08-09-2021, 06:48 | #67501 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Vgotel i55 read user code done 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 28D27DEFE81A229EE12929BAB08DF24B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 88888 PLock|MobTrack : Not active Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
08-09-2021, 07:41 | #67502 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Moto xt1254 frp reset done Operation : Moto ADB Enable [ v1.03 ] Mode : Enable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! -- > Info : Wait till device boot, make "Enable ADB" operation after -- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"! Done! Elapsed: 00:00:06 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1254 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:34 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : quark_verizon Model : XT1254 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:14 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:06 |
08-09-2021, 12:33 | #67503 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Infinix hot9 play format done Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! Update configuration ... Update Ok! Load IDBase v718267 Ok! Operation : Memory Tool Init [ v2.27 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : F0D11F513D29E8D04A214C3FF3AE4AA5 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 079CC4E5DD565A1556418E227B47DECB9E29868A7B451C0EC9 5E1D43ED2CA628 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680f_h6116.bin EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A484347386134A2103254535713 EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 271733843 ( 0x10325453) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3C2A2A4B35CCCD1CDEC9B0BE385BE4D5 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [3] [0] Erase partition : FRP Erase partition Ok! [1] Erase partition : CACHE Erase partition Ok! [2] Erase partition : USERDATA Erase partition Ok! Operation finished! |
08-09-2021, 14:08 | #67504 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SAMSUNG A12 SM-A125F FRP RESET and FIRMWARE RESET DONE BY Infinity Box CM2MT2 Vlog Just Apply the A12 Test Point... link to test point removed due to very bad image hosting service, get testpoint from Infinity server... Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : CD8F20C5F30C4C4544DDA25F4B2D153D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CC063304A280F1A1D8A81E672EB0BCFE2A9AB39FF0FD924647 130ED56B36B7ED BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp_titan_rat.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 13014E47314A395238100F4E00BF28F1 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 256770239 ( 0x0F4E00BF) , MF : 2/2021 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2237114B5661A53774A08CB88F76D134 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Device : a12 Product Model : SM-A125F Product Name : a12nsxx Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012.A125FXXU1BUE3 Build Time : 06.05.2021 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-01 Product Info : a12 Product Board : k65v1_64_bsp_titan_rat Board Platform : mt6765 Product Manfct : samsung NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__CD8F20C5F30C4C4544DDA25F4B2D153D\ [1] Read : PGPT Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! Done! Elapsed: 00:00:39 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : CD8F20C5F30C4C4544DDA25F4B2D153D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CC063304A280F1A1D8A81E672EB0BCFE2A9AB39FF0FD924647 130ED56B36B7ED BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp_titan_rat.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 13014E47314A395238100F4E00BF28F1 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 256770239 ( 0x0F4E00BF) , MF : 2/2021 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2237114B5661A53774A08CB88F76D134 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! Operation : Read Firmware [ v2.27 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB VCOM (Android) (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : CD8F20C5F30C4C4544DDA25F4B2D153D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CC063304A280F1A1D8A81E672EB0BCFE2A9AB39FF0FD924647 130ED56B36B7ED BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp_titan_rat.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 13014E47314A395238100F4E00BF28F1 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395238 EMMC: VEN : MICRON : G1J9R8 EMMC: SNN : 256770239 ( 0x0F4E00BF) , MF : 2/2021 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2237114B5661A53774A08CB88F76D134 DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Device : a12 Product Model : SM-A125F Product Name : a12nsxx Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012.A125FXXU1BUE3 Build Time : 06.05.2021 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-01 Product Info : a12 Product Board : k65v1_64_bsp_titan_rat Board Platform : mt6765 Product Manfct : samsung MT6765__samsung__SM-A125F__11__RP1A.200720.012.A125FXXU1BUE3__RP1A.200 720.012__a12 Read : preloader.bin Read : efs.img Read : sec_efs.img Read : steady.img Read : nvram.bin Read : spmfw.img Read : tinysys-scp.bin Read : sspm.img Read : uh.img Read : tz.img Read : tzar.img Read : gz.img Read : lk.bin Read : dtbo.img Read : vbmeta.img Read : btd.img Read : md1rom.img Read : param.img Read : up_param.img Read : boot.img Read : recovery.img Read : vbmeta_samsung.img Read : efuse.img Read : super.img ExtSparse : Compression ratio : 9% Read : prism.img ExtSparse : Compression ratio : 86% Read : optics.img ExtSparse : Compression ratio : 94% Read : cache.img Read : omr.img Read : spu.img Read : userdata.img FW Size : 5,22 GB Android Info saved : _Android_info.txt Scatter : MT6765_Android_scatter.txt Saved to : C:\Users\hp\Documents\MT6765__samsung__SM-A125F__11__RP1A.200720.012.A125FXXU1BUE3__RP1A.200 720.012__a12\ Done! Elapsed: 00:10:43 Last edited by InfinityHelp; 08-11-2021 at 09:00. |
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
08-09-2021, 15:04 | #67505 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Sky Mobile™
Member: 1049764 Status: Offline Sonork: 100.1678585 Thanks Meter: 62 | Itel L6502 Format & Frp Done Operation : Format FS / Reset Settings [ v2.13 ] Mode : Forced [ Format FS / Fix ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : Forced Wipe Wipe Ok : Forced Wipe Reconnect Power/Cable! Done! Elapsed: 00:02:30 Operation : Format FS / Reset Settings [ v2.13 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:20 |
The Following 2 Users Say Thank You to naazerkhan For This Useful Post: |
08-09-2021, 15:15 | #67506 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | itel W4003 format done Operation : Format FS / Reset Settings [ v2.13 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W4003 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
08-10-2021, 05:59 | #67507 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Ufone Simcan72 MT6572 Pattren Read Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0150 Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 122 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505070723648224A1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505070723648224A1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39511AE4E103E60D9FE845E0F73 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 5369 Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
08-10-2021, 08:38 | #67508 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X30 Flash Code: Brand : TINNO ProdName : QMobile X30 ProdModel : QMobile X30 Device : QMobile X30 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111019EE7048B227B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111019EE7048B227B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25D41009CCEE0666010DC50E5C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3821 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4050ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:55 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:20 Reconnect Power/Cable! |
08-10-2021, 08:51 | #67509 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Itel A23S SC9832E Read Fw Done Code: Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : A23S-SU335-8.1-MZ-Voda-L-V020-20210602 Ver. Incmt : MZ-Voda-L-V020-20210602 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-06-01 Build Time : 02.06.2021 Product Model : itel A23S Product Brand : Itel Product Name : SU335 Product Device : itel-A23S Product Manfct : ITEL MOBILE LIMITED Product Info : itel A23S Product Board : sp9832e_1h10_32b Board Platform : sp9832e NVMng : SecurityInfo IMEI[1] : 355183 IMEI[2] : 354648 IMEI[3] : 867400 WIFIMAC : 40D25FE67D8F BT_MAC : 40D25FE67D8E SEC : SLS:0, SKS:0, SKV:3 Platform Version: MOCORTM_17B_Release_W18.26.1_P25_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P25 HW Version: sc9832e_modem CMP_Time : 08-27-2020 14:37:04 MODEM TAG : MOCORTM_17B_Release_W18.26.1_P25_Debug_FM_BASE_17B_Release_W18.26.1_P25_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:43 Code: Operation : Read FW [ v2.13 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : A23S-SU335-8.1-MZ-Voda-L-V020-20210602 Ver. Incmt : MZ-Voda-L-V020-20210602 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-06-01 Build Time : 02.06.2021 Product Model : itel A23S Product Brand : Itel Product Name : SU335 Product Device : itel-A23S Product Manfct : ITEL MOBILE LIMITED Product Info : itel A23S Product Board : sp9832e_1h10_32b Board Platform : sp9832e AndroidVer : 8 VlnrLevel : 0x02 SP9832E__ITEL_MOBILE_LIMITED__itel_A23S__8.1.0__A23S-SU335-8.1-MZ-Voda-L-V020-20210602__OPM2.171019.012__itel_A23S Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : ldsp_l.bin Read : gdsp_l.bin Read : modem_l.bin Read : deltanv_l.bin Read : nvitem_l.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : pm_sys.bin Read : boot.img Read : recovery.img Make : persist.img Read : boot_logo.bmp Read : fastboot_logo.bmp Read : system.img ExtSparse : Compression ratio : 90% Read : vendor.img ExtSparse : Compression ratio : 87% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 47% Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! Waiting for a miracle ... Mankind should survive Found vodka! Firmware size : 0x5E6A3E80 ( 1,48 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:10:03 |
The Following User Says Thank You to yuranc8 For This Useful Post: |
08-10-2021, 09:10 | #67510 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH1909 Format Code: Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Product Manfct : OPPO Build Time : 19.03.2021 Product Brand : OPPO Product Model : CPH1909 Product Info : CPH1909 Product Device : CPH1909 Product Name : CPH1909 SW OTA Version : CPH1909EX_11.A.46_0460_202103191930 Display ID : CPH1909EX_11_A.46 Kernel Info : 4.9.77 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.26 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : E180383B9DCE99A58E674628A066ACD0 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4D37914CC3AF8960A07933E0C6BE8C3E0585F74209E6F32CCCEAA824244C40CA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D42018AC5C637B6A9 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 2328217143 ( 0x8AC5C637) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : EF36320665C2964DFCDB84CE43CABC80 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
08-10-2021, 09:10 | #67511 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFive Falak Format Code: Operation : Read UserCode [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Reading data ... STATE : NOT ACTIVE : CODE : 0012 Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
08-10-2021, 09:11 | #67512 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile i8i_2019 Frp Code: Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1545915581 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-12-05 Build Time : 27.12.2018 Product Model : QMobile i8i 2019 Product Info : i8i 2019 Product Brand : QMobile Product Name : i8i_2019 Product Device : i8i_2019 Product Model : i8i 2019 Product Model : I8I2019 Product Manfct : QMobile Product Board : i8i-2019 Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.21.1_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.21.1_P2 HW Version: sc7731e_modem CMP_Time : 06-07-2018 16:54:31 MODEM TAG : MOCORTM_17C_W18.21.1_P2_Debug_FM_BASE_17C_W18.21.1_P2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:52 Operation : Format FS / Reset Settings [ v2.13 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
08-10-2021, 09:11 | #67513 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH2083 Format Code: Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-10-05 Product Manfct : OPPO Build Time : 09.10.2020 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.45_0450_202010092240 Display ID : CPH2083EX_11_A.45 Display ID : CPH2083EX_11_A.45_201009 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:28 Operation : Reset Settings/Format FS [ v2.26 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 537BEE87181FEF2DC080F1A71A8B95E9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 14585C39B3B5741B376BC0D40346401519C045DE057610D158251D5846749C0F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E0300449F28671F EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 4497192 ( 0x00449F28) , MF : 6/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : CA4391EFEF05D278403A5ABC91C29A65 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
08-10-2021, 09:12 | #67514 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Realme RMX1941 Format Code: Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2021-05-05 Product Manfct : Realme Build Time : 08.05.2021 Product Brand : Realme Product Model : RMX1941 Product Info : RMX1941 Product Name : RMX1941 Product Device : RMX1941 SW OTA Version : RMX1941EX_11.A.34_0340_202105081158 Display ID : RMX1941EX_11_A.34 Kernel Info : 4.9.117 USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:42 Operation : Reset Settings/Format FS [ v2.26 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : B53A699446DE73AA340EECD9F2988901 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : AD0ECB0B1B3A5DF4799473267A0C68E54A7D064DBF7F47E8BBC1C2922A4CB713 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Oppo : A1K-A12-A31-A32 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D420335F897909687 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 905484176 ( 0x35F89790) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D3A227B6725062C4375F4932A94D363 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
08-10-2021, 09:13 | #67515 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | GFIVE Stark Frp Code: Patch Level : P00610 Display ID : GFIVE_StarK_20200522 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-04-05 Build Time : 22.05.2020 Product Model : Stark Product Brand : GFIVE Product Name : Stark Product Device : Stark Product Manfct : GFIVE Product Info : Stark Product Board : mt6580 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) Done! Elapsed: 00:00:23 Operation : Reset Settings/Format FS [ v2.26 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4D0101043030443008821131317629F7 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 0401014D3044303031118208F7297631 EMMC: VEN : UNKNOWN [0x04] : OEM : 1 : ID : 4D3044303031 EMMC: VEN : UNKNOWN [0x04] : M0D001 EMMC: SNN : 2181625641 ( 0x8208F729) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x39D000000 [ 14.45 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C844023528033799FF047FC98608811F STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
