10-04-2021, 13:47 | #68191 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Itel l6006 reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : itel-L6006 Product Model : itel L6006 Product Name : SU385 Patch Level : QP1A.190711.020 Display ID : L6006-SU385-10-IN-V019-20201120 Ver. Incmt : IN-V019-20201120 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-10-05 Build Time : 20.11.2020 Product Manfct : ITEL MOBILE LIMITED Product Info : SU385 Product Board : sp9832e_1h10_32b Board Platform : sp9832e Platform Version: MOCORTM_18A_W20.31.2_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.31.2 HW Version: sc9832e_modem CMP_Time : 07-28-2020 20:36:20 MODEM TAG : MOCORTM_18A_W20.31.2_Debug_FM_BASE_18A_W20.31.2_sc 9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:27 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
10-04-2021, 13:48 | #68192 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Motorola moto g4 play reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8916 CID : 0x0002 UID : 728F342300000000000000000000 Model Info ============ IntName : harpia SW Info ============ DevSWVer : Blur_Version.24.201.3.harpia_vzw.verizon.en.US DevQCVer : AU_LINUX_ANDROID_LA.BR.1.1.3_RB1.05.01.00.032.015 BaseBand : M8916_20250106.08.05.23.01R HARPIA_NA_CUST BootLDRv : moto-msm8916-81.04 HW Info ============ eMMCInfo : 16GB Samsung REV=08 PRV=07 TYPE=57 DRAMInfo : 2GB Samsung S8 SDRAM DIE=8Gb Lock Info ============ BLUnlock : no WarrantyVoid : no FRP Lock : protected (77) Done! Elapsed: 00:00:06 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! -- > Info : Wait till device boot, make "Enable ADB" operation after -- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"! Done! Elapsed: 00:00:06 Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1609 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:00:40 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : harpia_vzw Model : XT1609 FRP reset passed! Make FACTORY RESET from menu! -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE! Done! Elapsed: 00:00:12 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:07 |
10-04-2021, 15:58 | #68193 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A5s CPH1909 Pattren/FRP Reset Done 1 Click With King Infinity CM2 Code: Card found : A19EC787 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM135) MODE : BOOTROM PORT : 135 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8104349D48BC83C035E52D564E08F2D5 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 20AD262759E8D1BB52A28460C30CA40D11C8703D1D4046D1B7DCCB5BA91CD08E BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D4201E07ED2247687 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 3766407716 ( 0xE07ED224) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B3CEDAFB9B9F3AE6A686F3DD8189CE0 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
10-05-2021, 13:22 | #68195 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Nokia 105 ta 1174 read flash file done by cm2 Card found : S/N : 73CA70CC , v0150 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : AD2F8167D9385B2BD8E39F299FF56C3F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : M915_5_61D_11C_128X160_PCB01_gprs_MT6261_S00.M915_ 5_61D_11C_128X160.bin FileVersion : M915_5_61D_11C_128X160 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : AD2F8167D9385B2BD8E39F299FF56C3F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Reading Flash Content now ... Read Flash now Read Ok , 4194304 bytes read Check and collect compile info File_Info : M915_5_61D_11C_128X160_PCB01_gprs_MT6261_S00.M915_ 5_61D_11C_128X160.bin FileVersion : M915_5_61D_11C_128X160 Saved to : C:\InfinityBox\CM2MTK\Read_out\M915_5_61D_11C_128X 160_PCB01_gprs_MT6261_S00.M915_5_61D_11C_128X160.b in Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
10-05-2021, 13:23 | #68196 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vivo s1 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 84189AE5C609A17FE6E795853EE67348 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 113FFE5298FE90B74F032BB11290DCA091F8D40F1A86C4AF9C 4022193DE1944F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloa EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445636444D420233176A4A17F1 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445636444D42 EMMC: VEN : SAMSUNG : DV6DMB EMMC: SNN : 857172554 ( 0x33176A4A) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 7AA1C472F9A36A239761FF39FE781704 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
10-05-2021, 13:24 | #68197 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Lg k330 reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase sFRP#3 Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
10-05-2021, 13:26 | #68198 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Itel l6502 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
10-05-2021, 14:00 | #68199 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | Starlight star plus full factory resetdone original poster MS-GSM DZGSM |
The Following User Says Thank You to profkefah For This Useful Post: |
10-05-2021, 20:45 | #68200 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Logic M3 Read Flash and User Code Readed DONE in Secs |
The Following User Says Thank You to Shensohau For This Useful Post: |
10-06-2021, 15:15 | #68201 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,804 | Starlight c note pro x write firmware done original poster MS-GSM DZGSM |
10-07-2021, 07:17 | #68202 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Oppo A5s smart reset done Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : A8A7D05BC64A7C8DF166C2EE8688D6F5 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FE500FAEC9D845ADCB6C217F4D6CC583C99673F169F0595008 CB6F6538FF29D8 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42036196907BB695 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 1637257339 ( 0x6196907B) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F7F5795212AC1C0CD5502694B6CB3D03 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
10-07-2021, 07:18 | #68203 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Mi One Q5 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 504E01FE35394A317749124B2B322917 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : FE014E50314A39354B1249771729322B EMMC: VEN : MICRON : OEM : 78 : ID : 50314A39354B EMMC: VEN : MICRON : P1J95K EMMC: SNN : 1232541481 ( 0x49771729) , MF : 3/2015 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00200000 [ 2.00 MB ] USER : 0x1D3000000 [ 7.30 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6D4E97619D414D2B3F16EB463F83D22A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8D5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
10-07-2021, 07:22 | #68204 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | itel l5503l frp cm2 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel L5503L Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:16 |
The Following User Says Thank You to limonbogra For This Useful Post: |
10-07-2021, 09:45 | #68205 (permalink) |
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Inifnix x650c Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2EF36DC588ADB32B66A2602B51A33318 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 179F93A874DA8D1B93BA6E84C27DEB008F52A72263CA27A48D 183E78ABAAF03F BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x650c_h626.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A684339615033015177E2119659 EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 1366811153 ( 0x5177E211) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 90838FABF9FAD5C2E0B44B24ED0153B3 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
