Old 07-31-2019, 15:10   #59956 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 980
Vgotel ocean 6 reset frp done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 19 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:25
Reconnect Power/Cable!
Old 07-31-2019, 17:58   #59957 (permalink)
Member: 580077
Sonork: 100.1591941
Thanks Meter: 161
alcatel 9001d frp done (cable edl )
Card found : 7B6F6528 , v0138
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 0618CAF9
ID_BLOCK_L : 8E766CEA45D1DEC9B6EB656AB58C0444
ID_BLOCK_L : F3820C9F9003AB38DD187DAAB877616A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
The Following User Says Thank You to nori2007 For This Useful Post:
Old 08-01-2019, 04:22   #59958 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
OALE X1 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : F40122426977696E20103237313664AF
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
[eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
[eMMC] : FLASH_CID : F40122426977696E20103237313664AF
[eMMC] : FLASH_LEN : 0x00000001CD000000
[eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395B1616AFC27051A63AADF1C17
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:40
Old 08-01-2019, 05:36   #59959 (permalink)
Member: 2233266
Thanks Meter: 242
v120 frp done cm2 mtk-morning work
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Running DA ver.4.2 on BBID : 0x9C
eMMC Flash : 90014A483847346132A559C33AC924B9
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A559C33AC924B9
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x3A62B5451D5116985FB43DECD36E4FFB
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Old 08-01-2019, 07:45   #59960 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Nokia N3 MT6737 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 460001154D32364E2FED0342153FFDE4
[eMMC] : FLASH_INF : [SAMSUNG] , BM26N
[eMMC] : FLASH_CID : 150100464E36324D4203ED2FE4FD1615
DEV RID : 0xD9C8F395F411038CE92B2B0925EEC6EB
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:53
Old 08-01-2019, 08:38   #59961 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Huawei Y520-U22 MT6572 Hanging Probelam Fix Only Formate With King Infinity CM2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040300A574B89131
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040300A574B89131
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3951D6447D2C99655A00ED030C6
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
Old 08-01-2019, 09:27   #59962 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Oppo A37FW QLM FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Reset Settings [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26DFF941
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 46BED4228D190601FE53BDA26D34BC8C
ID_BLOCK_L : BAC977D6DB4AF471946334EDE70E1823
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:12
Old 08-01-2019, 10:41   #59963 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
OALE X2 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : F40122426977696E2010323731368481
[eMMC] : FLASH_CID : F40122426977696E2010323731368481
DEV RID : 0xD9C8F3955FA5AB5383231A731E928027
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:34
Old 08-01-2019, 11:03   #59964 (permalink)
Member: 1025102
Thanks Meter: 73
Reser FRP Motorola TX 1700 - OK
Old 08-01-2019, 11:07   #59965 (permalink)
Member: 1025102
Thanks Meter: 73
Goog reset FRP Motorola TX 1700
Old 08-01-2019, 11:53   #59966 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 980
Huawei mya l22 reset frp done by cm2
Card found : S/N : 73CA70CC , v0137
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D33314553B30D421DB7DDF2
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:20
Old 08-01-2019, 11:55   #59967 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 980
VGO TEl I550 PLUS RESET PASSWORD DONE BY CM2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 42D977B475618E444EB4519E3048A2BB
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Old 08-01-2019, 11:57   #59968 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 980
Voice v990 hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_197 C8E8AF84A_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
Old 08-01-2019, 12:01   #59969 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 980
Rivo m1 hang on logo done by cm2
Infinity SC Firmware Detected
FW Size : 1653 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : M1
Device Model : sp7731c_1h10_32v4
Device CPU : sp7731ceb
Device IntName : sp7731c_1h10_32v4_oversea
Device Version : 6.0
Device Compile : 3/9/2017 11:24:09 AM
Device Project : MRA58K release-keys
Device ExtInfo : M1
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x21 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_720x1280.bin
Write Data ...
Write Data Ok!
Write CodeData : logo2.bin
Write Data ...
Write Data Ok!
Write CodeData : logo3.bin
Write Data ...
Write Data Ok!
Write CodeData : logo4.bin
Write Data ...
Write Data Ok!
Write CodeData : logo5.bin
Write Data ...
Write Data Ok!
Write CodeData : logo6.bin
Write Data ...
Write Data Ok!
Write CodeData : logo7.bin
Write Data ...
Write Data Ok!
Write CodeData : logo8.bin
Write Data ...
Write Data Ok!
Write CodeData : logo9.bin
Write Data ...
Write Data Ok!
Write CodeData : logo10.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:09
Old 08-01-2019, 13:16   #59970 (permalink)
Member: 2233266
Thanks Meter: 242
spd 6531e formate done cm2 spd
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.74852 seconds with 9 queries
