07-10-2020, 04:35 | #63691 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Lenovo A319 flash done ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101F795146F823D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101F795146F823D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x033C52172AD66BF8A3908151CE40B69D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3794 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:05:14 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:32 |
07-10-2020, 04:36 | #63692 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Reset Settings/Format FS [ v2.12 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM38) MODE : PRELOADER PORT PORT : 38 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : CCD078B388059BBA7C309C6DB98F146FADBF150F8ED49F2EF1 E26217638D329E AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201A1759B14C641 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BCA658FE653923DFF64E21E15C81EEEC DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 |
07-10-2020, 04:37 | #63693 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format FS / Reset Settings [ v2.05 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:05 |
07-10-2020, 04:40 | #63694 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 88 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000002F93F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:46 Reconnect Power/Cable! |
07-10-2020, 05:49 | #63695 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,114 | Lava a67 frp removed by king cm2 Chinese Miracle II [SPD module] v 1.24 Operation : Format File System / Reset Settings [ v1.24 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 40 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000007C9F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
07-10-2020, 06:24 | #63696 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 ITEL A25 (L5002) sp9832e FRP RESET DONE Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : L5002-F3210-9.0-OP-V040-20200507 Ver. Incmt : OP-V040-20200507 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 1588839139 Product Model : itel L5002 Product Brand : Itel Product Name : F3210 Product Device : itel-L5002 Product Manfct : itel Product Info : L5002 Product Board : L5002 Board Platform : sp9832e Display ID : L5002-F3210-9.0-OP-V040-20200507 Platform Version: MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_ITEL_RLS1_W19.36.4_P6 HW Version: sc9832e_modem CMP_Time : 02-27-2020 20:34:00 MODEM TAG : MOCORTM_18A_ITEL_RLS1_W19.36.4_P6_Debug_FM_BASE_18 A_ITEL_RLS1_W19.36.4_P6_sc9832e_modem_sharkle_Smar t_Phone UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:04:13 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:47 |
The Following 6 Users Say Thank You to amjadnona For This Useful Post: |
07-10-2020, 07:29 | #63697 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Oppo a37 reset frp done by cm2 Card found : 73CA70CC , v0144 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : OPPO ProdName : A37f ProdModel : A37f Device : A37f AndroidVer: 5.1.1 SWVersion : A37fEX_11.A.28_INT_028_201710081545 Manufact. : OPPO SysPatch : LMY47V DevComTime: 10/8/2017 9:26:49 AM QLMxCPU : MSM8916 USERData : NORMAL GCSec : EMPTY Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
07-10-2020, 07:31 | #63698 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Moto xt1774 reset frp done by cm2 Card found : 73CA70CC , v0144 Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8920 CID : 0x0002 IMEI : 355669080457982 UID : 9F616F3900000000000000000000 Model Info ============ DevModel : XT1774 IntName : owens SW Info ============ DevSWVer : Blur_Version.26.311.21.owens_verizon.verizon.en.US DevQCVer : LA.UM.5.6.r1-03800-89xx.0 BaseBand : M8920_02.02.06.73.04R OWENS_NA_CUST BootLDRv : moto-msm8920-BD.32 HW Info ============ eMMCInfo : 16GB SAMSUNG QE13MB RV=08 PV=0D FV=000000000000000D DRAMInfo : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F Lock Info ============ WarrantyVoid : no FRP Lock : no protection (77) Done! Elapsed: 00:00:10 Operation : Reset Settings [ v1.03 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:07 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1774 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1774 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1774 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:59 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : owens_verizon Model : Moto E (4) Plus FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:13 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:05 |
07-10-2020, 08:19 | #63699 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Echo Dune frp lock remove done Code: Operation : Identify [ v2.12 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100513832534D42004FBEC68DA347 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832534D42004FBEC68D5247 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q82SMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3FA9F36B9D8E56D182541DC1C7E41864 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : ECHO_DUNE_V06_20180821_1238 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-07-05 Build Time : 1534826311 Product Model : ECHO_DUNE Product Brand : ECHO Product Name : ECHO_DUNE Product Device : ECHO_DUNE Product Manfct : ECHO Product Info : ECHO_DUNE Product Board : ECHO_DUNE Board Platform : mt6737m USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) IMEI[0] : 35xxxxxxxxxxxxx0 IMEI[1] : 35xxxxxxxxxxxxx7 IMEI[2] : 35xxxxxxxxxxxxx6 NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Done! Elapsed: 00:00:24 Code: Operation : Reset Settings/Format FS [ v2.12 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x02 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100513832534D42004FBEC68DA347 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513832534D42004FBEC68D5247 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q82SMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3A3E00000 [ 14,56 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3FA9F36B9D8E56D182541DC1C7E41864 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 |
The Following 3 Users Say Thank You to Manikanika81 For This Useful Post: |
07-10-2020, 08:49 | #63700 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | QMobile XLI SC7731E 8.1.0/FRP/Logo Fix Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device ! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_512MB_RS_LOW Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1554788373 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-04-01 Build Time : 1555382463 Product Info : k101 Product Model : QMobile XLi Product Brand : QMobile Product Name : QMobile_XLi Product Device : QMobile_XLi Product Manfct : QMobile Product Model : XLi Product Model : XLi Product Board : k101 Board Platform : sp7731e Ver. Incmt : 1554788373 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem MODEM TAG : MOCORTM_17C_W18.23.4_P2_Debug_FM_BASE_17C_W18.23.4 _P2_sc7731e_modem_pike2_pub UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:01:51 https://www.youtube.com/watch?v=UalJp6hmgec |
07-10-2020, 13:47 | #63701 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Itel Power 400 Format FFS Done WITHOUT BOOT KEY SVC Mode Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : SPRD ( Legacy ) ModemInfo : Platform Version: MOCOR_16A.Itel_W18.19.4_Debug Project Version: it5617-G2423-EnUr-PK-20190905 BASE Version: BASE_SVN HW Version: sc6531efm_bar CMP_Time : 09-05-2019 15:40:22 SecInfo : IMEI[1] : 359XXXXXXXXXXX IMEI[2] : 35XXXXXXXXXXXX IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : D87E7618722A SEC_ID : 7ADEFFFFB6CF64B9 Done! Elapsed: 00:00:37 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to amjadnona For This Useful Post: |
07-10-2020, 14:39 | #63702 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Vgo tel ocean 6 hang on logo done by cm2 Card found: S/N : 73CA70CC , v0144 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Infinity SC Firmware Detected FW Size : 2582 MiB Load Ok! File Info Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : VGOTEL Device Model : OCEAN_6 Device CPU : VGOTEL Device IntName : OCEAN 6 Device Version : 6.0 Device Compile : 1/4/2017 1:48:28 AM Device Project : VGOTEL_OCEAN_6_V08 Device ExtInfo : OCEAN 6 Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 12 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x19 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731C_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin Write Data ... Write Data Ok! Write CodeData : logo_480x854.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x854.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Erase Block : PERSIST Erase block ... Block erase Ok! Write CodeData : sysinfo.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Erase Block : MISC Erase block ... Block erase Ok! Write FSImage : userdata.img Write Data ... Write Data Ok! Elapsed: 00:06:58 Reconnect Power/Cable! |
07-10-2020, 14:47 | #63703 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Infinix X650 (Hot 8 Lite) FRP RESET DONE Card found : A9EC786B , v0144 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.12 Load IDBase v518137 Ok! Operation : Reset Settings/Format FS [ v2.12 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 510001154D3336440824014267B6E1E4 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514436334D42012408E4E1B667 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E41DD6DA33990C8A11092C2A8E7888EB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:02:12 Reconnect Power/Cable! |
07-10-2020, 16:09 | #63704 (permalink) |
Member: 1555233 Status: Offline Thanks Meter: 2,192 | KING CM2 Qmobile Black Two FRP RESET DONE Card found : A9EC786B , v0144 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Operation : Identify [ v2.05 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : QMobile BlackTwo_MP_21_06 Ver. Incmt : 48 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-03-05 Build Time : 1500601636 Product Model : QMobile Black Two Product Brand : QMobile Product Name : Black_Two Product Device : Black_Two Product Board : sp7731cea Product Manfct : QMobile Board Platform : sc8830 Product Info : Black_Two Platform Version: MOCORTM_14B_7731C_W16.xx.x_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.xx.x MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 07-04-2016 13:42:20 MODEM TAG : MOCORTM_14B_7731C_W16.xx.x_Debug_TM_BASE_W16.xx.x_ sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN [EXTFS] Done! Elapsed: 00:03:05 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:43 |
The Following 4 Users Say Thank You to amjadnona For This Useful Post: |
07-10-2020, 21:03 | #63705 (permalink) |
Member: 2897012 Status: Offline Thanks Meter: 400 | LG ISAI FL hang on logo fix done Code: Operation : Identify [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS 3.0 , ver.1.0 , with proto ver.01000001 HWInfo : BaseBand : MSM8974 HWInfo : ChargeLv : 0% HWInfo : MEM_INFO : 032GE4 , MEM_LEN : 0x03A3E000 [eMMC 32 GiB] DevInfo : Model : LGL24 , Type : LGL2410a DevInfo : ANDROID 4.4.2 DevInfo : PSN : PT44060314031AT0D , PID : LGL2458aae3ae DevInfo : IMEI : 356458050028091 DevInfo : SecMode : U , Build : U , RCT : 000F4240 SWInfo : SWver : V10a , SW : LGL24AT-00-V10a-440-50-JUN-19-2014+0 SWInfo : FacSW : LGL24AT-00-V10a-KDDI-JP-JUN-19-2014+0 RegInfo : Region : JP , Provider : KDDI Prepare passed, mode 0x00 Boot done! Brand : KDDI ProdName : g3_kddi_jp ProdModel : LGL24 Device : g3 AndroidVer: 4.4.2 SWVersion : LGL24AT-00-V10a-KDDI-JP-JUN-19-2014+0 Manufact. : LGE LGMxCPU : MSM8974 Done! Elapsed: 00:01:29 Code: Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! Format UserData Format Cache Format done Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
The Following User Says Thank You to Manikanika81 For This Useful Post: |
