Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #65088 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2015 Location: Islam Age: 34
Member: 2371500 Status: Offline Thanks Meter: 5,102 | first time Nokia clone 220 4g Ta 1155 format and read flash done by cm2 assalmu alykom phone issue reboot once make call format then read flash done Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 115 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6BF3410C8B775D50CAA684F0F84D3574 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E00000-0x00FFFFFF , LEN : 0x00200000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 115 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 6BF3410C8B775D50CAA684F0F84D3574 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : 2C00 CB00 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EE , [Numonyx] N25W128 [0] : FLASH_DIE : 002C 00CB 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : J022_5_60A_BT_11B_PCB01_gprs_MT6260_S00.J022_5_60A_11B_240X320.bin FileVersion : J022_5_60A_11B_240X320 [ScatCFG] : MT6260 / J022_5_60A_11B_240X320 / NOR , SF Firmware saved to : D:\BST\infinty\CM2MTK\Read_out\J022_5_60A_BT_11B_PCB01_gprs_MT6260_S00\ Done! Elapsed: 00:00:59 Reconnect Power/Cable! download from here nokia clone 220 4g Ta 1155 J022_5_60A_BT_11B_PCB01_gprs_MT6260_S00 if post helpful press thanks button |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
![]() | #65091 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Oct 2014 Location: Gilgit/Pakistan
Member: 2276996 Status: Offline Thanks Meter: 66 | Download the latest version of Infinity Box from here. |
![]() | #65094 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 58,973 | Quote:
File transferred to Infinity support area | |
![]() | #65095 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,343 | ![]() Operation : Read Firmware [ v2.16 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4400014531303446FA090136A9960F61 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 4501004446343031360109FA610F96A9 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 62BD1A3ABA9E0FD7711A933BE5E6AB9 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : H97_P5085_VGOTEL_V04_20190709 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-07-05 Build Time : 09.07.2019 Product Model : NEW 7 Product Brand : VGOTEL Product Name : NEW_7 Product Device : NEW_7 Product Manfct : VGOTEL Product Info : NEW_7 Product Board : NEW_7 Board Platform : mt6580 MT6580__VGOTEL__NEW_7__8.1.0__H97_P5085_VGOTEL_V04 _20190709__O11019__NEW_7 Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : persist.img ExtSparse : Compression ratio : 100% Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : odmdtbo.img Read : vendor.img ExtSparse : Compression ratio : 69% Read : tz.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 25% Read : cache.img Read : userdata.img FW Size : 1.31 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : C:\Users\AkhtarAli\Desktop\MT6580__VGOTEL__NEW_7__ 8.1.0__H97_P5085_VGOTEL_V04_20190709__O11019__NEW_ 7\ Done! Elapsed: 00:07:45 Operation : Reset Settings/Format FS [ v2.16 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2028 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4400014531303446FA090136A9960F61 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 4501004446343031360109FA610F96A9 EMMC: VEN : SANDISK | OEM : 01 | DEV : DF4016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 62BD1A3ABA9E0FD7711A933BE5E6AB9 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
![]() | #65096 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 674 | QMobile X33 Operation : Format FS / Reset Settings [ v2.09 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile X33 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:33 |
![]() | #65097 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | Condor T9 : identify + read firmware + read nvram + reset setting / frp + flash ok Operation : Identify [ v2.09 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : SP648_V13_20190510 MemoryInfo : EMMC : 16 GB ; DRAM : 2 GB Platform Version: MOCORTM_18B_W19.10.2_P1_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_P1 HW Version: sc9863A_modem CMP_Time : 03-27-2019 18:13:12 MODEM TAG : MOCORTM_18B_W19.10.2_P1_Debug_FM_BASE_18B_W19.10.2 _P1_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 35 IMEI[2] : 35 WIFIMAC : 000000000000 BT_MAC : 000000000000 SEC : SLS:0, SKS:0, SKV:4 SEC_ID : QUJDREM3QkNDRUNCQTBDRUNCQTBDRUM4QTBDRENDRjVGNQ== Done! Elapsed: 00:01:21 ********************** Operation : Identify [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : SP648_V13_20190510 Ver. Incmt : 18420 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-01 Build Time : 10.05.2019 Product Model : Griffe T9 Product Brand : Condor Product Name : Griffe_T9 Product Device : Griffe_T9 Product Manfct : SPA Condor Electronics Product Info : Griffe_T9 Product Board : sp9863a_1h10 Board Platform : sp9863a NVMng : SecurityInfo IMEI[1] : 35 IMEI[2] : 35 IMEI[3] : 86 SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W19.10.2_P1_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_P1 HW Version: sc9863A_modem CMP_Time : 03-27-2019 18:13:12 MODEM TAG : MOCORTM_18B_W19.10.2_P1_Debug_FM_BASE_18B_W19.10.2 _P1_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:40 ************************************************** ** Operation : Read FW [ v2.09 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Patch Level : PPR1.180610.011 Display ID : SP648_V13_20190510 Ver. Incmt : 18420 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-01 Build Time : 10.05.2019 Product Model : Griffe T9 Product Brand : Condor Product Name : Griffe_T9 Product Device : Griffe_T9 Product Manfct : SPA Condor Electronics Product Info : Griffe_T9 Product Board : sp9863a_1h10 Board Platform : sp9863a AndroidVer : 9 VlnrLevel : 0x02 SP9863A__SPA_Condor_Electronics__Griffe_T9__9__SP6 48_V13_20190510__PPR1.180610.011__Griffe_T9 Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : dtb.img Read : dtbo.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : nvitem_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : system.img Read : vendor.img Read : otp_product.img ExtSparse : Compression ratio : 1% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 14% Read : phase.cfg Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! In search of truth ... Mankind should survive Found snow! Firmware size : 0xDEBDA128 ( 3,48 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:34:03 ************************************************** **** Operation : Read NVM [ v2.09 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 35 IMEI[2] : 35 IMEI[3] : 86 SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x000C60C8 Platform Version: MOCORTM_18B_W19.10.2_P1_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W19.10.2_P1 HW Version: sc9863A_modem CMP_Time : 03-27-2019 18:13:12 MODEM TAG : MOCORTM_18B_W19.10.2_P1_Debug_FM_BASE_18B_W19.10.2 _P1_sc9863A_modem_sharkl3_pub Reconnect Power/Cable! Done! Elapsed: 00:01:37 ************************************************ Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.09 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.09 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 ************************************************* Open : Condor_Griffe_T9_V13.pac VER : BP_R1.0.0 LEN : 3,29 GiB CPU : s9863a1h10 VER : MocorDroid9.0_Trunk Reading package ... Read package finished! Patch Level : PPR1.180610.011 Display ID : SP648_V13_20190510 Ver. Incmt : 18420 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-04-01 Build Time : 10.05.2019 Product Model : Griffe T9 Product Brand : Condor Product Name : Griffe_T9 Product Device : Griffe_T9 Product Manfct : SPA Condor Electronics Product Info : Griffe_T9 Product Board : sp9863a_1h10 Board Platform : sp9863a Operation : Flash Firmware [ v2.09 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : SlowSparse Fix : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : Condor_Griffe_T9_V13.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x24 PMTMng : Update PMT Ok! CODE : vbmeta-sign.img FSIMG : persist.img UBOOT : u-boot-spl-16k-sign.bin CODE : ltedsp.bin ERASE : UBOOT_LOG FSIMG : product.img CODE : dtb.img CODE : logo.bmp CODE : boot.img CODE : gnssbdmodem.bin CODE : prodnv.img CODE : sml-sign.bin CODE : wcnmodem.bin CODE : ltegdsp.bin FSIMG : userdata.img ERASE : MISC CODE : ltemodem.bin CODE : fastboot.bmp FSIMG : vendor.img CODE : gnssmodem.bin ERASE : UBOOT FSIMG : system.img CODE : pmsys.bin CODE : tos-sign.bin CODE : dtbo.img UBOOT : u-boot-sign.bin ERASE : L_RUNTIMENV1 CODE : recovery.img FSIMG : cache.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:10:26 ************************************************** *** |
![]() | #65098 (permalink) |
Junior Member ![]() Join Date: Sep 2020 Location: Maputo, Mozambique
Member: 2967320 Status: Offline Thanks Meter: 6 | ZTE Blade L130 Unlock Done By Infinity Box Operation : SP Unlock [ v2.09 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : VDC_ZA_P731K30V1.0.0B06 Platform Version: MOCORTM_17C_W18.41.3_P13_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P13 HW Version: sc7731e_modem CMP_Time : 03-04-2019 14:15:17 MODEM TAG : MOCORTM_17C_W18.41.3_P13_Debug_FM_BASE_17C_W18.41. 3_P13_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 861486040700535 IMEI[2] : 867400020316620 WIFIMAC : 6014669AAA80 BT_MAC : 4859A47537A9 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version Ok Balance: 20, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:02:37 |
The Following 4 Users Say Thank You to Mrsupremo For This Useful Post: |
![]() | #65099 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: Plumtree, Zimbabwe
Member: 2647569 Status: Offline Thanks Meter: 62 ![]() | Konka SP9 Firmware Read done Quote:
The Following 2 Users Say Thank You to gchipangura For This Useful Post: |
![]() | #65100 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2016 Location: Greece Age: 29
Member: 2578145 Status: Offline Thanks Meter: 113 | MLS iQ1804 Firmware Dump by CM2MT2 Here is a firmware Dump of a Greek Company tablet MLS iQ1804 https://losaiiis-my.sharepoint.com/:...QjACA?e=iqThcJ ![]() ![]() Στ?λθηκε απ? το SM-N960F μου χρησιμοποι?ντας Tapatalk |
The Following User Says Thank You to teokarafou For This Useful Post: |
