reboot phone now...
Software Info: V 08.71 15-11-11 RM-614 (c) Nokia
IMEI: 356247041368710
PPM version : V 08.71 15-11-11 RM-614 (c) Nokia T
Product code: 0594111
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:00:55
GSM007
Old 10-09-2012, 07:56   #17276 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Phone found!
read info... - Ok
Long Prod.SN : 0
HWID : 2008
Batery: 3795 mV
CMT BT: 4217-v529
LCDVer: SEIKO
Country : Finland
Blocks : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
SDD key status : Ok
SimLock status : Ok
User Code : 99699
Done!
Check files done...
WMDRM read ... ok
ADL req restart
Reboot....
EM0 ID: 00005361
ASIC MODE ID: 00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
PPM Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Reboot phone now...
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:00:55
GSM007
Old 10-09-2012, 07:56   #17277 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Phone found!
read info... - Ok
Long Prod.SN : 0
HWID : 2008
Batery: 3795 mV
CMT BT: 4217-v529
LCDVer: SEIKO
Country : Finland
Blocks : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
SDD key status : Ok
SimLock status : Ok
User Code : 99699
Done!
Check files done...
WMDRM read ... ok
ADL req restart
Reboot....
EM0 ID: 00005361
ASIC MODE ID: 00
FLIC : 00300020
Req : XSR 1.6
Processing ALG ...
Boot Done!
ADL: Check mode
Select ASIC [C900]
Cert Read done!
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
MCU Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
PPM Write done
Partitioning....
Partitioning Ok...
Erasing....
Erasing Ok...
CNT Write done
ADL: Close_Session
ADL: Reboot
Flashing done!
Reboot phone now...
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:00:55
GSM007
Old 10-09-2012, 08:11   #17278 (permalink)
Member: 144708
Sonork: 100.1615125
Thanks Meter: 387
Nokia C1 Flashing Done
MCU : rm607__04.40.mcusw
PPM : rm607__04[1].40.ppm_m_c
CNT : rm607__04.40.image_mh_0595598
Check files done...
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_2.3_M1S1
FLASHID : 89008289
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI : 357401043491488
PCcode : 059G896
RPL saved : c:\InfinityBox\BEST\Backup\Cert\357401043491488_XG 213_CRT.rpl
File : rm607__04.40.mcusw
Image : rm607__04.40.mcusw_ebl_psi.fls
Cert sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:01:56
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:59
File : rm607__04[1].40.ppm_m_c
Image : package_m_c.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:14
Write , Start : 0x41C00000 , Len : 0x0031A50C
Flashing , wait ...
Region flash done, time : 00:00:06
File : rm607__04.40.image_mh_0595598
Image : package_mh_0595598.image.fls
Cert sent
Found 2 region(s)
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:02:39
Write , Start : 0x42200000 , Len : 0x00C20000
Flashing , wait ...
Region flash done, time : 00:00:25
Erasing, wait ...
Erase done, time : 00:00:04
No write data, skip
Flashing done!
Total flash time : 00:06:38
Reboot phone now...
Connected phone - C1-01
Software Info: V 04.40 23-02-11 RM-607 (c) Nokia
IMEI: 357401043491488
PPM version : V 04.40 23-02-11 RM-607 (c) Nokia M_C
Product code: 059G896
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Done!
Elapsed: 00:07:35
GSM007
Old 10-09-2012, 08:51   #17279 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 824
 COM13 [VCP0] selected
module  v1.38
Device: Sony-Ericsson-J120i
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
loading...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 89886200010001:89886200000000
flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb
software version: 032H-000
software version: MLD-5-
Check hardware done
Read data ...
reading Sony-Ericsson-J120i_eeprom_calibration-1...
file saved: E:\InfinityBox\HModule\Sony-Ericsson-J120i_eeprom_calibration-1_20121009-111854.6AE.bin
Read data done
Check data ...
error: not locked or unknown eeprom
Check data done
Write ...
.........data prepared Ok
Write: eeprom
Write done
Finished, time used: 24 sec
Remove/Install battery now !
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 10-09-2012, 08:52   #17280 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks Meter: 824
module  v1.38
Action: unlock
Boot ...
loading...
Boot done
Set baud ...
812500
Set baud done
Check hardware ...
Check hardware done
Read data ...
Read data done
Check data ...
Check data done
Write ...
Write: eeprom
Write done
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.69116 seconds with 10 queries
