11-18-2021, 13:53 | #68626 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | LAVA W119 reading user code done الفرسان فون gem flash |
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
11-18-2021, 14:30 | #68627 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Realme c2 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 62DD540CC795D71D35F815C9810971FC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 97ABCFC1418DC9042D942F2B7299362E9BF7DB222AF2072B67 0B2A4DF76217B4 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6762_18540.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42030EA19B986655 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 245472152 ( 0x0EA19B98) , MF : 6/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 690DC304C7816316D3312DC52C649BCD DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:16 |
11-18-2021, 14:31 | #68628 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Oppo a15 remove frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6E82AB522F0CF5C433B83A63914B7D30 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 54C0D0923F724446F0D4B6971B078E68D85B78CDBB6ABC81B5 41B72D17802709 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E030034E568C769 EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 3466600 ( 0x0034E568) , MF : 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 46AECC2B97D4900E2B4CE9BF4ECC423 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:02:52 Reconnect Power/Cable! |
11-18-2021, 15:25 | #68629 (permalink) |
Freak Poster Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 99 | A107F U8 recoverd sucessfully with CM2 A107F 100% working after flah sctter file with GREAT TOOL CM2. Operation : Write Flash [ v2.28 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :20 [FL] : Set : preloader_s96116ca1.bin [FL] : Set : efuse.img [FL] : Set : param.img [FL] : Set : up_param.img [FL] : Set : md1rom.img [FL] : Set : spmfw.img [FL] : Set : tinysys-scp.bin [FL] : Set : sspm.img [FL] : Set : lk.bin [FL] : Set : boot.img [FL] : Set : recovery.img [FL] : Set : dtbo.img [FL] : Set : tz.img [FL] : Set : vendor.img [FL] : Set : product.img [FL] : Set : system.img [FL] : Set : vbmeta.img [FL] : Set : cache.img [FL] : Set : omr.img [FL] : Set : userdata.img [FL] : Total size : 0xE46F7294 [ 3.57 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MTK USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 89A9B4074E4504C3F5DD76F1CD9392BE BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 6F7DD4CA3F83CB9BFB69A67807005C7E12A7EE5CE7DFC05331 4FA678DB83C7A9 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6765 EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0008 EMI : [00] : eMMC : DDR3 : ID : 150100514436334D42 : VEN : SAMSUNG | DEV : QD63MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 700100464D42434541 : VEN : KINGSTON | DEV : FMBCEA : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100515836334D42 : VEN : SAMSUNG | DEV : QX63MB : RAM : [ 2.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100515836334142 : VEN : SAMSUNG | DEV : QX63AB : RAM : [ 2.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100475836424142 : VEN : SAMSUNG | DEV : GX6BAB : RAM : [ 3.00 GB ] EMI : [06] : eMMC : DDR3 : ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ] EMI : [07] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D420358E8D3278667 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 1491653415 ( 0x58E8D327) , MF : 8/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D2307CC3E133EF8C65BC515ABA01D43 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000600000 Erase : 0x0000000006B00000 : 0x0000000001D00000 Erase : 0x000000000A800000 : 0x0000000006000000 Erase : 0x0000000011800000 : 0x0000000000800000 Erase : 0x0000000015080000 : 0x0000000000980000 Erase : 0x0000000015D00000 : 0x0000000006900000 Erase : 0x000000001CA00000 : 0x00000001F3600000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : EFUSE Write : PARAM FAIL : SEC : IMG TYPE MISMATCH Write : UP_PARAM FAIL : SEC : IMG TYPE MISMATCH Write : MD1IMG FAIL : SEC : IMG TYPE MISMATCH Write : SPMFW Write : SCP1 Write : SSPM_1 Write : LK Write : BOOT Write : RECOVERY Write : DTBO Write : TEE1 Write : VENDOR Write : PRODUCT FAIL : SEC : IMG TOO LARGE Write : SYSTEM Write : VBMETA Write : CACHE Write : OMR FAIL : SEC : IMG TYPE MISMATCH Write : USERDATA Ultra : OK! [ All failed parts successfully flashed ] SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:02:43 Reconnect Power/Cable! |
The Following User Says Thank You to Mian Jahangir I For This Useful Post: |
11-18-2021, 17:52 | #68630 (permalink) |
Member: 314003 Status: Online Thanks Meter: 2,999 | Infinix X612B Frp Code: Product Device : Infinix-X612B Product Model : Infinix X612B Product Name : X612B-GL Patch Level : QP1A.190711.020 Display ID : X612B-X612BBC-QGo-GL-210720V034 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-07-05 Build Time : 20.07.2021 Product Info : BC3-OP Product Board : infinix_x612b Board Platform : mt6761 Product Manfct : INFINIX MOBILITY LIMITED Product Info : X612B-GL USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V127_6_P5 NVRAM : 0xB40AC5D2 NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : AC2334EAD5D6 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:01:47 Operation : Reset Settings/Format FS [ v2.28 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : DB59693750B9FA147C319B96A06D33A8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : AC83593FA75953C8A23B02A408A7884F46DD6118F9758FC6CDDE7F94751D9AB9 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_infinix_x612b.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 15010051583633414203209DD00CA735 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334142 EMMC: VEN : SAMSUNG : QX63AB EMMC: SNN : 547213324 ( 0x209DD00C) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 103393524D56A4651D9A606D1A635F42 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
11-18-2021, 19:19 | #68631 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Online Thanks Meter: 1,640 | Xiaomi Redmi 9A (Dandelion) IMEI REPAIR Done Code: Card found : 5C203D37 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Operation : Repair Security [ v2.28 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : F702DC4AAB3B3860DF0AED593CE6A70D BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 08F882D77D2660E50C02811BF02EA091F5E28872EB4DB9418E6F225D597FC712 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765 AP_SWTM : Tue Feb 23 20:49:04 CST 2021 AP_SWVR : alps-mp-q0.mp1.tc8sp3-V1.4_lcsh.q0mp1.k62v1.64.bsp_P55 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R3.MP.V107.5.P81 MD_SWVR : LCSH_Q0MP1_MT6762_SP_HW MD_HWVR : Unknown IMEI[1] : FFFFFFFFFFFFFFF IMEI[2] : FFFFFFFFFFFFFFF IMEI[2] : 354652313555559 Item : update Ok! Done! Elapsed: 00:02:11 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
11-18-2021, 21:24 | #68632 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Itel A23 Pro Network Unlock Done Flash Mode😌 Code: Card found : 46828B86 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : L5006S Product Model : itel L5006S Product Name : L5006S Patch Level : QP1A.190711.020 Display ID : L5006S-F3212MZ-10.0-MZ-Vodacom-V012-20210508 Ver. Incmt : MZ-Vodacom-V012-20210508 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-04-05 Build Time : 08.05.2021 Product Name : F3212MZ Product Device : itel-L5006S Product Info : L5006S Product Board : L5006S Board Platform : sp9832e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 35xxxxxxxxxxxxxxx IMEI[2] : 35xxxxxxxxxxxxxxx IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:43 Code: Operation : SP Unlock [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 35xxxxxxxxxxxxxxx IMEI[2] : 35xxxxxxxxxxxxxxx IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:25 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
11-19-2021, 07:54 | #68634 (permalink) |
Member: 811049 Status: Offline Thanks Meter: 99 | huawei ksa-lx9 format done ksa-lx9 done 1 clck via TP CM2 tool Load IDBase v718267 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : CB51B25E4B1AB01EDCA4840454BF35D4 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 5ACA9682493EE8B52EF64DAC80A9562178007A5A504C05CDC2 3D6FDBD5B39597 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k61v1_64_mexico.bin EMI : CNT : 0010 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D4201D8C1D2AD36F3 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 3636581037 ( 0xD8C1D2AD) , MF : 3/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B82CAB08B81CECF73722E4A4C39C7602 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
11-19-2021, 12:39 | #68635 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile g3 lite hang on loag done by cm2 Card found : S/N : 73CA70CC , v0150 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 481AFF362019EE8F6348DDD6E95A9078 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin FileVersion : MAUI.11C.W13.52.MP.V2.F9 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F9.bin Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
11-19-2021, 12:40 | #68636 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Infinix X627 Reset Done Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM24) MODE : BOOTROM PORT : 24 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 7AE551BAF0ACE348940F9358A7661FD9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 882207BE54EDA427940A2A40021CB0CE9750DB459F41B01A78 36A9D3B14262C5 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x627_h624.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 700100544132383332231A63CB2F66D7 EMMC: VEN : KINGSTON : OEM : 0 : ID : 544132383332 EMMC: VEN : KINGSTON : TA2832 EMMC: SNN : 442747695 ( 0x1A63CB2F) , MF : 6/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7E0995BC6C295E8B64B023883CE2935 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
11-19-2021, 14:20 | #68637 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix x680b reset frp done by cm2 Card found : 73CA70CC , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v98353 Ok! Update configuration ... Update Ok! Load IDBase v98353 Ok! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2CC3803C9DF1548BD370FBDF3E67A585 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1BBE4CEDD93AA6412F694EDEADC7C8FBD0F24B44F3176DF231 A7AC727A12C1A6 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for EMI BROM : SLA : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680b_h6215.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142023DE4CEC9B71B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1038405321 ( 0x3DE4CEC9) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 34A5C8895A1A48677834D85FFEDDFFB6 DA : USB : HIGH-SPEED Boot done! Product Brand : Infinix Product Device : Infinix-X680B Product Model : Infinix X680B Product Name : X680B-OP Patch Level : QP1A.190711.020 Display ID : X680B-H6215EFIJ-Q-OP-210408V247 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-04-05 Build Time : 08.04.2021 Product Info : x680b_h6215 Product Board : Infinix-X680B Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM check : Passed! NVRAM : SEC NORMAL [ No extra security ] Backup sensetive data [ 16 ] Backup path : Backup\MT6765__2CC3803C9DF1548BD370FBDF3E67A585\ [26] Read : NVRAM [10] Read : NVDATA [3] Read : PROINFO [27] Read : LK [9] Read : NVCFG [12] Read : PROTECT1 [13] Read : PROTECT2 [1] Read : PGPT [11] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:36 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 2CC3803C9DF1548BD370FBDF3E67A585 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 1BBE4CEDD93AA6412F694EDEADC7C8FBD0F24B44F3176DF231 A7AC727A12C1A6 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680b_h6215.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445036444142023DE4CEC9B71B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445036444142 EMMC: VEN : SAMSUNG : DP6DAB EMMC: SNN : 1038405321 ( 0x3DE4CEC9) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 34A5C8895A1A48677834D85FFEDDFFB6 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
11-20-2021, 10:01 | #68639 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | VGOTEL NEW 7 pattren password remove done Infinity Box Card found : C1B4DF65 , v0150 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.28 Load IDBase v718267 Ok! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM3) MODE : PRELOADER PORT PORT : 3 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4400014531303446695F0136E5C610D0 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 450100444634303136015F69D010C6E5 EMMC: VEN : SANDISK : OEM : 0 : ID : 444634303136 EMMC: VEN : SANDISK : DF4016 EMMC: SNN : 1600770064 ( 0x5F69D010) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3E44E8E3BB14EBD27B0B09BBD38D63E0 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : H97_P5085_VGOTEL_V04_20190709 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-07-05 Build Time : 09.07.2019 Product Model : NEW 7 Product Brand : VGOTEL Product Name : NEW_7 Product Device : NEW_7 Product Manfct : VGOTEL Product Info : NEW_7 Product Board : NEW_7 Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) NVRAM : 0x7702994A NVRAM : State : Ok! INFO : WiFi MAC : AA0037003600 INFO : BlTh MAC : 480BB2C802F4 INFO : IMEI[1] : 3597---- INFO : IMEI[2] : 3597--------- Backup sensetive data [ 16 ] Backup path : Backup\MT6580__3E44E8E3BB14EBD27B0B09BBD38D63E0\ [3] Read : NVRAM [20] Read : NVDATA [2] Read : PROINFO [8] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [6] Read : PERSIST [0] Read : PRELOADER Backup done! Done! Elapsed: 00:00:42 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4400014531303446695F0136E5C610D0 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 450100444634303136015F69D010C6E5 EMMC: VEN : SANDISK : OEM : 0 : ID : 444634303136 EMMC: VEN : SANDISK : DF4016 EMMC: SNN : 1600770064 ( 0x5F69D010) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3E44E8E3BB14EBD27B0B09BBD38D63E0 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
11-20-2021, 10:20 | #68640 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Oppo A5s CPH1909 Pattren/ Password Remove done Infinity Box Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C3CBF733C2DF6C2CF77E829CCEAD321B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : AE605239DF7E0025BE882A0D1121655002D9D066CF873FBC0C F71B549EC3C2DA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D420191B26A85B689 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 2444388997 ( 0x91B26A85) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FBCB7F0DE7F258F267B000E885B51D7 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2021-04-05 Product Manfct : OPPO Build Time : 19.03.2021 Product Brand : OPPO Product Model : CPH1909 Product Info : CPH1909 Product Device : CPH1909 Product Name : CPH1909 SW OTA Version : CPH1909EX_11.A.46_0460_202103191930 Display ID : CPH1909EX_11_A.46 Kernel Info : 4.9.77 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption *) NVRAM : OPPO6765_18511_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R 2_TC16_SP_V50_5_P97 NVRAM : 0xBC0ACB13 NVRAM : State : Ok! INFO : WiFi MAC : 9C5F5A16E57D INFO : BlTh MAC : 9C5F5A16E57C Backup sensetive data [ 16 ] Backup path : Backup\MT6765__C3CBF733C2DF6C2CF77E829CCEAD321B\ Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! Done! Elapsed: 00:00:18 Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C3CBF733C2DF6C2CF77E829CCEAD321B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : AE605239DF7E0025BE882A0D1121655002D9D066CF873FBC0C F71B549EC3C2DA BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_18511.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D420191B26A85B689 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 2444388997 ( 0x91B26A85) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FBCB7F0DE7F258F267B000E885B51D7 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.28 ] |
