08-13-2018, 07:50 | #52171 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Samsung j7 6 format done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 241 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014618D0F1B021 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014618D0F1B021 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7D8306F6B5AC0AA01F8A2A04D4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
08-13-2018, 08:00 | #52172 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Moto Xt926 reset done Operation : Reset Settings [ v1.03 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:15 |
08-13-2018, 08:18 | #52173 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Qmobile x25 ddead recover by full flash with cm2 QMOBILE X25 DDEAD RECOVER BY FULL FLASH WITH CM2 Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040500A100426113 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040500A100426113 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD4F31DC10189AB1D618591B270ECB0DB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4187 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:23 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:52 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:35 Reconnect Power/Cable! |
08-13-2018, 08:22 | #52174 (permalink) |
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Q mobile m95 hang on logo recover with cm2 spd Q MOBILE M95 HANG ON LOGO RECOVER WITH CM2 SPD Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Loading : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles FastCheck : 0x00537684CD Loading files ... File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : M95 v1 by Nasir Mobiles.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : M95 v1 by Nasir Mobiles File : Infinity_fdl1.bin File : Infinity_fdl2.bin File : nvitem_w.bin File : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : sc7731g_CP0_modem.bin File : DSP_DM_Gx.bin File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin File : logo_540x960.bin File : fblogo_540x960.bin File : boot.img File : system.img File : cache.img File : recovery.img File : userdata.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : sc7731g_CP0_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_Gx.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fblogo_540x960.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:58 Reconnect Power/Cable! |
08-13-2018, 08:28 | #52175 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Enegry X1 MT6580 FRP Reset Done with Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050704E6688D6375 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050704E6688D6375 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39579DCB9B00A92218F6A6DB6A5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
08-13-2018, 09:38 | #52176 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Haier-JS-500 (JAZZ) write factory firmware Done :) Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010F69C2A8A25F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010F69C2A8A25F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D7669AB3834BBF5AC34B37808 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Haier-JS-500 ProdName : hct72_cwet_kk ProdModel : JS 500 Device : hct72_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : HM-JS-500-H01-S007-PK SECURITY : IMEI_SW [1] : 869323020048092 IMEI_SW [2] : 869323020048100 BTMAC Addr : C8D7791ECC68 WiFi MAC : C8D7791EF4A4 Done! Elapsed: 00:00:32 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : hct72_cwet_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111010F69C2A8A25F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111010F69C2A8A25F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D7669AB3834BBF5AC34B37808 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : hct72_cwet_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) Backup enabled! Backup saved : Backup\Flash\90014A483447326111010F69C2A8A25F\ BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x0000000094840000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hct72_cwet_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:35 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:10 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:25 Reconnect Power/Cable! |
08-13-2018, 10:29 | #52177 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37FW QLM Read Pattre Done By Infinity CM2 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 24E6539C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 29DBB14DE876636E590EC6CF0853E3EB ID_BLOCK_L : BDD07ED1C24DFD768B6A2FE4EE011F3C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
08-13-2018, 10:56 | #52178 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37FW FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 24E6539C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 29DBB14DE876636E590EC6CF0853E3EB ID_BLOCK_L : BDD07ED1C24DFD768B6A2FE4EE011F3C Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
08-13-2018, 12:19 | #52179 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Hotwav Venus R9 SPD 7731 Firmware Read Done By CM2 - > Wait phone connected ... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : sp7731c_c7367_qhd_oversea Model Brand : HOTWAV Model Device: sp7731c_c7367_qhd AndrVersion : 6.0 BaseBand CPU: SP7731CEB Project Ver : C7367_HWD_R9_BengalHOTWAV_324_QHD_NOGPS_B1_V01.01. B03 Model Ext : Venus_R9 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.27.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_540x960.bin [Read Ok] : fblogo_540x960.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : sysinfo.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1927 MiB Saved to : D:\New folder (3)\SP7731CEB_sp7731c_c7367_qhd_6.0_C7367_HWD_R9_B engalHOTWAV_324_QHD_NOGPS_B1_V01.01.B03_Venus_R9\ Done! |
08-13-2018, 12:21 | #52180 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Symphony V47 HW3 V11 MTK6580 Firmware Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Symphony ProdName : V47 ProdModel : V47 Device : V47 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-n0.mp2-V1_len6580.we.n_P50 [Read Ok] : preloader_rs631.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / rs631 / EMMC Android Info saved HWConfig Info saved FW Size : 1987 MiB Scatter saved to : J:\Copy-Upload\New folder (4)\MT6580__Symphony__V47__V47__7.0__alps-mp-n0.mp2-V1_len6580.we.n_P50\ All done! |
08-13-2018, 12:22 | #52181 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Winstar WS112 MTK 6580 Firmware Read Done By CM2 Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E09E50772D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E09E50772D9 [eMMC] : FLASH_BRT : 0x00020000 , 0x00020000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x6D75BC6318A2BAA0A98ACE4F84C2E087 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Winstar ProdName : B36E4 ProdModel : WS112 Device : WS112 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_droi6580.weg.m_P29 [Read Ok] : preloader_b36e841b15.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / b36e841b15 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1661 MiB Scatter saved to : J:\Copy-Upload\New folder (5)\MT6580__Winstar__WS112__WS112__6.0__alps-mp-m0.mp1-V2.34_droi6580.weg.m_P29\ All done! Done! |
08-13-2018, 12:24 | #52182 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Samsung J210F Clone Frimware Read Done By CM2 Boot Ok! Reading Flash Content now ... Brand : samsung ProdName : Galaxy J2(2016) ProdModel : SM-J210F Device : Galaxy J2(2016) AndroidVer: 4.4.4 MTKxCPU : MT6577 MTKxPRJ : J7725_SK_4.1_V1.1 [Read Ok] : preloader_j7725.bin [Read Ok] : DSP_BL [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : EBR2 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6577 / V1.0.0 / j7725 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 456 MiB Scatter saved to : D:\New folder (6)\MT6577__samsung__SM-J210F__Galaxy_J2(2016)__4.4.4__J7725_SK_4.1_V1.1\ All done! |
08-13-2018, 12:24 | #52183 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | sony experia f8332 firmware backup don Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048602A26CD870C3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A26CD870C3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x05E7B28E76F3847FB30C88BD5274627A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : alps ProdName : full_zechin6580_weg_m ProdModel : F8332 Device : zechin6580_weg_m AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_zechin6580.weg.m [Read Ok] : preloader_zechin6580_weg_m.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / zechin6580_weg_m / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1024 MiB Scatter saved to : C:\Users\alimobile\Desktop\MT6580__alps__F8332__ze chin6580_weg_m__7.0__alps-mp-m0.mp1-V2.34_zechin6580.weg.m\ All done! Done! Elapsed: 00:06:23 Reconnect Power/Cable! Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048602A26CD870C3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A26CD870C3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x05E7B28E76F3847FB30C88BD5274627A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P15_1_2g_n NVM Read Ok, MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P15_1_2g_n_ eMMC.spnv Done! Elapsed: 00:00:15 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6580 , Project : zechin6580_weg_m , Storage : EMMC Files found : 9 , Set to Flash : 8 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : zechin6580_weg_m Device CPU : MT6580 Device IntName : full_zechin6580_weg_m Device Version : 7.0 Device Compile : 7/31/2017 8:36:51 AM Device Project : alps-mp-m0.mp1-V2.34_zechin6580.weg.m Device ExtInfo : F8332 Ready to Flash! |
The Following User Says Thank You to alimobile279 For This Useful Post: |
08-13-2018, 12:25 | #52184 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Tinmo F3000 Nand 6572 Firmware Read Done By CM2 Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00EC00BC0000006A005600EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0096 , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 00EC 00BC 0000 006A 0056 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x6D75BC636E3D191EF1AF41725A01F56C INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_c799_q21_f3000.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / c799_q21_f3000 / NAND FW Size : 261 MiB Brand : alps ProdName : c799_q21_f3000 ProdModel : F3000 Device : c799_q21_f3000 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.5 Android Info saved Scatter saved to : E:\HM 4.4.2_1\New folder (9)\MT6572_NAND_alps__F3000__c799_q21_f3000__4.4.2 __ALPS.KK1.MP7.V1.5 Done! |
08-13-2018, 12:34 | #52185 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Koreya K63 MTK 6580 Frimware Read Done By CM2 Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : h828 ProdName : h828 ProdModel : h828 Device : h828 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_YUANDA6580.WE.L [Read Ok] : preloader_yuanda6580_we_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / yuanda6580_we_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1200 MiB Scatter saved to : L:\New folder\MT6580__h828__h828__h828__5.1__ALPS.L1.MP6. V2_YUANDA6580.WE.L\ All done! |
