05-15-2022, 14:46 | #70981 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X6812 MT6768 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM169) MODE : BOOTROM PORT : 169 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : B82FAF11E4FB3C2577B9F0F7C72B8541 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : C206532E954C609DA1CBAB54E0E331F95EC286005E63C969C55DC72F425D40A7 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100445636444142028288FEF6B84F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445636444142 : PRV : 0x02 EMMC: VEN : SAMSUNG : DV6DAB EMMC: SNN : 2190016246 ( 0x8288FEF6 ) , MF : 11/2021 EMI : DEV : FireFly EMI : SRC : preloader_x6812_h6912.bin EMI : CNT : 0011 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445636444142028288FEF6B84F EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445636444142 : PRV : 0x02 EMMC: VEN : SAMSUNG : DV6DAB EMMC: SNN : 2190016246 ( 0x8288FEF6 ) , MF : 11/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 58FE420E2D1DE8AC932A2A8850309DF9 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:54 Reconnect Power/Cable! |
05-15-2022, 15:16 | #70982 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Oppo reno 3 reset frf done by cm2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM28) MODE : BOOTROM PORT : 28 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 CODE : Lafite TYPE : MODERN [RAPHAEL] BROM : MEID : 713C7658519936797342219F5A2A14C7 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 3E48093967EBA62152DCBCC398C88449D7BA0356D3D396A818 C0716B66C8C291 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6779 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856383030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V8001JM-B81 IFW : 1000 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 3cfbea00640d REG : 0x101010000 CHIP : MT6779 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : DFE7542C67CC90B9C731E551D84CABC6 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:20 |
05-15-2022, 15:17 | #70983 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile i6 metal 2018 7731e reset frp dome by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:42 |
05-15-2022, 15:18 | #70984 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile x30 v3 hang on logo done by cm2 Card found : 73CA70CC , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Sedning Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sedning Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:39 |
05-15-2022, 16:09 | #70985 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo Y91 MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 4AF655A6F80303159D311C76E4BA0F8D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BD77A36532FB80806D0114A87466E622369568D486FA3DB4B3C0F58BE4579AC6 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100514536334D4203AC21D3F9B565 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 2887898105 ( 0xAC21D3F9 ) , MF : 11/2018 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514536334D4203AC21D3F9B565 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 2887898105 ( 0xAC21D3F9 ) , MF : 11/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9A83C6FC177A8E3A79396F6F0CF789 DA : USB : HIGH-SPEED Boot done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 4AF655A6F80303159D311C76E4BA0F8D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BD77A36532FB80806D0114A87466E622369568D486FA3DB4B3C0F58BE4579AC6 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100514536334D4203AC21D3F9B565 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 2887898105 ( 0xAC21D3F9 ) , MF : 11/2018 EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514536334D4203AC21D3F9B565 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514536334D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : QE63MB EMMC: SNN : 2887898105 ( 0xAC21D3F9 ) , MF : 11/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9A83C6FC177A8E3A79396F6F0CF789 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
05-15-2022, 17:30 | #70987 (permalink) |
No Life Poster Join Date: Jul 2012 Location: tunisia
Member: 1788877 Status: Offline Thanks Meter: 475 | oppo a15 cph2185 reset and frp DONE Hi Operation : Reset Settings/Format FS [ v2.34 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM76) MODE : BOOTROM PORT : 76 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : AD9FE7C276B3AC42C8446BC55E27E656 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 496DB5FC6A81B76492C38F51873068BF150E85726E7C34EFE4 1BBEC38AD44D79 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 1501003458364B4D42035C70D4FBA799 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 1550898427 ( 0x5C70D4FB ) , MF : 10/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 1501003458364B4D42035C70D4FBA799 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 3458364B4D42 : PRV : 0x03 EMMC: VEN : SAMSUNG : 4X6KMB EMMC: SNN : 1550898427 ( 0x5C70D4FB ) , MF : 10/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2C9A8A2F5FE6E690925FA4E1ECE39C9A DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:44 thx team |
The Following 3 Users Say Thank You to aamigoo For This Useful Post: |
05-15-2022, 19:56 | #70988 (permalink) |
Insane Poster Join Date: Nov 2016 Location: Algérie
Member: 2650328 Status: Offline Thanks Meter: 4 | tecno pop 4 hard reset + frp ********************* Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
05-16-2022, 07:28 | #70989 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | qmobile i6 metal one format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072B6B46222425 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072B6B46222425 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x033C5217D667B2D01E19FF95F94CAFD3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
05-16-2022, 07:47 | #70990 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A53 MT6765 FRP/Pattren Rest Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM69) MODE : BOOTROM PORT : 69 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 1915A9F1A71DB72FF3E5676DEDA02F05 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 05E1181B734A9BCF6D3059ABA5B6ACB7E9112A897BA437AB95361DFA02D57FB0 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 90014A68423861503E030028D73BB74D EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 2676539 ( 0x0028D73B ) , MF : 11/2020 EMI : DEV : FireFly EMI : SRC : preloader_oppo6765.bin EMI : CNT : 000C EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 90014A68423861503E030028D73BB74D EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 2676539 ( 0x0028D73B ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D3EF57A44BD079118D0A51B95D2DA18F DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x825757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
05-16-2022, 10:16 | #70991 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,193 | Nokia TA-1352 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.13 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.380_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P13 HW Version: sc9863A_modem CMP_Time : 08-09-2021 10:39:43 MODEM TAG : MOCORTM_20A_W21.15.3_P13_Debug_4G_MODEM_20A_W21.15.3_P13_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 350266785164842 IMEI[2] : 350266785164859 WIFIMAC : 44917C39D2F3 BT_MAC : 44917C39D2F2 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 10, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:47 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
05-16-2022, 11:07 | #70992 (permalink) |
Member: 2650328 Status: Offline Thanks Meter: 4 | condor t8 plus frp ***Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1633 (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v1820 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 13014E53304A394836100358A09245EB EMMC: VEN : MICRON : OEM : 78 : ID : 53304A394836 : PRV : 0x10 EMMC: VEN : MICRON : S0J9H6 EMMC: SNN : 56139922 ( 0x0358A092 ) , MF : 4/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 785356F5159D9131F15E297354F7EF7A DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:01:04 Reconnect Power/Cable! *********** |
05-16-2022, 11:12 | #70993 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | ViVo 1908 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 899CA3AAA66A1A9FD48E9454446109C0 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4FD8B2B870CD3C5446A1DE51D1EC9F237FD115FDE0D93E4B0F F690615FFE36AF BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100514436334D42010991D2F386D7 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 160551667 ( 0x0991D2F3 ) , MF : 8/2019 EMI : DEV : FireFly EMI : SRC : preloader_k61v1_64_bsp.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100514436334D42010991D2F386D7 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 514436334D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : QD63MB EMMC: SNN : 160551667 ( 0x0991D2F3 ) , MF : 8/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7F52582C4ABFB75C332E20383921458D DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x805757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
05-16-2022, 14:10 | #70994 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vivo 1714 MT6750 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : MEID : 075F0A89EE7DB834F933625F8547346E BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI not found BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D4201F286DC99641D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 4068924569 ( 0xF286DC99 ) , MF : 6/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A61CBA1757D8CE9ED84BB42E5A8483E6 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Boot done! Done! Elapsed: 00:02:05 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : MEID : 075F0A89EE7DB834F933625F8547346E BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 150100474436424D4201F286DC99641D EMMC: VEN : SAMSUNG : OEM : 0 : ID : 474436424D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : GD6BMB EMMC: SNN : 4068924569 ( 0xF286DC99 ) , MF : 6/2017 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A61CBA1757D8CE9ED84BB42E5A8483E6 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM48) MODE : PRELOADER PORT PORT : 48 Boot done! SmartInfo : 0x8F5454 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : PRIVACY Format Ok : USERDATA Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
05-16-2022, 14:19 | #70995 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | x650 format done Operation : Reset Settings/Format FS [ v2.34 ] Mode : FULL FACTORY ( WIPE + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : TECNO : LB6 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 684A0190506138420800033EAB576DDF DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 90014A68423861503E030008DF6D57AB EMMC: VEN : HYNIX : OEM : 74 : ID : 68423861503E : PRV : 0x03 EMMC: VEN : HYNIX : hB8aP> EMMC: SNN : 581485 ( 0x0008DF6D ) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B0E144CB707F66BD70DCED72378DA11 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
