11-12-2020, 09:16 | #64891 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmbile I6 Metal 1 SPD77XX FRP Reset Done With King Infinity CM2 Code: Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 3 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : Size : 0x0000000117FF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
11-12-2020, 09:25 | #64892 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 306676 Status: Offline Thanks Meter: 148 | Alcatel Pixi 3-4 [ OT-4013x ] unlock succesfully Alcatel Pixi 3-4 [ OT-4013x ] unlock succesfully Code: Card found : S/N : xxxxxxxx , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : FE014E50314A39344D126B0F186C727F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xFE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , M49J1 [eMMC] : FLASH_CID : FE014E50314A39344D126B0F186C727F [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 [eMMC] : FLASH_UCP : 3736 MiB [eMMC 4 GiB] DEV RID : 0x7266EA41B13EDCEF9212F777BF74B4F2 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
11-12-2020, 10:56 | #64893 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Sunlight Format Code: Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0C6B63CF326A_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
11-12-2020, 10:57 | #64894 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Memobile Power5000i Format Code: Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_117745B01D87_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
11-12-2020, 10:57 | #64895 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile CS1 Plus Frp Code: Patch Level : NRD90M Display ID : alps-mp-n0.mp1-V1.0.2_tinno6737m.35.n_P126 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-04-05 Build Time : 1495855465 Board Platform : mt6737m Product Info : CS1_Plus Product Model : QMobile CS1 Plus Product Model : CS1 Plus Product Model : CS1PLUS Product Brand : QMobile Product Name : CS1_Plus Product Device : CS1_Plus Product Manfct : QMobile USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC_1640_V3961AN_QMB_01.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484247346132A5338018D73523 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484247346132A5338018D73423 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1697FA5E3D2FAB3F13C401554708C941 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-12-2020, 10:58 | #64896 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X572 Frp Code: Patch Level : NRD90M Display ID : X572-H5312CE-N-171024V75 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-08-05 Build Time : 1508837009 Product Model : Infinix X572 Product Brand : Infinix Product Name : H5312 Product Device : Infinix-X572 Product Manfct : Infinix Board Platform : mt6753 Product Info : Infinix-X572 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) Done! Elapsed: 00:00:21 Operation : Reset Settings/Format FS [ v2.14 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2012 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A484247346132A52269D8701C1F DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484247346132A52269D870741F EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3E35438E3CC69B171FDC227DAF4D9D3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
11-12-2020, 11:42 | #64897 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Jazz Digit Flash Code: Patch Level : KOT49H Display ID : Digit_M42421DG_SW18 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 03.09.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:21 Created by Infinity-Box (c) 2020 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : KOT49H Display ID : Digit_M42421DG_SW15 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 22.08.2020 Product Model : Digit4G Product Brand : Digit Product Name : Digit4G Product Device : Digit4G Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G Preloader [HW DEV] Info : EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.16 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :17 [FL] : Set : preloader_fise6731_kaie_s_e_k.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.img [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x20E87698 [ 526.53 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN RAPHAEL BROM : MEID : FDC5F8A4648DA9877536A78CB224C6C6 BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v1924 | Manual : Enabled BROM : SOCID : 7AA38A1D14DFA24CC375B3DA9769D11ABB6372EC85801FF7F01B9768AADBABB6 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaie_s_e_k.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 90014A48344732611102C23A545245CD EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G2a EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 26656DE5D122FC5B11864943C71E6D2 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x00000000D71DBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : MCUPMFW Write : LK Write : LK2 Write : LOADER_EXT1 Write : LOADER_EXT2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:01:17 Reconnect Power/Cable! |
11-12-2020, 11:44 | #64898 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KC1 Frp Code: Patch Level : PPR1.180610.011 Display ID : KC1-H6114A-P-190731V165 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-07-05 Build Time : 31.07.2019 Product Model : TECNO KC1 Product Brand : TECNO Product Name : H6114A Product Device : TECNO-KC1 Product Manfct : TECNO MOBILE LIMITED Product Info : kc1_h6114 Product Board : TECNO-KC1 Board Platform : mt6761 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption *) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] STORAGE : LifeStatus : eMMC : NOT implemented in selected DA! Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled BROM : SOCID : 4993F28D0F6F46ACD21CC608306F591206D33D9530FCC6D9491BDA51B9C9C341 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 90014A484147346132A551002699A513 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 87350D1EBEC81986E067A81EB3C4854 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-12-2020, 11:55 | #64899 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37f QLM Pattren/FRP Reset Done With King Infinity CM2 Code: Operation : Read PatternLock [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 24EFC3D3 ID_BLOCK_L : D0104AB4238FB4B790C50F10DFAA2A22 ID_BLOCK_L : AAD967C6CB5A84018473249D971E0833 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... PatternLock sequence : 2635 Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-12-2020, 12:04 | #64900 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile l106 reset password done by cm2 Card found : 73CA70CC , v0146 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.06 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0D8 A1BDDFF93_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
11-12-2020, 14:02 | #64901 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgo tel i251 reset password done by cm2 Card found : S/N : 73CA70CC , v0146 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : F4EC7B58B9570DA503F6242755D042DF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
11-12-2020, 14:05 | #64902 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Dbeif tv d1000+ reset password done by cm2 Card found : S/N : 73CA70CC , v0146 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : B47A020A2CA749FB026F980F7DADEAB0 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
11-12-2020, 14:06 | #64903 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x2 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0146 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : s3510ap ProdModel : QMobile X2 Device : s3510ap AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
11-13-2020, 06:58 | #64904 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Q Mobile i8i Pro 2 Frp Remove Done With King Cm2 Operation : Format FS / Reset Settings [ v2.08 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:27 |
11-13-2020, 12:30 | #64905 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo y71 reset frp done by cm2 Card found : 73CA70CC , v0146 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 0E1E665A ID_BLOCK_L : C31239DC47CE0743DF1953A35F42F68D ID_BLOCK_L : F7BC36C53BC7EE573EB7491AB55F5228 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Brand : vivo ProdName : msm8937_64 ProdModel : vivo 1724 Device : msm8937_64 AndroidVer: 8.1.0 Manufact. : vivo SysPatch : OPM1.171019.011 DevComTime: 5/15/2020 8:53:20 AM USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 0E1E665A ID_BLOCK_L : C31239DC47CE0743DF1953A35F42F68D ID_BLOCK_L : F7BC36C53BC7EE573EB7491AB55F5228 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
