Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #69046 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,340 | ![]() Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile XLi Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:27 |
![]() | #69047 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 989 | ITEL A33 FRP lock is successfully reseted Infinity Box 🌄 Card found : C1B4DF65 , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : W5001P-F3102-8.1-OP-V064-20200611 Ver. Incmt : OP-V064-20200611 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-06-05 Build Time : 11.06.2020 Product Model : itel W5001P Product Brand : Itel Product Name : F3102 Product Device : itel-W5001P Product Manfct : itel Product Info : F3102 Product Board : itel-W5001P Board Platform : sp7731e Platform Version: MOCORTM_17C_W18.31.2_P27_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.31.2_P27 HW Version: sc7731e_modem CMP_Time : 01-16-2020 20:28:37 MODEM TAG : MOCORTM_17C_W18.31.2_P27_Debug_FM_BASE_17C_W18.31. 2_P27_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:40 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
The Following 3 Users Say Thank You to naveedullah0044 For This Useful Post: |
![]() | #69048 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2016
Member: 2573997 Status: Offline Thanks Meter: 109 | ![]() huawei dua l22 imei repair succes flash mode one click by selecting firefly platform log: Operation : Repair Security [ v2.31 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM14) MODE : BOOTROM PORT : 14 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : B425593E50F97C5626C49B3D5B0C0C35 BROM : SecLevel : 0x000000E3 BROM : SecMode : SBC+SLA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : A368984F3A5598DB7AB247879D234328D564F43C6671CF0085 95BF4A32ECF04C BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v04.04.04 on MT6739 FireFly : eMMC init passed! EMMC: CSD : D02701328F5903FFFFFFFFE78A400017 EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 90014A484147346132D4008255155737 EMMC: VEN : HYNIX : OEM : 74 : ID : 484147346132 EMMC: VEN : HYNIX : HAG4a2 EMMC: SNN : 8541461 ( 0x00825515) , MF : 5/2020 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x00 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 16 GB EMMC: EXTCSD [SIZE] : Actual : 0x3AB400000 [ 14.68 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] DA : USB : HIGH-SPEED Boot done! NVRAM : 0xB30ABE18 NVRAM : State : Ok! INFO : WiFi MAC : 10327E6A8DB1 INFO : BlTh MAC : 10327E6E5E41 INFO : IMEI[1] : 86................427 INFO : IMEI[2] : 86................426 INFO : set IMEI[1] : 35...............060 INFO : set IMEI[2] : 35.................21 Update NVRAM ... Update dependencies ... Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
The Following User Says Thank You to Mudasir Ali For This Useful Post: |
![]() | #69049 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | Samsung A10s A107f u8 frp remove done cm2 Code: Samsung A10S A107FFrp remove done via cm2 no need test point just plug cable or reset smart extra 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C44EE216EDEB8122F6B42542621653E7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 229F71D6D69143C6FE933BCC4D6F58A4B3BFDC2BC77D3F6BFAD0843DCD2FDB38 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ra1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100515836334D42006669D0A857AD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334D42 EMMC: VEN : SAMSUNG : QX63MB EMMC: SNN : 1718210728 ( 0x6669D0A8) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A7133596CBFC25DA3888C00C15D9252B DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Device : a10s Product Model : SM-A107F Product Name : a10sxx Patch Level : RP1A.200720.012 Display ID : RP1A.200720.012.A107FXXU8CUI2 Build Time : 15.09.2021 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-09-01 Product Info : a10s Product Board : S96116RA1 Board Platform : mt6765 Product Manfct : samsung NVRAM : TITAN_S1_Q0MP1_K62V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_TC10_PR1_SP_V4_P43 NVRAM : 0xBC0AD96C NVRAM : State : Ok! NVRAM : SecLv : Vendor Signed INFO : WiFi MAC : 1089FBE4375E INFO : BlTh MAC : 1089FBE4375F INFO : IMEI[1] : 54C11C6BFA5ABE4 INFO : IMEI[2] : 76F80CEB1267588 STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! Done! Elapsed: 00:00:39 Operation : Reset Settings/Format FS [ v2.31 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM36) MODE : BOOTROM PORT : 36 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : C44EE216EDEB8122F6B42542621653E7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 229F71D6D69143C6FE933BCC4D6F58A4B3BFDC2BC77D3F6BFAD0843DCD2FDB38 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_s96116ra1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100515836334D42006669D0A857AD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334D42 EMMC: VEN : SAMSUNG : QX63MB EMMC: SNN : 1718210728 ( 0x6669D0A8) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A7133596CBFC25DA3888C00C15D9252B DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
![]() | #69050 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,731 | Vgotel i515 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Load File File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 54FFE30F4AB02070696AAAE82F72DC15 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.bin FileVersion : MAUI.11C.W13.52.MP.V2.F45 Flash now Erase region , wait ... Write data , wait ... Write : FISE61D_11C_PCB01_GPRS_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F45.BIN.bin Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
![]() | #69051 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,731 | Vivo a11k reset pattern done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.31 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.31 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM16) MODE : BOOTROM PORT : 16 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 8616C5029B9C7C6807FBB534197F71B9 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 7F8BE9CBC013C8A9749BAE368E37E724C0B1781C81FA3C29A3 2A16EF1625982A BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765_19451.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 90014A68423861503E035A52909127DF EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 1515360401 ( 0x5A529091) , MF : 2/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 82F8AA29BA1974566252E1C6D2699C0 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
![]() | #69052 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,731 | Itel l6502 remove frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6502 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
![]() | #69053 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,731 | Qmobile x30 v3 hang on logo done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
![]() | #69054 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,340 | ![]() Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile i8i PRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
![]() | #69055 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2020 Location: Mozambique Age: 18
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 596 | Nokia C10 TA-1342 NetworkUnlock Done Code: Card found : 46828B86 , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : Identify [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.300_B01 release-keys MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2_P3_sc7731e_modem_pike2_pub PSN1 : E645484181101104 PSN1 : E286655860B81303468 NVMng : SecurityInfo IMEI[1] : 357735917424483 IMEI[2] : 357735917424491 WIFIMAC : 44917C1A301B BT_MAC : 44917C1A301A SEC : SLS:2, SKS:0, SKV:4 Done! Elapsed: 00:00:20 Code: Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.300_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2_P3_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 357735917424483 IMEI[2] : 357735917424491 WIFIMAC : 44917C1A301B BT_MAC : 44917C1A301A SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 45, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Reconnect Power/Cable! After Time Requested Code: Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Mantis_00WW-user 11 RP1A.201005.001 V1.300_B01 release-keys Platform Version: MOCORTM_17C_W21.11.2_P3_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.11.2_P3 HW Version: sc7731e_modem CMP_Time : 05-25-2021 21:34:06 MODEM TAG : MOCORTM_17C_W21.11.2_P3_Debug_FM_BASE_17C_W21.11.2_P3_sc7731e_modem_pike2_pub NVMng : SecurityInfo IMEI[1] : 357735917424483 IMEI[2] : 357735917424491 WIFIMAC : 44917C1A301B BT_MAC : 44917C1A301A SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 40, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:27 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
![]() | #69056 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,207 | Qmobile i8i 2020 formate done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
![]() | #69057 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,207 | Qmobile i8i flash done Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : OPM2.171019.012 release-keys Ver. Incmt : 1574120907 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-12-05 Build Time : 21.12.2019 Product Model : i7i 2020 Product Info : i7i_2020 Product Brand : QSmart Product Name : i7i_2020 Product Device : i7i_2020 Product Model : i7i2020 Product Manfct : QMobile Product Board : i7i-2020 Board Platform : sp7731e SECSolution : MODERN [RS/0S/1S/2S] Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update PMT Ok! Prepare target ... Prepare Ok! FSIMG : prodnv.img CODE : recovery.img CODE : tos.bin CODE : tos.bin CODE : sml.bin CODE : sml.bin UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : boot_logo.bmp CODE : fastboot_logo.bmp FSIMG : persist.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : modem_wcn.img CODE : modem_w.bin CODE : deltanv_w.bin CODE : gdsp_w.bin CODE : pm_sys.bin CODE : boot.img FSIMG : system.img FSIMG : cache.img FSIMG : vendor.img CODE : vbmeta.img CODE : vbmeta.img FSIMG : userdata.img UBOOT : u-boot-spl.bin ERASE : MISC ERASE : UBOOT_LOG ERASE : FLASH_W Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:03:35 |
![]() | #69058 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2003 Location: zimbab Age: 44
Member: 32705 Status: Offline Thanks Meter: 64 | Nokia C1 Factory Reset Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Wipe Ok : UserData >>> INFO : FRP reset require FlashMode! Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
![]() | #69059 (permalink) |
Member: 32705 Status: Offline Thanks Meter: 64 | iTel A14 Reset and FRP Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel A14 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:50 |
![]() | #69060 (permalink) |
