10-20-2018, 14:57 | #54001 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Lenovo TB-X103F FRP removed Code: Card found : 3B4417C4 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 212 [APQ8009] ID_BLOCK_S : 0A951125 ID_BLOCK_L : A24238C671FDEAE5C2B7594681D85870 ID_BLOCK_L : 4C07892015BC2EA75A95FE373DF0EEED Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
10-20-2018, 14:57 | #54002 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | samsung clone GT-i8552 galaxy win hang on logo one click format Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D0033D265402F8B [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB9E2EB77CE29B73B68D029AED1E36D0A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to naveedullah0044 For This Useful Post: |
10-20-2018, 15:04 | #54003 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Tecno s1 flashing done With King Infinity CM2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004548384344340119851D13B465 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 4DC8H [eMMC] : FLASH_CID : 7001004548384344340119851D13B465 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0xB9E2EB77A22EBBA2C4A57DAF1600E962 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : mtk_android , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4003 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000380000-0x0000000000500000 Erase : 0x0000000001C80000-0x00000001C5300000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash Write Done, time used : 00:06:51 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Data Verify Done, time used : 00:00:06 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:21 Reconnect Power/Cable! |
10-20-2018, 15:10 | #54004 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Qmobile i5.5 FRP Remove with cm2 Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001341F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:30 |
10-20-2018, 17:59 | #54005 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | MINT MOBILE M3cr stuck on logo done by flashing Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 30 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_320x480.bin Write Data ... Write Data Ok! Write CodeData : fblogo_320x480.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:02:54 Reconnect Power/Cable! |
10-21-2018, 09:03 | #54006 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile xl40 reset password done by cm2 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 38F2C4DE77CCAF07620848EB32341CED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 15 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 38F2C4DE77CCAF07620848EB32341CED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-21-2018, 09:37 | #54007 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | China MJ Phone M200 MT6261 Read Code Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 5B93054A99F4B476273810CFFD631177 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 0085 PLock|MobTrack : Not active Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
10-21-2018, 09:39 | #54008 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone J710F Read Pattren Done With Phardo King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E355530304D02ADC282308081 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D02ADC282308081 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395C284B66F1931A0726F72B3B4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 268357491 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
10-21-2018, 09:39 | #54009 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo y65 reset pattern done by cm2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 90F08057 ID_BLOCK_L : C01F04DF4ACD0240DC1C5CBE5A41F58E ID_BLOCK_L : A9EE649B6999D86968E51B2483093C7E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GE6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
10-21-2018, 10:23 | #54010 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Jazz J7 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 70010045483843453801115E64346371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 70010045483843453801115E64346371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39504424C33916A0DF1BC62C0A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-21-2018, 11:03 | #54011 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x32 hang on logo done by cm2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 19 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B1F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
10-21-2018, 13:02 | #54012 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A57 QLM Pattren Reset Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : F4BCBC2F ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 0FDF5EEADCC4534C8FDBDF8D2A85C2BF ID_BLOCK_L : 685BC2CF7E2CA535F4F1DAC1E5B4C6B5 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
10-21-2018, 13:19 | #54013 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I2 SPD77XX Hanging Probelam Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001545F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
10-21-2018, 14:56 | #54014 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x30 hang on logo done by cm2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101159B80686233 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101159B80686233 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3950EC371ED77CF47B19CCCCEE3 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3744 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:55 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:58 Reconnect Power/Cable! |
10-21-2018, 15:01 | #54015 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile s3 reset pattern done by cm2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050748A1C92F7289 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050748A1C92F7289 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DE91EF3182F0C3EBF6EAFC24CC INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
