12-02-2016, 10:31 | #38146 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Micromax Q415 FRP RESET / READ Firmware done !!! Micromax Q415 FRP RESET / READ Firmware done !!! Code: Operation : Reset Settings [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 01FD6379 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 5BF3348E77304208 ID_BLOCK_L : C060A78CDF6373C4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 01FD6379 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 5BF3348E77304208 ID_BLOCK_L : C060A78CDF6373C4 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0000C000/00100000/00001000/00001000 Boot Ok! Brand : Micromax ProdName : Q415 ProdModel : Micromax Q415 Device : Q415 AndroidVer: 5.1.1 Manufact. : Micromax QLMxCPU : MSM8909 DevInfo : MSM8909__Micromax__Micromax__ANDR_v5.1.1__Micromax_Q415__Q415__Q415 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : oem.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1588 MiB Done! Elapsed: 00:02:59 |
The Following User Says Thank You to UzUnlocker For This Useful Post: |
12-02-2016, 11:15 | #38147 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Samsung J200H (Clone) Read Factory Firmware / Remove Virus Done :) Bla bla ......etc Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581DD97A2A91C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581DD97A2A91C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D07499CF958B66B3BC8477883 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Samsung ProdName : Galaxy-J2 ProdModel : SM-J200H Device : Galaxy-J2 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_P3_1_wg_n EXTRA : LCD [0] : s6d77a1a01_dsi_vdo LCD [1] : sc7798_dsi_vdo LCD [2] : hx8369b_dsi_vdo LCD Res : 800x480 TOUCH [0] : ft5206 TOUCH [1] : TOUCH [2] : ft5206 CAM [0] : ov5640_yuv CAM [1] : s5k4ecgx_yuv CAM [2] : ov2655_yuv CAM [3] : gc0329_yuv CAM [4] : gc0328_yuv CAM [5] : gc2145_yuv CAM [6] : gc0309_yuv CAM [7] : gc0307_yuv CAM [8] : gc2155_yuv CAM [9] : s5k6aafx_yuv CAM [10] : hi253_yuv CAM [11] : gc2035_yuv CAM [12] : gt2005_yuv MODEM : keytak72_cwet_kk_hspa LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG fa_IR th_TH km_KH my_MM el_GR hdpi -sw600dp -sw720dp Done! Elapsed: 00:00:24 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581DD97A2A91C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581DD97A2A91C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D07499CF958B66B3BC8477883 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Samsung ProdName : Galaxy-J2 ProdModel : SM-J200H Device : Galaxy-J2 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_j7225.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / j7225 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 954 MiB Scatter saved to : G:\Firmware\MT6572__Samsung__SM-J200H__Galaxy-J2__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:04:48 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581DD97A2A91C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581DD97A2A91C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D07499CF958B66B3BC8477883 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictionary Collect done : 0x0005 [DDCleaner Info] : Files to remove : 6 [DDCleaner Info] : Additional garbage detected : 1 Removing files ... [DDCleaner] : Removed 6 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:51 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581DD97A2A91C7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581DD97A2A91C7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D07499CF958B66B3BC8477883 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait [User Select] : Remove Files and Garbage [DDCleaner Info] : Files to remove : 3 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 3 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
12-02-2016, 13:58 | #38149 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Cell C Fantasy read firmware and frp reset done Model Name : Fantasy Model Brand : Cell_C Model Device: Cell_C AndrVersion : 5.1 BaseBand CPU: SP7731CEB Project Ver : Cell_C_Fantasy_IND_Ver2.0_160628_1200 Model Ext : Fantasy [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_Trunk_W15.49.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1743 MiB Saved to : H:\flash firmware\infinity\SP7731GEA_HS7731SP_4.4.2_HS_U601 _S01_HS-U601\SP7731CEB_Cell_C_5.1_Cell_C_Fantasy_IND_Ver2. 0_160628_1200_Fantasy\ Done! Elapsed: 00:07:46 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 217 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000747F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 |
12-02-2016, 14:37 | #38151 (permalink) |
No Life Poster Join Date: May 2013 Location: UFI-BOX+EASYJTAG BOX Age: 34
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | ...:::Symphony V30 Read Factory Done_Golden Box {Infinity CM2}:::... ...:::Symphony V30 Read Factory Done {Infinity CM2}:::... Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001DF99552A72D5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453001DF99552A72D5 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xADC2A14CB43A045159B753E3AC9A18E5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Symphony ProdName : V30 ProdModel : V30 Device : V30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : UP29 [Read Ok] : preloader_up29_h404_sy_v30.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / up29_h404_sy_v30 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 805 MiB Scatter saved to : C:\Users\TaHa_MoNi\Desktop\MT6572__Symphony__V30__V30__4.4.2__UP29\ All done! Done! Elapsed: 00:04:01 Reconnect Power/Cable! |
12-02-2016, 14:37 | #38152 (permalink) |
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | ...:::Symphony W16_3G Read Factory Done_Golden Box {Infinity CM2}:::... ...:::Symphony W16-3G Read Factory Done {Infinity CM2}:::... Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930105FDE8296B0BB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930105FDE8296B0BB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xADC2A14C3A38C5F74A89C31AA43CA993 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : Symphony ProdName : up11_id_gp ProdModel : Symphony Xplorer W16 Device : up11_id_gp AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_up11_id_gp.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / up11_id_gp / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 681 MiB Scatter saved to : C:\Users\TaHa_MoNi\Desktop\MT6572__Symphony__Symphony_Xplorer_W16__up11_id_gp__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:02:58 Reconnect Power/Cable! |
12-02-2016, 14:37 | #38153 (permalink) |
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | ...:::Maximus_I Cube Read Factory Done_Golden Box {Infinity CM2}:::... ...:::Maximus_I Cube Read Factory Done {Infinity CM2}:::... Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034473AFD55892E520D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473AFD55892E520D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xADC2A14C3BBAA5496DEBD2002BEA042F INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : i cube ProdName : yk828_v12_emmc_wcdma ProdModel : i cube Device : i cube AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_yk828_v12_emmc_wcdma.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / yk828_v12_emmc_wcdma / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 678 MiB Scatter saved to : C:\Users\TaHa_MoNi\Desktop\MT6572__i_cube__i_cube__i_cube__4.4.2__ALPS.KK1.MP7.V1\ All done! Done! Elapsed: 00:03:53 Reconnect Power/Cable |
12-02-2016, 15:50 | #38155 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Lava Atom 2 Stuck on LOGO <<< Success Report >>> Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Atom_2 Model Brand : Lava Model Device: Atom_2 AndrVersion : 4.4.2 BaseBand CPU: SP7731GEA CompileDate : 7/17/2015 11:08:08 AM Project Ver : Lava_iris_Atom_2_S106_20150717 Model Ext : Atom 2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 27 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001799FB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
12-02-2016, 16:15 | #38156 (permalink) |
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | ARK Benefit S502 Plus [SC7731] Flashing done ARK Benefit S502 Plus [SC7731] Flashing done Code: Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 122 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp7731gea_hdrplus_dt Model Brand : ARK Model Device: Benefit_S502_Plus AndrVersion : 5.1 BaseBand CPU: SP7731GEA_HDR CompileDate : 06.09.2015 5:43:57 Project Ver : ARK_Benefit_S502_PLUS_V007 Model Ext : Benefit_S502_Plus ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Reconnect Power/Cable! Loading : ARK_Benefit_S502_PLUS_V007.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : ARK_Benefit_S502_PLUS_V007_FS031_CF2_BSE70J_ARK_L43284_20150828_DDR3_HD_G4W18_ALS_183231 FastCheck : 0x006858E247 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo_hd_ark.bmp File : logo_hd_ark.bmp File : prodnv.img File : cache.img File : u-boot.bin File : SC7730_UMS.xml Load Ok! Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : ARK_Benefit_S502_PLUS_V007.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : ARK_Benefit_S502_PLUS_V007_FS031_CF2_BSE70J_ARK_L43284_20150828_DDR3_HD_G4W18_ALS_183231 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo_hd_ark.bmp File : logo_hd_ark.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 122 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_hd_ark.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo_hd_ark.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:03:09 Reconnect Power/Cable! |
12-03-2016, 01:51 | #38160 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Reliance ls-5006 lock reset without data lossse with cm2qlm:- READ INFO Code: Infinity-Box Qualcomm Module [QLM] v 1.04 Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 12F957E4 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E640C7F97 ID_BLOCK_L : C060A78CCC5F4E5B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000748000000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Reliance ProdName : Reliance_TBT5755B2 ProdModel : Smartphone BE LS-5006 Device : TBT5755B2 AndroidVer: 5.1.1 Manufact. : Reliance QLMxCPU : MSM8916 QLMxPRJ : TBT575523_1003_V010026 Done! Elapsed: 00:00:08 RESET LOCKS Code: Operation : Reset UserLocks [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 12F957E4 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 5BF3348E640C7F97 ID_BLOCK_L : C060A78CCC5F4E5B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000748000000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:52 WBR sahil2000ind |
