06-04-2010, 07:32 | #2836 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | c200 done module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:8203:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb detecting chip #01 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb detecting chip #02 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb detecting chip #03 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb detecting chip #01 in region #00... flash: 89890000040089:89890000000000 flash: Intel ST [def 0040x040000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FE4CE156.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S500_02_V1_0_005_090505.BIN_CB249E8F].rpl rom info detection finished ==================== New firmware detected (v.3.07, database date: unknown): GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S500_02_V1_0_005_090505.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: FE4CE156 rom info ver: 05 sw version: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S500_02_V1_0_005_090505.BIN project-id: FXD-S500_02_V1.0.005_090505, 8F9E24CB code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S500_02_V1_0_005_090505__ffs... file saved: C:\Documents and Settings\butt\Desktop\GINWAVE25_08A_GEMINI_PCB01_G PRS_MT6225_S00.FXD-S500_02_V1_0_005_090505__ffs_20100603-113344.B0E.bin flash: 89890000040089:89890000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89890000040089:89890000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S500_02_V1_0_005_090505__system_log_FE4CE156_CB249 E8F_20100603-113404.B0X.bin Finished, time used: 4 min 44 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to naveedbutt For This Useful Post: |
06-04-2010, 11:10 | #2837 (permalink) |
No Life Poster Join Date: Jan 2009 Location: aurangabad
Member: 937338 Status: Offline Sonork: 100.1651155 Thanks Meter: 114 | uninor zte r220 unlock sucsessfuly module v3.27 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B903:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: E-INDIA-UNINOR-P103D1V1.0.0B03 Version: E-INDIA-UNINOR-P103D1V1.0.0B03 44 byte(s) read imei: 35519103069051 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to VINOD399 For This Useful Post: |
06-05-2010, 06:51 | #2838 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v3.41 Action: reset settings ("format ffs") Model: LG-KG200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:5541:B1C4 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7330SA00-001-R1D Version: EP1 60 byte(s) read imei: 35282701406837 connection Ok building list... done items to clear: 221 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 197 of 221 items remains: 0 Finished, time used: 2 min 33 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
06-05-2010, 09:00 | #2839 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 38
Member: 171512 Status: Offline Thanks Meter: 1,034 | TOUCH SCREEN CALIBRATION PK COM16 [VCP0] selected module v3.09 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HUSCKY_S12_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_229_YYMMDD_CAM_MCPMCP_O__fullflash_2 0100603-121358.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:7C03:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: HUSCKY-S12_BXD_L6EN_229_081010_CAM030_MCP128+32_BT_FM Version: CKT25_GEMINI_HW 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 512 byte(s) read 223 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 10 sec Remove/Install battery now ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
06-05-2010, 17:57 | #2840 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot 305 unlock done!!! COM26 [VCP0] selected module v3.38 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F0A:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.DF4E2 FB2.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: DF4E2FB2 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 163 provider: 305X-2CRGTE1 customization: CP16CA12 customization: XP16CA12 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CA12 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35776903033017 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_DF4E2FB2_2FA8B35C_201 00605-174650.B0X.bin Finished, time used: 3 min 50 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
06-05-2010, 18:53 | #2841 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | ot 305 unlock done again!! COM26 [VCP0] selected module v3.38 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9E70:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.D4E63 822.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_2FA8B35C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: D4E63822 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 5CB3A82F code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 163 provider: 305X-2CRGTE1 customization: CP16CA12 customization: XP16CA12 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP16CA12 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35776903032624 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_D4E63822_2FA8B35C_201 00605-184959.B0X.bin Finished, time used: 4 min 14 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to fokal2008 For This Useful Post: |
06-06-2010, 11:13 | #2842 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.38 Device: Sony-Ericsson-K200i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AB003 software version: CXC1250831 version flex: CDA102773/54 imei: 35617701515363 Check hardware done Read data ... reading Sony-Ericsson-K200i_35617701515363_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_eeprom_calibration-1_20100606-030701.80E.bin reading Sony-Ericsson-K200i_35617701515363_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_eeprom_calibration-2_20100606-030705.80E.bin reading Sony-Ericsson-K200i_35617701515363_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701515363_ffs_20100606-030847.80E.bin Read data done Check data ... Check data done Write ... flash: 01227E22212200:46237300000000 Erase: ffs Write done Finished, time used: 2 min 29 sec Remove/Install battery now ! |
06-06-2010, 12:54 | #2843 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v3.14 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9403:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BV_C001_1_0836_MP_V6 Version: HEXING25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35701300212615 connection Ok building list... done items to clear: 133 warning: wrong packet cs items cleared: 133 of 133 warning: wrong packet cs building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! |
06-06-2010, 14:07 | #2844 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM8 [VCP0] selected module v3.14 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3E03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: L78D.V02.MU Version: XZTECH25_L78_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 157 warning: wrong packet cs warning: wrong packet cs items cleared: 157 of 157 items remains: 0 Finished, time used: 34 sec Remove/Install battery now ! |
06-07-2010, 09:36 | #2845 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Peshawar,Pakistan
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | Vodafone-340 unlock done by infinty... Vodafone-340 unlock done by infinty...interface spider man. here is logs... COM11 [VCP1] selected module v3.39 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0803:A007 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203095219 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to star1989 For This Useful Post: |
06-07-2010, 09:41 | #2846 (permalink) |
Member: 1251758 Status: Offline Sonork: 100.1614930 Thanks Meter: 94 | Vodafone-340 unlock done by infinty... Vodafone-340 unlock done by infinty...interface spider man. here is logs... COM11 [VCP1] selected module v3.39 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:0803:A007 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203095219 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! CLICK THANX BUTTON |
06-07-2010, 11:05 | #2847 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,473 | Uninor S212 UNLOCKING DONE BY INFINITY Code: COM5 [VCP1] selected module v3.41 Action: "sp-unlock" unlock method: smart fast Model: ZTE-S212 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:508D:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-IN-UNINOR-P109A12V1.0.1B01 Version: KONKA23C_08A_GEMINI_HW 80 byte(s) read imei: 35707403053957 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
06-07-2010, 14:11 | #2848 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 48
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v3.38 Action: "sp-unlock" Método de Destravamento: Inteligente Modelo: ZTE-X761 Verificando Dados. Aguarde... O Telefone Deverل Estar DESLIGADO! Pressione e SEGURE o Botمo de Ligar! 19200 autodetect Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FD03:0008 status: FF Connecting at 19200, wait... Solte o Botمo de Ligar! Telefone Encontrado. Aguarde... Hardware: MT6225,E05 Data: 2006.06.14 Versمo: 1.0 Versمo: X761_Z2_SF_BFFA108 Versمo: ZTEMT25_07A_HW_C 44 byte(s) read IMEI: 35787302421667 Conectado 157 byte(s) read Lendo Dados... Construindo Novos Dados... Escrevendo Dados... 145 byte(s) read Lendo Dados... 972 byte(s) read Construindo Novos Dados... Escrevendo Dados... verifying... Verificado Feito Finalizado. Tempo Gasto: 29 sec Remova/Recoloque a Bateria! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
06-07-2010, 14:22 | #2849 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v3.38 Dispositivo: Vodafone-541 Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:B203:A009 status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 98006F00000004:09EA0000000000 Flash AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.C F6183EC.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: CF6183EC rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification Versمo: 17C provider: 708X-2FVDES1 Customizaçمo CN17FE82 Customizaçمo XN17FE82 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... Erro: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected Customizaçمo XN17FE82 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected Customizaçمo XN17FE82 customization name adjusted Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 98006F00000004:09EA0000000000 Flash 98006F00000004:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: 35908103069001 Flash 98006F00000004:09EA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 98006F00000004:09EA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_CF6183EC_064A906B_20100607-102123.B0X.bin Finalizado. Tempo Gasto: 5 min 48 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-07-2010, 14:32 | #2850 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | COM3 [VCP0] selected Mَdulo v3.38 Dispositivo: Vodafone-541 Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:CD03:A000 status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 01227E22302200:09EA0000000000 Flash Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Arquivos de programas\InfinityBox\MModule\backup_security\id.4 3959B45.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_741CA52F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 43959B45 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 2FA51C74 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification Versمo: 17N provider: 708X-2GVDES1 Customizaçمo CN17FE92 Customizaçمo XN17FE92 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished Estado do Travamento do Cartمo SIM: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... Erro: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 01227E22302200:09EA0000000000 Flash 01227E22302200:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected Customizaçمo XN17FE92 customization name adjusted Flash 01227E22302200:09EA0000000000 Flash 01227E22302200:09EA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 01227E22302200:09EA0000000000 Flash 01227E22302200:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected Customizaçمo XN17FE92 customization name adjusted Flash 01227E22302200:09EA0000000000 Flash 01227E22302200:09EA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 01227E22302200:09EA0000000000 Flash 01227E22302200:09EA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: 35908103414294 Flash 01227E22302200:09EA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 01227E22302200:09EA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Voda fone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_43959B45_741CA52F_20100607-103049.B0X.bin Finalizado. Tempo Gasto: 5 min 16 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
