GSMSERVER GSM Shop
Old 07-31-2020, 09:33   #63961 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,204
Qmobile I6 Matel 1 MT6580 FRP Reset Done With King Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505073010EC582437
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505073010EC582437
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xD9C8F3950A68A708499F9ECCFF5030F1
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Reconnect Power/Cable!
Old 07-31-2020, 10:08   #63962 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,136
Cxcess x499 reset password done by cm2
Card found : 73CA70CC , v0144
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.06 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1A7 F213B80F7_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 07-31-2020, 10:09   #63963 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,136
Qmobile sp1000 reset password done by cm2
Card found : S/N : 73CA70CC , v0144
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 087CD88939EDF6F71A765D51257CB74C
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:23
Old 07-31-2020, 11:12   #63964 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,204
Qmobile I8I SPD77XX 2019 FRP Reset Done With King Infinity CM2
Card found: S/N : A19EC787 , v0144
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:28
Old 07-31-2020, 12:29   #63965 (permalink)
Member: 2963610
Thanks Meter: 34
E-Tachi B2 spd 6531e reset password done by infinity cm2
The Following 2 Users Say Thank You to Malik Shani G For This Useful Post:
Old 07-31-2020, 12:31   #63966 (permalink)
zeeshan ali 786's Avatar
Member: 2711874
Sonork: 100.650600
Thanks Meter: 98
good job................
The Following User Says Thank You to zeeshan ali 786 For This Useful Post:
Old 07-31-2020, 13:38   #63967 (permalink)
limonbogra's Avatar
Member: 2856614
Sonork: 100.650600
Thanks Meter: 81
lava ln9810 frp reset by cm2
Operation : Format FS / Reset Settings [ v2.01 ]
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:25
The Following 2 Users Say Thank You to limonbogra For This Useful Post:
Old 07-31-2020, 13:56   #63968 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,943
Smile QMobile i8i 2019
Operation : Format FS / Reset Settings [ v2.05 ]
Mode : Default [ Reset Settings + FRP ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : Qmobile : QMobile i8i 2019
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:37
Old 07-31-2020, 14:32   #63969 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,136
Qmobile n210 hang on call done by cm2
SCRD mode : AUTO
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Identify [ v1.06 ]
BootMode : FLASH
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
Boot Done!
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:21
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_109 7146F61B0_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:25
Operation : Read Flash [ v1.06 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Flash Ok, Size : 4.00 MiB
Platform Version: G399_ALX_M312_Qmobile_N210_FM_1CAM_3IN1_D_mEAPU_2S IM_V02_20191023
Saved to : G:\Mix Flash File\G399_ALX_M312_Qmobile_N210_FM_1CAM_3IN1_D_mEA PU_2SIM_V02_20191023.bin
Done!
Elapsed: 00:01:01
Old 08-01-2020, 12:58   #63970 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 616
Thumbs up Tecno F1 Repair IMEI, DUMP done
Operation : Identify [ v2.14 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM13)
MODE : PRELOADER PORT
PORT : 13
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BROM|BL  : 0xFF|0x01
BROM : PRELOADER PORT
MODE : TECNO : SECURE_v2 | Manual : Enabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_SWSEC.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 484A0190613447382809A532A786094C
DAInf: 4 : 2 : 156
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 90014A483847346132A509284C0986A7
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x1D2000000 [ 7,28 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        DRAM: 0x40000000 [ 1,00 GB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 3DDF01DB581CD414CC0868F483904E1A
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : O11019
Display ID     : F1-VP510EFG-GO-200622V20
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2020-06-05
Build Time     : 1592824943
Product Model  : TECNO F1
Product Brand  : TECNO
Product Name   : VP510
Product Device : TECNO-F1-PRO
Product Manfct : TECNO MOBILE LIMITED
Product Info   : k80_bsp
Product Board  : F1
Board Platform : mt6580
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
IMEI[0] : 3536
IMEI[1] : 3536
IMEI[2] : 3546
NVRAM check : Passed!
NVRAM : SEC NORMAL  [ No extra security ]
Done!
Elapsed: 00:00:28
Operation : Repair Security [ v2.14 ]
Mode : FLASH
PORT : 13
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
     DA : DRAM ready!
        EMMC:
Boot done!
IMEI[0] : 3536
IMEI[1] : 3536
IMEI[2] : 3546
IMEI[0] : 575758765875768
IMEI[1] : 765768768876861
Update NVRAM ...
Update dependencies ...
Done!
Elapsed: 00:00:29
Operation : Read Firmware [ v2.14 ]
ExtSparse   : Enabled
ForceRead   : Disabled
PORT : 13
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
     DA : DRAM ready!
        EMMC:
Boot done!
Ver. CodeName  : REL
Product Board  : F1
MT6580__TECNO_MOBILE_LIMITED__TECNO_F1__8.1.0__F1-VP510EFG-GO-200622V20__O11019__k80_bsp
SecureDevice : Paired type!
-> INFO : That device WILL dead after ReadOut Flashing!
-> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available!
-> INFO : In most cases you can "unsecure" device in Engineer mode
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : persist.img
ExtSparse : Compression ratio : 97%
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : odmdtbo.img
Read : vendor.img
ExtSparse : Compression ratio : 64%
Read : tz.img
Read : secro.img
Read : system.img
ExtSparse : Compression ratio : 20%
Read : cache.img
Read : userdata.img
FW Size  : 1,25 GB
Android Info saved : _Android_info.txt
Scatter  : MT6580_Android_scatter.txt
Saved to : C:\Users\YwS\Desktop\MT6580__TECNO_MOBILE_LIMITED__TECNO_F1__8.1.0__F1-VP510EFG-GO-200622V20__O11019__k80_bsp\
Done!
Elapsed: 00:08:35
The Following 3 Users Say Thank You to yuranc8 For This Useful Post:
Old 08-01-2020, 17:36   #63971 (permalink)
CYB3R GSM's Avatar
Member: 2469611
Thanks Meter: 366
Vivo PD1917F_EX MEta Mode Reset Done
Display ID     : O11019 release-keys
Ver. CodeName  : REL
Sec. Patch     : 2020-02-05
Build Time     : 1585151994
Product Model  : vivo 1812
Product Brand  : vivo
Product Name   : PD1917F_EX
Product Device : PD1917F_EX
Product Manfct : vivo
Product Info   : k61v1_64_bsp
Operation : Reset Settings/Format FS [ v2.14 ]
Mode : META
PTFN : MediaTek USB Port (COM31)
MODE : BOOTROM
PORT : 31
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+ARB
BROM : BOOTROM
BROM : ARB : ACTIVE : LOG : F0: 102B 0000  F3: 0000 0000 [0200]  V0: 0000 0000 [0001]
BROM : SOCID : A1FC5A818E3A9F265955918911ED5D9AD2F304D7B7A2A214EC7C0B63AE9E52B4
BROM : Configuring target for META
BROM : META configured!
INIT : META confirmed!
Boot done!
AP_CHIP : MT6761,S01
AP_SWVR : alps-mp-o1.mp7.tc19sp-V1.19_k61v1.64.bsp_P104
AP_HWVR : S01
Format Ok : UserData
Done!
Elapsed: 00:00:52
Old 08-02-2020, 07:38   #63972 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,136
Qmobile lt360 hang on logo done by cm2
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.14
Load IDBase v714142 Ok!
Update configuration ...
Update Ok!
Mode : FLASH
PTFN : MediaTek PreLoader USB VCOM Port (COM4)
PORT : 4
BROM : Init BROM
BROM init passed!
CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
TYPE : LEGACY MTK
MODE : 0_base : BASE_v2012 | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6572
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 530001153030534AB352004D2721FD1F
DAInf: 4 : 2 : 136
DA : DRAM ready!
EMMC: 150100534A5330304D0052B31FFD2127
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : SJS00M
EMMC:
BOOT1 : 0x00100000 [ 1.00 MB ]
BOOT2 : 0x00100000 [ 1.00 MB ]
RPMB : 0x00020000 [ 128.00 KB ]
USER : 0xE9000000 [ 3.64 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x20000000 [ 512.00 MB ]
CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 924CEF5BBFBEDA494FE14074D33A2282
Boot done!
Patch Level : KOT49H
Display ID : ALPS.KK1.MP7.Band1.2.5.V1.3-2019-05-10_21-12
Ver. CodeName : REL
Ver. Release : 4.4.2
Build Time : 1557493952
Product Model : LT360
Product Name : LT360
Product Device : zl9e_xdf_p13_qmobile_lt360_d_emmc32_4_ddr1_b15_fl
Product Board : zl9e_xdf_p13_qmobile_lt360_d_emmc32_4_ddr1_b15_fl
Product Brand : alps
Product Manfct : alps
Product Info : zl9e_xdf_p13_qmobile_lt360_d_emmc32_4_ddr1_b15_fl
Done!
Elapsed: 00:00:17
Mode : FULL FACTORY ( WIPE + FRP )
PORT : 4
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 136
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Done!
Elapsed: 00:00:17
Old 08-02-2020, 07:49   #63973 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,138
Itel A25 frp remove done
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:53
Old 08-02-2020, 07:51   #63974 (permalink)
Member: 1555233
Thanks Meter: 1,404
KING CM2 Infinix Hot 8 Lite X650 FRP Reset Done
Card found : A9EC786B , v0144
Load IDBase v714150 Ok!
Mode : FLASH
PTFN : MediaTek PreLoader USB VCOM (Android) (COM10)
PORT : 10
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
MODE : TECNO : LB6 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 510001154D33364410A00142C3C6C0E4
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100514436334D4201A010E4C0C6C3
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
DRAM: 0x80000000 [ 2.00 GB ]
RNID : BCA8F2FB432706E3892B3A3CECB922C
Boot done!
Display ID : X650-H8029AB-OGo-200322V331
Ver. CodeName : REL
Sec. Patch : 2020-04-05
Build Time : 1584859655
Product Brand : Infinix
Product Name : H8029
Product Device : Infinix-X650
Product Info : Infinix-X650
Product Model : Infinix X650
Product Manfct : INFINIX MOBILITY LIMITED
Product Board : Infinix-X650
Done!
Elapsed: 00:03:23
Mode : FRP [ RESET PROTECTION ]
PORT : 10
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:17
The Following 6 Users Say Thank You to amjadnona For This Useful Post:
Old 08-02-2020, 11:24   #63975 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,136
Vgotel i515 hang on logo done by cm2
Load File
File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F45
Load File Ok
Operation : Flash [ v1.58 ]
======= Flash
Files set for flashing :
[ MCU ] : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 54FFE30F4AB02070696AAAE82F72DC15
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
Flash now
Erase region , wait ...
Write data , wait ...
Write : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin
Done!
Elapsed: 00:00:45
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 1.26488 seconds with 9 queries
