03-20-2010, 16:07 | #2266 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | Successfully unlocked Voda 340 module v3.16 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:EA03:A000 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.40 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203153157 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to kasrawiz For This Useful Post: |
03-20-2010, 16:54 | #2267 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | zte gx 760 unlock done with infinity even failed with other tools it was asking for np code COM4 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:C503:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z10UK_GD_BFFA112 Version: ZTEMT25_07A_HW_A 44 byte(s) read imei: 35235302467437 connection Ok 157 byte(s) read reading data... reading data #4... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! great thanks infinity team |
The Following User Says Thank You to .::M Irfan::. For This Useful Post: |
03-20-2010, 16:58 | #2268 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | ZTE X760 unlock successfully Code: COM3 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X760 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:A403:0000 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X760_Z10RO_RO_BFFA102 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35897503091901 connection Ok 157 byte(s) read reading data... reading data #4... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to sebY7676 For This Useful Post: |
03-20-2010, 17:47 | #2269 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Successfully Unlocked Alcatel OT-103 COM5 [VCP0] selected module v3.25 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6B2A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM17CC41 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124->0826B698 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 352471035****** flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201003 20-212522.B0X.bin Finished, time used: 6 min 17 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to murtaza_nns For This Useful Post: |
03-20-2010, 23:10 | #2270 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 523148 Status: Offline Thanks Meter: 41 | UTStarcom GPPE-1238cw Unlock done !! Operation logs: COM12 [VCP0] selected module v3.10 Action: "sp-unlock" unlock method: smart fast Model: UTStarcom-GPRS1238 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:922F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: C2011+_1.18_US_CW_PNM_T3_OV90 Version: CELLONSZ23C_07B_HW 67 byte(s) read imei: 35710xxxxxxxxxxx connection Ok 178 byte(s) read reading data... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done warning: wrong packet cs Finished, time used: 14 sec Remove/Install battery now ! -This phone is from Cables&Wireles Panama -Use last MModule version and select phone model UTStarcom-GPRS1238. -Cable pinout is same for ZTE-x761 -Here Full Flash Backup for support MEGAUPLOAD - The leading online storage and file delivery service Thanks Infinity Box !! |
The Following User Says Thank You to felo28 For This Useful Post: |
03-21-2010, 10:12 | #2271 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | vodaphone 340 unlock ok thanks infinty team Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
03-21-2010, 13:30 | #2272 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Dead LG C2500 alive after complete format with Infinity! COM14 [VCP0] selected module v3.01 Device: LG-C2500 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6217:8A00]... CPU: MT6217 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LG-C2500__ffs... file saved: D:\Program Files\InfinityBox\MModule\LG-C2500__ffs_20100321-172530.A3E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:29EA0000000000 Finalization Done Finished, time used: 4 min 25 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to msashami For This Useful Post: |
03-21-2010, 13:35 | #2273 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Vodafone 225 Unlock again !! COM4 [VCP0] selected module v1.73 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: -SA-P108A2V1.0.0B08 VDF-P108A2B07-RoFr-SA03 g3dBV2.0 Aug 10 2007 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20100321-162601.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20100321-162602.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20100321-162608.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20100321-162620.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 48 sec Remove/Install battery now ! thx Teem !! |
The Following 2 Users Say Thank You to nishue For This Useful Post: |
03-22-2010, 06:33 | #2274 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>>>vodafone 340 unlock ok infinity-box<<<<< COM4 [VCP1] selected module v3.26 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E503:A00F status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.40 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203157247 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
The Following User Says Thank You to shahid41 For This Useful Post: |
03-22-2010, 09:12 | #2275 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Age: 29
Member: 1140401 Status: Offline Sonork: 100.1586294 Thanks Meter: 374 | j110i new unlock Successfully COM25 [VCP0] selected module v1.38 Device: Sony-Ericsson-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 039C-000 software version: KIM-5- Check hardware done Read data ... reading Sony-Ericsson-J110i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J110i_eeprom_calibration-1_20100322-130734.6AE.bin Read data done Check data ... error: not locked or unknown eeprom Check data done Write ... .........data prepared Ok flash: 89886200010001:89886200000000 Write: eeprom Write done Finished, time used: 29 sec Remove/Install battery now ! |
The Following User Says Thank You to GsmVeer For This Useful Post: |
03-22-2010, 12:09 | #2276 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM11 [VCP0] selected module v1.73 Device: LG-KG276 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG271 P16 92 V10d XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20100322-154248.B1E.bin loading data... data loaded imei: 35617601868192200 reading eeprom-security_35617601868192200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_35617601868192200_20100322-154249.B1E.bin reading eeprom-complete_35617601868192200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_35617601868192200_20100322-154250.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 18 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
03-22-2010, 12:57 | #2277 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | alcatel 708 unlock succefuly COM6 [VCP0] selected module v3.25 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E603:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.755BF 7B9.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A8667CC5].rpl rom info detection finished device-id: 755BF7B9 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, C57C66A8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, part #2) calculation... error: security area (sec info, part #2) header is invalid security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CB27 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done security area (sec info, part #2) calculation... identification header detected customization: XN16CB27 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35400703723066 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_755BF7B9_A8667CC5_20 100322-124814.B0X.bin Finished, time used: 4 min 38 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to yahia ali For This Useful Post: |
03-22-2010, 13:11 | #2278 (permalink) |
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>>> alcatel s319x unlock ok infinity-box<<<<<<< COM4 [VCP2] selected module v3.27 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1563:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XH16CB31 customization name adjusted flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35239402376670 flash: 98000300000001:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20100322-170736.B0X.bin Finished, time used: 3 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
03-22-2010, 14:08 | #2279 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Bristol, UK
Member: 607045 Status: Offline Thanks Meter: 127 | Vodafone 340 successfuly flashed COM3 [VCP0] selected module v3.27 Device: Vodafone-340 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 15_M00_02_38_En_Fr_Es_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:E603:A001 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_40.BIN project-id: BM35A1.V2.22.M00.02.40, 00000000 code offset: 00000000 ffs offset/size [01]: 00B80000/00480000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00B80000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_40__system_log__00000000_20100322-175150.B0X.bin Area: Firmware flash: EC257E25082501:2AEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization detected: BM35A1X1 customization: BM35A1X1 flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_40__system_log__00000000_20100322-180450.B0X.bin Finished, time used: 13 min 47 sec Remove/Install battery now ! Thank u so much Infinity Team. |
The Following User Says Thank You to naveed7791 For This Useful Post: |
03-23-2010, 07:35 | #2280 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | LG-KG290 Unlocked By Infinity Code: COM4 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357456010044132 file saved: C:\Program Files\InfinityBox\LgA\eeprom_357456010044132_LG-KG290_20100323-120020.B1E.bin .............. Check flash Done Check space ... current eeprom imei: 357456010044132 ......................................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 42 sec Remove/Install battery now ! |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
