11-08-2021, 12:25 | #68536 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | QMobile LT100 Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile LT100 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:33 |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
11-08-2021, 12:30 | #68537 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Jazz JS7 Pro Frp Reset Done Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001154D323237FBDB00427773E7D6 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100463732324D4200DBFBD6E77377 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 463732324D42 EMMC: VEN : SAMSUNG : F722MB EMMC: SNN : 3690714855 ( 0xDBFBD6E7) , MF : 7/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4D4777B550F1373824D36D2E72483D48 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:02:42 Reconnect Power/Cable! |
11-09-2021, 11:37 | #68538 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Oppo A12 Smart Reset Done Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 53E01CB898CBEC646EC31C2078CCCC74 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : CE6695F2270E72B94A499193E07C88AFFE15E0A13128EAF55E F01332D230F20A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E0358913619C6B9 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 1485911577 ( 0x58913619) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : BBCB52A721261074FFDBCBF0F474D48A DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
11-09-2021, 13:37 | #68539 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | nokia c20 network unlock done......via world 1st tool [cm2] Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.230_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2 _P3_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 357735914497425 IMEI[2] : 357735914497433 WIFIMAC : 44917C110367 BT_MAC : 44917C110366 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 40, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:31 |
The Following 2 Users Say Thank You to bigjef1 For This Useful Post: |
11-10-2021, 07:53 | #68540 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Australia
Member: 177568 Status: Offline Thanks Meter: 146 | Nokia C30 unlock done Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : *******_00WW-user 11 RP1A.201005.001 V1.260_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 359174220xxxxxx IMEI[2] : 867400020xxxxxx WIFIMAC : 44917C1342E9 BT_MAC : 44917C1342E8 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 40, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : *******_00WW-user 11 RP1A.201005.001 V1.260_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P5_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P5 HW Version: sc9863A_modem CMP_Time : 05-11-2021 10:59:41 MODEM TAG : MOCORTM_20A_W21.15.3_P5_Debug_4G_MODEM_20A_W21.15. 3_P5_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 359174220xxxxxx IMEI[2] : 867400020xxxxxx WIFIMAC : 44917C1342E9 BT_MAC : 44917C1342E8 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 35, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:35 |
The Following 2 Users Say Thank You to mtb116 For This Useful Post: |
11-10-2021, 09:33 | #68541 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Tecno Spark 5 Pro Kd7 SMART RESET Done! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 294A620153C03C1557929ED6B1FE347A BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 13E3A9511AFC485C7F4EEBD5055FE6CFCB01BEE62423528201 57EAD477D71668 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_kd7_ EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010044503644414203352CCA0D1705 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 892127757 ( 0x352CCA0D) , MF : 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 736C3BCDAD81E7369AE115A3D7E0595D DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
11-10-2021, 10:01 | #68542 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | BLU Z3 IMI REAPIR successfully Infinity Box 🎌 Card found : C1B4DF65 , v0150 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 Operation : Repair Security [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] OLD IMEI[1] : 3----------- NEW IMEI[1] : 3------- NVMng : Update Ok! OLD IMEI[2] : 3----------------- NEW IMEI[2] : 3------------ NVMng : Update Ok! NVMng : Aplly new settings ... NVMng : Security data updated! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
11-10-2021, 10:45 | #68543 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Infinix Hot 9 Play X680 B FRP lock is successfully reseted Infinity Box 💡 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Card found : C1B4DF65 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 4B72576592D26BFE3178459EA5615342 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9FA853DD58DAD15FD3B8755091806A4CB9D8BA14137F05576D 2B4BCB99C1751B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680b_h6215.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142038236CAA787FD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 2184628903 ( 0x8236CAA7) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3193E604D92DD5EF5CE9186E48DF68D8 DA : USB : HIGH-SPEED Boot done! Product Brand : Infinix Product Device : Infinix-X680B Product Model : Infinix X680B Product Name : X680B-OP Patch Level : QP1A.190711.020 Display ID : X680B-H6215EFIJ-Q-OP-210323V238 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-02-05 Build Time : 23.03.2021 Product Info : x680b_h6215 Product Board : Infinix-X680B Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V107_4_P14 NVRAM : 0xA208C02F NVRAM : State : Ok! INFO : WiFi MAC : AC2334DCEDA1 INFO : BlTh MAC : AC2334DCEDA0 INFO : IMEI[1] : 35-------------- INFO : IMEI[2] : 3------------- Backup sensetive data [ 16 ] Backup path : Backup\MT6765__4B72576592D26BFE3178459EA5615342\ Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:21 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 4B72576592D26BFE3178459EA5615342 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9FA853DD58DAD15FD3B8755091806A4CB9D8BA14137F05576D 2B4BCB99C1751B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680b_h6215.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142038236CAA787FD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 2184628903 ( 0x8236CAA7) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3193E604D92DD5EF5CE9186E48DF68D8 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
11-10-2021, 14:33 | #68544 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | DCODE DS-BD1 Remove FRP Lock Done :) Code: Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM44) MODE : PRELOADER PORT PORT : 44 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : D601004D4D43363447516CE90024385B EMMC: VEN : UNKNOWN [0xD6] : OEM : 0 : ID : 4D4D43363447 EMMC: VEN : UNKNOWN [0xD6] : MMC64G EMMC: SNN : 1827209252 ( 0x6CE90024) , MF : 3/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C733C3C5E8E1406BB74CD02CDA52B86C DA : USB : HIGH-SPEED Boot done! Product Brand : DCODE Product Device : DS_BD1 Product Model : DS-BD1 Product Name : DS_BD1 Patch Level : RP1A.200720.011 Display ID : DS_BD1_H1_20210611_V6.0 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-05-05 Build Time : 11.06.2021 Product Info : DS_BD1 Product Board : k62v1_64_bsp Board Platform : mt6765 Product Manfct : Premier Code (PRIVATE) LIMITED USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) NVRAM : 0x9F08C053 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : 1C9F4EB4C9A0 INFO : IMEI[1] : 351x53200 INFO : IMEI[2] : 351x53200 Backup sensetive data [ 16 ] Backup path : Backup\MT6765__C733C3C5E8E1406BB74CD02CDA52B86C\ [16] Read : NVRAM [8] Read : NVDATA [2] Read : PROINFO [7] Read : NVCFG [11] Read : PROTECT1 [12] Read : PROTECT2 [1] Read : PGPT [14] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:01:45 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM44) MODE : PRELOADER PORT PORT : 44 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : D601004D4D43363447516CE90024385B EMMC: VEN : UNKNOWN [0xD6] : OEM : 0 : ID : 4D4D43363447 EMMC: VEN : UNKNOWN [0xD6] : MMC64G EMMC: SNN : 1827209252 ( 0x6CE90024) , MF : 3/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C733C3C5E8E1406BB74CD02CDA52B86C DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
11-10-2021, 14:59 | #68545 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Tanzania
Member: 2758606 Status: Offline Sonork: pasua Thanks Meter: 108 | Tecno spark 4(kc8) dead boot & imei repair done by great cm2 Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Product Brand : TECNO Product Device : TECNO-KC8 Product Model : TECNO KC8 Product Name : H6110 Patch Level : QP1A.190711.020 Display ID : KC8-H6110LMN-Q-OP-210708V261 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-07-05 Build Time : 08.07.2021 Product Info : kc8_h6110 Product Board : TECNO-KC8 Board Platform : mt6761 Product Manfct : TECNO MOBILE LIMITED Preloader [HW DEV] Info : EMI : DEV : MT6761 EMI : SRC : preloader_kc8_h6110.bin EMI : CNT : 000A EMI : [00] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [02] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [04] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 1.00 GB ] EMI : [05] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [06] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [07] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] EMI : [08] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [09] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :22 [FL] : Set : preloader_kc8_h6110.bin [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : sspm.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : tz.img [FL] : Set : vendor.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : recovery.img [FL] : Set : tkv.img [FL] : Set : tranfs.img [FL] : Set : userdata.img [FL] : Total size : 0xCDFD578C [ 3.22 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 700100544132383332230A67EA67962D EMMC: VEN : KINGSTON : OEM : 0 : ID : 544132383332 EMMC: VEN : KINGSTON : TA2832 EMMC: SNN : 174582375 ( 0x0A67EA67) , MF : 9/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AF199178691AB99FA6A84595AECFBC59 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000009B00000 Erase : 0x000000000DB00000 : 0x00000000DAD00000 Erase : 0x00000000EC800000 : 0x0000000014D00000 Erase : 0x0000000101800000 : 0x0000000016280000 Erase : 0x0000000119A80000 : 0x00000000C4580000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG FAIL : SEC : IMG TYPE MISMATCH Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : RECOVERY Write : TKV Write : TRANFS Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:06 Reconnect Power/Cable! File downloaded from support |
The Following User Says Thank You to massoudou For This Useful Post: |
11-10-2021, 15:25 | #68546 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Itel A23 Pro Network Unlocked Code: Card found : 46828B86 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212MZ-10.0-MZ-Vodacom-V013-20210630 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 357068261047076 IMEI[2] : 354648020000004 WIFIMAC : 3C7AF0035BEA BT_MAC : 3C7AF0035BE9 SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:29 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
11-10-2021, 15:33 | #68547 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Tecno KF6K MT6768 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Identify [ v2.27 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 3471BC745FF5C1013AFFD1D7A1DD68F8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9419734B7420A693CDED5575C6542847D51DF93E7FBCFB28B1CA4456109947D4 BROM : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6768 AP_SWTM : Fri Sep 3 19:55:53 CST 2021 AP_SWVR : alps-mp-r0.mp1-V8.24.1_reallytek.r0mp1.k61v1.64.bsp_P74 MD_CHIP : MT6768 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V149.4.P10 MD_SWVR : TK_MD_BASIC_HW MD_HWVR : Unknown IMEI[1] : 354122421269527 IMEI[2] : 354122421269535 NVRAM : SEC NORMAL [ No extra security ] NVRAM saved as : MT6768_1.0_MOLY.LR12A.R3.MP.V149.4.P10_TK_MD_BASIC_HW.bin Done! Elapsed: 00:00:40 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 3471BC745FF5C1013AFFD1D7A1DD68F8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9419734B7420A693CDED5575C6542847D51DF93E7FBCFB28B1CA4456109947D4 BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM27) MODE : BOOTROM PORT : 27 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 3471BC745FF5C1013AFFD1D7A1DD68F8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9419734B7420A693CDED5575C6542847D51DF93E7FBCFB28B1CA4456109947D4 BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : TECNO : RAPHAEL_V2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330100612F5F38DB EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 6369119 ( 0x00612F5F) , MF : 3/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 9914B307A437BBC6885E46048C46C135 DA : USB : HIGH-SPEED Boot done! Product Brand : TECNO Product Device : TECNO-KF6k Product Model : TECNO KF6k Product Name : KF6k-OP Patch Level : RP1A.200720.011 Display ID : KF6k-H696AeAgAfAh-R-OP-210715V278 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-07-05 Build Time : 15.07.2021 Product Info : kf6k_h696 Product Board : TECNO-KF6k Board Platform : mt6768 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 16 ] Backup path : Backup\MT6768__9914B307A437BBC6885E46048C46C135\ [36] Read : NVRAM [19] Read : NVDATA [3] Read : PROINFO [18] Read : NVCFG [21] Read : PROTECT1 [22] Read : PROTECT2 [1] Read : PGPT [20] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:53 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : TECNO : RAPHAEL_V2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A6843396150330100612F5F38DB EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 6369119 ( 0x00612F5F) , MF : 3/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 9914B307A437BBC6885E46048C46C135 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
11-10-2021, 16:04 | #68548 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Realme 6 RMX2001 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.27 Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Identify [ v2.27 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : HW Report [ v2.27 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:32 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : HW Report [ v2.27 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:06 Operation : HW Report [ v2.27 ] HWreport : Mode : eMMC 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Info : LEGACY : HW reporting feature unavailable for current device! Done! Elapsed: 00:00:06 Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth Error : Protocol Error : Fail to init Control! >>> Check USB driver, restart software Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.27 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 1FE096B8BBDA63A935F6D079C1C73421 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 45A9BADBBEC64274163975D36ED033ED6BDB2A67DCC9CFF07FC96EE1F8D7A65B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6785.bin EMI : CNT : 000F EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1300 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330063003500340031006600370063 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A92E56A1A656F263116D924D7AE086C7 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
11-11-2021, 07:39 | #68549 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,420 | Qmobile i6 Metal One Frp Remove Done Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019065314738B930070561B301D5 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A4838473165050730B9D501B361 EMMC: VEN : HYNIX : OEM : 74 : ID : 483847316505 EMMC: VEN : HYNIX : H8G1e EMMC: SNN : 817485057 ( 0x30B9D501) , MF : 11/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3902A59E36E3FF3F772C01473FE4369 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
11-11-2021, 10:17 | #68550 (permalink) |
Freak Poster Join Date: Aug 2018 Location: bagbari bogra dhaka bangladesh
Member: 2856614 Status: Offline Sonork: 100.650600 Thanks Meter: 252 | symphony i74 auto restart fix by write file with cm2 Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Open : i74_HW1_V8_20191202.pac VER : BP_R1.0.0 LEN : 3.23 GiB CPU : sp9832e_1h10 VER : i74_HW1_V8_20191202 Reading package ... Read package finished! Patch Level : P00610 Display ID : i74_HW1_V8 Ver. Incmt : 1570846599 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 12.10.2019 Product Model : i74 Product Brand : SYMPHONY Product Name : i74 Product Device : i74 Product Manfct : SYMPHONY Product Info : i74 Board Platform : sp9832e Product Board : sp9832e_1h10 Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : i74_HW1_V8_20191202.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x25 PMTMng : Update PMT Ok! NVRM : sharkle_pubcp_Smart_Phone_nvitem.bin NVMng : Load 0x2F NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 359999101461945 IMEI[2] : 359999101461952 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x000C5D54 NVMng : Init DST NVMng : Rx29 : Wx28 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : prodnv.img ERASE : UBOOT_LOG UBOOT : u-boot-spl-16k-sign.bin CODE : vbmeta-sign.img CODE : SC9600_sharkle_pubcp_Smart_Phone_modem.dat CODE : sharkle_pubcp_Smart_Phone_deltanv.bin CODE : SharkLE_LTEA_DSP.bin CODE : SHARKLE_DM_DSP.bin CODE : sharkle_cm4.bin CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : PM_sharkle_cm4.bin CODE : boot.img CODE : dtb.img CODE : dtbo.img CODE : recovery.img FSIMG : system.img FSIMG : userdata.img CODE : FWVGA_logo_256_td.bmp CODE : fastboot_FWVGA_logo_256_td.bmp FSIMG : cache.img ERASE : L_RUNTIMENV1 ERASE : MISC CODE : tos-sign.bin CODE : sml-sign.bin FSIMG : vendor.img FSIMG : product.img UBOOT : u-boot-sign.bin FSIMG : persist.img Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:03:25 |
The Following 2 Users Say Thank You to limonbogra For This Useful Post: |
