05-01-2009, 08:18 | #166 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Why you make posts in wrong thread and do not read thread with your questions and my answers ? http://forum.gsmhosting.com/vbb/showthread.php?t=659450 |
05-01-2009, 08:50 | #167 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | unlock samsung cdma S299 is done show error on end proces but phone is going unlocked thx infi team Quote:
br. | |
The Following User Says Thank You to gsm_enggine For This Useful Post: |
05-01-2009, 09:03 | #168 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 38
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | sony ericsson j100 unlocked COM7 [VCP1] selected Action: unlock Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 230400 Set Baud Done Check Flash-1... SW version: R1E004 HW version: _NC2 LP ver: CXC1250384_lp_INDIA_R1E0 Flex ver: FFN_NC2_01_FILE imei otp: 354155013xxxxxx9 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35415501xxxxxx_20090430-113059.80E.bin imei eeprom: 3541550xxxxxx9 Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
05-01-2009, 09:05 | #169 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | china restart with sim format ok COM14 [Serial2] selected module v2.79 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:CF03:0004 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: YR_CAT01_L4EN_202_071127_LY3_SIV100AB_SA75_CTF_FM_ BT Version: CKT25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 160 warning: wrong packet cs items cleared: 160 of 160 building list... done items remains: 0 Finished, time used: 20 sec Remove/Install battery now ! |
05-01-2009, 09:09 | #170 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Lg kg-110 imei "00000" with full flash file KG110P40-ESA-V10j_000-00_MAR-12-2007_Vn_full_code_alchemy[1].B1M.bin loaded Testing COM7 at 921600... COM7 [VCP0] selected module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 255255255255255 current otp imei: 354701016343563 file saved: C:\Program Files\InfinityBox\LGA\eeprom_255255255255255_LG-KG110_20090407-221428.B1E.bin ........ version: 404-XXV10j91KG110P40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FFFFFF00000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 467 sec Remove/Install battery now ! |
05-01-2009, 09:13 | #171 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Spice s-525 format & rebuild imei ok COM7 [VCP2] selected module v2.58 Device: Spice-S525 Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25032501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: IACN05_07B_PCB01_GSM_MT6205B_DN.2_00.BIN ver. sw 2: 2.00, 00000000 ffs offset/size: 00300000/000E0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[IACN05_07B_PCB01_GSM_MT6205B_DN.2_00.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[IACN05_07B_PCB01_GSM_MT6205B_DN.2_00.BIN]_20090422-201001.B0E.bin flash: EC257E25032501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25032501:18E59F00000000 Finalization Done Finished, time used: 55 sec Remove/Install battery now ! Model: Spice-S525 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6205B, E0 Hardware version: GW22C_HW Software version: 2.00" Software date: 2003.07.29 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 353481020812413 verification Ok Finished, time used: 9 sec Power off phone now ! |
The Following 2 Users Say Thank You to himanshu taldar For This Useful Post: |
05-01-2009, 09:17 | #172 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Motorola w200 "cdma" unlock with china unicom flash done COM4 [VCP0] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 921600 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W200_eeprom]... file saved: C:\Program Files\InfinityBox\QCModule\Motorola-W200_eeprom_20090429-110904.B2E.bin software version: 2.2.08. flex version: FFN_A66_0111_036 LP version: LPH_A66_ASIA2_016 hardware version: MOTOROLA_A66 ESN: 34DE63D5 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 406 sec Remove/Install battery now ! |
05-01-2009, 09:19 | #173 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Samsung s299 "cdma" sp-unlock done COM4 [VCP0] selected module v1.01 Device: Samsung-SCH-S299 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done non-fatal error: can not restart phone operation finished Finished, time used: 14 sec Remove/Install battery now ! |
05-02-2009, 08:28 | #174 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 38
Member: 171512 Status: Offline Thanks Meter: 1,034 | 2 SIMS RESTART N CALIBRATION OK''THANKS INFINTY TEAM COM19 [VCP0] selected module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:0005 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.52 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35440701967560 connection Ok building list... done items to clear: 135 warning: wrong packet cs items cleared: 135 of 135 warning: wrong packet cs building list... done items remains: 0 Finished, time used: 24 sec Remove/Install battery now ! AND AFTER THIS SET CALIBRATION NOT OK AND HERE IS SET CALIBRATION OK COM19 [VCP0] selected module v2.73 Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:0005 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12.52 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-2)... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 16 17 18 done 209 byte(s) read writing data... verification... verification Ok Finished, time used: 47 sec Remove/Install battery now ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
05-02-2009, 08:33 | #175 (permalink) |
No Life Poster Join Date: Mar 2009 Location: yasir telecom.. Age: 34
Member: 1001830 Status: Offline Sonork: 100.1652282 Thanks Meter: 242 | dont write theeze kinds of thread brother bcz every one knows infinity is the best and they unlock each and every mobile which has support i love my infinity and infinity team .... Quick reply thanks infinity |
05-02-2009, 21:07 | #176 (permalink) |
Freak Poster Join Date: Jan 2006 Location: somewhere
Member: 227038 Status: Offline Thanks Meter: 78 | succefull unlocked sony-ericsson T303 sw version : R2BB12 1209-8242 1210-8802 R9A HS EROM Version : CXC1250616_R5A036 COM3 [VCP5] selected module v1.32 Device: Sony-Ericsson-T303 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb software version: 1209-8242 software version: R2BB012 Check hardware done Read data ... reading Sony-Ericsson-T303_eeprom_calibration-1... file saved: E:\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090502-205548.80E.bin Read data done Check data ... Check data done Write ... ............................ flash: 89890400040089:89890400000000 Write: simlock Write done Finished, time used: 192 sec Remove/Install battery now ! |
The Following User Says Thank You to gsm-nisse For This Useful Post: |
05-04-2009, 15:44 | #178 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Samsung B279 unlocked successfully... COM4 [VCP0] selected module v1.03 Device: Samsung-SCH-B279 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 20 sec Remove/Install battery now ! |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
05-04-2009, 17:33 | #179 (permalink) |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | zte 341 done with infinity COM3 [VCP0] selected module v2.58 Action: unlock unlock method: smart fast Model: SFR-341 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:6A03:000D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z3_EFPSY_B07A106 Version: ZTEMT25_07A_HW_A 44 byte(s) read imei: 35672002078725 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! thanks to infinity team for good support |
The Following User Says Thank You to toutou_gsm For This Useful Post: |
05-06-2009, 05:11 | #180 (permalink) |
Freak Poster Join Date: May 2005 Location: hanoi.vietnam
Member: 142949 Status: Offline Thanks Meter: 71 | bavapen b104e support good with files in support COM3 selected module v1.65 Device: Bavapen-104e Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Bavapen-104e_eeprom-static_20090506-110128.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Bavapen-104e_eeprom-security_20090506-110129.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Bavapen-104e_eeprom-complete_20090506-110131.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 204 sec Remove/Install battery now ! |
The Following User Says Thank You to nguyenhuu For This Useful Post: |
