07-25-2019, 05:23 | #59866 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Quote:
07-25-2019, 05:27 | #59867 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile double dhamal hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1A8 378E57AF7_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read Flash [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Read Ok, 4194304 bytes Saved to : G:\Mix Flash File\0D8B27B2B693_SPRD_SPI_WINBOND_W25Q_4MiB.bin Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
07-25-2019, 11:16 | #59868 (permalink) |
Freak Poster Join Date: Feb 2014 Location: bhilai
Member: 2125323 Status: Offline Thanks Meter: 63 | Voto v4 pin lock pattern lock frp done by cm2 VOTO V4 PIN LOCK PATTERN LOCK FRP DONE BY CM2 |
The Following User Says Thank You to jiten007 For This Useful Post: |
07-25-2019, 12:26 | #59869 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | LG K8 K350n FRP Reset done SW : LGK350nAT-01-V10k-EUR-XX-FEB-27-2019+0 ----------------------- Card found : 07XXXXXX , v0137 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS 3.0 , ver.1.1 , with proto ver.01000004 HWInfo : BaseBand : MT6735 HWInfo : ChargeLv : 50% HWInfo : MEM_INFO : H8G1e , MEM_LEN : 0x00E90000 [eMMC 8 GiB] DevInfo : Model : LG-K350n , Type : K35014h DevInfo : ANDROID 6.0 DevInfo : PSN : CT67S160603000124 , PID : LGK350OJSGV49T DevInfo : IMEI : 357823073375408 DevInfo : SecMode : N , Build : U , RCT : 000F4240 SWInfo : SWver : V14h , SW : LGK350nAT-01-V10k-EUR-XX-FEB-27-2019+0 SWInfo : FacSW : LGK350nAT-00-V14h-GLOBAL-COM-FEB-27-2019+0 RegInfo : Region : COM , Provider : GLOBAL Prepare passed, mode 0x01 Boot done! Brand : lge ProdName : mm1v_global_com ProdModel : LG-K350 Device : mm1v AndroidVer: 6.0 SWVersion : LGK350AT-00-V14h-GLOBAL-COM-FEB-27-2019+0 Manufact. : LGE LGMxCPU : MT6735 Done! Elapsed: 00:00:14 -------------------------------------- Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#0 block Ok! Erase FRP#1 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:22 |
The Following 2 Users Say Thank You to gile@gile For This Useful Post: |
07-25-2019, 16:36 | #59870 (permalink) |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | motorola w375 phone psw reset done motorola w375 phone psw reset done COM12 [VCP0] selected Action: format Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... rom code version: 0411 initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.64 HW version: MOTOROLA_H80S LP ver: 0064_011 Flex ver: FLEX_A5_003 cpu id: 08B6 imei eeprom: 3536140109009506 required SW version: 0.0.64 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 361401090095_20190725-201329.34E.bin Check Flash-2 Done Write... Write Done Finished, time used: 268 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to jawad_anis For This Useful Post: |
07-26-2019, 00:12 | #59871 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 214169 Status: Offline Thanks Meter: 37 | Hyundai E465Go Google Account removed 100% Card found : 214D**** , v0137 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2 Operation : Format FS / Reset Settings [ v2.00r2 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
The Following 2 Users Say Thank You to jimmy-d For This Useful Post: |
07-26-2019, 06:25 | #59872 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile X700 Pro F.R.p Reset Done Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM264) MODE : PRELOADER PORT PORT : 264 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM264) MODE : PRELOADER PORT PORT : 264 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D333238376D004219A3F2C4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832334D42006D37C4F2A319 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q823MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CA5C8F3E715D9D98AC8F3C8F79506B41 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
07-26-2019, 06:40 | #59873 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | @@@@@@@@@@@@@symphony v155 hang on logo and frp remove firmware backup without any da Code: Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: F40122426977696E20100000E32C50F EMMC: VEN : BIWIN | OEM : 2201 | DEV : Biwin EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B36524F5958EA2A5A0E82FB5F591619D DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-11-05 Build Time : 1543906037 Product Model : V155 Product Brand : Symphony Product Name : V155 Product Device : V155 Product Board : V155 Product Manfct : Symphony Product Info : V155 Product Board : k39tv1_bsp_1g Board Platform : mt6739 USERDATA : ENCRYPTED Done! Elapsed: 00:00:18 Code: Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: F40122426977696E20100000E32C50F EMMC: VEN : BIWIN | OEM : 2201 | DEV : Biwin EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B36524F5958EA2A5A0E82FB5F591619D DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:47 Reconnect Power/Cable! Code: Operation : Read Firmware [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: F40122426977696E20100000E32C50F EMMC: VEN : BIWIN | OEM : 2201 | DEV : Biwin EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B36524F5958EA2A5A0E82FB5F591619D DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-11-05 Build Time : 1543906037 Product Model : V155 Product Brand : Symphony Product Name : V155 Product Device : V155 Product Board : V155 Product Manfct : Symphony Product Info : V155 Product Board : k39tv1_bsp_1g Board Platform : mt6739 MT6739__Symphony__V155__8.1.0__O11019__V155 Read : preloader.bin Read : recovery.img Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : mcupmfw.img Read : nvram.bin Read : lk.bin Read : loader_ext.img Read : boot.img Read : logo.bin Read : odmdtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 61% Read : system.img ExtSparse : Compression ratio : 12% Read : cache.img Read : userdata.img FW Size : 1.43 GB Android Info saved : _Android_info.txt Scatter : MT6739_Android_scatter.txt Saved to : C:\Users\kotha\Desktop\MT6739__Symphony__V155__8.1.0__O11019__V155\ Done! Elapsed: 00:03:15 |
The Following User Says Thank You to kothamamun For This Useful Post: |
07-26-2019, 09:31 | #59874 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V7 PLUS 1716 AND:8.1.0 SnapDragon 625 [MSM8953] BRUSH Done SUCCESSFULLY BRUSH DONE(VIVO V7 PLUS 1716 AND:8.1.0 SnapDragon 625 [MSM8953])USB THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
07-26-2019, 09:34 | #59875 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | 10 OR.E AND:8.1.0 SnapDragon 430 [MSM8937] BRUSH Done SUCCESSFULLY BRUSH DONE(10 OR.E AND:8.1.0 SnapDragon 430 [MSM8937])USB THANKS INFINITY-BOX TEAM |
07-26-2019, 09:40 | #59876 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO A6020A46 AND:5.1.1 SnapDragon 610 [MSM8936] BRUSH Done SUCCESSFULLY BRUSH DONE(LENOVO A6020A46 AND:5.1.1 SnapDragon 610 [MSM8936])USB THANKS INFINITY-BOX TEAM |
07-26-2019, 09:44 | #59877 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | ONE PLUS X AND:6.0.1 SnapDragon 801 [MSM8974] BRUSH Done SUCCESSFULLY BRUSH DONE(ONE PLUS X AND:6.0.1 SnapDragon 801 [MSM8974])USB THANKS INFINITY-BOX TEAM |
07-26-2019, 09:58 | #59878 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | VIVO V11 PRO 1804 AND:8.1.0 SnapDragon 660 [MSM8956 Plus] BRUSH Done SUCCESSFULLY BRUSH DONE(VIVO V11 PRO 1804 AND:8.1.0 SnapDragon 660 [MSM8956 Plus])USB THANKS INFINITY-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
07-26-2019, 11:33 | #59879 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Huawei chm u01 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Huawei Device Model : CHM-U01 Device CPU : MT6582 Device IntName : CHM-U01 Device Version : 4.4.2 Device Compile : 8/27/2015 3:31:46 AM Device Project : ALPS.KK1.MP1.V2.11 Device ExtInfo : CHM-U01 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A2EA88A15B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040503A2EA88A15B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0386520DD949DCE729134AB0DAA7E23B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3964 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:26 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:58 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:33 Reconnect Power/Cable! |
07-26-2019, 11:36 | #59880 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile m350 reset pattern done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D42016107F05814AB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D42016107F05814AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0CF2E6DEE92F731C98095D68AAC4337B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
