06-09-2010, 16:04 | #2866 (permalink) |
Banned Join Date: Sep 2009 Location: PM P L Z Age: 37
Member: 1116719 Status: Offline Thanks Meter: 542 | module v1.77 Device: ZTE-125 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100606-010447.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100606-010448.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100606-010449.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20100606-010454.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area repair write error [004D0000:0800]... Ok repair write error [004E2000:0800]... Ok repair write error [004E3800:0800]... Ok repair write error [004E9000:0800]... Ok repair write error [004EC000:0800]... Ok Write Done Finished, time used: 1 min 51 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to >>.123.<< For This Useful Post: |
06-09-2010, 17:37 | #2867 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | Other nokia 1661 unlock full whith infinity Port COM1 open OK Connect phone on selected interface... Wait... Phone found... Phone in Local mode Phone connected - Ok IMEI 011886000473065 Read Lock Info Locked to T-Mobile;U.S.A. Unlocking... Unlock - Ok Port COM1 close |
The Following 2 Users Say Thank You to thewolverine For This Useful Post: |
06-09-2010, 20:55 | #2868 (permalink) |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Sonyericsson k200i flash SONYERICSSON K200I FLASH Code: COM6 [VCP0] selected module v1.34 Device: Sony-Ericsson-K200i "advanced chip detection" active Action: flash write "smart write" active "format ffs" active Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AA008 software version: CXC1250827 version flex: CDA102772/1 imei: 35617701161764 Check hardware done Read data ... reading Sony-Ericsson-K200i_35617701161764_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701161764_eeprom_calibration-1_20100609-224309.80E.bin reading Sony-Ericsson-K200i_35617701161764_eeprom_calibration-2... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701161764_eeprom_calibration-2_20100609-224313.80E.bin reading Sony-Ericsson-K200i_35617701161764_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-K200i_35617701161764_ffs_20100609-224455.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware flash: 01227E22212200:46237300000000 Write: Firmware Area: Flex flash: 01227E22212200:46237300000000 Write: Flex flash: 01227E22212200:46237300000000 Erase: ffs ffs format done Write done Finished, time used: 161 sec Remove/Install battery now ! |
The Following User Says Thank You to sajidashraf For This Useful Post: |
06-09-2010, 21:46 | #2869 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,226 | Quote:
06-10-2010, 08:18 | #2870 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM24 [VCP0] selected module v3.14 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:8FD3:C0AA status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: D421_V1.00 Version: D421_05C_HW detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... done 208 byte(s) read 156 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1258 Finished, time used: 19 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
06-10-2010, 08:22 | #2871 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.72 Device: LG-KG370 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: .00 ULC2GL KG370 P16 ARB V10d XXX-XX OCT 22 2007 +0 , Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-static_20100610-002128.B1E.bin loading data... data loaded imei: 35297702325287000 reading eeprom-security_35297702325287000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-security_35297702325287000_20100610-002129.B1E.bin reading eeprom-complete_35297702325287000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG370_eeprom-complete_35297702325287000_20100610-002130.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
06-10-2010, 08:25 | #2872 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | LG Kg270 Blinking Solve in 1 Minute!!! Great Infinity ==== log: [6/10/2010 12:20:07 PM] ==== COM24 [VCP0] selected module v1.73 Device: LG-KG270 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20100610-122050.B1E.bin loading data... data loaded imei: 00000000000000000 reading eeprom-security_00000000000000000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_00000000000000000_20100610-122050.B1E.bin reading eeprom-complete_00000000000000000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_00000000000000000_20100610-122052.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 43 sec Remove/Install battery now ! Code: Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KG270P16-92-V10e-XXX-XX-JUN 20 2007+0 original imei: 00000000000000000 new imei: 35588954741477 error: imei verification failed, try again. Done Finished |
06-10-2010, 08:41 | #2873 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | IMEI Problem solved by eeprom repair ==== log: [6/10/2010 12:31:55 PM] ==== COM24 [VCP0] selected module v1.73 Device: LG-KG270 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20100610-123233.B1E.bin loading data... data loaded imei: 00000000000000000 reading eeprom-security_00000000000000000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_00000000000000000_20100610-123233.B1E.bin reading eeprom-complete_00000000000000000... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_00000000000000000_20100610-123234.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 43 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KG270P16-92-V10e-XXX-XX-JUN 20 2007+0 imei: 35558801354220900 Done Finished ==== log: [6/10/2010 12:33:03 PM] ==== COM24 [VCP0] selected module v1.73 Device: LG-KG270 Checking data, wait... Action: "sp-unlock" direct unlock method #2 (Airtel etc.) Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20100610-123317.B1E.bin loading data... data loaded imei: 35558801354220900 reading eeprom-security_35558801354220900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35558801354220900_20100610-123317.B1E.bin reading eeprom-complete_35558801354220900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35558801354220900_20100610-123319.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-security Writing: eeprom-security probably you need to restore original imei after unlock process Write Done Finished, time used: 13 sec Remove/Install battery now ! Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei original imei: 35558801354220900 new imei: 35558801358854 error: imei verification failed, try again. Done Finished |
06-10-2010, 08:58 | #2874 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks Meter: 392 | Vodafone 225 Unlock !!!! COM4 [VCP0] selected module v1.78 Device: Vodafone-225 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: -SA-P108A2 SST V1.0.0B11 Jul 18 2008 12 29 51 VDF-P108A2B07-RoFr Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-static_20100610-132328.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-security_20100610-132329.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20100610-132335.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-225_lock-area_20100610-132348.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 51 sec Remove/Install battery now ! thank U !!! |
The Following 2 Users Say Thank You to nishue For This Useful Post: |
06-10-2010, 12:38 | #2875 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM12 [VCP1] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7D03:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: A03_BHT_DSIM_ST_V3 Version: GOLDDRAGON25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35994802017818 connection Ok building list... done items to clear: 164 warning: wrong packet cs warning: wrong packet cs items cleared: 164 of 164 building list... done items remains: 0 Finished, time used: 45 sec Remove/Install battery now ! |
06-10-2010, 13:33 | #2876 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | alcatel ot v670 unlock done!! COM26 [VCP1] selected module v3.41 Device: Alcatel-V670X, V670A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A03:8A02]... CPU: MT6226 chip: 0031:8E24:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.56AE3 D73.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_D6AAA1C8].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 56AE3D73 rom info ver: 05 sw version: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN project-id: MAUI.06A.W06.52.SP1.V24, C8A1AAD6 code offset: 00000000 ffs offset/size [01]: 01000000/01000000 TCL-ID identification version: 190 provider: V670X-2ARGFR2 customization: CC19DV21 customization: XC19DV21 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01000000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_Communication_Inc_C7_Series area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XC19DV21 customization name adjusted flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35305102097772 flash: 01227E22302200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-V670X,V670A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24__system_log_56AE3D73_D6AAA1C8_20 100610-133009.B0X.bin Finished, time used: 5 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
06-10-2010, 16:58 | #2877 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Alcatel ot-303a call down solved whith infinity COM1 [Serial0] selected module v3.41 Device: Alcatel-303X, 303A Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:B0BC:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.A2 2FD4B0.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN_6483DA11].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A22FD4B0 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN project-id: MAUI.08A.W08.36.SP1.V9, 11DA8364 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16G provider: 303A-2DRGDO3 customization: CI16NQ10 customization: XI16NQ10 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Alcatel-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Alcatel-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__ffs_20100609-235603.B0E.bin original imei: 01180200532237 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-303X,303A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V9__system_log_A22FD4B0_6483DA11_2010 0609-235638.B0X.bin Finished, time used: 8 min 20 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
06-10-2010, 17:09 | #2878 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Lg kp115a phone frezze solved whith infinity box [COM1 [Serial0] selected module v1.39 Device: LG-KP115 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 0114450033------- file saved: C:\Archivos de programa\InfinityBox\LGA\eeprom_011445003325960_LG-KP115_20100610-000224.B1E.bin .... reading _eeprom-ffs_0114450033------... file saved: C:\Archivos de programa\InfinityBox\LGA\_eeprom-ffs_011445003325960_LG-KP115_20100610-000637.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 292 sec Remove/Install battery now ! |
06-10-2010, 19:00 | #2879 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | N98+ successufly format with infinity Code: COM3 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F80F:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SINOMOTECH25_GEMINI_PCB01_GPRS_MT6225_S00.HBM1722_8_12_1_0T02M1222_M551S.BIN project-id: HBM1722.8.12.1.0T02M1222_M551S, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SINOMOTECH25_GEMINI_PCB01_GPRS_MT6225_S00.HBM1722_8_12_1_0T02M1222_M551S__ffs... file saved: C:\Documents and Settings\badero\Bureau\SINOMOTECH25_GEMINI_PCB01_GPRS_MT6225_S00.HBM1722_8_12_1_0T02M1222_M551S__ffs_20100610-175219.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to Agadir__Gsm For This Useful Post: |
06-10-2010, 19:24 | #2880 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Alcatel ot-708a unlock done COM1 [Serial0] selected module v3.41 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5403:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.E0 54DCE6.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8DF3C2F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E054DCE6 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 2F3CDFE8 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 16W provider: 708A-2CRGDO3 customization: CN16NQ30 customization: XN16NQ30 TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... max address is too big, should be recalculated: 00006F50->00006C54 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16NQ30 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN16NQ30 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01194600742541 flash: 01227E22302200:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_E054DCE6_E8DF3C2F_20 100610-022255.B0X.bin Finished, time used: 4 min 10 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
