01-01-2016, 08:24 | #30001 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Voice v440 Flashing Done Code: Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C189D1_VOICE_V00_M24E_141014.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CA7A806F6F3FC03A6AF1AB0C940F3B6B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C189D1_VOICE_V00_M24E_141014.bin FileVersion : C189D1_VOICE_V00_M24E_141014 Flash now Erase region , wait ... Write data , wait ... Write : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C189D1_VOICE_V00_M24E_141014.bin Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
01-01-2016, 08:25 | #30002 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile N150 Flashing Done Code: Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_N150_V01_230115.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CA7A806F6F3FC03A6AF1AB0C940F3B6B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : DONE NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 [ERROR] : DA_BLANK_FLASH SDS_INFO : Not exists File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_N150_V01_230115.bin FileVersion : QMobile_N150_V01_230115 Flash now Erase region , wait ... Write data , wait ... Write : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_N150_V01_230115.bin Done! Elapsed: 00:02:01 Reconnect Power/Cable! |
01-01-2016, 08:26 | #30003 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile L4 Flashing Done Code: Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_L4_V01_12022015.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CA7A806F6F3FC03A6AF1AB0C940F3B6B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_L4_V01_12022015.bin FileVersion : QMobile_L4_V01_12022015 Flash now Erase region , wait ... Write data , wait ... Write : HONGYU61M_11C_PCB01_gprs_MT6261_S00.QMOBILE_L4_V01_12022015.bin Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
01-01-2016, 08:27 | #30004 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile M225 Flashing Done Code: Operation : Flash [ v1.40 ] ======= Flash Files set for flashing : [ MCU ] : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C299A_QMOBILE_V00_M225_141231.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CA7A806F6F3FC03A6AF1AB0C940F3B6B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 File_Info : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C299A_QMOBILE_V00_M225_141231.bin FileVersion : C299A_QMOBILE_V00_M225_141231 Flash now Erase region , wait ... Write data , wait ... Write : HONGYU61M_11C_PCB01_gprs_MT6261_S00.C299A_QMOBILE_V00_M225_141231.bin Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
01-01-2016, 09:00 | #30005 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,363 | Lava 244 read user code done- Quote:
Infinity Box Support Team. | |
01-01-2016, 11:02 | #30007 (permalink) | |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Noir X6 Hang problem Sovled Qmobile Noir X6 Hang problem Sovled Quote:
01-01-2016, 11:25 | #30008 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile Noir i5 Hang Problem Solved Code: Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164040501A1703E519D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A1703E519D [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
01-01-2016, 11:46 | #30009 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,300 | Ricoh forstar ft970 Rockchip Tablet Stuck on logo solv Formate fs Code: Chinese Miracle II [RKT Module] v 1.0 Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK3066 Read Info Ok! Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 please add boot chnge button normal mode to boot mode many time very hard to find boot key/boot mode finding in tablet |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
01-01-2016, 12:01 | #30010 (permalink) |
No Life Poster Join Date: May 2008 Location: Pakistan
Member: 775524 Status: Offline Sonork: 100.1608849 Thanks Meter: 125 | CM2 tool is best for me waoooooo CM2 great box for me after too much search for a file for Clone I8552 mtk 6572 i found a file which was infected after flash with this my set ok but now always show <phone service has stop> i try all other box even CM2 latest version 1.40 but same then i flash again and clear infected file by CM2 1.34 version now my set 100% clear thanks CM2 team Operation : Remove Viruses [SmartAV] [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201A700C252C08D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201A700C252C08D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 27 Removing infected files and scripts ... SmartAV Report : Removed 27 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:16 Reconnect Power/Cable! Operation : Format FileSystem [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D4201A700C252C08D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZX5 [eMMC] : FLASH_CID : 1501004E35585A4D4201A700C252C08D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
The Following User Says Thank You to Nabeel khan For This Useful Post: |
01-01-2016, 12:08 | #30011 (permalink) |
No Life Poster Join Date: Jul 2006 Location: punjab Age: 44
Member: 315867 Status: Offline Sonork: 100.1654770 Thanks Meter: 708 | karbonn a35 smart av done Chinese Miracle II [MTK module] v 1.40 Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42010630C8E411E3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42010630C8E411E3 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Karbonn ProdName : A35 ProdModel : A35 Device : a880_a35 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : Karbonn_A35_MTK_V1011_$(shell MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V15_1_2g_n EXTRA : LCD [0] : otm9605a_qhd_dsi_vdo_a35 LCD [1] : ili9807_qhd_ky_vdo_dx LCD Res : 960x540 TOUCH [0] : ft6306 TOUCH [1] : GT9XX CAM [0] : ov5640_yuv CAM [1] : t8ev5_yuv CAM [2] : gc0329_yuv MODEM : modem_2g_co_a880_a35_20140321 LOCALE : en_US hi_IN ja_JP fr_FR it_IT de_DE es_ES en_GB hdpi Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35575A4D42010630C8E411E3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42010630C8E411E3 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 59 Removing infected files and scripts ... SmartAV Report : Removed 59 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:01:12 Reconnect Power/Cable! |
01-01-2016, 13:07 | #30014 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Philippines
Member: 696820 Status: Offline Sonork: 100.1684793 Thanks Meter: 274 | Alcatel 5015e.. Mt6580.. Google Reset Protection.. Done! hello mates, just wanna share.. Alcatel 5015e.. Google Account Problem Job done by CM2.. Format / Reset Settings Logs: Code: Card found : S/N : -------- Chinese Miracle II [MTK module] v 1.39 Operation : Format FileSystem [ v1.39 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6580 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6580_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100513732534D4200A530D31C92C1 DA Stat : v4.2 on BBID : 0x94 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200A530D31C92C1 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear Google Reset Protection Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! thanks INFINITY Team! |
