Old 07-22-2009, 14:41   #601 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
kg-270 flash
COM3 [VCP0] selected
module v1.68
Device: LG-KG270
Checking data, wait...
Action: flash write
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL CIS Open KG270 KG270 P16 07 V10h XXX-XX JAN 24 200
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20090722-192716.B1E.bin
loading data...
data loaded
imei: 35858201803080400
reading eeprom-security_35858201803080400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35858201803080400_20090722-192717.B1E.bin
reading eeprom-complete_35858201803080400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35858201803080400_20090722-192718.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 73 sec
Remove/Install battery now !
The Following User Says Thank You to cel_phon For This Useful Post:
Old 07-23-2009, 01:35   #602 (permalink)
Gokuu2007's Avatar
Member: 712887
Sonork: gokuu2011
Thanks Meter: 349
repair imei
repair imei lg mg230 by infinity box is the best
COM4 [VCP0] selected
modulo v1.39
Servicio: LG-MG230
Checkeando datos, espere...
Habilitada la deteccion avanzada del chip
Action: imei repair
Boot ...
El Telefono deberia estar APAGADO !
Mantenga Presionado el boton Power !
Conectando, espere...
Deje de presionar el boton power ahora !
Flash 01227E223C2200:FEEA0000000000
Flash Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Seleccionar velocidad ...
921600
Seleccionar velocidad Done
Check flash ...
current eeprom imei: 010685812063135
current otp imei: 011171004575052
Archivo guardado: H:\InfinityBox\LGA\eeprom_010685812063135_LG-MG230_20090722-193213.B1E.bin
Version: 732-101V10a57MG230dP32FL
Check flash Done
Check space ...
Check space Done
Borrar: ...
Borrar: Done
Escribir ...
Escribir Done
Finalizado, tiempo usado: 30 sec
Quite/coloque la bateria ahora !
The Following User Says Thank You to Gokuu2007 For This Useful Post:
Old 07-23-2009, 06:45   #603 (permalink)
luqmaan751's Avatar
Member: 416940
Thanks Meter: 173
ALCATEL S319x unlock success
COM5 selected
module v2.80
Device: Alcatel-S319X, S319A
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
S319X-2FVDIT1_XH16DS32_JRD23_07A_PCB01_GPRS_MT6223_S00.M AUI_07A_W07_36_SP1_V20_2008-10-29_En_Fr_Es_It_De_simfree.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:3F30:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN
ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000
ffs offset/size: 00C00000/00400000
ffs address assigned: 00C00000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) check...
security area (code #1) fixed
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-100402.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CH16DS32
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
use default security area (code #3, part #1) pattern
..................security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20090723-101411.B0X.bin
Finished, time used: 627 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to luqmaan751 For This Useful Post:
Old 07-23-2009, 08:12   #604 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
KP105 UNLOCK OK
COM44 [VCP0] selected
module v1.65
Device: LG-KP105
Action: unlock
read unlock codes
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL BYT FR KP105 01 FL 208 V10b 208-20 NOV-05-2008 +0
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-static_20090723-104639.B1E.bin
loading data...
data loaded
imei: 35406503595369900
reading eeprom-security_35406503595369900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-security_35406503595369900_20090723-104639.B1E.bin
reading eeprom-complete_35406503595369900...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP105_eeprom-complete_35406503595369900_20090723-104641.B1E.bin
Check memory ...
loading data...
data loaded
code: 43911342
Finished, time used: 16 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 07-23-2009, 08:14   #605 (permalink)
nelsky's Avatar
Member: 583353
Thanks Meter: 259
C635 konka unlocked w/ easy pic inside
using this pinout easily unlocked by infinity....
KONKA C635
logs:
COM6 [VCP0] selected
module v2.82
Action: unlock
unlock method: smart fast
Model: Konka-C635
19200 autodetect
Initializing [6223:8A04:8A00]...
CPU: MT6223
chip: 0011:022C:000C
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E04
Date: 2005.07.11
Version: 1.0
Version: KAB635C_JMA_En_Fr_Sp_1.03.B22
Version: KONKA23_07A_HW
44 byte(s) read
imei: 359242010nelsky
connection Ok
157 byte(s) read
reading data...
reading data #4...
building new data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
br,
The Following User Says Thank You to nelsky For This Useful Post:
Old 07-23-2009, 09:05   #606 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
MOTOROLA C-261 FORMAT
COM3 [VCP1] selected
Action: format
Device: C261
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 0.1.44
HW version: MOTOROLA_E58S
LP ver: LP1_0144
Flex ver: FLEX_90_64_4706
cpu id: 08B6
imei eeprom: 3586050055181041
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35860500551810_20090723-140318.34E.bin
Check Flash-2 Done
Write...
Write Done
Finished, time used: 64 sec
Old 07-23-2009, 12:35   #607 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM26 [VCP0] selected
module v2.75
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:BC03:0000
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
identification#1 protocol ver: 04
ver. sw 1: CKT25_GEMINI_PCB01_GPRS_MT6225_S00.A522-008_8G-3_112_080730.BIN
ver. sw 2: A522-008_8G-3_112_080730, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 37 sec
Old 07-23-2009, 12:37   #608 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
COM3 [VCP2] selected
module v2.82
Action: reset settings
Model: LG-KG195
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:51C1:2EEE
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7332SA00-001
Version: FP_0620
60 byte(s) read
imei: 35000441253456
connection Ok
building list...
done
items to clear: 213
warning: wrong packet cs
items cleared: 202 of 213
building list...
done
items remains: 0
Finished, time used: 116 sec
Old 07-23-2009, 12:38   #609 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.82
Model: LG-KG195
19200 autodetect
CPU: MT6226
status: FF
Date: 2005.04.12
Version: 1.0
Version: FP_0620
60 byte(s) read
connection Ok
building list...
done
items to clear: 213
building list...
done
items remains: 0
Old 07-23-2009, 14:55   #610 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
Thanks Meter: 1,234
ZTE X761 New Version
==== log: [22/07/2009 13:55:22] ====
COM13 [VCP0] selected
module v2.79
Action: unlock
Model: ZTE-X761
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4203:0007
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X761_Z0_S_AFFA106
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35787302238460
connection Ok
157 byte(s) read
reading data...
writing data...
145 byte(s) read
reading data...
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
The Following User Says Thank You to The_Dj For This Useful Post:
Old 07-23-2009, 15:14   #611 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
module v2.75
Action: touchscreen calibration
mode: 1
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:E203:000B
Connecting, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: FXD-S3_FOREIGN_MR106_004_S5T24T-MC-C01-RF3198_V1.0.019_080605
Version: GINWAVE25_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-2)...
1 2 3 4 5 6 7 8 9error:
detection failed (9 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 33 sec
Old 07-23-2009, 18:24   #612 (permalink)
Member: 98928
Thanks Meter: 475
secssfully unlock and change lang ALCATEL C701X
use flash file from support area (sim free) , and lower ver every thing is ok
after write flash make ffs format
i used this file:C701X-2AALAP1_XC18BM25_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V17_2007-06-19_simfree_En_Fr_Tr_Ar.B0M
module v2.82
Device: Alcatel-C701X, C701A
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A03:8A02]...
CPU: MT6226
chip: 0031:74A1:A000
status: 01
Boot Done
Initialize ...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud ...
230400
Set baud Done
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.82F99 59C.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN_49C9B029].rpl
device-id: 82F9959C
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V17, D64F36B6
ffs offset/size: 01200000/00E00000
ffs address assigned: 01200000
sim-lock status: disabled
original imei: 35320501327255
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17__system_log_82F9959C_49C9B029_20 090721-230346.B0X.bin
Finished, time used: 239 sec
The Following User Says Thank You to bavesore For This Useful Post:
Old 07-24-2009, 06:35   #613 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,204
Alcatel S521a Unlock And flash Done with firmware SimFree!!!!!! Live Alive Again!!!!! Dead with other Box
Thanks Infinity Team!!!!
Best Regards
Old 07-24-2009, 06:42   #614 (permalink)
69eyes's Avatar
Member: 942693
Sonork: 1592619
Thanks Meter: 2,204
LG-MG120 Unlock Done!!!!
COM208 [VCP0] selected
module v1.39
Device: LG-MG120
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
flash: 01227E22022201:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 0110560xxxxxxxx
file saved: C:\Archivos de programa\InfinityBox\LGA\eeprom_011056000296003_LG-MG120_20090719-140752.B1E.bin
Check flash Done
Check space ...
finalization done
Check space Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Best Regards
The Following User Says Thank You to 69eyes For This Useful Post:
Old 07-25-2009, 01:43   #615 (permalink)
Member: 243158
Thanks Meter: 25
Alcatel-Mandarina-Duck-MD02 Successfully Unlocked
module v2.82
Device: Alcatel-Mandarina-Duck-MD01, MD02
"format ffs" active
write: Firmware
MD02X-2CRGES1_XC19FW21_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24_2008-09-19_En_Es_Euskera_Catalan_Galego_simfree.B0M.bin
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 00311F8:A000
status: 01
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A864C 0E6.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_E5797CF9].rpl
device-id: A864C0E6
ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw 2: MAUI.06A.W06.52.SP1.V24, 0683861A
ffs offset/size: 01000000/01000000
ffs address assigned: 01000000
original imei: 35719502130990
Write ...
security area (code #1) calculation...
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-Mandarina-Duck-MD01,MD02_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A _W06_52_SP1_V24__system_log_A864C0E6_E5797CF9_2009 0725-001200.B0X.bin
Area: Firmware
Write: Firmware
customization: CC19FW21
done
done
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-Mandarina-Duck-MD01,MD02_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A _W06_52_SP1_V24__system_log_A864C0E6_E5797CF9_2009 0725-002837.B0X.bin
Finished, time used: 1037 sec
The Following User Says Thank You to abdel7650 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 11.45948 seconds with 10 queries
