07-13-2021, 07:56 | #67216 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 ta 103 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0149 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : DD36D58EFD794539850727DEDA4294F5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00390000-0x003FFFFF , LEN : 0x00070000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
07-13-2021, 08:39 | #67217 (permalink) |
No Life Poster Join Date: Nov 2013 Location: pakistan P G L Age: 39
Member: 2067643 Status: Offline Sonork: 1611265 Thanks Meter: 474 | tecno b1f smart reset Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM21) MODE : BOOTROM PORT : 21 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 757513A3E012C707658BB92DB9A3E2DA BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x000000FE AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D3236459B6A0342FB37ACD2 DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 150100464536324D42036A9BD2AC37FB NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_b1_f8018.bin EMI : CNT : 0006 EMI : [00] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [01] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [02] : ID : ADDE14A7424AAD : VEN : UNKNOWN | DEV : §BJ* : RAM : [ 512.00 MB ] EMI : [03] : ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [05] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100464536324D42036A9BD2AC37FB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 1788596908 ( 0x6A9BD2AC) , MF : 3/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CDB095576C5E7B8F5A8767EC64070B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM22) MODE : PRELOADER PORT PORT : 22 Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to iftikharrana58 For This Useful Post: |
07-13-2021, 08:50 | #67218 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Black Two SPD77xx FRP/Pattren Reset Done With King Infinity CM2 Code: Card found: S/N : A19EC787 , v0149 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 7.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 82 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC Loader v7 InfinityBox Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
07-13-2021, 14:10 | #67219 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | Itel a23r (jio) network unlock success by great infinity tool ITEL A23R (JIO) NETWORK UNLOCK SUCCESS BY GREAT INFINITY TOOL JUST 5 INFINITY CREDITS REQUIRED. CHECK WITH BSNL SIM ON SIM1 CALLING & NETWORK WORKING FINE. Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! VER : BP_R1.0.0 LEN : 87910B92 ( 2.12 GiB ) CPU : sp9832e_1h10 VER : itel_A23R_081_1801_161220 Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : itel_A23R_081_1801_161220.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : 081.15.01 Ver. Incmt : IN-JIO-V015-20200513 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-05-05 Build Time : 01.06.2020 Product Model : itel A23R Product Brand : Itel Product Name : SU335R Product Device : itel-A23 Product Manfct : itel Product Info : itel A23R Product Board : sp9832e_1h10_32b Board Platform : sp9832e NVMng : SecurityInfo IMEI[1] : 356090111085180 IMEI[2] : 356090111085198 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:E Platform Version: MOCORTM_17B_Release_W18.26.1_P23_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P23 HW Version: sc9832e_modem CMP_Time : 03-06-2020 23:53:35 MODEM TAG : MOCORTM_17B_Release_W18.26.1_P23_Debug_FM_BASE_17B _Release_W18.26.1_P23_sc9832e_modem_sharkle_Smart_ Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:54 Operation : SP Unlock [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : itel_A23R_081_1801_161220.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 356090111085180 IMEI[2] : 356090111085198 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:2, SKS:0, SKV:E SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 10, price:5 Process... Finished Disconnected Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:37 |
The Following 2 Users Say Thank You to ajaystarin For This Useful Post: |
07-13-2021, 16:51 | #67220 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo Y20 MTK6765 FRP/Pattren Reset Done With Phardo King Infinity CM2 Code: Card found : A19EC787 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.26 Load IDBase v77228 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.26 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 0D9AFBED19CF93C87DFE3CF301B7A7EE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 943A150887A5191190B59B660DEDB47F98F9399C1AEB769CA5AB6DED073D50CA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100444836444142028963CC36B7E3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444836444142 EMMC: VEN : SAMSUNG : DH6DAB EMMC: SNN : 2305018934 ( 0x8963CC36) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : EF1162CA8C3B598F605C60FFACC5CC53 DA : USB : HIGH-SPEED Boot done! Product Brand : vivo Product Device : 2026 Product Model : V2026 Product Name : 2026 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k65v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-01 Build Time : 07.06.2021 Product Board : k65v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 14 ] Backup path : Backup\MT6765__0D9AFBED19CF93C87DFE3CF301B7A7EE\ [35] Read : NVRAM [10] Read : NVDATA [25] Read : PROINFO [36] Read : LK [9] Read : NVCFG [20] Read : PROTECT1 [21] Read : PROTECT2 [23] Read : PERSIST [0] Read : PRELOADER [22] Read : SECCFG Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:51 Operation : Reset Settings/Format FS [ v2.26 ] Mode : FORCED EXT FORMAT 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 0D9AFBED19CF93C87DFE3CF301B7A7EE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 943A150887A5191190B59B660DEDB47F98F9399C1AEB769CA5AB6DED073D50CA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100444836444142028963CC36B7E3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 444836444142 EMMC: VEN : SAMSUNG : DH6DAB EMMC: SNN : 2305018934 ( 0x8963CC36) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : EF1162CA8C3B598F605C60FFACC5CC53 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
07-13-2021, 17:52 | #67221 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Turkiye-Konya
Member: 2199727 Status: Offline Thanks Meter: 217 | oppo a15 (cph 2185) phone lock remove ok Card found : BAD19788 , v0149 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.26 Load IDBase v77228 Ok! Update configuration ... Update Ok! Load IDBase v77228 Ok! Operation : Identify [ v2.26 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 837A609BCC9F088234A467CDD801EF53 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4A32F8A491C73B9F575ADC54DB095DF5C6C175196B208B014C D040359E523564 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : A1K-A12-A31-A32 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 1501003458364B4D4203B1EFCCB0A7AF EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 2985282736 ( 0xB1EFCCB0) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A4E7C9721813E51513C77DE7E37475F8 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.26 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 837A609BCC9F088234A467CDD801EF53 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4A32F8A491C73B9F575ADC54DB095DF5C6C175196B208B014C D040359E523564 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : A1K-A12-A31-A32 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0002 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] EMMC: CID : 1501003458364B4D4203B1EFCCB0A7AF EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 2985282736 ( 0xB1EFCCB0) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A4E7C9721813E51513C77DE7E37475F8 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to bulutiletisim For This Useful Post: |
07-13-2021, 18:09 | #67222 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Movitel M6235 Readed User Code Card found : 46828B86 , v0149 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SecInfo : Done! Elapsed: 00:01:16 Operation : Read UserCode [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! UserCode : 2468 Done! Elapsed: 00:01:28 Reconnect Power/Cable! |
07-14-2021, 08:35 | #67223 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1877732 Status: Offline Thanks Meter: 119 | HUAWEI Y6 2019 MRD LX1F FRP RESET WITH GREAT CM2 dongle one click frp reset Operation : Reset Settings/Format FS [ v2.24 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM122) MODE : BOOTROM PORT : 122 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN RAPHAEL BROM : MEID : 4C7257686F3CB13DD729D6C06D19CBFF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 9A692E9AA79BC011BD3365202D4E9666011158F3214D4EFA0A 697AF6932F2E9A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k61v1_64_mexico.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 150100514436334D420107B19B1246B9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1FDB01C0F77C26B670F45216A2EEFB8E DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:53 Reconnect Power/Cable! https://www.youtube.com/watch?v=xr3zLQcKqo0 |
The Following User Says Thank You to kashu345 For This Useful Post: |
07-14-2021, 10:20 | #67224 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | vivo 1901 Format & Frp Code: Product Brand : vivo Product Device : 1901 Product Model : vivo 1901 Product Name : 1901 Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012 release-keys Product Info : k62v1_64_bsp Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-04-01 Build Time : 07.05.2021 Product Board : k62v1_64_bsp Board Platform : mt6765 Product Manfct : vivo USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption **) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.25 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 9B1D9FCA05BE73B706C71D5BF9F735EF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : F9C0985A7BFF7B115DAA993E990C4CE1B0D6154DB103D04D27169770110D34DD BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k62v1_64_bsp.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100525036344D4201349C9BFC775D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344D42 EMMC: VEN : SAMSUNG : RP64MB EMMC: SNN : 882678780 ( 0x349C9BFC) , MF : 7/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 623BF487CD64AD2049BE8675DEB89 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
07-14-2021, 10:21 | #67225 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile_S6S Frp Code: Brand : QMobile ProdName : QMobile_S6S ProdModel : QMobile S6S Device : QMobile_S6S AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_rgk6580.we.m Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420DF08C9024A39B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DF08C9024A39B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25EE1DB3C88C2C0BE9016FA113 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
07-14-2021, 10:23 | #67226 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO RENO 3 Format Code: Product Board : oppo6779 Board Platform : mt6779 Product Brand : alps Product Device : oppo6779 Product Manfct : alps Product Model : oppo6779 Product Name : vnd_oppo6779 STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:54 Operation : Reset Settings/Format FS [ v2.25 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 2880F2ADE47153FFE142AB7B5B244106 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : B47D66620C6B5E1B855583A41FF5C802D3079C6B278B9D9391DFE2AA9FEE48AC BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6779.bin EMI : CNT : 000D EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3842383030314A4D2D424330 UFS: VEN : 0x01CE VID : KM8B8001JM-BC0 IFW : 0600 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x3B96000000 [ 238.34 GB ] FSN : 399c14140c1d REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3F05411FEF6D259FBD5603F6ED1BAF4 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
07-14-2021, 10:24 | #67227 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Voice V1010 Format Code: Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1C6D2A1CF0DF_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
07-14-2021, 10:25 | #67228 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | VgoTel I251 Pasword Code: Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 11 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : CCE65D3264A655150BD1A2EC7354D4FD BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 885522 PLock|MobTrack : Not active Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
07-14-2021, 10:26 | #67229 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Nokia 2.3 Format & Frp Code: Product Brand : Nokia Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Patch Level : QP1A.190711.020 Display ID : 00WW_2_340_SP03 Product Info : IRM_sprout Product Model : 00WW Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-02-05 Build Time : 02.02.2021 Product Board : MT6761 Board Platform : mt6761 Product Manfct : HMD Global USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:26 Operation : Reset Settings/Format FS [ v2.25 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : AA8E551E625036B1EC444BCDC60F1E6D BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : FFB172CA4BC9BB7DC7FE8D5D5835AB3093CC339DDAB73FB19D1EF0198382F8B0 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_t99621aa2.bin EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 70010054413238333220317847E5B615 EMMC: VEN : KINGSTON : OEM : 0 : ID : 544132383332 EMMC: VEN : KINGSTON : TA2832 EMMC: SNN : 829966309 ( 0x317847E5) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A8DCE5B7946B5D0E718F3303ABA21816 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825755 Format Ok : USERDATA Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
07-14-2021, 10:26 | #67230 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-KE5k Frp Code: Product Brand : TECNO Product Device : TECNO-KE5k Product Model : TECNO KE5k Product Name : KE5k-OP Patch Level : QP1A.190711.020 Display ID : KE5k-H6122CD-Q-OP-201216V149 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-12-05 Build Time : 16.12.2020 Product Info : ke5k_h6122 Product Board : TECNO-KE5k Board Platform : mt6765 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) STORAGE : LifeStatus : eMMC : OK! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.25 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 54B0EAC94665FE04D711CBDCB3E0C107 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Disabled BROM : SOCID : 3A3958256F4CC4254758A6C483FC54C5BFB0594A5A82F140C4A4B629C3B983CD BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_ke5k_h6122.bin EMI : CNT : 0013 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142025D67CE0DA7EF EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1567084045 ( 0x5D67CE0D) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3B624EF0F349107F2C09080E65FC236E DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
