Old 10-12-2021, 14:02   #68221 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,670
Lenovo k6 remove frp pattern done by cm2
Card found : 73CA70CC , v0150
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 430 [MSM8937]
ID_BLOCK_S : 3762C395
ID_BLOCK_E : 00007A2A
ID_BLOCK_L : 472B1AE0D492DD363B7854880396A5DC
ID_BLOCK_L : C0AB8960750C31BE7FE55A9E1A7AFC4A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:24
Reconnect Power/Cable!
Old 10-12-2021, 14:03   #68222 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,670
Oppo a37 reset frp done by cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 2687E70E
ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159
ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
Old 10-12-2021, 14:10   #68223 (permalink)
Member: 2371500
Thanks Meter: 4,525
Stream ht28 b2 plus FRP remove done
original poster
Mofdi Electronics DZGSM
The Following 2 Users Say Thank You to profkefah For This Useful Post:
Old 10-12-2021, 19:01   #68224 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
QMobile X30 Flash
Brand     : TINNO
ProdName  : QMobile X30
ProdModel : QMobile X30
Device    : QMobile X30
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:09
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447326111019EE7048B227B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111019EE7048B227B
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C25D41009CCEE0666010DC50E5C
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3504 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:59
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:24
Old 10-12-2021, 19:02   #68225 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
QMobile I8i Frp
Model Name  : I8i
Model Brand : QMobile
Model Device: I8i
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 11/12/2017 7:52:25 am
Project Ver : QMobile I8i_MP_11_12
Model Ext   : QMobile I8i
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:38
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 27 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:31
Old 10-12-2021, 19:03   #68226 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
OPPO CPH2083 Format
Patch Level    : PPR1.180610.011
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2021-07-05
Product Manfct : OPPO
Build Time     : 01.07.2021
Product Brand  : OPPO
Product Model  : CPH2083
Product Info   : CPH2083
Product Name   : CPH2083
Product Device : OP4BFB
SW OTA Version : CPH2083PUEX_11.A.59_0590_202107012325
Display ID     : CPH2083EX_11_A.59
Display ID     : CPH2083EX_11_A.59_210701
Kernel Info    : 4.9.117
USERDATA : FILESYSTEM : EXT4  with FBE ( File-Base Encryption )
NVRAM : OPPO6765_19451_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_PIE_P35_PR1_TC16_SP_V1_P107
NVRAM : 0xBC0AFB20
NVRAM : State : Ok!
INFO  : WiFi MAC : B0B5C3C4B0CF
INFO  : BlTh MAC : B0B5C3C4B0CE
STORAGE : Life Status : eMMC : OK!
STORAGE : OTP Status : UNLOCKED!
Done!
Elapsed: 00:00:41
Operation : Reset Settings/Format FS [ v2.28 ]
Mode : SMART RESET
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM22)
MODE : BOOTROM
PORT : 22
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Cervino
     TYPE : MODERN [RAPHAEL]
BROM : MEID : F3B29AC5BA27CE03249FC8B4B8EC85CC
BROM : SecLevel : 0x000000E5
BROM : SecMode  : SBC+SDA+EXT
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
BROM : SOCID : 114F3F2E22C08A7FD38FBAE14AC354559C021533C2DE212209E939B1292AEC56
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
BROM : PreBoot stage #1
BROM : PreBoot stage #2
AGENT : 0_base : BASE_v2112 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : FireFly
     EMI : SRC : preloader_oppo6765_19451.bin
     EMI : CNT : 000A
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x0003A000 [ 232.00 KB ]
        DRAM: 0xC0000000 [ 3.00 GB ]
        EMMC: CID : 90014A68423861503E0343860280277D
        EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E
        EMMC: VEN : HYNIX : hB8aP>
        EMMC: SNN : 1132855936 ( 0x43860280) , MF : 2/2020
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0x747C00000 [ 29.12 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 2B5C5C061DF561585E64A8AABD382C6
DA : USB : HIGH-SPEED
Boot done!
SmartInfo : 0x815757
Format Ok : RESET PROTECTION
Format Ok : USERDATA
Format Ok : CACHE
Done!
Elapsed: 00:00:43
Old 10-12-2021, 19:04   #68227 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
WIKO v2806 Frp
Model Name  : v2806
Model Brand : WIKO
Model Device: v2806
AndrVersion : 6.0
BaseBand CPU: V2806
CompileDate : 23/02/2017 4:02:03 pm
Project Ver : MRA58K release-keys
Model Ext   : JERRY
Elapsed: 00:00:36
3. Insert cable
Phone found! [ 27 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:34
Old 10-12-2021, 19:05   #68228 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
vivo 1812 Format
Patch Level    : O11019
Display ID     : O11019 release-keys
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2021-02-01
Build Time     : 08.04.2021
Product Model  : vivo 1812
Product Brand  : vivo
Product Name   : PD1917F_EX
Product Device : PD1917F_EX
Product Manfct : vivo
Product Info   : k61v1_64_bsp
Board Platform : mt6761
USERDATA : FILESYSTEM : EXT4  with FDE ( Full Disk Encryption *)
NVRAM : BBK_O1MP7_K61V1_64_BSP_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R2_MP_V32_21_P139
NVRAM : 0xB50AF625
NVRAM : State : Ok!
INFO  : WiFi MAC : 18E777DD3F0D
INFO  : BlTh MAC : 18E777DD3F0C
INFO  : IMEI[1] : 860779041009158
INFO  : IMEI[2] : 860779041009141
Done!
Elapsed: 00:00:37
Mode : SMART RESET
PTFN : MediaTek USB Port (COM5)
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     CODE : Merlot
BROM : MEID : E209E85F30116ABDA53D26FB2A0C0947
BROM : BOOTROM
BROM : SOCID : 338D8E6261ABD0F849BE626574CDE6069838953EF15205CC4B6FBFF288943B89
AGENT : Found MT6761
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_k61v1_64_bsp.bin
     EMI : CNT : 0006
        SRAM: 0x0003A400 [ 233.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        EMMC: CID : 150100514436334D42010BBFF26EB6F1
        EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42
        EMMC: VEN : SAMSUNG : QD63MB
        EMMC: SNN : 197128814 ( 0x0BBFF26E) , MF : 11/2019
        EMMC:
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 15B43650EECD213D1923B3209B0677E1
Boot done!
SmartInfo : 0x805757
Format Ok : CACHE
Done!
Elapsed: 00:00:48
Old 10-12-2021, 19:06   #68229 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
QMobile X5 Format
Brand     : QMobile
ProdName  : s3512ap
ProdModel : QMobile X5
Device    : s3512ap
AndroidVer: 4.4.2
MTKxCPU   : MT6571
Done!
Elapsed: 00:00:10
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID    : 0xD5229C25B73DA6EB3FC6D771EF214310
EXT RAM    : 0x10000000 [256 MiB]
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:16
Old 10-12-2021, 19:07   #68230 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
Nokia 2.2 Frp
Product Model  : wasp
Product Brand  : alps
Patch Level    : RP1A.200720.011
Display ID     : 00WW_3_270_SP04
Ver. CodeName  : REL
Ver. Release   : 11
Sec. Patch     : 2021-08-05
Build Time     : 23.07.2021
Product Model  : Nokia 2.2
Product Brand  : Nokia
Product Name   : Wasp_00WW
Product Device : WSP_sprout
Product Manfct : HMD Global
Product Info   : WSP_sprout
Product Model  : 00WW
Product Board  : MT6761
NVRAM : 0x9F08BE77
NVRAM : State : Ok!
INFO  : WiFi MAC : 4C6AF6ABBA25
INFO  : BlTh MAC : 4C6AF62BBA25
INFO  : IMEI[1] :
INFO  : IMEI[2] :
Done!
Elapsed: 00:00:37
Mode : FRP [ RESET PROTECTION ]
PTFN : MediaTek USB Port (COM30)
MODE : BOOTROM
PORT : 30
BROM : Init BROM
BROM init passed!
     CODE : Merlot
BROM : MEID : 425D2DBF6E1E10DC9B9B02CDE502DA43
BROM : SecLevel : 0x000000E1
BROM : SecMode  : SBC+EXT
BROM : BOOTROM
BROM : SOCID : 4667720875A404AEE7555366549CFE17EB77024545BC12A8D8A9A0D9A3364E11
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : INFINITY
     EMI : SRC : PRELOADER_INFINITY_0
     EMI : CNT : 0001
        DRAM: 0x40000000 [ 1.00 GB ]
        EMMC: CID : 880103534C44333247418202F3245611
        EMMC: VEN : FORESEE : OEM : 3 : ID : 534C44333247
        EMMC: VEN : FORESEE : SLD32G
        EMMC: SNN : 2181231396 ( 0x8202F324) , MF : 5/2019
        EMMC:
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x73A000000 [ 28.91 GB ]
        RNID : C6B46489586C43C25EFE044CF000C337
Boot done!
Done!
Elapsed: 00:00:26
Old 10-12-2021, 19:08   #68231 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
TECNO-LD7 Frp
Product Brand  : TECNO
Product Device : TECNO-LD7
Product Model  : TECNO LD7
Product Name   : LD7-OP
Patch Level    : QP1A.190711.020
Display ID     : LD7-H694NOPQRSVZ-Q-OP-210107V297
Ver. CodeName  : REL
Ver. Release   : 10
Sec. Patch     : 2020-12-05
Build Time     : 07.01.2021
Product Info   : ld7_h694
Product Board  : TECNO-LD7
Board Platform : mt6768
Product Manfct : TECNO MOBILE LIMITED
USERDATA : FILESYSTEM : F2FS  with FBE ( File-Base Encryption )
NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6768_S00.MOLY_LR12A_R3_MP_V118_11_P16
NVRAM : 0xB80AC7E2
NVRAM : State : Ok!
INFO  : WiFi MAC : AA0036004400
INFO  : BlTh MAC : C4BF6047CC9A
INFO  : IMEI[1] :
INFO  : IMEI[2] :
Done!
Elapsed: 00:00:43
MODE : BOOTROM
PORT : 30
BROM : Init BROM
BROM init passed!
     CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     CODE : Talbot
BROM : MEID : E5FD4CDE6E3AA8D9123F932E827F02CD
BROM : BOOTROM
BROM : SOCID : 4FED9D161A81C32E53C5DBB14CEA195CDB8D9C5062D658701EBEF936832731A0
AGENT : Found MT6768
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : DEV : FireFly
     EMI : SRC : preloader_ld7_h694.bin
     EMI : CNT : 000F
        SRAM: 0x00070000 [ 448.00 KB ]
        DRAM: 0x100000000 [ 4.00 GB ]
        EMMC: CID : 90014A68444561503303DD71C161A7B3
        EMMC: VEN : HYNIX : OEM : 74 : ID : 684445615033
        EMMC: VEN : HYNIX : hDEaP3
        EMMC: SNN : 3715219809 ( 0xDD71C161) , MF : 10/2020
        EMMC:
              USER   : 0x1D1F000000 [ 116.48 GB ]
        CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
        RNID : 9D21042A2A4BDAD16F4B6A53AA132ED3
Boot done!
Done!
Elapsed: 00:00:30
Old 10-12-2021, 19:09   #68232 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
******* 4GXX Frp
Display ID     : DANY-*******4G-20200729
Ver. Incmt     : 05320
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-10-05
Build Time     : 03.02.2021
Product Model  : ******* 4GXX
Product Brand  : indigi
Product Name   : G4i
Product Device : G4i
Product Manfct : indigi
Product Info   : sp9832e_1h10
Product Board  : sp9832e_1h10
Board Platform : sp9832e
Platform Version: MOCORTM_18A_W19.08.2_P9_Debug
Project Version:   sharkle_Smart_Phone
BASE  Version:    FM_BASE_18A_W19.08.2_P9
HW Version:        sc9832e_modem
CMP_Time : 06-10-2019 14:45:06
MODEM TAG : MOCORTM_18A_W19.08.2_P9_Debug_FM_BASE_18A_W19.08.2_P9_sc9832e_modem_sharkle_Smart_Phone
USERDATA : FILESYSTEM : F2FS  with FDE ( Full Disk Encryption ***)
 - > INFO : Remove cable from device to switch it off!
Done!
Elapsed: 00:01:27
Operation : Format FS / Reset Settings [ v2.13 ]
Mode : Reset FRP
BootMode : FLASH
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_0S
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : 0x0008
FDL :  EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True
FDL : RAW : 0x0002
FDL : FLH : 0x400000
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:22
Old 10-12-2021, 19:11   #68233 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
S10+ T65 Format
Brand     : T65
ProdName  : S10+
ProdModel : S10+
Device    : zm5e_om_m6_s10_emmc32_8_ddr2_b15_gps_fl
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.Band1.2.5.V1.3
Done!
Elapsed: 00:00:21
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : FE014E503058585858100575EA898025
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , XXXX0
[eMMC] : FLASH_CID : FE014E503058585858100575EA898025
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00100000
DEV RID    : 0xD5229C25F2E8AF9FE344868F9E1B6A9E
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:28
Old 10-12-2021, 19:12   #68234 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,791
QMobile Black_Two Frp
Model Name  : Black_Two
Model Device: Black_Two
AndrVersion : 6.0
CompileDate : 07/05/2018 5:01:27 am
Project Ver : QMobile BlackTwo_MP_07_05
Model Ext   : QMobile Black Two
Elapsed: 00:00:28
3. Insert cable
Phone found! [ 34 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:29
Old 10-12-2021, 21:19   #68235 (permalink)
Member: 85718
Thanks Meter: 153
Medion Lifetab S10334
Card found : 05C0DF82 , v0150
Infinity-Box RockChip Service Tool [RKT] v2.01
Operation : Identify [ v2.01 ]
----- > Phone/Tablet :
1. Power Off device
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : Normal [ LOADER OPEN ]
Machine : RK3066
Device : RK30SDK
ExtInfo : 4.4.2
SoC CPU : 310B
SoC PDT : 2013
SoC SWN : 0131
SoC REV : V101
Flash CSx : 0x00
Flash Type : 45DE949376 [ NAND ]
Flash Vend : SANDISK
Flash Size : 0x0000000211000000 ( 8,27 GiB )
Flash Info : 4194304/16384/32/40/5
Connect Ok!
Done!
Elapsed: 00:00:41
Operation : Read PatternLock [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : RK30SDK
ExtInfo : 4.4.2
SoC CPU : 310B
SoC PDT : 2013
SoC SWN : 0131
SoC REV : V101
Flash CSx : 0x00
Connect Ok!
Direct Access : Ok!
Patternlock NOT set!
Done!
Elapsed: 00:00:28
Operation : Reset UserLocks [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : RK30SDK
ExtInfo : 4.4.2
SoC CPU : 310B
SoC PDT : 2013
SoC SWN : 0131
SoC REV : V101
Flash CSx : 0x00
Connect Ok!
Info : Device is not supported yet!
Operation : Read Firmware [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Device connection test not passed! Breaking!
Probably you boot device in wrong mode!
Device not found!
Remove battery, cable. Check cable and connection. Repeat operation!
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : RK30SDK
ExtInfo : 4.4.2
SoC CPU : 310B
SoC PDT : 2013
SoC SWN : 0131
SoC REV : V101
Flash CSx : 0x00
Connect Ok!
DevInfo : RK3066
Reading Flash Content ...
[Read Ok] : param.cfg
[Read Ok] : misc.img
[Read Ok] : kernel.img
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : system.img
Android Info saved!
Read finished!
Configuration : RK3066 / 45DE949376 [ NAND ]
Firmware Size : 813 MiB
Done!
Elapsed: 00:02:41
Operation : Reset Settings [ v2.01 ]
1. Power Off device
----- > IoT/Box :
Wait for device ...
Device Connected!
Machine : RK3066
Device : RK30SDK
ExtInfo : 4.4.2
SoC CPU : 310B
SoC PDT : 2013
SoC SWN : 0131
SoC REV : V101
Flash CSx : 0x00
Connect Ok!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:01:45
The Following User Says Thank You to ct3im For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.44110 seconds with 9 queries
