![]() | #2881 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | module v1.39 Device: LG-KP135 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 353955022193955 file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955022193955_LG-KP135_20100610-224808.B1E.bin .... reading _eeprom-ffs_353955022193955... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_353955022193955_LG-KP135_20100610-224916.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 121 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
![]() | #2882 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | ZTE A661 unlock done COM1 [Serial0] selected module v3.41 Action: "sp-unlock" unlock method: smart fast Model: ZTE-A661 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:AE03:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: SE-DM-CLARO8-P103E1V1.0.0B06 Version: SE-DM-CLARO8-P103E1V1.0.0B06 44 byte(s) read imei: 35480303065584 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to thewolverine For This Useful Post: |
![]() | #2883 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2008 Location: brazil Age: 48
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 ![]() | COM3 [VCP0] selected Mَdulo v3.38 Action: "sp-unlock" Método de Destravamento: Inteligente Modelo: Vodafone-340 Verificando Dados. Aguarde... O Telefone Deverل Estar DESLIGADO! Pressione e SEGURE o Botمo de Ligar! 19200 autodetect Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001 ![]() status: 01 Connecting at 19200, wait... Solte o Botمo de Ligar! Telefone Encontrado. Aguarde... Hardware: MT6225,E05 Data: 2006.06.14 Versمo: 1.0 Versمo: BM35A1.V2.22.M00.02.42 Versمo: FOXLINK25_08B_HW 81 byte(s) read IMEI: 35592203224438 Conectado 186 byte(s) read Lendo Dados... Construindo Novos Dados... Escrevendo Dados... 174 byte(s) read Lendo Dados... 972 byte(s) read Construindo Novos Dados... Escrevendo Dados... verifying... Verificado Feito Finalizado. Tempo Gasto: 36 sec Remova/Recoloque a Bateria! |
The Following User Says Thank You to Alexandro Monte For This Useful Post: |
![]() | #2884 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 ![]() | COM3 [VCP0] selected Mَdulo v3.38 Action: "sp-unlock" Método de Destravamento: Inteligente Modelo: Vodafone-340 Verificando Dados. Aguarde... O Telefone Deverل Estar DESLIGADO! Pressione e SEGURE o Botمo de Ligar! 19200 autodetect Inicializando [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7603:A00E status: 01 Connecting at 19200, wait... Solte o Botمo de Ligar! Telefone Encontrado. Aguarde... Hardware: MT6225,E05 Data: 2006.06.14 Versمo: 1.0 Versمo: BM35A1.V2.22.M00.02.42 Versمo: FOXLINK25_08B_HW 81 byte(s) read IMEI: 35592203224449 Conectado 186 byte(s) read Lendo Dados... reading data #2... Construindo Novos Dados... Escrevendo Dados... 174 byte(s) read Lendo Dados... 972 byte(s) read Construindo Novos Dados... Escrevendo Dados... verifying... Verificado Feito Finalizado. Tempo Gasto: 14 sec Remova/Recoloque a Bateria! |
The Following 2 Users Say Thank You to Alexandro Monte For This Useful Post: |
![]() | #2885 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Huawei T158 unlock done COM1 [Serial0] selected module v1.78 Device: Huawei-T158 Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-static_20100611-023515.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-security_20100611-023516.B1E.bin reading eeprom-complete... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_eeprom-complete_20100611-023523.B1E.bin reading additional data... file saved: C:\Archivos de programa\InfinityBox\Pana01\Huawei-T158_lock-area_20100611-023543.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 1 min 7 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to thewolverine For This Useful Post: |
![]() | #2886 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | ZTE R220 unlock done COM1 [Serial0] selected module v3.41 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FA03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: SE-DM-CLARO8-P103D1FV1.0.0B03 Version: SE-DM-CLARO8-P103D1FV1.0.0B03 44 byte(s) read imei: 35519103052390 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to thewolverine For This Useful Post: |
![]() | #2887 (permalink) |
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 ![]() | COM3 [VCP0] selected Mَdulo v3.38 Dispositivo: Alcatel-S320X Verificando Dados. Aguarde... Detecçمo Avançada da Flash Habilitada Action: rebuild security area ====> Boot ... Pressione e SEGURE o Botمo de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1AD7:A00C status: 01 Tamanho do Pacote de Inicializaçمo: 0400 Solte o Botمo de Ligar! Boot Done ====> Inicializar ... detecting chip #00 in region #00... Flash 98004900000002:2AEA0000000000 Flash Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 Nْmero do Chip da Flash/Regiمo Detectada: 01/01 Inicializar Done ====> Determinar Velocidade ... 115200 Determinar Velocidade Done ====> Inicializar Cَdigo de Boot ... Inicializar Cَdigo de Boot Done ====> Verificar Integridade do Firmware ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification Versمo: 16F provider: S320X-2ATLES1 Customizaçمo CH16CF1F Customizaçمo XH16CF1F TCL-ID identification done rom info structure: 2nd [standard] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished Estado do Travamento do Cartمo SIM: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected Customizaçمo XH16CF1F customization name adjusted Flash 98004900000002:2AEA0000000000 Flash 98004900000002:2AEA0000000000 Escrever security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... Feito Flash 98004900000002:2AEA0000000000 Flash 98004900000002:2AEA0000000000 Escrever security area (sec info, hash) security area (sec info, hash) calculation done Verificar Integridade do Firmware Done ====> Verificar Conteْdo do Firmware ... Verificar Conteْdo do Firmware Done ====> Salvar Cَpia de Dados ... IMEI Original: 35239502336638 Flash 98004900000002:2AEA0000000000 Salvar Cَpia de Dados Done ====> Programar Dados Necessلrios ... Programar Dados Necessلrios Done ====> Operaçمo Especial ... Operaçمo Especial Done ====> Escrever ... Escrever Done ====> Finalizaçمo ... FFS formatting... Flash 98004900000002:2AEA0000000000 Finalizaçمo Done Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Alca tel-S320X_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07 _36_SP1_V20__system_log__00000000_20100611-172157.B0X.bin Finalizado. Tempo Gasto: 3 min 50 sec Remova/Recoloque a Bateria! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 3 Users Say Thank You to Alexandro Monte For This Useful Post: |
![]() | #2888 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Alcatel ot-600a unlock done COM1 [Serial0] selected module v3.41 Device: Alcatel-600X, 600A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3303:A009 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:08EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.DB 30AB8E.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: DB30AB8E rom info ver: 05 sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4 code offset: 00020000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 266 provider: 600A-2DAVDO3 customization: CJ26NU1C customization: XJ26NU1C TCL-ID identification done rom info structure: 2nd [enhanced] generation TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is invalid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRD_COMMUNICATION_B82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26NU1C customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XJ26NU1C customization name adjusted flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:08EA0000000000 flash: 98000300000001:08EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01176200204070 flash: 98000300000001:08EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:08EA0000000000 Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_DB30AB8E_C4B7397C_2010 0611-051309.B0X.bin Finished, time used: 4 min 17 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
![]() | #2889 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM16 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3803:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M110_618_080928_PER_ABR_V1.1.6 Version: LONGYU25_GEMINI_HW detecting structure #2... 4 5 11 done 67 byte(s) read imei: 35959900004424 connection Ok building list... done items to clear: 168 warning: wrong packet cs warning: wrong packet cs items cleared: 168 of 168 building list... done items remains: 0 Finished, time used: 24 sec Remove/Install battery now ! |
![]() | #2890 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM16 [VCP0] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:C203:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6C0AC57B.[M780_PCB01_GPRS_MT6225_S00.M780_FGVTRAT_7N_9325_2S ET_V02.BIN_39BC3579].rpl rom info detection finished device-id: 6C0AC57B rom info ver: 04 sw version: M780_PCB01_GPRS_MT6225_S00.M780_FGVTRAT_7N_9325_2S ET_V02.BIN project-id: M780_FGVTRAT_7N_9325_2SET_V02, 7935BC39 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: M780_PCB01_GPRS_MT6225_S00.M780_FGVTRAT_7N_9325_2S ET_V02__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\M780_PCB01_GPRS_M T6225_S00.M780_FGVTRAT_7N_9325_2SET_V02__ffs_20100 611-234903.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 780_PCB01_GPRS_MT6225_S00.M780_FGVTRAT_7N_9325_2SE T_V02__system_log_6C0AC57B_39BC3579_20100611-234921.B0X.bin Finished, time used: 2 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
![]() | #2891 (permalink) |
Registered User ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM24 [VCP0] selected module v3.14 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9803:0005 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.08B.W08.52.MP.V2.090905 Version: F25_08B_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35893703107136 connection Ok warning: wrong packet cs warning: wrong packet cs building list... done items to clear: 136 warning: wrong packet cs warning: wrong packet cs items cleared: 136 of 136 building list... done items remains: 2 Finished, time used: 33 sec Remove/Install battery now ! |
The Following User Says Thank You to Shakeel_pattoki For This Useful Post: |
![]() | #2892 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 39
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | vodafone 340 unlock done COM12 [VCP0] selected module v3.41 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7E03:A00C status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.34 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203018484 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to kushol For This Useful Post: |
![]() | #2893 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | COM24 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B103:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #04 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #05 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #06 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #07 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25062501:18E59F00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4AD58925.[GINWAVE25_6416_06B_PCB01_GSM_MT6225_S00.FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1_1_12_080509.BIN_57580815].rpl rom info detection finished device-id: 4AD58925 rom info ver: 04 sw version: GINWAVE25_6416_06B_PCB01_GSM_MT6225_S00.FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1_1_12_080509.BIN project-id: FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1.1.12_080509, 15085857 code offset: 00000000 ffs offset/size [01]: 00700000/00100000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00700000 standard ffs/eeprom offset confirmed: 00700000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00700000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE25_6416_06B_PCB01_GSM_MT6225_S00.FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1_1_12_080509__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_6416_06 B_PCB01_GSM_MT6225_S00.FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1_1_12_080509__ffs_20100612-132734.B0E.bin flash: EC257E25062501:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC257E25062501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_6416_06B_PCB01_GSM_MT6225_S00.FXD-T33-ML_MR102_004_5S01-GC-C03-RFMD_V1_1_12_080509__system_log_4AD58925_57580815_ 20100612-132746.B0X.bin Finished, time used: 7 min 24 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
![]() | #2894 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks Meter: 151 | LG KG110 unlocked succssfully.... COM120 [VCP1] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 3xxxxxxxxxxxxxx current otp imei: xxxxxxxxxxxxxxx file saved: C:\Program Files\InfinityBox\LGA\eeprom_3559xxxxxxxxxx_LG-KG110_20100612-185707.B1E.bin ........ version: 404-XXV20c91KG110P40FL Check flash Done Check space ... current eeprom imei: 3xxxxxxxxxxxxxxxxxx ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! |
The Following User Says Thank You to saif@cellplus For This Useful Post: |
![]() | #2895 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | lg kg 130 done COM3 [VCP0] selected module v1.39 Device: LG-KG130 Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 355311018201410 current otp imei: 355311018201410 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311018201410_LG-KG130_20100612-130621.B1E.bin ....... version: XXX-XXV10fEURKG130P40 reading XXX-XXV10fEURKG130P40_eeprom-ffs_355311018201410... file saved: C:\Program Files\InfinityBox\LGA\XXX-XXV10fEURKG130P40_eeprom-ffs_355311018201410_LG-KG130_20100612-131214.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 430 sec Remove/Install battery now ! |
The Following User Says Thank You to naveedbutt For This Useful Post: |
