12-30-2015, 12:04 | #29971 (permalink) |
Freak Poster Join Date: Sep 2011 Location: philippines
Member: 1649546 Status: Offline Thanks Meter: 123 | O+98.96 Android hang logo done Chinese Miracle II [SPD module] v 1.09 Operation : Format File System [ v1.09 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! FRP Not found Mount : /data Size : 0x000000009C1FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:42 Reconnect Power/Cable! O+8.96 Android hang logo done Last edited by jong2; 12-30-2015 at 12:10. |
12-30-2015, 13:46 | #29972 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bangladesh
Member: 1092417 Status: Offline Sonork: 100.1645946 Thanks Meter: 45 | Nokia 206 rm-873 flash and recovered! NOKIA 206 RM-873 FLASH AND RECOVERED! Code: Core : v2.15 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm873__03.58.mcusw PPM : rm873__03.58.ppm_e2 CNT : rm873__03.58.image_e2_059R4F5 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.53_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 356702058300113 PCcode : 059S1R0 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356702058300113_2nd_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm873__03.58.mcusw Image : rm873__03.58.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:02:08 Write , Start : 0x40280000 , Len : 0x01800000 Flashing , wait ... Region flash done, time : 00:01:06 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0xF9DB ===Flashing [PPM]=== File : rm873__03.58.ppm_e2 Image : package_e2.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A80000 , Len : 0x00680000 Erasing, wait ... Erase done, time : 00:00:19 Write , Start : 0x41A80000 , Len : 0x004E2A6C Flashing , wait ... Region flash done, time : 00:00:09 CRC check passed , 0x61C6 ===Flashing [CNT]=== File : rm873__03.58.image_e2_059R4F5 Image : package_e2_059R4F5.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42100000 , Len : 0x01D20000 Erasing, wait ... Erase done, time : 00:03:32 Write , Start : 0x42100000 , Len : 0x00EC0000 Flashing , wait ... Region flash done, time : 00:00:28 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:06 No write data, skip CRC check passed , 0xBF7B Flashing done! Total flash time : 00:08:02 Reboot phone now... Reading Phone Info.... Connected phone - 206 Software Info: V 03.58 05-12-12 RM-873 (c) Nokia IMEI: 356702058300113 PPM version : V 03.58 05-12-12 RM-873 (c) Nokia E2 Product code: 059S1R0 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Check and Upload User Certificates ... Total - 42 certs Certificates found, skip upload ... Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:09:58 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - 206 Software ver : V 03.58 05-12-12 RM-873 (c) Nokia IMEI : 356702058300113 XappVer : 00000866 PPM : V 03.58 05-12-12 RM-873 (c) Nokia E2 CNT : Content: e2_059R4F5 V 03.58 05-12-12 RM-873 (c) Nokia Product SN : C7158FEBI Product code : 059S1R0 Base Prd.code: 059P5C1 Module code : 0205284 Long Prod.SN : 0 Hardware info======= HWID : 2000 Battery: 4992 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 356702058300113 IMEI spNet : 3A 65 07 02 85 03 10 01 IMEI svNet : 33 65 07 02 85 03 10 01 F5 Sl Conf : 001-01-00000000000 Sl Prof : 800000000004000-B Sl Aux : 000B0000 Hw Sig : 3638572B1D3EBA73 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL30 (20 digit) phone detected... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
12-30-2015, 14:02 | #29974 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | qmobile e40 flash done very quickly 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 56B3EF68D1BA85489B67335F7CBE1669 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 SDS_INFO : Not exists File_Info : TINNO50M_3232_11B_PCB01_gsm_MT6250_S00.B2050B_MP_F 3F8_PK_F5_06_V7.bin FileVersion : B2050B_MP_F3F8_PK_F5_06_V7 Flash now Erase region , wait ... Write data , wait ... Write : Q Mobile E40 MTK 625A.bin Done! Elapsed: 00:01:15 Reconnect Power/Cable! Finish at : [12/30/2015 / 5:41:07 PM] |
The Following User Says Thank You to haroon454 For This Useful Post: |
12-30-2015, 14:03 | #29975 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Searching....
Member: 1442705 Status: Offline Thanks Meter: 1,061 | Lemon B555i MT6261 Read Flash Read User Code Reset Code Done Last edited by Absar_Global; 12-30-2015 at 14:12. |
The Following User Says Thank You to Absar_Global For This Useful Post: |
12-30-2015, 14:26 | #29976 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Faislabad Age: 34
Member: 1657674 Status: Offline Thanks Meter: 855 | videocon Z51 Read Flash Done and MONKEY virus Remove Done Operation : Remove Viruses [SmartAV] [ v1.38 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A05C9911F71D1 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A05C9911F71D1 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473A05C9911F71D1 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Z51 Quad ProdName : Z51 Quad ProdModel : Z51 Quad Device : Z51_Quad AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.11 [Read Ok] : preloader_kphone82_wet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / kphone82_wet_kk / EMMC FW Size : 795 MiB Scatter saved to : C:\Users\Ali jaan\Desktop\A319\MT6582__Z51_Quad__Z51_Quad__Z51_ Quad__4.4.2__ALPS.KK1.MP1.V2.11\ All done! Done! Elapsed: 00:03:40 Reconnect Power/Cable! |
12-30-2015, 14:42 | #29977 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | Maximus superme spd7731 read pattern+formate done via cm2 Maximus superme spd7731 read pattern+formate done via cm2 read pattern but touch not work properly so need to formate safe formate with cm2 log here Code: Operation : Format File System [ v1.09 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000A13FC000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
12-30-2015, 23:03 | #29979 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | INFINITY BEST 2.15 WORKING PERFECT Connect phone on selected interface... IDM initializing, wait... Checking access to Products folder... Folder for RM-971 not exist. Attempt to create Prepare done, collect info [Query] : RM-971_FATIMAGE_UA_30.06.11 , 5,58 MB [Query] : RM-971_ROM_eMP_30.06.11 , 1,28 MB [Query] : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 , 2,90 MB [Query] : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 , 145,36 KB [Query] : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 , 1,15 KB [Query] : RM-971_VIVA_eMP_30.06.11 , 4,01 MB [Query] : RM971_059V151_30.06.11_036.vpl , 4,77 KB [Query] : RM-971_IMAGE_eMP_059V151_care_30.06.11_001.cfg , 2,92 KB Files to download : 8 Total size to download : 13,92 MB Downloading now, please, wait... [Download] : RM-971_FATIMAGE_UA_30.06.11 [Download] : RM-971_ROM_eMP_30.06.11 [Download] : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 [Download] : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 [Download] : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 [Download] : RM-971_VIVA_eMP_30.06.11 [Download] : RM971_059V151_30.06.11_036.vpl [Download] : RM-971_IMAGE_eMP_059V151_care_30.06.11_001.cfg Verify files now ..... [Verify Ok] : RM-971_IMAGE_eMP_059V151_care_30.06.11_001.cfg [Verify Ok] : RM-971_ROM_eMP_30.06.11 [Verify Ok] : RM-971_FATIMAGE_UA_30.06.11 [Verify Ok] : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 [Verify Ok] : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 [Verify Ok] : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 [Verify Ok] : RM-971_VIVA_eMP_30.06.11 All done, all files were downloaded! Core : v2.15 , MTKx FlashEngine : v9.3 Verify files ... MAUI : RM-971_ROM_eMP_30.06.11 VIVA : RM-971_VIVA_eMP_30.06.11 LANG : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 CUST : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 JMPT : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 94 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E7B8530818C433D8C42E5E4C1587C583 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : Rivendell.20.14.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Rivendell.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00A60000-0x00FF3FFF , LEN : 0x00594000 SecureDecrypt : RM-971_ROM_eMP_30.06.11 SecureDecrypt : RM-971_VIVA_eMP_30.06.11 SecureDecrypt : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 SecureDecrypt : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 SecureDecrypt : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 OVRLP : 000069B900000001 PHPID : Rivendell.20.14.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-971_ROM_eMP_30.06.11 Write : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 Write : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 Write : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 Write : RM-971_VIVA_eMP_30.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-971_ROM_eMP_30.06.11 [VERIFY] DONE : RM-971_LANG_PACK_ROM_UA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_CUSTPACK_ROM_UA_LATAM_LTA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_JUMP_TABLE_UA_LATAM_LTA_eMP_30.06.11_001 [VERIFY] DONE : RM-971_VIVA_eMP_30.06.11 CODE_VERIFY : Ok Will Upload FAT Image now Write : RM-971_FATIMAGE_UA_30.06.11 FAT Image Flash done! FAT Verify Ok Rebooting phone now Flashing done! Total flash time : 00:05:26 Reboot phone Ok Connect phone on selected interface... |
12-31-2015, 08:34 | #29980 (permalink) |
No Life Poster Join Date: Jul 2010 Location: B.J.M Age: 36
Member: 1338323 Status: Offline Sonork: 100,1662431 Thanks Meter: 301 | Lenovo A606 Hang On Logo Format Done CM2 CM2 Bidhan_mobile |
The Following User Says Thank You to bidhan_mobile For This Useful Post: |
12-31-2015, 08:51 | #29981 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Pakistan
Member: 1726229 Status: Offline Thanks Meter: 223 | Q Mobile X6i 3g Spd Read PatternLock Q Mobile X6i 3g Spd Read PatternLock done Operation : Read PatternLock [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! FlashMode Set : Ok! Reading PatternLock ... [Read Mode] : HSUSB : 0x3000 Read Ok , decrypt PatternLock Sequence : 412365987 Done! Elapsed: 00:02:46 Reconnect Power/Cable! |
12-31-2015, 09:13 | #29982 (permalink) |
Freak Poster Join Date: Feb 2008 Location: royal mobiles kotla
Member: 714116 Status: Offline Thanks Meter: 48 | next x8 read flash Reading Flash Conent now ... Brand : NEXT X8 ProdName : NEXT X8 ProdModel : NEXT X8 Device : NEXT X8 AndroidVer: 4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.30 [Read Ok] : preloader_yuanda72_wet_a_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / yuanda72_wet_a_jb3 / EMMC FW Size : 678 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__NEXT_X8__NEXT_ X8__NEXT_X8__4.2__ALPS.JB3.MP.V1.30\ All done! Done! Elapsed: 00:03:18 Reconnect Power/Cable! |
The Following User Says Thank You to sajid11 For This Useful Post: |
12-31-2015, 10:08 | #29983 (permalink) |
Freak Poster Join Date: Apr 2008 Location: World of technology
Member: 749754 Status: Offline Sonork: partycrasher131 Thanks Meter: 134 | xtouch a1 lte frp done frp done thanx to cm2.... read info Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 56000170303030319B115038C7C30D9F DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 70010056313030303850119B9F0D72C7 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : XTOUCH ProdName : A1_LTE ProdModel : A1_LTE Device : A1_LTE AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1_VANZO6735M.35GC.L_P40 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 56000170303030319B115038C7C30D9F DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 70010056313030303850119B9F0D72C7 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to partycrasher131 For This Useful Post: |
12-31-2015, 11:04 | #29984 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung e1200y dead recover done Code: Operation : Flash [ v1.09 ] ======= Flash Files set for flashing : [ MCU ] : samsung_EiderVESS_E1200Y_SWA_09242014105619__samsung-e1200y single sim.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 Flash CAP : 02000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : samsung_EiderVESS_E1200Y_SWA_09242014105619__samsung-e1200y single sim.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:58 Reconnect Power/Cable! Operation : Format File System [ v1.09 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 8 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
12-31-2015, 11:22 | #29985 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx e311 av done Code: Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A484147326505072B7374FF52F7 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505072B7374FF52F7 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 32 Removing infected files and scripts ... SmartAV Report : Removed 32 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:30 Reconnect Power/Cable! Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A484147326505072B7374FF52F7 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505072B7374FF52F7 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
