Old 06-15-2010, 15:58   #2911 (permalink)
Member: 633231
Thanks Meter: 666
OT-600a Not simcard inserted problem solved
COM1 [Serial0] selected
module v3.41
Device: Alcatel-600X, 600A
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:2703:A005
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:08EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.4C 8F8491.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 4C8F8491
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 7C39B7C4
code offset: 00020000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 266
provider: 600A-2DAVDO3
customization: CJ26NU1C
customization: XJ26NU1C
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Alcatel-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__ffs...
file saved: C:\Archivos de programa\InfinityBox\MModule\Alcatel-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__ffs_20100614-225200.B0E.bin
original imei: 01176200074837
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_4C8F8491_C4B7397C_2010 0614-225710.B0X.bin
Finished, time used: 13 min 27 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to thewolverine For This Useful Post:
Old 06-15-2010, 16:17   #2912 (permalink)
Member: 633231
Thanks Meter: 666
Verykool i305 security area repair done after dead for unlock
module v3.44
Device: Verykool-i305
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:94D2:000C
status: FF
Boot Done
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.44, database date: 14.06.2010):
I305FM_SAD_PCB01_GPRS_MT6223P_S00.KAAI305FM_SAD_SP _EN_FR_2_04_406.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 05
sw version: I305FM_SAD_PCB01_GPRS_MT6223P_S00.KAAI305FM_SAD_SP _EN_FR_2_04_406.BIN
project-id: KAAI305FM_SAD_Sp_En_Fr_2.04.406, 00000000
code offset: 00000000
ffs offset/size [01]: 00A00000/00600000
TCL-ID is absent
ffs/eeprom address assigned: 00A00000
sec info (fast) detection...
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 1 min 47 sec
Old 06-15-2010, 16:29   #2913 (permalink)
Member: 633231
Thanks Meter: 666
LG kp202 unlock done
module v1.39
Device: LG-KP202
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 354912014044729
current otp imei: 354912014044729
file saved: C:\Archivos de programa\InfinityBox\LGA\eeprom_354912014044729_LG-KP202_20100614-232542.B1E.bin
version: ure----LGELECKP20204d
Check flash Done
Check space ...
finalization done
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 44 sec
Old 06-15-2010, 17:15   #2914 (permalink)
Member: 633231
Thanks Meter: 666
Ot-600a phone freeze solved
module v3.44
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:6903:A00F
status: 01
Boot Done
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.38 586CDF.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C4B7397C].rpl
TCL-ID detection...
device-id: 38586CDF
rom info ver: 05
version: 266
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
file saved: C:\Archivos de programa\InfinityBox\MModule\Alcatel-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__ffs_20100615-001028.B0E.bin
original imei: FFFFFFFFFFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-600X,600A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B _W07_28_SP1_V38__system_log_38586CDF_C4B7397C_2010 0615-001343.B0X.bin
Finished, time used: 12 min 19 sec
Old 06-15-2010, 20:28   #2915 (permalink)
Member: 523148
Thanks Meter: 41
Coral 255 unlock 100%
COM1 [VCP0] selected
module v3.44
Action: "sp-unlock"
unlock method: smart fast
Model: Coral-255
19200 autodetect
CPU: MT6223
chip: 0011:7351:000C
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: SFE-DIG8-P109A14V1.0.0B04
Version: ZTENJ23D_09A_HW
86 byte(s) read
imei: 35295904001227
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 13 sec
The Following 2 Users Say Thank You to felo28 For This Useful Post:
Old 06-15-2010, 21:23   #2916 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
sucessfully convert pantech
today i have sucessfully convert pantech pg-1410(850/1900) to pg-1400(900/1800)
steps are here
1)flash the phone with 1400
2)unlock the phone with 1400
3)make filter modification like c139 filter
The Following 2 Users Say Thank You to emush For This Useful Post:
Old 06-15-2010, 23:19   #2917 (permalink)
Member: 679135
Sonork: 100.1606448
Thanks Meter: 436
Imei repair Louis ******* A502
COM3 [VCP1] selected
module  v3.13
Device: Autodetect 6205-6227 NOR
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 358903036962358
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:2303:0002
status: FF
Boot Done
flash: EC257E25082501:18E59F00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
TCL-ID is absent
New firmware detected (v.3.13, database date: 02.05.2010):
CBT_A502_PCB01_GPRS_MT6225_S00.CBT_A502_SM_TOPSUN_004.BIN
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
rom info ver: 04
sw version: CBT_A502_PCB01_GPRS_MT6225_S00.CBT_A502_SM_TOPSUN_004.BIN
project-id: CBT.A502.SM.TopSun.004, 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect standard location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
====>  Write ...
Write: imei
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 3 sec
LOUIS ******* A502
SN: 7215217257226
IMEI:358903036962358
Fullflash (RapidShare: 1-CLICK Web hosting - Easy Filehosting)
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 06-16-2010, 07:52   #2918 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
zte a36 repair done thanks
COM4 [VCP0] selected
module v1.73
Device: ZTE-A36
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:22A0
Connecting Done
Check hardware ...
sw version: .00 P108A6 SST V1.0.0B06 P108A6V1.0.0B06 g3dBV2.0 Dec 7 2007 14
Check hardware Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100614-184956.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100614-184956.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100614-184958.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 18 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 06-16-2010, 08:35   #2919 (permalink)
baig65's Avatar
Member: 569388
Thanks Meter: 80
china 5030 no power done.
module v3.07
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:AD44:000C
status: FF
Boot Done
flash: 98000300000001:2BEA0000000000
Initialize Done
====> Set baud ...
460800
Set baud Done
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4DAF0B91.[CELLTEL23C_CBM46_GEMINI_08A_PCB01_GPRS_MT6223P_S00 .CBM46_N5030J_V172.BIN_CE298100].rpl
New firmware detected (v.3.07, database date: unknown):
device-id: 4DAF0B91
rom info ver: 04
sw version: CELLTEL23C_CBM46_GEMINI_08A_PCB01_GPRS_MT6223P_S00 .CBM46_N5030J_V172.BIN
project-id: CBM46_N5030J_V172, 008129CE
TCL-ID is absent
ffs/eeprom chip: 00
reading: CELLTEL23C_CBM46_GEMINI_08A_PCB01_GPRS_MT6223P_S00 .CBM46_N5030J_V172__ffs...
file saved: C:\Documents and Settings\gsm_baig\Desktop\5030 rian\CELLTEL23C_CBM46_GEMINI_08A_PCB01_GPRS_MT6223 P_S00.CBM46_N5030J_V172__ffs_20100616-151608.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\C ELLTEL23C_CBM46_GEMINI_08A_PCB01_GPRS_MT6223P_S00. CBM46_N5030J_V172__system_log_4DAF0B91_CE298100_20 100616-151647.B0X.bin
Finished, time used: 2 min 36 sec
The Following User Says Thank You to baig65 For This Useful Post:
Old 06-16-2010, 09:18   #2920 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
COM9 [VCP0] selected
module v3.14
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6239 NOR
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:1D29:2A98
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: X6_PK_English.06.12.9320.V1.39
Version: X6_MT26_05C_HW_PCB02
detecting structure #2...
done
60 byte(s) read
imei: 35542801500253
connection Ok
detecting structure #1...
done
208 byte(s) read
reading data #2...
156 byte(s) read
Phone lock: On
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 669969
Finished, time used: 16 sec
The Following User Says Thank You to msashami For This Useful Post:
Old 06-16-2010, 09:18   #2921 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
module v1.39
Device: LG-KP135
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 353955020887129
file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955020887129_LG-KP135_20100616-123014.B1E.bin
reading _eeprom-ffs_353955020887129...
file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_353955020887129_LG-KP135_20100616-123719.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 465 sec
Old 06-16-2010, 09:49   #2922 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM12 [VCP0] selected
module v3.43
Device: ZTE-X760
Action: "sp-unlock"
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:6D03:000D
status: FF
Boot Done
flash: 98000300000001:18E59F00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.84971 5A0.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15FR_FS_BF FA105.BIN_BF24DCF1].rpl
device-id: 849715A0
rom info ver: 04
sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15FR_FS_BF FA105.BIN
project-id: X760_Z15FR_FS_BFFA105, F1DC24BF
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
startup code area #1 check...
startup code area #1 fixed
reading: ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15FR_ FS_BFFA105__ffs...
file saved: C:\Program Files\InfinityBox\MModule\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15FR_ FS_BFFA105__ffs_20100616-014354.B0E.bin
detection procedure, wait...
detection procedure completed
detecting parameters to apply patch area 1...
error: area 1 can not apply patch
detecting parameters to apply patch area 2...
error: area 2 can not apply patch
detecting parameters to apply patch area 3...
required data found
Write: area 3 (pass 1)
area 3 patch applied Ok
====> Write ...
Write: ffs
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X760_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X760_Z15FR_ FS_BFFA105__system_log_849715A0_BF24DCF1_20100616-014528.B0X.bin
Finished, time used: 3 min 23 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 06-16-2010, 13:11   #2923 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
module v3.14
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A103:000C
status: FF
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: 06B_03_L10_BM572
Version: HEXING_MTK622506B0712MP_HW
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 173
warning: wrong packet cs
items cleared: 172 of 173
building list...
done
items remains: 1
Finished, time used: 36 sec
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 06-16-2010, 19:44   #2924 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
vodafone 125 unlock done!!
COM26 [VCP0] selected
module v1.76
Device: ZTE-125
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20100616-151727.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20100616-151729.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20100616-151736.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20100616-151756.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 1 min 16 sec
The Following 2 Users Say Thank You to fokal2008 For This Useful Post:
Old 06-16-2010, 20:26   #2925 (permalink)
Alexandro Monte's Avatar
Member: 846805
Sonork: alex cavalcante
Thanks Meter: 261
COM3 [VCP0] selected
Mَdulo v3.38
Dispositivo: Alcatel-222X, 222A
Verificando Dados. Aguarde...
Detecçمo Avançada da Flash Habilitada
Action: rebuild security area
====> Boot ...
Pressione e SEGURE o Botمo de Ligar!
19200 fixed
Conectando. Aguarde...
Inicializando [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:4807:A00C
status: 01
Tamanho do Pacote de Inicializaçمo: 0400
Solte o Botمo de Ligar!
Boot Done
====> Inicializar ...
Flash 01227E221A2201:2BEA0000000000
Flash Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Nْmero do Chip da Flash/Regiمo Detectada: 01/01
Inicializar Done
====> Determinar Velocidade ...
115200
Determinar Velocidade Done
====> Inicializar Cَdigo de Boot ...
Inicializar Cَdigo de Boot Done
====> Verificar Integridade do Firmware ...
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN
project-id: MAUI.08A.W08.36.SP1.V28, 00000000
ffs offset/size [01]: 003A0000/00058000
Versمo: 168
provider: 222X-2ATLES1
Customizaçمo CO16NJ03
Customizaçمo XO16NJ03
TCL-ID is present
ffs/eeprom address assigned: 003A0000
Estado do Travamento do Cartمo SIM: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Escrever security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
Feito
Escrever security area (sec info, hash)
security area (sec info, hash) calculation done
Verificar Integridade do Firmware Done
====> Verificar Conteْdo do Firmware ...
Verificar Conteْdo do Firmware Done
====> Salvar Cَpia de Dados ...
IMEI Original: 35591603330927
Salvar Cَpia de Dados Done
====> Programar Dados Necessلrios ...
Programar Dados Necessلrios Done
====> Operaçمo Especial ...
Operaçمo Especial Done
====> Escrever ...
Escrever Done
====> Finalizaçمo ...
FFS formatting...
Finalizaçمo Done
Arquivo Salvo: C:\Arquivos de programas\InfinityBox\MModule\backup_security\Alca tel-222X,222A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20100616-162557.B0X.bin
Finalizado. Tempo Gasto: 2 min 7 sec
Remova/Recoloque a Bateria!
The Following User Says Thank You to Alexandro Monte For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.71476 seconds with 10 queries
