Old 06-07-2010, 17:32   #2851 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Vodafone 541 hanna montana
COM9 [VCP0] selected
module v3.40
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:8403:A004
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Programas\InfinityBox\MModule\backup_security\i d.4CC68523.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_741CA52F].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 4CC68523
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, 2FA51C74
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17O
provider: 708X-2GVDPT2
customization: CN17EP91
customization: XN17EP91
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35400703393188
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Programas\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_4CC68523_741CA52F_20100607-172919.B0X.bin
Finished, time used: 4 min 12 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to DUSKnenixs For This Useful Post:
Old 06-07-2010, 19:54   #2852 (permalink)
top man's Avatar
Member: 617412
Thanks Meter: 177
Huawei g600 successfully unlock
COM66 [VCP0] selected
module v3.40
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G6600
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E5.2PT01V01.04
Version: BYD35_09A_PMWY_HW
82 byte(s) read
imei: 35751003044311
connection Ok
189 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 17 sec
INFINITY TEAM NICE WORK .UNDER TEST HUAWEI G600 SUCCESSFULLY UNLOCK.
The Following 2 Users Say Thank You to top man For This Useful Post:
Old 06-07-2010, 19:56   #2853 (permalink)
top man's Avatar
Member: 617412
Thanks Meter: 177
Huawei g6600 successfully unlock
module v3.40
Action: "sp-unlock"
Model: Huawei-G6600
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
82 byte(s) read
connection Ok
189 byte(s) read
reading data...
reading data #2...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
SRRY TO EVERYBODY G6600 HUAWEI NOT G600
GOODWORK INFINITY TEAM
UNDERTEST SUCCESSFULLY UNLOCK HUAWEI G6600
Old 06-08-2010, 10:22   #2854 (permalink)
fasttechjlm's Avatar
Member: 268415
Thanks Meter: 57
OT-222 unlocked
COM7 [VCP0] selected
module v3.38
Device: Alcatel-222X, 222A
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:6425:A00C
status: 01
Boot Done
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
921600
Set baud Done
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: 2nd [standard] generation
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN
project-id: MAUI.08A.W08.36.SP1.V28, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
version: 167
provider: 222X-2CRGGB1
customization: CO16CL01
customization: XO16CL01
TCL-ID is present
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: 35591603257180
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-222X,222A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20100608-141847.B0X.bin
Finished, time used: 4 min 57 sec
The Following User Says Thank You to fasttechjlm For This Useful Post:
Old 06-08-2010, 10:46   #2855 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
ZTE N281 CSKA OPERATOR GLOBUL BULGARIA SUCCESSFULL UNLOCKED
COM3 [VCP0] selected
module v3.37
Action: "sp-unlock"
Model: ZTE-N281
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
Version: EB-BG-GLOBUL9-P107A3V1.0.2B01
83 byte(s) read
imei: 35769203226197
connection Ok
189 byte(s) read
reading data...
reading data #2...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 21 sec
The Following 2 Users Say Thank You to delchoni For This Useful Post:
Old 06-08-2010, 10:54   #2856 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 218
Fly SL500i successfully repaired restart problem.
module v3.41
Action: reset settings ("format ffs")
Model: Fly-SL500i
19200 autodetect
Initializing [6219:8B02:8B01]...
CPU: MT6219
chip: 0031:5DC1:E65E
status: FF
detected CPU: MT6226MA
Hardware: MT6219B,E02
Date: 2005.04.12
Version: 1.0
Version: SL900A.05C.W06.08.MP.V64
Version: ESL6227_05C_HW
60 byte(s) read
imei: 35933500071333
connection Ok
building list...
done
items to clear: 217
items cleared: 135 of 217
building list...
done
items remains: 0
Finished, time used: 6 min 34 sec
The Following 2 Users Say Thank You to shuric For This Useful Post:
Old 06-08-2010, 11:56   #2857 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM22 [VCP0] selected
module v3.14
Device: Autodetect 6205-6239 NOR
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001203:0002
status: FF
Boot Done
flash: 98000300000001:18A59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20100608-035307.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 8 sec
The Following 2 Users Say Thank You to cel_phon For This Useful Post:
Old 06-08-2010, 13:04   #2858 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
<< Alcatel OT-106X unlocked oke with infinity box >>
Alcatel ot-106x succesfull unlocked with infinty box
#Cable = ALC-120
#Mmodule V3.41
http://www.youtube.com/watch?v=zUaEdWgtCUQ
Br Mounir
The Following User Says Thank You to Mounir For This Useful Post:
Old 06-08-2010, 16:23   #2859 (permalink)
BaNgErS's Avatar
Member: 553262
Thanks Meter: 297
Arrow Huawei G7002 on O2-UK gone in 11 seconds...
Here is how...
1. Connect phone to Infinity Box with Alcatel C701 cable (v3 system connector, same as all Alcatel MTK cpu models)
2. Choose correct make Huawei and model G7002
3. In service tab, click SP-unlock
4. Enjoy unlocked phone
PS FIRST AND ONLY INFINITY SUPPORTS THIS MODEL SINCE FEW MONTHS NOW
Here is log...
COM10 [VCP1] selected
module v3.41
Action: "sp-unlock"
Model: Huawei-G7002
19200 autodetect
CPU: MT6225
chip: 0001:A303:0000
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: G5.2EG01V02.11
Version: P2
67 byte(s) read
imei: 35645603069724
connection Ok
178 byte(s) read
reading data...
reading data #2...
writing data...
166 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
The Following User Says Thank You to BaNgErS For This Useful Post:
Old 06-08-2010, 19:21   #2860 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
Mَdulo v3.38
Action: "sp-unlock"
Método de Destravamento: Inteligente
Modelo: Huawei-G7002
Verificando Dados. Aguarde...
O Telefone Deverل Estar DESLIGADO!
Pressione e SEGURE o Botمo de Ligar!
19200 autodetect
Inicializando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:410F:0002
status: FF
Solte o Botمo de Ligar!
Telefone Encontrado. Aguarde...
Data: 2006.06.14
Versمo: 1.0
Versمo: G5.2PY01V02.06
Versمo: P2
67 byte(s) read
Aviso: wrong packet cs
IMEI: 35645603048113
Conectado
178 byte(s) read
Lendo Dados...
Construindo Novos Dados...
Escrevendo Dados...
166 byte(s) read
Lendo Dados...
972 byte(s) read
Escrevendo Dados...
verifying...
Verificado
Feito
Finalizado. Tempo Gasto: 9 sec
Remova/Recoloque a Bateria!
The Following 2 Users Say Thank You to Alexandro Monte For This Useful Post:
Old 06-08-2010, 19:29   #2861 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,204
OT363A Flash OK!!
==== [06-06-2010 15:23:10] ====
COM26 [VCP0] selected
module  v3.38
Device: Alcatel-363X, 363A
Action: write flash
"smart write" active
"format ffs" active
write: Firmware
363A-2AAVDO3-26B_XI26NH34_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9_2009-07-14_En_Fr_Es_It_Pt.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:BB89:A00C
status: 01
Boot Done
flash: 98000300000001:2BEA0000000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.FB7767E0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_481CB0D4].rpl
TCL-ID detection...
device-id: FB7767E0
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN
project-id: MAUI.08A.W08.36.SP1.V9, D4B01C48
ffs offset/size [01]: 00C00000/00400000
version: 26C
provider: 363A-2AEECL3
customization: CI26NL30
customization: XI26NL30
TCL-ID is present
ffs/eeprom address assigned: 00C00000
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
original imei: 01184600081983
====>  Write ...
usb bootloader (file) is absent
startup code area #1 calculation...
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcatel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_FB7767E0_481CB0D4_20100606-152423.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
relocation table detected
name table[00] #7000000 detected
customization: CI26NH34
customization detected: CI26NH34
done
Write Done
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcatel-363X,363A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_FB7767E0_481CB0D4_20100606-153416.B0X.bin
Finished, time used: 10 min 48 sec
The Following 2 Users Say Thank You to 69eyes For This Useful Post:
Old 06-08-2010, 19:32   #2862 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,204
THIS Z250i UNLOCK DONE ONLY WITH INFINITY BOX!!
==== log: [06-06-2010 12:10:59] ====
module  v1.38
Device: Sony-Ericsson-Z250i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 20881CFFFFFFFF:20881C00000000
flash: ST Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb
software version: 1630-000
software version: ABU-3-
Check hardware done
Read data ...
reading Sony-Ericsson-Z250i_eeprom_calibration-1...
file saved: C:\Archivos de programa\InfinityBox\HModule\Sony-Ericsson-Z250i_eeprom_calibration-1_20100606-121220.80E.bin
Read data done
Check data ...
warning: Probably wrong model selected,
Do you want to continue ?
model selection confirmed by user
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 1 min 55 sec
The Following User Says Thank You to 69eyes For This Useful Post:
Old 06-08-2010, 21:10   #2863 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
Thumbs up Unlock Vodefone 541 okey
COM21 [VCP0] selected
module v3.03
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:2603:A004
status: 01
Boot Done
flash: 98006F00000003:09EA0000000000
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Programme\InfinityBox\MModule\backup_security\i d.4FA182AD.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
TCL-ID detection...
device-id: 4FA182AD
rom info ver: 07
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
version: 17B
provider: 708X-2EVDDE1
customization: CN17FB75
customization: XN17FB75
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
........error: no any expected answer
done
original imei: 00000000000000
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Programme\InfinityBox\MModule\backup_security\V odafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_4FA182AD_E8F450A0_20100608-215618.B0X.bin
Finished, time used: 4 min 23 sec
The Following User Says Thank You to Nurettin Duman For This Useful Post:
Old 06-09-2010, 05:50   #2864 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v3.14
Model: Autodetect 6205-6239 NOR
error: boot initialization step #3 failed:
19200 autodetect
CPU: MT6223
high speed boot On
chip: 0011:86C1:000C
status: FF
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: PN-SC_CN_LLNUMLD_209_YYMMDD_CAM_MCPMCP_O
Version: CKT23C_08A_GEMINI_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35410100056239
connection Ok
building list...
done
items to clear: 150
warning: wrong packet cs
items cleared: 150 of 150
building list...
done
items remains: 0
Finished, time used: 40 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 06-09-2010, 14:58   #2865 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM12 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:C603:0001
status: FF
Boot Done
flash: 98000300000001:18E59F00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.DB7BAA98.[5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN_7F80B444].rpl
New firmware detected (v.3.07, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: DB7BAA98
rom info ver: 04
sw version: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2.BIN
project-id: N96_P11_TOSHIBA_S5LCD_V1.0.2, 44B4807F
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
standard ffs/eeprom offset detected: 00E00000
ffs/eeprom chip: 00
reading: 5800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_ S5LCD_V1_0_2__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\5800_ABROAD_PCB01 _GPRS_MT6225_S00.N96_P11_TOSHIBA_S5LCD_V1_0_2__ffs _20100609-065549.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\5 800_ABROAD_PCB01_GPRS_MT6225_S00.N96_P11_TOSHIBA_S 5LCD_V1_0_2__system_log_DB7BAA98_7F80B444_20100609-065616.B0X.bin
Finished, time used: 2 min 20 sec
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.54385 seconds with 10 queries
