08-15-2018, 09:09 | #52276 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile A120 v2 hang on logo don With Great Cm2 Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A348AF4117 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A348AF4117 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x0386520DF1C5CE9247338EA32588D9FB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4031a , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : Unknown (not supported or without battery) SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:29 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:27 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:14 Reconnect Power/Cable! |
08-15-2018, 09:19 | #52277 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | QMobile X36 7.0 Remove FRP Lock Done :) Code: Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : QMobile_X36 Model Brand : QMobile Model Device: QMobile_X36 AndrVersion : 7.0 BaseBand CPU: X36 CompileDate : 9/20/2017 4:27:17 AM Project Ver : NRD90M Model Ext : QMobile X36 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:27 Reconnect Power/Cable! Code: Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001039F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
08-15-2018, 09:34 | #52278 (permalink) |
Freak Poster Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 144 | MT6737_Onyx-3+LTE_6.0_EUROSTAR_EUROSTAR_Onyx-3+LTE_V1.5_02-12-2016 MT6737_Onyx-3+LTE_6.0_EUROSTAR_EUROSTAR_Onyx-3+LTE_V1.5_02-12-2016 CM2 Format Only Hang Logo Done By Zaka Ullah Bhatti |
The Following User Says Thank You to bhatti123 For This Useful Post: |
08-15-2018, 09:54 | #52279 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Rivo Rx90 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D4200D11FF29D7255 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200D11FF29D7255 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395BC22F68C8268B000A325578F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
08-15-2018, 10:30 | #52280 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | XIAOMI REDMI 4A ROLEX SnapDragon 425 [MSM8917] PATTERN & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN & FRP(XIAOMI REDMI 4A ROLEX SnapDragon 425 [MSM8917])USB THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
08-15-2018, 10:31 | #52281 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | XIAOMI REDMI 5 PLUS VINCE SnapDragon 625 [MSM8953] PATTERN,FRP&MI ID REMOVE Done SUCCESSFULLY REMOVE PATTERN,FRP&MI ID(XIAOMI REDMI 5 PLUS VINCE SnapDragon 625 [MSM8953])USB THANKS INFINITY-BOX TEAM |
08-15-2018, 10:31 | #52282 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO A6020A40 SnapDragon 610 [MSM8936] FRP REMOVE Done SUCCESSFULLY REMOVE FRP(LENOVO A6020A40 SnapDragon 610 [MSM8936])USB THANKS INFINITY-BOX TEAM |
08-15-2018, 10:31 | #52283 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A33F SnapDragon 410 [MSM8916] PATTERN & FRP REMOVE Done SUCCESSFULLY REMOVE PATTERN & FRP(OPPO A33F SnapDragon 410 [MSM8916])USB THANKS INFINITY-BOX TEAM |
08-15-2018, 10:32 | #52284 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO K33 KARATE SnapDragon 430 [MSM8937] FRP REMOVE Done SUCCESSFULLY REMOVE FRP(LENOVO K33 KARATE SnapDragon 430 [MSM8937])USB THANKS INFINITY-BOX TEAM |
08-15-2018, 10:50 | #52285 (permalink) |
No Life Poster Join Date: Jan 2015 Location: STATE OF JAMMU & KASHMIR
Member: 2327602 Status: Offline Sonork: 100.1620953 Thanks Meter: 276 | Q mobile i2 pro frp/user lock reset/read flash file done with cm2 Q MOBILE I2 PRO FRP/USER LOCK RESET/READ FLASH FILE DONE WITH CM2 RESET USER LOCK/FRP Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011F7FC000 State : 0x0001 Mount : /cache Size : 0x000000000FA00000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:23 READ FLASH FILE Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Prepare Ok! - > Wait phone connected ... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! - > Wait phone connected ... Phone found! [ 14 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : i2_PRO Model Brand : QMobile Model Device: i2_PRO AndrVersion : 5.1 BaseBand CPU: I2 PRO Project Ver : QMobile_i2_PRO_MP_05_12 Model Ext : QMobile i2 PRO [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2315 MiB Saved to : C:\Users\user\Desktop\Shazz File,s\I2_PRO_i2_PRO_5.1_QMobile_i2_PRO_MP_05_12_Q Mobile_i2_PRO\ Done! Elapsed: 00:08:24 Reconnect Power/Cable! |
The Following User Says Thank You to shazzmob For This Useful Post: |
08-15-2018, 11:05 | #52286 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinx X5010 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464536324D42035ABCD06EA4A5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D42035ABCD06EA4A5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F3953EEC99F8D1B1B555FF3C6545 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
08-15-2018, 11:43 | #52287 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5i MT6582 Logo Stuck Fix Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040509A1EDBA91AF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040509A1EDBA91AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39542A07184168CDCC12CA64D64 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
08-15-2018, 12:35 | #52288 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | VIVO V7+ 1716 Format + Frp Reset Done In Single Click Via Infinity CM2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : 249C9EFE ID_BLOCK_L : 27F6DD38A32AFBA773C5B747A39E5261 ID_BLOCK_L : 753AB047BD456CD5BC09CF9837DDD0AA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mubarak2344 For This Useful Post: |
08-15-2018, 12:37 | #52289 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Lenovo K50a40 Format + Frp Reset Done In Single Click Via Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6752 BB_CPU_NME : [MediaTek] MT6732|MT6752_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8F NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200BB61CA656217 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200BB61CA656217 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x97F8A39EDE21DA53FFA7A196E57FC085 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
08-15-2018, 12:52 | #52290 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Lenovo A6020a46 Format + Frp Reset Done In Single Click Via Infinity CM2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 610 [MSM8936] ID_BLOCK_S : 09BE6303 ID_BLOCK_E : 00010001 ID_BLOCK_L : 4387339C4A6288FBAA22B2E0A1357831 ID_BLOCK_L : 3C33C640B6364F806EA82C10D2EE9618 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
