Old 12-01-2010, 13:38   #6901 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Read full flash beyond b720 done
COM7 [VCP0] selected
module  v3.25
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F903:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.25, database date: 23.11.2010):
TELACOM25_08A_PMWY_PCB01_GPRS_MT6225_S00.TL_T678_P58U11F09LO1_00_22.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: TELACOM25_08A_PMWY_PCB01_GPRS_MT6225_S00.TL_T678_P58U11F09LO1_00_22.BIN
project-id: TL_T678_P58U11F09LO1_00.22, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: TELACOM25_08A_PMWY_PCB01_GPRS_MT6225_S00.TL_T678_P58U11F09LO1_00_22__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\BEYOND  B720\TELACOM25_08A_PMWY_PCB01_GPRS_MT6225_S00.TL_T678_P58U11F09LO1_00_22__fullflash_20101130-135632.B0M.bin
Finished, time used: 12 min 49 sec
Remove/Install battery now !
The Following User Says Thank You to G_TRON84 For This Useful Post:
Old 12-01-2010, 13:40   #6902 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
G-star 678 read full flash done
COM25 [VCP2] selected
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:1703:000C
status: FF
Boot Done
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Initialize Done
====>  Set baud ...
921600
Set baud Done
rom info structure: [standard] type (04)
TCL-ID is absent
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.GDL135_ZD20_DSIM_ST_V33.BIN
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.GDL135_ZD20_DSIM_ST_V33.BIN
project-id: GDL135_ZD20_DSIM_ST_V33, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.GDL135_ZD20_DSIM_ST_V33__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\G-STAR 678\GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.GDL135_ZD20_DSIM_ST_V33__fullflash_20101130-141145.B0M.bin
Finished, time used: 11 min 44 sec
Old 12-01-2010, 13:42   #6903 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Blackberry copy 8520 read done
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:7703:0001
status: FF
Boot Done
flash: EC240200000000:18E59F00000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HD91502_8_12_1_0T03M1107_M511A.BIN
rom info ver: 04
sw version: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HD91502_8_12_1_0T03M1107_M511A.BIN
project-id: HD91502.8.12.1.0T03M1107_M511A, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HD91502_8_12_1_0T03M1107_M511A__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\BB8520\TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HD91502_8_12_1_0T03M1107_M511A__fullflash_20101130-143020.B0M.bin
Finished, time used: 11 min 28 sec
Old 12-01-2010, 13:55   #6904 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
CHINESE BLACKBERRY 9700i READ DONE
COM25 [VCP0] selected
module  v3.25
Device: Autodetect 6228-6253 NAND
Action: read firmware NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (230400)...
done
ram test...
testing...
ram test passed
===>  detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: M6235_X1010_JBL_02_V14
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: MTK35_09A_BOOTLOADER_V005_MT6235B_M6235_X1010_JBL_02_V14.bin
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: MTK35_09A_PCB01_GPRS_MT6235B_S01.M6235_X1010_JBL_02_V14.BIN
project-id: M6235_X1010_JBL_02_V14, 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: [standard] type (07)
TCL-ID is absent
===>  done
area size: 32Mb
number of areas/bytes to read: 1:02000000
file saved: C:\Program Files\InfinityBox\ChineseMiracle\bbc9700i\MTK35_09A_PCB01_GPRS_MT6235B_S01.M6235_X1010_JBL_02_V14__firmware_20101128-162730.B4M.bin
Disconnect...
done
Finished, time used: 33 min 3 sec
Old 12-01-2010, 14:00   #6905 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Asiafhone af702 read done
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:E003:000F
status: FF
Boot Done
Initialize Done
====>  Set baud ...
230400
Set baud Done
TCL-ID is absent
SCUD_GEMINI_PCB01_GPRS_MT6225_S00.806_A_V05_01.BIN
rom info ver: 04
sw version: SCUD_GEMINI_PCB01_GPRS_MT6225_S00.806_A_V05_01.BIN
project-id: 806_A.V05.01, 00000000
TCL-ID is absent
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E80000
Detected ffs/eeprom address is non-standard: 00E80000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E80000
ffs/eeprom size: 00180000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E80000-00FFFFFF
firmware area: 00000000-00E7FFFF
reading: SCUD_GEMINI_PCB01_GPRS_MT6225_S00.806_A_V05_01__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\asiafhone af702\SCUD_GEMINI_PCB01_GPRS_MT6225_S00.806_A_V05_01__fullflash_20101129-182538.B0M.bin
Finished, time used: 17 min 58 sec
Old 12-01-2010, 14:09   #6906 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Ht mobile ht71 read,format,repair imei,read info done
READ FULL FLASH
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:F403:0009
status: FF
Boot Done
flash: 01227E223C2200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
number of flash chip/regions detected: 02/01
Initialize Done
====>  Set baud ...
921600
Set baud Done
total flash region size: 02000000
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.F5CFF730.[U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23.BIN_06DC078B].rpl
New firmware found (v.3.25, database date: 21.11.2010):
device-id: F5CFF730
rom info ver: 04
sw version: U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23.BIN
project-id: UPU25U26V07B23, 8B07DC06
ffs offset/size [01]: 01C00000/00400000
TCL-ID is absent
standard ffs/eeprom offset detected: 01C00000
checking area [00000000]: 00080000-01FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 01C00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
standard ffs/eeprom address selected by user
ffs/eeprom size: 00400000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01C00000-01FFFFFF
firmware area: 00000000-01BFFFFF
reading: U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HTMOBILE _HT71\U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__fullflash_20101128-131406.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__system_log_F5CFF730_06DC078B_20101128-131510.B0X.bin
Finished, time used: 23 min 5 sec
FORMAT FFS
module  v3.25
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
device-id: F5CFF730
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HTMOBILE _HT71\U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__ffs_20101128-141801.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__system_log_F5CFF730_06DC078B_20101128-141935.B0X.bin
Finished, time used: 5 min 12 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
REPAIR IMEI
Action: "repair imei"
Model: Autodetect 6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
imei-1: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 371710904016636
verification Ok
Finished, time used: 10 sec
READ DETAILED INFO
module  v3.25
Action: read/check information
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
device-id: F5CFF730
rom info ver: 04
TCL-ID is absent
standard ffs/eeprom offset confirmed: 01C00000
ffs/eeprom chip: 00
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
detecting firmware version...
firmware version: U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23.BIN
detecting firmware build...
firmware date/time: 2009-02-28 15-14
hw1: U25_06B_HW
done
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Id Cn
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V07B23__system_log_F5CFF730_06DC078B_20101128-142252.B0X.bin
Finished, time used: 1 min 57 sec
Old 12-01-2010, 14:13   #6907 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
COM2 [VCP1] selected
module v1.39
Device: LG-KP115
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 352129020295466
file saved: C:\Documents and Settings\TANIKA\Desktop\eeprom_352129020295466_LG-KP115_20101201-183923.B1E.bin
reading _eeprom-ffs_352129020295466...
file saved: C:\Documents and Settings\TANIKA\Desktop\_eeprom-ffs_352129020295466_LG-KP115_20101201-184034.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 185 sec
The Following User Says Thank You to joni_rajpura For This Useful Post:
Old 12-01-2010, 14:16   #6908 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Huawei cdma phone read phone lock done
COM20 [VCP0] selected
Device: Huawei-C2205
Action: user code
Connect...
Phone must be Powered-On
Connect Done
Read phone info...
software compiled: Feb 25 201017:06:35
software released: Jun 29 200619:00:00
software version: SCNRZ...*
model id: 4
MSM: 20B1
build id: QSC6010-SCNRZ-....
ESN: 80030EAD
Read phone info Done
Verify access...
user code: 1010
Verify access Done
Decode data...
code is not set or unknown eeprom
Decode data Done
Finished, time used: 14 sec
Old 12-01-2010, 14:21   #6909 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Nokia copy e75 read full flash done
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:4B03:0005
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
New firmware found (v.3.25, database date: 06.11.2010):
PCB2.0_BT6601_TS1003_SPANSION256M.S750_BY_T08_M1014_S_ML_C.BIN
rom info ver: 04
sw version: PCB2.0_BT6601_TS1003_SPANSION256M.S750_BY_T08_M1014_S_ML_C.BIN
project-id: S750_BY_T08_M1014_S_ML_C, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: PCB2.0_BT6601_TS1003_SPANSION256M.S750_BY_T08_M1014_S_ML_C__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\PCB2.0_BT6601_TS1003_SPANSION256M.S750_BY_T08_M1014_S_ML_C__fullflash_20101110-152413.B0M.bin
Finished, time used: 22 min 5 sec
Old 12-01-2010, 14:25   #6910 (permalink)
Member: 495352
Sonork: 100.1589707
Thanks Meter: 70
Tv mobile t88 read full flash and ffs done
FULL FLASH
module  v3.25
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0603:000F
status: FF
Boot Done
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1.BIN
rom info ver: 04
sw version: TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1.BIN
project-id: TM009C_LANG_B_V0.2.1, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1__fullflash_20101111-121717.B0M.bin
Finished, time used: 11 min 52 sec
FFS
module  v3.25
Action: read ffs/eeprom
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\TM009C_LANG_B_PCB01_GPRS_MT6225_S00.TM009C_LANG_B_V0_2_1__ffs_20101111-121930.B0E.bin
Finished, time used: 1 min 53 sec
Old 12-01-2010, 15:39   #6911 (permalink)
caremobiles's Avatar
Member: 332724
Sonork: 100.1605077
Thanks Meter: 231
COM10 [QCUSB_COM10_1] selected
module v1.41
Device: Micromax-C111
operation: SP-unlock
connecting...
CJF.10.IOct 09 2010
MICROMAX C111 09 Oct 2010 selected..
Offline..
Downloading mode..
prepare for patching...
try conecting..1
Sending Boot..
patching in progress...
patching in progress 50%...
patching in progress 100%...
done...
Finished, time used: 42 sec
Thank you very much for giving easy and safe solutions of this CDMA Software.All the Best.
The Following 2 Users Say Thank You to caremobiles For This Useful Post:
Old 12-01-2010, 17:11   #6912 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,270
6600f done with best
Selected FlashSettings : FullFlash
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : E4E60B4C_rm325__06.20.mcusw
PPM : 9278630B_rm325__06.20.ppm_ma
CNT : BCB970D1_rm325__06.20_ISM_013.image_ma_arabic_black
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
[BB5 FLASH]: Bootrom Ok!
RAP_PUB:   24A00002B0AF0254DB4BE8F9BD17D8989B5583B3
CMT_ROOT:  9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
   ===Flashing [MCU]===
Erase : Processing E4E60B4C_rm325__06.20.mcusw
Found 5 areas to erase
Erasing area 0x00000000 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x01760000 - 0x0195FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0175FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:05
Write : Processing E4E60B4C_rm325__06.20.mcusw
Total 1521 [1521/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:02:13
MCU Write done
   ===Flashing [PPM]===
Erase : Processing 9278630B_rm325__06.20.ppm_ma
Found 1 areas to erase
Erasing area 0x01960000 - 0x021FFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:38
Write : Processing 9278630B_rm325__06.20.ppm_ma
Total 413 [413/0/0] blocks to write, writing...
TIME : Write time : 00:00:38
PPM Write done
   ===Flashing [CNT]===
Checking content info...
Check Image : Content size is 128k, use direct write mode
Erase : Processing BCB970D1_rm325__06.20_ISM_013.image_ma_arabic_black
Found 2 areas to erase
Erasing area 0x02660000 - 0x03F9FFFF, NOR, CMT
Result: 0000
Erasing area 0x02200000 - 0x0265FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:44
Write : Processing BCB970D1_rm325__06.20_ISM_013.image_ma_arabic_black
Total 528 [528/0/0] blocks to write, writing...
TIME : Write time : 00:00:43
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:09:03
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia 6600 fold
Software Info:     V 06.20 28-07-09 RM-325 (c) Nokia
IMEI:  3557290251******
PPM version :   V 06.20 28-07-09 RM-325 (c) Nokia             MA
Product code:  0559304
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
Set phone to Normal mode...
AfterFlash operations done...
Done!
Elapsed: 00:10:12
The Following 4 Users Say Thank You to Mohsin-* For This Useful Post:
Old 12-01-2010, 17:32   #6913 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
3600s done with best
registered to: mohsin
Connect phone on selected interface...
MCU : rm352__07.23.mcusw
PPM : rm352__07.23.ppm_mb
CNT : rm352__07.23.image_mb_dark_red
Check files done...
RAP_PUB:   23C0000D35407D560B6374C1539731A751DC3549
Waiting for response: 29
ADL : Check data
ADL : Data accepted
Erase : Processing rm352__07.23.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Result: 0000
Result: 0000
Erasing area 0x00140000 - 0x014DFFFF, NOR, CMT
Result: 0000
Erasing area 0x014E0000 - 0x0167FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:37
Write : Processing rm352__07.23.mcusw
Total 1376 [1376/0/0] blocks to write, writing...
TIME : Write time : 00:02:34
MCU Write done
Erase : Processing rm352__07.23.ppm_mb
Erasing area 0x01680000 - 0x01F1FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:37
Write : Processing rm352__07.23.ppm_mb
Total 403 [403/0/0] blocks to write, writing...
TIME : Write time : 00:00:48
PPM Write done
Erase : Processing rm352__07.23.image_mb_dark_red
Erasing area 0x01F20000 - 0x022BFFFF, NOR, CMT
Result: 0000
Erasing area 0x022C0000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:22
Write : Processing rm352__07.23.image_mb_dark_red
Total 480 [480/0/0] blocks to write, writing...
TIME : Write time : 00:00:51
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:08:51
Reboot phone now...
Connected phone -   Nokia 3600 slide
Software Info:     V 07.23 17-07-09 RM-352 (c) Nokia
IMEI:  3593060226*****
PPM version :   V 07.23 17-07-09 RM-352 (c) Nokia             MB
Product code:  0562049
Checking...
Read Info Done!
SwUpgradeSet...OK!
Product code update...
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:10:52
Phone found!
Series 40 Device detected!
read info...  - Ok
Old 12-01-2010, 18:56   #6914 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 529
1202 unlocked
BB5 Easy Service Tool
card found: S/N
Port COM1 open OK
Connect phone on selected interface... Wait...
Phone found...
Phone in Test mode
IMEI: 358310
Phone connected
Check phone mode...
Phone already in Test mode, skip change...
Read Lock Info
Locked to Unknown providers
Connect to server...
Unlocking...
All done !
Resetting selected items...
Check phone mode...
Settings User Data Defaults...
Set OK!
Phone disconnected
Port COM1 close
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 12-01-2010, 19:03   #6915 (permalink)
rkinfo_khan's Avatar
Member: 978268
Thanks Meter: 83
SUCCESSFULLY FLASHED AND UNLOCKED NEW VER HAIER C2076
COM127 [QCUSB_COM127_2] selected
module v1.38
Device: Haier-C2076
operation: SP-unlock (DIAG-mode disabled)
connecting...
Check conection...
OK...
Sending command...
Sending command 30%...
Sending command 60%...
Sending command 90%...
Sending command 100%...
Checking version...
C2076-VM-V0.3.3 selected..
patching in progres...
patching in progres 50%...
patching in progres 95%...
Done...
Phones should restart now...
Finished, time used: 15 sec
The Following 2 Users Say Thank You to rkinfo_khan For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.65166 seconds with 10 queries
