05-23-2015, 06:48 | #22501 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Panabo City
Member: 265729 Status: Offline Sonork: jhunpanabo Thanks Meter: 144 | Operation : Repair Security [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6572, E01 HW : VANZO72_WET_JB3_HSPA_HW SW : MOLY.WR8.W1315.MD.WG.MP.V1.P33 MM : 2000.00.00 VR : 1.0 SN : 072601MT0123458424_201601 10P Security Info : IMEI [1] : 862592025403414 IMEI [2] : 862592025403422 Read Ok! Update IMEI[1] to : 862592025403414 done! Update IMEI[2] to : 862592025403422 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:12 Reconnect Power/Cable! |
The Following User Says Thank You to JHUNpanabO For This Useful Post: |
05-23-2015, 09:25 | #22502 (permalink) |
No Life Poster Join Date: May 2013 Location: TkinterPy,Hex Cal,Ext2,Ext4,
Member: 1937038 Status: Offline Sonork: QQ 2045657399 Thanks Meter: 4,492 | RM-987 FLASH DONE. Connect phone on selected interface... Core : v2.07 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm987_14.0.5.mcusw.fls PPM : rm987_14.0.1_059V2R4_m3_2030_01_423819.rofs.fls CNT : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 221 [XMM2210 QIMING] IF uCHIPID : 1942120982E671C2 IF Resp Data : 194200021C030101 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : 1_1336.500_MKEYSKEY QIMING EEP config Ok FLASHID : 52F00000 , [ NOR ] Boot conf set, Target Ready Boot done! ===Flashing [MCU]=== Processing file : rm987_14.0.5.mcusw.fls Region count : 2 00 : [ PSI ] : rm987_14.0.5.mcusw.fls.fls 01 : [ Code ] : rm987_14.0.5.mcusw.fls.fls Parse done , flashing now Flash : 00 : rm987_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40000000 , Len : 0x00020000 Erase done Region Start : 0x40000000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done rm987_14.0.5.mcusw.fls.fls image flash done Flash : 01 : rm987_14.0.5.mcusw.fls.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x40040000 , Len : 0x00020000 Erase done Erase area 0x01 , Start 0x40060000 , Len : 0x00160000 Erase done Erase area 0x02 , Start 0x40340000 , Len : 0x023C0000 Erase done Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000 Erase done Region Start : 0x40040000 , Data Len : 0x00020000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40060000 , Data Len : 0x00160000 Region Load done Wait for phone write all data ... Write done Region Start : 0x40340000 , Data Len : 0x01E84B74 Region Load done Wait for phone write all data ... Write done rm987_14.0.5.mcusw.fls.fls image flash done ===Flashing [PPM]=== Processing file : rm987_14.0.1_059V2R4_m3_2030_01_423819.rofs.fls Region count : 1 00 : [ Cust ] : rofs_ebl_psi.fls Parse done , flashing now Flash : 00 : rofs_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000 Erase done Region Start : 0x42880000 , Data Len : 0x007E7AD8 Region Load done Wait for phone write all data ... Write done rofs_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls Region count : 1 00 : [ Cust ] : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls Parse done , flashing now Flash : 00 : rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x43800000 , Len : 0x04600000 Erase done Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000 Erase done Region Start : 0x43800000 , Data Len : 0x02B60000 Region Load done Wait for phone write all data ... Write done rm987_14.0.1_059V2R4_m3_2030_01_423819.image.fls.i mage.fls image flash done Flashing done! Total flash time : 00:02:15 Reboot phone now... Reading Phone Info.... Connected phone - 230 Software Info: V 14.0.5 21-04-14 RM-987 (c) Nokia IMEI: 351739060235684 PPM version : ec8642ff589b4bbe806a63df2e59aaeb36d5f929 Product code: 059V7T7 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 59 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:29 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-23-2015, 11:18 | #22503 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 40
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung 2202 blink repair by format Code: Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 89 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 [1] Flash DIE : 00EF 0060 0018 0000 [1] Flash VEN : Winbond , W25Q128 [1] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:03:41 Reconnect Power/Cable! |
The Following User Says Thank You to rehmani For This Useful Post: |
05-23-2015, 11:22 | #22504 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | opal 4l007 read flash and format done read flash Code: Operation : Read FullFlash [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C2 0025 0038 0000 [0] Flash VEN : Macronix , MX25 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Debug F3009_XBN_U59_OPAL_128X64_320X480_NOTVNOWIFI_L9 Project : F3009_XBN_U59_OPAL_128X64_320X480_NOTVNOWIFI_L9_V04.01B02 HWInfo : F3009_XBN_U59_OPAL_128X64_320X480_NOTVNOWIFI_L9_V04.01B02 Compile : 05-21-2014 22:16:10 Set FileInfo : Model Vendor : opal Model Name : touch three button ExtInfo Data : modal 4l007 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B_6531.W13.07_Debug_F3009_XBN_U59_OPAL_128X64_320X480_NOTVNOWIFI_L9_05212014221610_modal 4l007__opal-touch three button.bin Done! Code: Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C2 0025 0038 0000 [0] Flash VEN : Macronix , MX25 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
05-23-2015, 11:47 | #22505 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia e5-00 flashing done Code: Files Set for Flashing : MCU : rm632_102.002_prd.core.fpsx PPM : rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx PPM2 : rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CNT : rm632_102.002_U010.000_prd.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 17F0001432DE034410250507A58CA702457E9512 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00500020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358631049911456 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358631049911456_CRT.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_102.002_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:14 MCU Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_25.01_MEA_A_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 221 blocks TIME : Write time : 00:00:07 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_102.002_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ===Flashing [CNT]=== Erase : Processing rm632_102.002_U010.000_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:03 Write : Processing rm632_102.002_U010.000_prd.uda.fpsx Total writen 97 blocks TIME : Write time : 00:00:05 CNT Write done ADL: Request programm status NAND status : 00000004 / 00000004 / 00000000 ADL: Close_Session Content: 000300000000040000000400000000 ADL: Reboot Flashing done! Total flash time : 00:00:37 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.14 16-11-12 RM-632 (c) Nokia IMEI: 358631049911456 Ape Version: 102.002 Product code: 059H854 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! |
05-23-2015, 12:28 | #22507 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile E50 v3 Read User Code Done Code: Operation : Read UserCode [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 26 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CAAC2BF9A0090C614E728C5F4FFB4765 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 6555 PLock|MobTrack : Not active Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
05-23-2015, 12:28 | #22508 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia asha 301 security code reset done Code: Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:05 |
05-23-2015, 12:32 | #22509 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia asha 308 security code reset done Code: Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:11 |
05-23-2015, 12:38 | #22510 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia c1-01 flashing done Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm607__04.40.mcusw PPM : rm607__04.40.ppm_m_c CNT : rm607__04.40.image_m_c_0595609 Flashing phone now... Rules accepted for : XGOLD Generation Check files done... -> Check SW version... FlashFile version : 04.40 Phone version : 03.35 02-12-10 RM-607 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created Check communication with phone.... ADL req restart Communication verify done... Preparing... Check communication with phone... SL3 Simlock read (XGOLD) ... Ok Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_2.3_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 355962045519784 PCcode : 0596699 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355962045519784_XG213.rpl ===Flashing [MCU]=== File : rm607__04.40.mcusw Image : rm607__04.40.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:03 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:01:38 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:30 CRC check passed , 0xD471 ===Flashing [PPM]=== File : rm607__04.40.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:13 Write , Start : 0x41C00000 , Len : 0x0031A50C Flashing , wait ... Region flash done, time : 00:00:03 CRC check passed , 0x4A12 ===Flashing [CNT]=== File : rm607__04.40.image_m_c_0595609 Image : package_m_c_0595609.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:03:05 Write , Start : 0x42200000 , Len : 0x00B60000 Flashing , wait ... Region flash done, time : 00:00:14 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0x17AA Flashing done! Total flash time : 00:06:01 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 04.40 23-02-11 RM-607 (c) Nokia IMEI: 355962045519784 PPM version : V 04.40 23-02-11 RM-607 (c) Nokia M_C Product code: 0596699 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:07:07 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-23-2015, 12:39 | #22511 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia x2-00 flashing done Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meac CNT : rm618__08.35.image_meac_0595304 Flashing phone now... Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 000000000000B24A74A6E4F2F83E26BF1B6955FC ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 358274049145013 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358274049145013_CRT.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meac Total writen 100 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meac_0595304 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meac_0595304 Total writen 341 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:06 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-23-2015, 12:44 | #22512 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | nokia 5220 flashing done Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm411__07.23.mcusw PPM : rm411__07.23.ppm_mb CNT : rm411__07.23.image_mb_b_grey Flashing phone now... Rules accepted for : RAP3x Generation Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. ASIC ID: 000000010000022600010006030C192101033000 CPU ID : RAP3Gv3 , Features : No any extended features RAP_PUB: 058001128E9F0254676DD2370EF63F877FE33C7C CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ===Flashing [MCU]=== Erase : Processing rm411__07.23.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:08 Write : Processing rm411__07.23.mcusw Total 1289 [1289/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:01 MCU Write done ===Flashing [PPM]=== Erase : Processing rm411__07.23.ppm_mb Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:52 Write : Processing rm411__07.23.ppm_mb Total 400 [400/0/0] blocks to write, writing... TIME : Write time : 00:00:19 PPM Write done ===Flashing [CNT]=== Erase : Processing rm411__07.23.image_mb_b_grey Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:44 Checking content info... Check Image : Content size is 128k, use direct write mode Write : Processing rm411__07.23.image_mb_b_grey Total 472 [472/0/0] blocks to write, writing... TIME : Write time : 00:00:22 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:09:30 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5220 XpressMusic Software Info: V 07.23 17-07-09 RM-411 (c) Nokia IMEI: 353662011308301 PPM version : V 07.23 17-07-09 RM-411 (c) Nokia MB Product code: 0563616 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! ===== WARNING ===== Battery voltage is NOT enough for start ===== WARNING ===== AfterFlash operations done ;D Done! Elapsed: 00:10:31 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
05-23-2015, 12:50 | #22513 (permalink) |
Member: 2287188 Status: Offline Thanks Meter: 31 | Nokia asha 311 flashing done by best dongle Code: Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm714__07.36.mcusw PPM : rm714__07.36.ppm_mh CNT : rm714__07.36.image_mh_059F7M6_059Q1N3_427_03 Flashing phone now... Rules accepted for : RAPUxx Generation Check files done... -> Check SW version... FlashFile version : 07.36 Phone version : 03.81 18-06-12 RM-714 (c) Nokia -> Check SW version : Upgrade Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 8C190000FFFB7C40C00D538971E2D13DFD868A85 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354595059096967 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354595059096967.rp l === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm714__07.36.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm714__07.36.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 287 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [PPM]=== Erase : Processing rm714__07.36.ppm_mh Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm714__07.36.ppm_mh Total writen 104 blocks TIME : Write time : 00:00:02 PPM Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ===Flashing [CNT]=== Erase : Processing rm714__07.36.image_mh_059F7M6_059Q1N3_427_03 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing rm714__07.36.image_mh_059F7M6_059Q1N3_427_03 Total writen 793 blocks TIME : Write time : 00:00:11 CNT Write done ADL: Request programm status NAND status : 00000006 / 00000006 / 00000000 ADL: Close_Session Content: 000300000000060000000600000000 ADL: Reboot Flashing done! Total flash time : 00:00:22 Reboot phone now... |
05-23-2015, 12:50 | #22514 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | QMobile A63 MT6572 3Sim Read Factory File Done Code: Operation : Read Flash [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040502A1C11861E7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A1C11861E7 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : QMobile ProdName : QMobile A63 ProdModel : QMobile A63 Device : x3365 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : X3365_DX33651_QMOBILE-A63_L102 [Read Ok] : preloader_x3365.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : test.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / x3365 / EMMC FW Size : 810 MiB Scatter saved to : C:\Users\AkhtaraLi\Desktop\MT6572__QMobile__QMobile A63__x3365__4.2.2__X3365_DX33651_QMOBILE-A63_L102\ All done! Done! Elapsed: 00:03:55 Reconnect Power/Cable! |
05-23-2015, 13:28 | #22515 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Q Mobile LINQ X70 MT6582 V4.4.2 Read firmware, Done .:: BY ::. ..::: Chinese Miracle-2 MTK:::.. Code:
The Following 4 Users Say Thank You to kabul For This Useful Post: |
