Old 06-23-2010, 09:26   #3001 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
two iphone i9+++ blinking recover with infinity
here is logs
COM4 [VCP0] selected
module v3.15
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3603:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 20881CFFFFFFFF:20881C00000000
flash: ST Intel/Sharp ext [def 00FFx020000 0004x008000] 32Mb
otp offset: 01FE0000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 02000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.11F93FDD.[N31F_PCB01_GPRS_MT6225_S00.N31_V1.BIN_FA152076].rpl
rom info detection finished
New firmware detected (v.3.15, database date: 05.06.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 11F93FDD
rom info ver: 05
sw version: N31F_PCB01_GPRS_MT6225_S00.N31_V1.BIN
project-id: N31_V1, 762015FA
code offset: 00000000
ffs offset/size [01]: 01E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01E00000
standard ffs/eeprom offset confirmed: 01E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01E00000-01FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: N31F_PCB01_GPRS_MT6225_S00.N31_V1__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N31F_PCB01_GPRS_M T6225_S00.N31_V1__ffs_20100624-012301.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 31F_PCB01_GPRS_MT6225_S00.N31_V1__system_log_11F93 FDD_FA152076_20100624-012325.B0X.bin
Finished, time used: 2 min 48 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to .::M Irfan::. For This Useful Post:
Old 06-23-2010, 11:13   #3002 (permalink)
Member: 1043909
Thanks Meter: 61,452
here is logs
module v3.15
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
device-id: 11F93FDD
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
====> Write ...
Write Done
ffs formatting...
Finalization Done
Please, send to us this phone full flash backup file: [email protected]
Thank you !
Old 06-23-2010, 14:53   #3003 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
COM24 [VCP0] selected
module v1.73
Device: LG-KG275
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL KG270 P16 92 V10d XXX-XX May 29 2007 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20100623-182857.B1E.bin
loading data...
data loaded
imei: 35744501139195600
reading eeprom-security_35744501139195600...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_35744501139195600_20100623-182858.B1E.bin
reading eeprom-complete_35744501139195600...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_35744501139195600_20100623-182900.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 20 sec
The Following 2 Users Say Thank You to Shakeel_pattoki For This Useful Post:
Old 06-23-2010, 14:54   #3004 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM14 [VCP0] selected
module v3.15
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:5C03:0001
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: N81_ABROAD_2ADGB_S5LCD_V1.2.4
Version: M500_P3
detecting structure #2...
4 5 11 done
67 byte(s) read
imei: 35887900509046
connection Ok
building list...
done
items to clear: 177
warning: wrong packet cs
items cleared: 170 of 177
building list...
done
items remains: 7
Finished, time used: 1 min 6 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 06-24-2010, 06:57   #3005 (permalink)
md_amin's Avatar
Member: 1217931
Sonork: 100.1604251
Thanks Meter: 267
Alcatel S319x unlock done
COM12 [VCP1] selected
module v3.45
Device: Alcatel-S319X, S319A
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:386B:A00C
status: 01
Boot Done
flash: 98004900000002:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is present
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
project-id: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 16J
provider: S319X-2BVGGB1
customization: CH16CS20
customization: XH16CS20
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
original imei: 35239402001747
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20100623-234729.B0X.bin
Finished, time used: 3 min 7 sec
The Following 2 Users Say Thank You to md_amin For This Useful Post:
Old 06-24-2010, 12:38   #3006 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
ME-114 formated ok
COM10 [VCP1] selected
module v3.15
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:4E4D:000C
status: FF
Boot Done
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
TCL-ID is absent
New firmware detected (v.3.15, database date: 20.06.2010):
SMS_S08_ABTEL_2V8_TB_PCB01_GPRS_MT6223P_S00.SMS-S08_2V8_ABTEL_L2VI_203_100420_CAM010_MCP128+32_FM_ TB_PCB31.BIN
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
rom info ver: 07
sw version: SMS_S08_ABTEL_2V8_TB_PCB01_GPRS_MT6223P_S00.SMS-S08_2V8_ABTEL_L2VI_203_100420_CAM010_MCP128+32_FM_ TB_PCB31.BIN
project-id: SMS-S08_2V8_ABTEL_L2VI_203_100420_CAM010_MCP128+32_FM_ TB_PCB31, 00000000
ffs offset/size [01]: 00D00000/00300000
TCL-ID is absent
standard ffs/eeprom offset detected: 00D00000
standard ffs/eeprom offset confirmed: 00D00000
ffs/eeprom size: 00300000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00D00000-00FFFFFF
reading: SMS_S08_ABTEL_2V8_TB_PCB01_GPRS_MT6223P_S00.SMS-S08_2V8_ABTEL_L2VI_203_100420_CAM010_MCP128+32_FM_ TB_PCB31__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\SMS_S08_ABTEL_2V8 _TB_PCB01_GPRS_MT6223P_S00.SMS-S08_2V8_ABTEL_L2VI_203_100420_CAM010_MCP128+32_FM_ TB_PCB31__ffs_20100624-183423.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 4 min 11 sec
The Following User Says Thank You to hung phong For This Useful Post:
Old 06-24-2010, 15:12   #3007 (permalink)
Member: 154994
Sonork: 100.1577576
Thanks Meter: 22
LG 3610 newversion unlocked in 23 sec
COM2 [LGSIDIAG1] selected
module v1.04
Device: LG-3610
Action: "sp-unlock"
Phone should be Switched ON !
connecting...
OFFLINE...
sending boot...
sending command...
patching in progress...
patching in progress 50%...
patching in progress 100%...
Done...
Phones should be restarting now...
Finished, time used: 23 sec
The Following 8 Users Say Thank You to ajaycuteboy For This Useful Post:
Old 06-24-2010, 15:55   #3008 (permalink)
Member: 633231
Thanks Meter: 666
Other ZTE A661 unlock done
COM1 [Serial0] selected
module v3.44
Action: "sp-unlock"
unlock method: smart fast
Model: ZTE-A661
19200 autodetect
CPU: MT6225
chip: 0001:3C03:0002
status: FF
Date: 2006.06.14
Version: 1.0
Version: SE-DM-CLARO8-P103E1V1.0.0B06
44 byte(s) read
imei: 35480303046216
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
The Following 2 Users Say Thank You to thewolverine For This Useful Post:
Old 06-24-2010, 16:35   #3009 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
Originally Posted by yellowboss View Post
please, send to us this phone full flash backup file: [email protected]
thank you !
already sended to you with full flash, security backup, eeprom, pinouts complete,
Old 06-24-2010, 16:35   #3010 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
3RD ONE SCIPHONE BLINKING DONE
module v3.15
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:4503:0003
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CC0184EC.[N31F_PCB01_GPRS_MT6225_S00.N31_V1.BIN_FA152076].rpl
device-id: CC0184EC
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N31F_PCB01_GPRS_M T6225_S00.N31_V1__ffs_20100625-082441.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 31F_PCB01_GPRS_MT6225_S00.N31_V1__system_log_CC018 4EC_FA152076_20100625-082547.B0X.bin
Finished, time used: 2 min 58 sec
THANKS TO INFINITY TEAM THE GREAT TEAM,
WE WILL B MORE HAPPY IF YOU SUPPORT SPD CHIP ALSO,
Old 06-24-2010, 17:00   #3011 (permalink)
Member: 837432
Thanks Meter: 19
OT-660 successfully unlock
the best box ...INFINITY
COM8 [VCP0] selected
module v3.03
Device: Alcatel-660
====> Boot ...
error: boot initialization step #2 failed:
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:AC03:A006
status: 01
Boot Done
flash: 98006F00000003:08EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader (chip) is present: 00020000
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.3F186 3BF.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_C368F055].rpl
TCL-ID detection...
device-id: 3F1863BF
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 55F068C3
code offset: 00020000
ffs offset/size [01]: 01000000/00FE0000
version: 331
provider: 660X-2DTBGB1-S40
customization: CJ33DH04
customization: XJ33DH04
TCL-ID is present
ffs/eeprom address assigned: 01000000
startup code area #1 check...
startup code area #1 fixed
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
original imei: 00000000000000
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-660_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_2 8_SP1_V38__system_log_3F1863BF_C368F055_20100624-164800.B0X.bin
Finished, time used: 10 min 43 sec
The Following User Says Thank You to jani bravo For This Useful Post:
Old 06-24-2010, 19:16   #3012 (permalink)
Member: 1269161
Thanks Meter: 121
succes unlock alcatel ot203ex
COM3 [VCP0] selected
module v3.41
Device: Alcatel-203X, 203A, 203E
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:4C7F:A00C
status: 01
Boot Done
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
ffs offset/size [01]: 003A0000/00058000
version: 37L
provider: 203EX-2CMHFR1
customization: CM37DG33
customization: XM37DG33
TCL-ID is present
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: 35633103336417
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0100624-191203.B0X.bin
Finished, time used: 1 min 29 sec
The Following User Says Thank You to .:B-A-G:. For This Useful Post:
Old 06-24-2010, 21:39   #3013 (permalink)
Member: 736982
Thanks Meter: 27
successfully unlock avvio-505
modulo v3.46
Action: "sp-unlock"
Metodo unlock: smart fast
Modelo: Avvio-505
Checkeando datos, espere...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
19200 autodetect
Iniciando [6225:8A05:8A00]...
CPU: MT6225
chip: 0001403:000C
status: FF
Deje de presionar el boton power ahora !
Telefono detectado, espere...
Dato: 2006.06.14
Version: 1.0
Version: MAUI.08B.W09.16.MP.V12.F1
Version: AVVIO505_V2.1
81 byte(s) read
imei: 35171204110947
coneccion Ok
186 byte(s) read
Leyendo datos...
reading data #2...
construcción de nuevos datos..
escribiendo datos...
174 byte(s) read
Leyendo datos...
972 byte(s) read
verifying...
verificacion Ok
Listo
Finalizado, tiempo usado: 15 sec
Quite/coloque la bateria ahora !
The Following User Says Thank You to luinaranjo For This Useful Post:
Old 06-25-2010, 07:53   #3014 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Action: unlock
Device: C113(a),C114,C115,C116,C117,C118
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 1.0.49.E.
HW version: _E88
imei otp: 356480003387523
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _356480003387523_20100625-115005.18E.bin
imei eeprom: 356480003387523
Check Flash-2 Done
Write...
Write Done
Finished, time used: 41 sec
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 06-25-2010, 09:27   #3015 (permalink)
Member: 256247
Thanks Meter: 444
module v1.04
Device: ZTE-C339
Action: "sp-unlock"
connecting...
OFFLINE...
send spc...
disabling minlock...
Done...
Finished, time used: 7 sec
The Following 10 Users Say Thank You to irfanboss For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.54552 seconds with 10 queries
