02-06-2022, 14:14 | #69752 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,793 | Starlight c note pro x full factory reset done original poster MS-GSM DZGSM |
The Following User Says Thank You to profkefah For This Useful Post: |
02-06-2022, 14:44 | #69754 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | Itel p15 reset settings and frp done by cm2 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : itel W5005 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0004 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:25 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
02-06-2022, 17:45 | #69755 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,793 | Redmi 9a unlock bootloader + write firmware for bypass mi account, all done original poster MS-GSM DZGSM |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
02-06-2022, 18:38 | #69756 (permalink) |
Major Poster Join Date: Oct 2005 Location: Rancagua, Chile Age: 35
Member: 195049 Status: Offline Thanks Meter: 15 | Xiaomi Redmi Note 10S Reset FRP Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM87) MODE : BOOTROM PORT : 87 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 67C039C7939111813A32BA3A7D8FD475 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : E88CDEB822AF3EEFCDE1AA757F7A1106D3A9CDDF44C89090EA 91E1D349CF65F5 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : Xiaomi : Dimensity [800][1000] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v2112 AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k85v1_64.bin EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485131354145434D42444152 UFS: VEN : 0x01AD VID : H9HQ15AECMBDAR IFW : A002 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0x1DCAC00000 [ 119,17 GB ] FSN : 2010A5C7CA80 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C8AB1DD3388A405B8815E5CC859EF983 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
02-07-2022, 07:17 | #69757 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Ph
Member: 2348059 Status: Offline Sonork: 100.293844 Thanks Meter: 45 | vivo V2026 GOOGLE ACCOUNT Operation : Reset Settings/Format FS [ v2.32 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 086478036D9F5C3790CA00D634EC8486 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 376ACB210D026EC702301E24F1D41CA97B8BD5B4EA89A56E90 B3C872AF81DEA5 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k65v1_64_bsp.bin EMI : CNT : 0009 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100445836384D42095ADACCE1B78B EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445836384D42 EMMC: VEN : SAMSUNG : DX68MB EMMC: SNN : 1524288737 ( 0x5ADACCE1) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1EFA238F5EFD72323265553428F2FE3B DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:01:01 Reconnect Power/Cable! |
02-07-2022, 08:28 | #69758 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | OPPO A83 CPH1729 Smart Reset Done with TP connect :) Code: Operation : Reset Settings/Format FS [ v2.28 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM29) MODE : BOOTROM PORT : 29 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 CODE : Bianco TYPE : MODERN [RAPHAEL] BROM : MEID : 8B6E7A686071C4970EF844522CBDB00B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FA12931D485A9C828D0BEF83353C7233FE97ECB6F49D7D150AF1A8B90DF63C1B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A484247346132A53520322A4539 EMMC: VEN : HYNIX : OEM : 74 : ID : 484247346132 EMMC: VEN : HYNIX : HBG4a2 EMMC: SNN : 891302442 ( 0x3520322A) , MF : 4/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 764B492FD7F98227597FAE7146F5BDB DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8F5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:49 Reconnect Power/Cable! Operation : Identify [ v2.28 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM29) MODE : BOOTROM PORT : 29 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 CODE : Bianco TYPE : MODERN [RAPHAEL] BROM : MEID : 8B6E7A686071C4970EF844522CBDB00B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FA12931D485A9C828D0BEF83353C7233FE97ECB6F49D7D150AF1A8B90DF63C1B BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0003 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A484247346132A53520322A4539 EMMC: VEN : HYNIX : OEM : 74 : ID : 484247346132 EMMC: VEN : HYNIX : HBG4a2 EMMC: SNN : 891302442 ( 0x3520322A) , MF : 4/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 764B492FD7F98227597FAE7146F5BDB DA : USB : HIGH-SPEED Boot done! Patch Level : N6F26Q Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2019-10-05 Build Time : 03.09.2020 Product Manfct : OPPO Board Platform : mt6763 Product Model : OPPO A83js Product Brand : OPPO Product Name : A83js Product Device : M6763D Product Board : full_oppo6763_17101 Product Info : oppo6763_17101 SW Version : A.35 SW OTA Version : M6763D_11.A.35_0350_202009032342 SW OTA Name : A83jsEX_11_A.35_200903 Display ID : A83jsEX_11_A.35_200903 Kernel Info : 4.4.22-G202009032342 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM : OPPO6763_17101_ALLNETCT_MDBIN_PCB01_MT6763_S00.MOLY_LR12A_R1_TC16_SP_V26_P58 NVRAM : 0xCF10C671 NVRAM : State : Ok! INFO : WiFi MAC : 14C6974C403F INFO : BlTh MAC : 14C6974C403E Backup sensetive data [ 16 ] Backup path : Backup\MT6763__8B6E7A686071C4970EF844522CBDB00B\ [28] Read : NVRAM [13] Read : NVDATA [20] Read : PROINFO [29] Read : LK [12] Read : NVCFG [15] Read : PROTECT1 [16] Read : PROTECT2 [1] Read : PGPT [18] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! Done! Elapsed: 00:00:31 |
02-07-2022, 08:52 | #69759 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X688B MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0152 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! UserName and/or Password not set! Can't continue! Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 4F048761481685B471FE81823462DA6B BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 46B96F575A90ED1F404A740A2BB21DAAEF53735E292AF662B92F6139F53FD681 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x680f_h6116.bin EMI : CNT : 0004 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 90014A484347386134A2105250245705 EMMC: VEN : HYNIX : OEM : 74 : ID : 484347386134 EMMC: VEN : HYNIX : HCG8a4 EMMC: SNN : 273829924 ( 0x10525024) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 70D1ED3EB439D21F267EAB2BBFADF885 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
02-07-2022, 11:10 | #69760 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Oppo f11 pro remove frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : D333CE9CC1AB2BA1DF3F1E300A5299AF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 5D514611B0AC40969EC2124C35DEEEE0E91A31CF328454E859 E009340FF0354D BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : PreBoot stage #1 BROM : PreBoot stage #2 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E53304A394B391025873689480F EMMC: VEN : MICRON : OEM : 78 : ID : 53304A394B39 EMMC: VEN : MICRON : S0J9K9 EMMC: SNN : 629618313 ( 0x25873689) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 25B2B2D8DF895DF93FCB4AAE854EB0E1 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
02-07-2022, 11:11 | #69761 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile i5i reset frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
02-07-2022, 11:12 | #69762 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Samsung galaxy a03s reset frp done by cm2 Card found : 73CA70CC , v0151 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.32 Load IDBase v1121431 Ok! Update configuration ... Load IDBase v1121431 Ok! Operation : Reset Settings/Format FS [ v2.32 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM7) MODE : BOOTROM PORT : 7 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 4992EE13B390C8B08032DA93F4B175AC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 2C50C622E6BFD4A54EA415D29DA5F1894F4BC9DA1467F94265 0ED8D06A883379 BROM : Sending FireFly FireFly : Starting ... FireFly : Init Core FireFly : Core init done! FireFly : Running : v04.04.04 on MT6765 FireFly : eMMC init passed! EMMC: CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC: CSD : TEMP_WRITE_PROTECT: False EMMC: CSD : PERM_WRITE_PROTECT: False EMMC: CID : 15010047583642414200B8E668E758BB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 475836424142 EMMC: VEN : SAMSUNG : GX6BAB EMMC: SNN : 3102107879 ( 0xB8E668E7) , MF : 5/2021 EMMC: EXTCSD : rev1.8 ( eMMC 5.1 ) EMMC: EXTCSD [BOOT_BUS_WIDTH] : 0x02 EMMC: EXTCSD [PARTITION_CONFIG] : 0x48 EMMC: EXTCSD [SIZE] : Market : 32 GB EMMC: EXTCSD [SIZE] : Actual : 0x747C00000 [ 29.12 GB ] EMMC: EXTCSD [EOL] : EOL status : Normal ( Less than 80% reserved blocks used ) EMMC: EXTCSD [EOL_A] : SLC status : 0% - 10% used EMMC: EXTCSD [EOL_B] : MLC status : 0% - 10% used EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : Vendor Extra Done! Elapsed: 00:01:04 Reconnect Power/Cable! |
02-07-2022, 11:13 | #69763 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Vgo tel super jumbo i700 reset password done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 20D689B9BA4E77C11DC23D0D2D79A5BB BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
02-07-2022, 11:14 | #69764 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Vgo tel i900 reset password done by cm2 Card found : S/N : 73CA70CC , v0151 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C55A54EB2BFF74F1A753CAE3DA4926F6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : XG05_KM_V2407_VGOTEL_I900_F2_PCB01_gprs_MT6261_S00 .XG05_KM_V2407_VGOTEL_I900_F2_V01_20181107.bin FileVersion : XG05_KM_V2407_VGOTEL_i900_F2_V01_20181107 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 5 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : C55A54EB2BFF74F1A753CAE3DA4926F6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
02-07-2022, 11:28 | #69765 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Sylhet Korim Ullah Market Age: 28
Member: 1714226 Status: Offline Sonork: 100.1683394 Thanks Meter: 243 | vivo y91c format done by cm2 mt2 ver2.07 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM113) MODE : PRELOADER PORT PORT : 113 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : Y83 | Manual : Disabled BROM : Change Configuration settings for target AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_VIP.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: 90014A68423861503E0300715CE7A7E1 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FE27D0E4E104714B972BF455E0F01DBF DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to rubelgsm For This Useful Post: |
