![]() | #18616 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | code read by rpl Code: registered to: saeedullah_khan Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 00885 ===== USER CODE ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\356352056211928_XG213.rpl Connect phone on selected interface... |
![]() | #18617 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 110 Code: registered to: saeedullah_khan Connect phone on selected interface... Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm827__03.47.mcusw PPM : rm827__03.47.ppm_m2 CNT : rm827__03.47.image_m2_059N2R0 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.49_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 353259056088367 IMEI 2 : 353259056088375 PCcode : ’}¦SÍŒý NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\353259056088367_XG213_CRT.rpl ===Flashing [MCU]=== File : rm827__03.47.mcusw Image : rm827__03.47.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:04 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:06 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:37 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x73FB ===Flashing [PPM]=== File : rm827__03.47.ppm_m2 Image : package_m2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:16 Write , Start : 0x41BC0000 , Len : 0x0030F6D4 Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x0744 ===Flashing [CNT]=== File : rm827__03.47.image_m2_059N2R0 Image : package_m2_059N2R0.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:55 Write , Start : 0x421C0000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0x9819 Flashing done! Total flash time : 00:07:39 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 110 Software Info: V 03.47 31-05-13 RM-827 (c) Nokia IMEI: 353259056088367 PPM version : V 03.47 31-05-13 RM-827 (c) Nokia M2 Product code: 059N2R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 58 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:40 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok CMLA Key read ... Ok Reboot.... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... CMLA Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\353259056088367_XG213.rpl Connect phone on selected interface... |
The Following User Says Thank You to saeedullah_khan For This Useful Post: |
![]() | #18618 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: PAKISTAN
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,072 | C2-03 Flash Done :) Code: Connect phone on selected interface... Core : v1.74.5 , BB5XG FlashEngine : v6.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__07.63.mcusw PPM : rm702__07.63.ppm_m_a CNT : rm702__07.63.image_m_a_059D475 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359064043014763 IMEI 2 : 359064043014771 PCcode : 059D475 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359064043014763_XG213_CRT.rpl ===Flashing [MCU]=== File : rm702__07.63.mcusw Image : rm702__07.63.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:02:48 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:00:39 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x787E ===Flashing [PPM]=== File : rm702__07.63.ppm_m_a Image : package_m_a.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:26 Write , Start : 0x41DC0000 , Len : 0x00404794 Flashing , wait ... Region flash done, time : 00:00:04 CRC check passed , 0xCEB3 ===Flashing [CNT]=== File : rm702__07.63.image_m_a_059D475 Image : package_m_a_059D475.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:04:49 Write , Start : 0x424C0000 , Len : 0x00D00000 Flashing , wait ... Region flash done, time : 00:00:23 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:10 No write data, skip CRC check passed , 0x08DB Flashing done! Total flash time : 00:09:34 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.63 17-08-12 RM-702 (c) Nokia IMEI: 359064043014763 PPM version : V 07.63 17-08-12 RM-702 (c) Nokia M_A Product code: 059D475 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:10:39 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to syed tuqeer For This Useful Post: |
![]() | #18619 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | C2-00 Code: registered to: saeedullah_khan Connect phone on selected interface... Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.99.mcusw PPM : rm704__03.99.ppm_m_c CNT : rm704__03.99.image_m_c_magenta_059C1P3 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 359731043771200 IMEI 2 : 359731043771218 PCcode : 059C1R8 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\359731043771200_XG213_CRT.rpl ===Flashing [MCU]=== File : rm704__03.99.mcusw Image : rm704__03.99.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:02:13 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x6C69 ===Flashing [PPM]=== File : rm704__03.99.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:17 Write , Start : 0x41BC0000 , Len : 0x00398498 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x7DB1 ===Flashing [CNT]=== File : rm704__03.99.image_m_c_magenta_059C1P3 Image : package_m_c_magenta_059C1P3.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:04:08 Write , Start : 0x421C0000 , Len : 0x00A00000 Flashing , wait ... Region flash done, time : 00:00:13 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:07 No write data, skip CRC check passed , 0xC664 Flashing done! Total flash time : 00:07:50 Reboot phone now... Reading Phone Info.... Connected phone - C2-00 Software Info: V 03.99 03-04-12 RM-704 (c) Nokia IMEI: 359731043771200 PPM version : V 03.99 03-04-12 RM-704 (c) Nokia M_C Product code: 059C1R8 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:08:40 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
![]() | #18620 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 2700 classic Code: registered to: saeedullah_khan Connect phone on selected interface... Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm561__09.98.image_t_ph_blac Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected -> Custom flashing in dead mode active! -> Phone will boot in normal mode after flash! Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 19600202BB710F56B5F7DD1F8332BCCE9601B18F CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ===Flashing [CNT]=== Erase : Processing rm561__09.98.image_t_ph_blac Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:05:50 Write : Processing rm561__09.98.image_t_ph_blac Total 696 [696/0/0] blocks to write, writing... TIME : Write time : 00:00:36 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:06:27 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.97 18-06-10 RM-561 (c) Nokia IMEI: 357017045015180 PPM version : V 09.97 18-06-10 RM-561 (c) Nokia MEN Product code: 0587992 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:08:51 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL not support backup mode, rpl reading impossible SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\357017045015180_SIM.rpl Elapsed: 00:00:03 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
![]() | #18621 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | C2-03 Code: Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm702__07.65.ppm_m_c CNT : rm702__07.65.image_m_c_059D436 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 358266040430048 IMEI 2 : 358266040430055 PCcode : 059D434 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\358266040430048_2nd_XG213_CRT.rpl ===Flashing [PPM]=== File : rm702__07.65.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:26 Write , Start : 0x41DC0000 , Len : 0x005432A8 Flashing , wait ... Region flash done, time : 00:00:06 CRC check passed , 0x2433 ===Flashing [CNT]=== File : rm702__07.65.image_m_c_059D436 Image : package_m_c_059D436.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:03:52 Write , Start : 0x424C0000 , Len : 0x00D20000 Flashing , wait ... Region flash done, time : 00:00:19 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:08 No write data, skip CRC check passed , 0xE976 Flashing done! Total flash time : 00:04:53 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.65 19-09-12 RM-702 (c) Nokia IMEI: 358266040430048 PPM version : V 07.65 19-09-12 RM-702 (c) Nokia M_C Product code: 059D434 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:05:50 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created Check communication with phone.... Communication verify done... Preparing... SL3 Simlock read (XGOLD) ... Ok WMDRM Key read ... Ok Reboot.... Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_10.56_M1S1 Boot done! Read CRT block... Read EEPROM block... SL3 Simlock found (XGOLD) ... WMDRM Key found ... ===== USER CODE ===== Executing Code extraction... - > Phone Lock Code : 12345 ===== USER CODE ===== NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\358266040430048_2nd_XG213.rpl Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... |
![]() | #18622 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 6120 Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm243_07.20_prd_core.fpsx PPM : rm243_07.20_prd_vB21_01_mea_b.fpsx CNT : rm243_ENO_A_2009wk15v0.100.fpsx APE : rm243_07.20_prd_UDA_Nokia_Noir.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL2 Simlock read ... Ok SimLock Data saved... SimLock Key saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\352719049632911_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 11900111DA9D00522CB51B527766A2D36BF2BE3F ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP ... Processing PASUBTOC ... Boot Done! :) TIME : Boot time : 00:00:31 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL Server confirm flashmode! Get req info : empty ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm243_07.20_prd_core.fpsx Found 3 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT Result: 0000 Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT Result: 0000 Partition erase not allowed by loader Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_core.fpsx Total 404 [404/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS*CORE] CMT : Writing Hash CERT [SOS+ROFS] TIME : Write time : 00:00:55 MCU Write done ===Flashing [PPM]=== Erase : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Found 1 areas to erase Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_vB21_01_mea_b.fpsx Total 164 [164/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFX] TIME : Write time : 00:00:27 PPM Write done ===Flashing [CNT]=== Erase : Processing rm243_ENO_A_2009wk15v0.100.fpsx Found 1 areas to erase Erasing area 0x00880000 - 0x00B7FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_ENO_A_2009wk15v0.100.fpsx Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:01 CNT Write done ===Flashing [APE]=== Erase : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Found 1 areas to erase Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing rm243_07.20_prd_UDA_Nokia_Noir.fpsx Total 1 [1/0/0] blocks to write, writing... TIME : Write time : 00:00:00 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:01:25 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 6120 Software Info: V 07.20 05-10-09 RM-243 (c) Nokia IMEI: 352719049632911 Ape Version: 07.20 Product code: 0581707 Wait, when phone will be ready ... Checking... SimLock status : Can't get status Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:29 Connect phone on selected interface... |
![]() | #18623 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Nokia 301 Rm-839 Flash Done Code: Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 402415A448A20334 IF Resp Data : 50A9070100030101E0001409 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1315.400_M1S1 QUARK EEP config Ok FLASHID : EC004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! ===Flashing [MCU]=== Processing file : rm839__02.33.mcusw Region count : 8 00 : psi_flash_unsigned.fls 01 : slb_signed.fls 02 : main_toc_signed.fls 03 : rm839__02.33.mcusw_signed_mcusw.fls 04 : swap_signed.fls 05 : dynsw.fls 06 : aeneas_signed.fls 07 : fota_signed.fls Parse done , flashing now Processing image : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Load region psi_flash_unsigned.fls Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done psi_flash_unsigned.fls image flash done Processing image : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Load region slb_signed.fls Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done slb_signed.fls image flash done Processing image : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Load region main_toc_signed.fls Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done main_toc_signed.fls image flash done Processing image : 03 : rm839__02.33.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Load region rm839__02.33.mcusw_signed_mcusw.fls Region Start : 0x62E00000 , Data Len : 0x00F05210 Region Load done rm839__02.33.mcusw_signed_mcusw.fls image flash done Processing image : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Load region swap_signed.fls Region Start : 0x80000000 , Data Len : 0x00C1B3CC Region Load done swap_signed.fls image flash done Processing image : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Load region dynsw.fls Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done dynsw.fls image flash done Processing image : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Load region aeneas_signed.fls Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done aeneas_signed.fls image flash done Processing image : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Load region fota_signed.fls Region Start : 0x61F00004 , Data Len : 0x00145478 Region Load done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__02.33.ppm_m2 Region count : 1 00 : package_m2.ppm_ebl_psi.fls Parse done , flashing now Processing image : 00 : package_m2.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Load region package_m2.ppm_ebl_psi.fls Region Start : 0x80F00000 , Data Len : 0x00520D30 Region Load done package_m2.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__02.33.image_m2_059R1J6 Region count : 1 00 : package_m2_059R1J6.image.fls Parse done , flashing now Processing image : 00 : package_m2_059R1J6.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Load region package_m2_059R1J6.image.fls Region Start : 0xA1000000 , Data Len : 0x0193FA00 Region Load done package_m2_059R1J6.image.fls image flash done Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 02.33 17-05-13 RM-839 (c) Nokia IMEI: 355516056421585 PPM version : V 02.33 17-05-13 RM-839 (c) Nokia M2 Product code: 059Q9B8 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Checking User Certificates... Total - 58 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:01:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following User Says Thank You to danishalnoor For This Useful Post: |
![]() | #18624 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,072 | N86 8MP Flash Done :) Code: card found: S/N XXXX:XXXX registered to: Syed Tuqeer Ali Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Core : v1.74.5 , BB5XG FlashEngine : v6.7 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-484_30.009_prd.core.fpsx PPM : RM-484_30.009_022_prd.language.fpsx PPM2 : RM-484_30.009_54.1_prd.customer.fpsx CNT : RM-484_30.009_003_U001.uda.fpsx APE : rm484_ENO_x_2009wk42v0.a004 Flashing phone now... Rules accepted for : RAPIDO Generation Check files done... -> Check SW version... FlashFile version : 30.009 Phone version : 30.009 -> Check SW version : Reflash Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\3534030408XXXXX_SIM.rpl Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Batery valtage : 3535 mV -> Batery voltage less, than 3,8V (3535mV). Continue at user risk Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 076000167F9A0052B51A8A6D8C98290F448E9AD7 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 Waiting for response: 27 Waiting for response: 26 Waiting for response: 25 Waiting for response: 24 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : 479C6DDE3942E12C429C1D6ADED80371 RPAKeys : 01C4258BFD64668B6824B7545BE4904AE5C408A4 Pr.Code : 0580494 IMEI : 353403040828419 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-484_30.009_prd.core.fpsx Found 4 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x0A27FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_prd.core.fpsx Total 494 [494/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-484_30.009_022_prd.language.fpsx Found 1 areas to erase Erasing area 0x07A20000 - 0x0957FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_022_prd.language.fpsx Total 70 [70/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:05 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-484_30.009_54.1_prd.customer.fpsx Found 1 areas to erase Erasing area 0x09580000 - 0x0A27FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_54.1_prd.customer.fpsx Total 6 [6/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-484_30.009_003_U001.uda.fpsx Found 1 areas to erase Erasing area 0x0A280000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-484_30.009_003_U001.uda.fpsx Total 2 [2/0/0] blocks to write, writing... TIME : Write time : 00:00:00 CNT Write done ===Flashing [APE]=== Erase : Processing rm484_ENO_x_2009wk42v0.a004 TIME : Erase time : 00:00:00 Write : Processing rm484_ENO_x_2009wk42v0.a004 Total 18 [18/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS*ENO] TIME : Write time : 00:00:01 APE Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:42 Reboot phone now... Reading Phone Info.... Connected phone - Nokia N86 8MP Software Info: V ICPR72_09w36.25 18-02-10 RM-484 (c) Nokia IMEI: 3534030408XXXXX Ape Version: 30.009 Product code: 0580494 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! ===== WARNING ===== Battery voltage is can be not enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Elapsed: 00:01:21 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
![]() | #18625 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 3120 classic Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : PPM : rm364__10.00.ppm_m4 Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL2 Simlock read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\355213032060220_SIM.rpl -> MMC pass Record found, saving... Getting product info... RAP_BOOT: 0803000002010000 RAP_PUBLIC: 0A800108A9767F56B6F159E26453F9016AAB5261 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 Loader len: 300928, CHK: AB61 ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ===Flashing [PPM]=== Erase : Processing rm364__10.00.ppm_m4 Found 1 areas to erase Erasing area 0x01600000 - 0x01CBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:15 Write : Processing rm364__10.00.ppm_m4 Total 20 [20/0/0] blocks to write, writing... TIME : Write time : 00:00:32 PPM Write done ADL : End flashing Flashing done! Total flash time : 00:00:47 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3120 classic Software Info: V 10.00 06-03-09 RM-365 (c) Nokia IMEI: 355213032060220 PPM version : V 10.00 06-03-09 RM-364 (c) Nokia M4 Product code: 0565643 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 17 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:01:33 Connect phone on selected interface... |
![]() | #18626 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 200 Code: Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm761__11.95.mcusw PPM : rm761__11.95.ppm_mec CNT : rm761__11.95.image_mec_059J4X4 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352416057639900 IMEI 2 : 352416057639918 PCcode : 059J4X1 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\352416057639900_XG213_CRT.rpl ===Flashing [MCU]=== File : rm761__11.95.mcusw Image : rm761__11.95.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:51 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x495E ===Flashing [PPM]=== File : rm761__11.95.ppm_mec Image : package_mec.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00740000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41A80000 , Len : 0x00697CF0 Flashing , wait ... Region flash done, time : 00:00:08 CRC check passed , 0x27DB ===Flashing [CNT]=== File : rm761__11.95.image_mec_059J4X4 Image : package_mec_059J4X4.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:02:45 Write , Start : 0x421C0000 , Len : 0x00FA0000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0xCAB6 Flashing done! Total flash time : 00:06:21 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 200 Software Info: V 11.95 19-12-12 RM-761 (c) Nokia IMEI: 352416057639900 PPM version : V 11.95 19-12-12 RM-761 (c) Nokia MEC Product code: 059J4X1 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 43 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:22 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
![]() | #18627 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | Nokia 2700 classic Code: registered to: saeedullah_khan Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm561__09.98_009.image_x_ctv_id_v3_93748 Flashing phone now... Check files done... -> SWversion check skipped : Custom mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\358256043831623_SIM.rpl Getting product info... RAP_BOOT: 0803000302010000 RAP_PUBLIC: 0B600113408F0556923F4F74881915212138D47D CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723 RAP_PAPUBKEY: 3EA22A1DDA660002E56108DB5072A10F8709443F Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm561__09.98_009.image_x_ctv_id_v3_93748 ConvertImage: Page Size is 128K, no need convert Loader len: 308032, CHK: 037B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:05 Reopening the connection... Waiting for response: 30 Waiting for response: 29 Waiting for response: 28 ADL -> [2nd] changing... ADL Server confirm flashmode! ===Flashing [CNT]=== Erase : Processing rm561__09.98_009.image_x_ctv_id_v3_93748 Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:06:30 Write : Processing rm561__09.98_009.image_x_ctv_id_v3_93748 Total 1008 [1008/0/0] blocks to write, writing... TIME : Write time : 00:00:53 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:07:23 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 2700 classic Software Info: V 09.97 18-06-10 RM-561 (c) Nokia IMEI: 358256043831623 PPM version : V 09.97 18-06-10 RM-561 (c) Nokia MEN Product code: 0581967 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:08:35 Connect phone on selected interface... |
![]() | #18628 (permalink) |
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,741 | X2-01 Code: Core : v1.74 , BB5XG FlashEngine : v6.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : CNT : rm709__08.65_004.image_ma3_ctv_pk_9g521 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000A54519EF63C687AE240B443DDDAF4D ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357410049559347 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\357410049559347_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [CNT]=== Erase : Processing rm709__08.65_004.image_ma3_ctv_pk_9g521 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm709__08.65_004.image_ma3_ctv_pk_9g521 Total writen 563 blocks TIME : Write time : 00:00:06 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:07 Reboot phone now... Reading Phone Info.... Connected phone - X2-01 Software Info: V 08.63 25-03-11 RM-709 (c) Nokia IMEI: 357410049559347 PPM version : V 08.63 25-03-11 RM-709 (c) Nokia MA3 Product code: 059G521 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:01:25 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CMLA Key read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 0000000000A54519EF63C687AE240B443DDDAF4D ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : 37955B6FC432998EF0DB240E332228384D19ED09 ADL: Reading certificates... Reading NPC certificate... IMEI : 357410049559347 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... CMLA_KEY Data saved... RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\InfinityBox_install_BEST_v1.74\Backup\Cert\357410049559347.rpl All done, Disconnecting Elapsed: 00:00:12 Connect phone on selected interface... |
![]() | #18629 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: Syberia Age: 35
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yeah, I made that ![]() My own "brom" implementation, no any dll or anything. Code: Connect phone on selected interface... Files Selected : ROM : RM-944_ROM_eMP_11.01.11 LANG : RM-944_LANG_PACK_ROM_EI_eMP_11.01.11 CUST : RM-944_CUSTPACK_ROM_EI_EURO_RU_eMP_11.01.11 JMTB : RM-944_JUMP_TABLE_EI_EURO_RU_eMP_11.01.11 VIVA : RM-944_VIVA_eMP_11.01.11 Check files : Files are ok === Dead mode selected === 1. Insert cable in powered Off phone 2. Battery must be charged and inserted! Wait for phone... Phone found! [ 58 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.11.01.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SDECRYPT : RM-944_VIVA_eMP_11.01.11 SDECRYPT : RM-944_CUSTPACK_ROM_EI_EURO_RU_eMP_11.01.11 SDECRYPT : RM-944_LANG_PACK_ROM_EI_eMP_11.01.11 SDECRYPT : RM-944_JUMP_TABLE_EI_EURO_RU_eMP_11.01.11 SDECRYPT : RM-944_ROM_eMP_11.01.11 OVRL : 000069B900000001 PHPID : Bree.11.01.11.p1 OVRL : 00004DF900000001 FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok FLASH_STYLE : 01 (SEQ) Wait DA... Write : RM-944_ROM_eMP_11.01.11 Write : RM-944_LANG_PACK_ROM_EI_eMP_11.01.11 Write : RM-944_CUSTPACK_ROM_EI_EURO_RU_eMP_11.01.11 Write : RM-944_JUMP_TABLE_EI_EURO_RU_eMP_11.01.11 Write : RM-944_VIVA_eMP_11.01.11 CODE_LOAD : Ok Code Verify : Skipped Factory Set : Skipped Rebooting phone now Flashing done! Total flash time : 00:00:48 Reboot phone now... Connect phone on selected interface... |
The Following 11 Users Say Thank You to Dzirt For This Useful Post: |
