Old 11-26-2019, 12:17   #61351 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,460
LenovoTB3-710F Pattern Read
Brand     : Lenovo
ProdName  : LenovoTB3-710F
ProdModel : Lenovo TB3-710F
Device    : TB3-710F
AndroidVer: 5.0.1
MTKxCPU   : MT8127
MTKxPRJ   : TB3-710F_S000007_151015_ROW
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 8127
BB_CPU_NME : [MediaTek] MT8127_S00
BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8D
NAND Flash : NOT INSTALLED
eMMC Flash : 1101003031364737320051E8B27142E1
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 27G61
[eMMC] : FLASH_CID : 1101003031364737320051E8B27142E1
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xD5229C2526F807F6714669936B49DEB9
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 1478963
Done!
Elapsed: 00:00:16
Old 11-26-2019, 12:31   #61352 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,034
Wiko sunny 4 w-k130 firmware backup done world first
Operation : Read FW [ v2.03 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level    : OPM2.171019.012
Display ID     : OPM2.171019.012 release-keys
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2019-06-05
Build Time     : 1559298842
Product Info   : W_K130
Product Model  : W-K130-TMV
Product Brand  : WIKO
Product Name   : W-K130-TMV
Product Device : W-K130
Product Manfct : WIKO
Product Board  : k130
Board Platform : sp7731e
VlnrLevel : 0x00
SP7731E__WIKO__W-K130-TMV__8.1.0__OPM2.171019.012__W_K130
Read : prodnv.img
ExtSparse : Compression ratio : 16%
Read : phase.cfg
Read : recovery.img
Read : tos.bin
Read : sml.bin
Read : u-boot.bin
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Read : nvitem_w.bin
Make : persist.img
Read : gnssmodem.bin
Read : gnssbdmodem.bin
Read : modem_wcn.img
Read : modem_w.bin
Read : deltanv_w.bin
Read : gdsp_w.bin
Read : pm_sys.bin
Read : boot.img
Read : system.img
ExtSparse : Compression ratio : 91%
Make : cache.img
Read : vendor.img
ExtSparse : Compression ratio : 81%
Read : vbmeta.img
Make : userdata.img
Read : u-boot-spl.bin
Firmware size : 0x660F4944 ( 1.59 GiB )
Android Info saved : _Android_info.txt
Done!
Elapsed: 00:31:25
The Following 4 Users Say Thank You to kothamamun For This Useful Post:
Old 11-26-2019, 12:34   #61353 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,460
QMobile i2_POWER Flash
Model Name  : i2_POWER
Model Brand : QMobile
Model Device: i2_POWER
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 2016-11-28 8:41:14 AM
Project Ver : QMobile_i2_POWER_MP_08_11
Model Ext   : QMobile i2 POWER
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:28
Infinity SC Firmware Detected
FW Size : 2776 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : QMobile
Device Model   : i2_POWER
Device CPU     : sp7731cea
Device IntName : i2_POWER
Device Version : 6.0
Device Compile : 11/28/2016 8:41:14 AM
Device Project : QMobile_i2_POWER_MP_08_11
Device ExtInfo : QMobile i2 POWER
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 31 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:07:41
Old 11-26-2019, 13:29   #61354 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 982
Qmobile x2 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : s3510ap
ProdModel : QMobile X2
Device : s3510ap
AndroidVer: 4.4.2
MTKxCPU : MT6571
MTKxPRJ : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:15
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:15
Old 11-26-2019, 13:59   #61355 (permalink)
Member: 2936988
Thanks Meter: 29
Qmobile i5i Frp remove CM2 SPD2 DONE
The Following 2 Users Say Thank You to Zunair Mobile For This Useful Post:
Old 11-26-2019, 15:40   #61356 (permalink)
Member: 1172662
Sonork: 100.1625907
Thanks Meter: 9
client version is too old
respected team member please solve my problem i am sill waiting last five months
Card found : 2014F894 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19
Operation : Identify [FTM] [ v1.19 ]
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model : E1I
HW version : 3.0
HW RF_BAND : G_900_1800^W_1_8^L_1_3_5_20_40_41
SW version : E1M-064E-0-00WW-B01
SW serialnm : E1MLH3579E602088
Project DevCode : E1M
Bootloader type : RETAIL
Security Version : 0004
Done!
Elapsed: 00:00:09
Operation : Reset Settings [FTM] [ v1.19 ]
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Looking for SVC package in local database ...
SW : E1M-064E-0-00WW-B01
Package : E1M-064I
Device : E1I ( E1M )
BLType : RETAIL
SecVer : 04
Device authentification ...
Processing server operation ...
Connecting to server...
Connected
Authenticating...
Authentication error:Server reported error: 05 AUTHENTICATION_FAILED
Disconnected
Disconnected
Finished
Error : Device auth failed! Server reported error!
Send log and report.log to support! Include device info also!
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Package : E1M-064I
BLType : RETAIL
SecVer : 04
Connected
Authenticating...
Disconnected
Disconnected
Finished
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Package : E1M-064I
BLType : RETAIL
SecVer : 04
Connected
Authenticating...
Authenticated
Checking Client version...
Client version check error:Error: Client version is too old
Disconnected
Disconnected
Finished
Old 11-26-2019, 17:57   #61357 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,460
GFIVE_President_Smart_A98 Flash
Model Name  : revo_6408
Model Brand : GFIVE
Model Device: GFIVE
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA_HD
CompileDate : 2015-11-27 2:46:32 AM
Project Ver : GFIVE_President_Smart_A98-151127
Model Ext   : GFIVE_President_Smart_A98
Elapsed: 00:00:41
Loading    : SP7731GEA_GFive_new_64+8_RC_151127_B1.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : SP7731GEA_GFive_new_64+8_RC_151127_B1
FastCheck  : 0x003AAB4CBE
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : wcnnvitem.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : FWVGA_logo_256_td.bmp
File : fastboot_FWVGA_logo_256_td.bmp
File : cache.img
File : u-boot.bin
File : SC77xx.xml
Load Ok!
======= Flash
[ MCU ] : SP7731GEA_GFive_new_64+8_RC_151127_B1.pac
PacCPUinfo : SC77xx
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 31 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : wmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : wdsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : wcnmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : FWVGA_logo_256_td.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fastboot_FWVGA_logo_256_td.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:02:08
Old 11-26-2019, 18:09   #61358 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,460
GFIVE Falak Dead Recaver
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0E8ADFED1A79_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 11-27-2019, 09:09   #61359 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,875
Smile VgoTel i12 Read User Code Done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 10 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 01A98288F60A70DF2E0BBA262C1B59F1
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1199
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:34
Old 11-27-2019, 09:52   #61360 (permalink)
Member: 2253540
Thanks Meter: 27
Activation costs are a lot of good things though,,
I told everyone to use it
Old 11-27-2019, 11:22   #61361 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 982
Voice v50 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Identify : Code Integrity Check pass!
Done!
Elapsed: 00:02:49
Operation : Reset Settings [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:52
Old 11-27-2019, 12:04   #61362 (permalink)
laptop.dz's Avatar
Member: 834813
Thanks Meter: 72
Lg x230 (frp)
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 460001154D32584E7F32064287B0C006
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4206327F06C0A487
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0x032751D207BA1B71CA930F7BA0BB54EC
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:16
Old 11-27-2019, 12:05   #61363 (permalink)
CYB3R GSM's Avatar
Member: 2469611
Thanks Meter: 362
Originally Posted by LoveLess View Post
hey...
can u pls share the file..?
https://mega.nz/#!ZBwH2AAJ!mWZ9iEHiL...aY8emplkylu6Jw
Password: amazefileMP.V1
Old 11-27-2019, 12:10   #61364 (permalink)
laptop.dz's Avatar
Member: 834813
Thanks Meter: 72
Condor SP531 (frp)
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : FE014E50314A39354B12274BCC8663E3
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , K59J1
[eMMC] : FLASH_CID : FE014E50314A39354B12274BCC8663E3
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000001D3000000
[eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB]
DEV RID    : 0x032751D286F7ACC801381A11DB44ABAF
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:26
Old 11-27-2019, 12:13   #61365 (permalink)
laptop.dz's Avatar
Member: 834813
Thanks Meter: 72
Doogee x10
Operation : Write Flash [ v2.06 ]
Repartition   : Enabled
Flash Verify  : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW  : Enabled
SData Backup  : Disabled
Safe UserData : Disabled
Files :9
[FL] : Set : preloader_jc45btlc.bin
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : recovery.img
[FL] : Set : secro.img
[FL] : Set : logo.bin
[FL] : Set : md1rom.img
[FL] : Set : system.img
[FL] : Set : userdata.img
[FL] : Total size : 0x427831D3 [ 1.04 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM8)
MODE : BOOTROM
PORT : 8
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : MT6570_v1728_REPAIR | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA_6570.bin
AGENT : Found MT6570
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : MT6570
     EMI : SRC : preloader_jc45btlc.bin
     EMI : CNT : 0002
     EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 512.00 MB ]
     EMI : [01] : DRAM : EXTERNAL DRAM [LP/DDR2] , UNDEFINED : VEN : UNKNOWN   | DEV :  : RAM : [ 512.00 MB ]
     EMI : Init EMI from PRELOADER
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x20000000 [ 512.00 MB ]
        NAND: 98DE88A37251080000000000
        NAND:
              TSIZE  : 0x217800000 [ 8.37 GB ]
              ASIZE  : 0x1F7400000 [ 7.86 GB ]
              PSIZE  : 0x00004000 [ 16.00 KB ]
              BSIZE  : 0x00600000 [ 6.00 MB ]
              SSIZE  : 0x000007A0
              STYPE  : 0x0013
        CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : AC76CFFDD80AE356F04DE4E279062B72
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM10)
MODE : PRELOADER PORT
PORT : 10
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
OK
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Write : UBOOT
Write : BOOTIMG
Write : RECOVERY
Write : SEC_RO
Write : LOGO
Write : MD1IMG
Write : ANDROID
Write : USRDATA
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:03:52
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.88177 seconds with 9 queries
