07-11-2021, 09:30 | #67171 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Infinity k reset frp done by cm2 Card found : 73CA70CC , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.25 Load IDBase v618219 Ok! Update configuration ... Update Ok! Load IDBase v618221 Ok! Operation : Identify [ v2.25 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM35) MODE : PRELOADER PORT PORT : 35 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464531324D420DA78EE0F93EC5 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464531324D420DA78EE0F954C5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE12MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 66A4AD138D0CB624CE97111FA68608E5 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : TELENOR-INFINITY-K_L105 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2017-08-05 Build Time : 1504186443 Product Model : Infinity_K Product Brand : Telenor Product Name : Infinity_K Product Device : Infinity_K Product Board : full_i6389 Product Manfct : Telenor Board Platform : mt6737t Product Info : Infinity_K USERDATA : ENCRYPTED Done! Elapsed: 00:00:15 Operation : Reset Settings/Format FS [ v2.25 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM35) MODE : PRELOADER PORT PORT : 35 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT MODE : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464531324D420DA78EE0F93EC5 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464531324D420DA78EE0F954C5 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE12MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 66A4AD138D0CB624CE97111FA68608E5 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
07-11-2021, 09:32 | #67172 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Moto e4 reset frp done by cm2 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : perry_verizon_f Model : Moto E (4) FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:12 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:04 |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
07-11-2021, 10:45 | #67173 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A12 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.25 Load IDBase v616218 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.25 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 563CB5CB2EA6D70ABB12035724EDD505 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 6BB3A4E5349DAFEE0E21EE53C3D7BEE22AEC42314A8C76A6ED69763E94EE64EE BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E035A2A1D8317BF EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 1512709507 ( 0x5A2A1D83) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5E28666C5F256880464D254276B8A4B3 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-09-05 Product Manfct : OPPO Build Time : 10.09.2020 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.41_0410_202009102002 Display ID : CPH2083EX_11_A.41 Display ID : CPH2083EX_11_A.41_200910 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 14 ] Backup path : Backup\MT6765__5E28666C5F256880464D254276B8A4B3\ [28] Read : NVRAM [12] Read : NVDATA [19] Read : PROINFO [29] Read : LK [11] Read : NVCFG [14] Read : PROTECT1 [15] Read : PROTECT2 [17] Read : PERSIST [0] Read : PRELOADER [16] Read : SECCFG [5] Read : OPPORESERVE1 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:59 Operation : Reset Settings/Format FS [ v2.25 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 563CB5CB2EA6D70ABB12035724EDD505 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 6BB3A4E5349DAFEE0E21EE53C3D7BEE22AEC42314A8C76A6ED69763E94EE64EE BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E035A2A1D8317BF EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 1512709507 ( 0x5A2A1D83) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5E28666C5F256880464D254276B8A4B3 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
07-11-2021, 10:48 | #67174 (permalink) |
Major Poster Join Date: Jun 2007 Location: Ukraine/Kiev
Member: 530372 Status: Offline Thanks Meter: 17 | Next Redmi 6 Operation : Unlock BootLoader [ v2.26 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM81) MODE : BOOTROM PORT : 81 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 200E8CB6BF02F2C3C6FEF860DD471650 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 226E495F9E08D868BF25DB0F26A81A61612ECA4E9BFA94DFE0 116A3C9B9D7480 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.04.03 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 150100474436424D42016E010703559D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 1845561091 ( 0x6E010703) , MF : 5/2018 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29,12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 30% - 40% used EMMC: EXTCSD [EOL_B] : MLC status : 30% - 40% used EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-09-01 Build Time : 19.09.2018 Product Model : Redmi 6 Product Brand : xiaomi Product Name : cereus Product Device : cereus Product Info : cereus Product Manfct : Xiaomi Board Platform : mt6765 BootLoader State : Locked! BootLoader State : Unlocked! INFO : User confirmed PERMUNLOCK! Operation passed! Done! Elapsed: 00:01:31 |
The Following 4 Users Say Thank You to kern_max For This Useful Post: |
07-11-2021, 12:31 | #67175 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-LD7 Frp Code: Product Brand : TECNO Product Device : TECNO-LD7 Product Model : TECNO LD7 Product Name : LD7-OP Patch Level : QP1A.190711.020 Display ID : LD7-H694NOPQRSVZ-Q-OP-210409V333 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-04-05 Build Time : 09.04.2021 Product Info : ld7_h694 Product Board : TECNO-LD7 Board Platform : mt6768 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.25 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT MODE : INFINIX : RAPHAEL_V2 | Manual : Disabled BROM : SOCID : BF7EE92D69F68AEBD0882053A8022208AA6501437AA26AD5EA646B1A70F42A7F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A68444561503303500CBF6CA7E1 EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033 EMMC: VEN : HYNIX : hDEaP3 EMMC: SNN : 1343012716 ( 0x500CBF6C) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : A681459DE991BEBB73B7F746EAFBE11C DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-11-2021, 12:32 | #67176 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1923 Format Code: Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-05-05 Product Manfct : OPPO Build Time : 06.05.2021 Product Brand : OPPO Product Model : CPH1923 Product Info : CPH1923 Product Name : CPH1923 Product Device : OP486C SW OTA Version : CPH1923EX_11.A.40_0400_202105061633 Display ID : CPH1923EX_11_A.40 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:53 Operation : Reset Settings/Format FS [ v2.25 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6C1B53B78B71EFD71E0876B20FF720C0 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : CA74C446E679B27646B8F39EEEFA9C83B650287E8A40C26E66E58744F8B78111 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D4203C5FCA86E7657 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 3321669742 ( 0xC5FCA86E) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 12BCABB3E8182B0AEAF4D5437FD240 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
07-11-2021, 12:33 | #67177 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Motorola Moto E (4) Frp Code: Brand : motorola ProdName : woods_retail ProdModel : Moto E (4) Device : woods AndroidVer: 7.1.1 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n1.mp1-V1_lenovo6737m.35.n1_P129 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33364527B003424F2FBED0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM36E [eMMC] : FLASH_CID : 150100514536334D4203B027D0BE544F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C259D30E0C13E9BD6806193BBD4 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
07-11-2021, 13:21 | #67178 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KE5 Frp Code: Product Brand : TECNO Product Device : TECNO-KE5 Product Model : TECNO KE5 Product Name : KE5-GL Patch Level : QP1A.190711.020 Display ID : KE5-H6123ABC-QGo-GL-201016V172 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-05 Build Time : 15.10.2020 Product Info : ke5_h6123go Product Board : TECNO-KE5 Board Platform : mt6761 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:21 Operation : Reset Settings/Format FS [ v2.26 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : E1CA80738870A6A9A51DB501D3EC8814 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 7B87453203DB723255C26337B130E435E1BE10F2EE0B0B78DFA7A4C27D998A5C BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_ke5_h6123go.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 90014A68423861503E0300953475A71B EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 9778293 ( 0x00953475) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 42B97EDFBC602A88CC0A1FE9615BD470 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
07-11-2021, 14:01 | #67179 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,792 | oppo cph 1989 reset done original poster larouci2 DZGSM Operation : Reset Settings/Format FS [ v2.26 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN [RAPHAEL] BROM : MEID : ED565359E8D624C7723FD521C3EA6CC4 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 3F2DCF5EB7D64E04A1B012821A30E06246A8072F0D90FD2018 DC385842A3CCEA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2044 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228,00 KB ] DRAM: 0x200000000 [ 8,00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCB000000 [ 119,17 GB ] FSN : 00330061003100380039006300370036 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A4B97A001432B6464B36C8587C0E57E DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8F5754 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:01:01 Reconnect Power/Cable |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
07-11-2021, 15:07 | #67181 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | vivo y30 bootloader unlock don Card found : 0DA21111 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.26 Load IDBase v77228 Ok! Update configuration ... Update Ok! Load IDBase v77228 Ok! Operation : Unlock BootLoader [ v2.26 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8A621F460E0AE59E39015C4306CEB6EB BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FCA5E3E56B3C2B96D3A79EAD19B5EBEC2335E3EB3B418BF71C 63665E8F430BA4 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v03.04.03 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D05F01328F5913FFFFFFFFEF964000A9 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 13014E53304A394B39101B4529B3575D EMMC: VEN : MICRON : OEM : 78 : ID : 53304A394B39 EMMC: VEN : MICRON : S0J9K9 EMMC: SNN : 457517491 ( 0x1B4529B3) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 128 GB EMMC: EXTCSD [SIZE] : Actual : 0x1D1F000000 [ 116.48 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : k65v1_64_bsp Product Model : vivo 1938N Product Name : full_k65v1_64_bsp Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020 release-keys Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-07-01 Build Time : 04.09.2020 Product Info : k65v1_64_bsp Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo BootLoader State : Locked! BootLoader State : Unlocked! Done! Elapsed: 00:01:26 Reconnect Power/Cable! |
The Following 6 Users Say Thank You to alimobile279 For This Useful Post: |
07-11-2021, 16:24 | #67182 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,792 | Samsung GT-E1200R WRITE FIRMWARE DONE original poster MS-GSM DZGSM Last edited by MyGSM World; 07-12-2021 at 20:21. Reason: Image Correction On User Request. |
07-11-2021, 16:56 | #67183 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X32 Frp Code: Model Name : X32 Model Brand : QMobile Model Device: X32_new AndrVersion : 6.0 BaseBand CPU: X32 CompileDate : 2/23/2017 10:16:53 AM Project Ver : MRA58K release-keys Model Ext : QMobile X32 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
07-11-2021, 16:56 | #67184 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix Zero 3 Frp Code: Brand : Infinix ProdName : Infinix-X552-B1 ProdModel : Infinix Zero 3 Device : INFINIX-X552 AndroidVer: 6.0 MTKxCPU : MT6795 MTKxPRJ : X552-H952B1-M-170426V87 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010041575044335200936A4C5AB34F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 15010041575044335200936A4C5AB34F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C258CA4C7E5F19F10B6B46C790F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
07-11-2021, 16:57 | #67185 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Voice V190 Pasword Code: Operation : Read UserCode [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q64 : 0x00800000 [ 8MiB ] Reading data ... STATE : NOT ACTIVE : CODE : 4949 Done! Elapsed: 00:00:57 Reconnect Power/Cable! |
