Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #71851 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 306676 Status: Offline Thanks Meter: 148 | Nokia 2.3 [ TA-1206 ] reset FRP successfully ... Code: Card found : xxxxxxxx , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v723487 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM35) MODE : BOOTROM PORT : 35 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 CODE : Merlot TYPE : MODERN [RAPHAEL] BROM : MEID : 1118669EC84A7294E3CA8C1F1C9598CE BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 42D251058E621F3A9712BAB65B339301FC48DA3EFE2AA59A3A36433C36353CDE BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 7001005441323833322015A27DC2C6A9 EMMC: VEN : KINGSTON : OEM : 0 : ID : 544132383332 : PRV : 0x20 EMMC: VEN : KINGSTON : TA2832 EMMC: SNN : 362970562 ( 0x15A27DC2 ) , MF : 12/2019 EMI : DEV : FireFly EMI : SRC : preloader_t99621aa3.bin EMI : CNT : 0001 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 7001005441323833322015A27DC2C6A9 EMMC: VEN : KINGSTON : OEM : 0 : ID : 544132383332 : PRV : 0x20 EMMC: VEN : KINGSTON : TA2832 EMMC: SNN : 362970562 ( 0x15A27DC2 ) , MF : 12/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x74A000000 [ 29.16 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9AEEC8B55F831F6080868967428B5298 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
![]() | #71852 (permalink) |
Member: 306676 Status: Offline Thanks Meter: 148 | Vodafone 1100 [ VFD1100 ] reset FRP successfully ... Vodafone 1100 [ VFD1100 ] reset FRP successfully ... Code: Card found : xxxxxxxx , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v723487 Ok! Update configuration ... Load IDBase v723487 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4E03018864726143E27543205DC34413 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 8801034E43617264204375E21344C35D EMMC: VEN : FORESEE : OEM : 3 : ID : 4E4361726420 : PRV : 0x43 EMMC: VEN : FORESEE : NCard EMMC: SNN : 1977750340 ( 0x75E21344 ) , MF : 12/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CE100000 [ 7.22 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B666CBB6C37D450445D330EA2201459 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
![]() | #71853 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: lullipapi
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,353 | Vivo Y15 MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007024 : DA SEND ERROR! ERROR : SECURE BOOT : SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 150100525036344D42015474E4D97623 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525036344D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : RP64MB EMMC: SNN : 1416946905 ( 0x5474E4D9 ) , MF : 7/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 7DEE93C974D1D6CDC1A2A0B4510B16 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
![]() | #71854 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2020 Location: Mozambique Age: 19
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 954 | Nokia C20 TA-1352 SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.380_B01 release-keys MemoryInfo : EMMC : 16 GB ; DRAM : 1 GB Platform Version: MOCORTM_20A_W21.15.3_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P13 HW Version: sc9863A_modem CMP_Time : 08-09-2021 10:39:43 MODEM TAG : MOCORTM_20A_W21.15.3_P13_Debug_4G_MODEM_20A_W21.15.3_P13_sc9863A_modem_sharkl3_pub PSN1 : E7171811C3000710 PSN2 : E286694726C10801040 NVMng : SecurityInfo IMEI[1] : 350266789636597 IMEI[2] : 350266789636605 WIFIMAC : 44917C463359 BT_MAC : 44917C463358 SEC : SLS:2, SKS:0, SKV:4 Done! Elapsed: 00:00:25 Code: Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.380_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P13_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P13 HW Version: sc9863A_modem CMP_Time : 08-09-2021 10:39:43 MODEM TAG : MOCORTM_20A_W21.15.3_P13_Debug_4G_MODEM_20A_W21.15.3_P13_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 350266789636597 IMEI[2] : 350266789636605 WIFIMAC : 44917C463359 BT_MAC : 44917C463358 SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 0, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:42 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
![]() | #71855 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2014
Member: 2199727 Status: Offline Thanks Meter: 217 | casper via s10 tablet frp reset ok Operation : Reset Settings/Format FS [ v2.34 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM (Android) (COM12) MODE : PRELOADER PORT PORT : 12 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT8127 , SBID : 0x8A00 , HWVR : 0xCA04 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v1724 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT8127 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 514E011336334A326200104389729001 DAInf: 4 : 2 : 141 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 13014E51324A33364310006201907289 EMMC: VEN : MICRON : OEM : 78 : ID : 51324A333643 : PRV : 0x10 EMMC: VEN : MICRON : Q2J36C EMMC: SNN : 6422928 ( 0x00620190 ) , MF : 7/2015 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT8127 , SBID : 0x8A00 , HWVR : 0xCA04 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 78D7C6857D3839DE4AE802DBFD67AA70 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
![]() | #71856 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,743 | Jazz Digit 4G Elite Hang Logo Done By CM2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v723487 Ok! Update configuration ... Load IDBase v723487 Ok! Created by Infinity-Box (c) 2021 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Patch Level : MRA58K Display ID : Digit_M42843DG_SW09_20201023_1839 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2015-10-01 Build Time : 23.10.2020 Product Model : Digit4G-Elite Product Brand : Digit Product Name : Digit4G-Elite Product Device : Digit4G-Elite Product Manfct : alps Board Platform : mt6739 Product Info : Digit4G-Elite Product Model : mt6731 Preloader [HW DEV] Info : EMI : DEV : MT6739 EMI : SRC : preloader_fise6731_kaio_m.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 700100454534454434 : VEN : KINGSTON | DEV : EE4ED4 : RAM : [ 512.00 MB ] EMI : [01] : eMMC : DDR3 : ID : F40122426977696E20 : VEN : BIWIN | DEV : Biwin : RAM : [ 512.00 MB ] EMI : [02] : eMMC : DDR3 : ID : 150100463558354342 : VEN : SAMSUNG | DEV : F5X5CB : RAM : [ 512.00 MB ] EMI : [03] : eMMC : DDR3 : ID : 150100464A32354142 : VEN : SAMSUNG | DEV : FJ25AB : RAM : [ 512.00 MB ] EMI : [04] : eMMC : DDR3 : ID : FE014E50314A39344D : VEN : MICRON | DEV : P1J94M : RAM : [ 512.00 MB ] EMI : [05] : eMMC : DDR3 : ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ] Operation : Write Flash [ v2.34 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Disabled Files :3 [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x191B139C [ 401.69 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : 56870C11979ABE18107EEB0C0D81A500 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FEF839C18A8F36C86DFA7C119A0204C2441B4C363EF27F994C 6124E60944CF80 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_fise6731_kaio_m.bin EMI : CNT : 0006 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] EMMC: CID : 90014A48344732611102C6686AED85E7 EMMC: VEN : HYNIX : OEM : 74 : ID : 483447326111 : PRV : 0x02 EMMC: VEN : HYNIX : H4G2a EMMC: SNN : 3328731885 ( 0xC6686AED ) , MF : 8/2018 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0xE9000000 [ 3.64 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 83514E936A8DFF0F27E6CC9A5F252C5B DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! [FL] : Pre-Flash backup Backup sensetive data [ 18 ] Backup path : Backup\MT6739__56870C11979ABE18107EEB0C0D81A500\ Backup done! [FL] : Pre-Flash backup passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000108000 Erase : 0x0000000001908000 : 0x0000000001580000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x000000000E700000 : 0x0000000002000000 Erase : 0x0000000014000000 : 0x00000000D14FBE00 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : SYSTEM Write : CACHE Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:01:16 Reconnect Power/Cable! |
![]() | #71857 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,743 | Vivo s1 remove frp done by cm2 Card found : 73CA70CC , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v723487 Ok! Update configuration ... Load IDBase v723487 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : DB25E2AE7982BE035034A921F36A11AC BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : FD980DA6AA60B3066A27CDB8CE03337AF53F000C7B3A22A3D8 E8B9CD9D233C8C BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k68v1_64.bin EMI : CNT : 000B EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100445636444D4202AFAC903AB675 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 445636444D42 EMMC: VEN : SAMSUNG : DV6DMB EMMC: SNN : 2947321914 ( 0xAFAC903A) , MF : 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 956D0774FA7253AA9044AD4FDE6D4464 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
![]() | #71858 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 2,955 | Infinix X663 Format & Frp Code: Product Brand : Infinix Product Device : Infinix-X663 Product Model : Infinix X663 Product Name : X663-GL Patch Level : RP1A.200720.011 Display ID : X663-H6915ABCEFGHIO-R-GL-220419V738 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-04-05 Build Time : 19.04.2022 Product Info : x663_h6915 Product Board : Infinix-X663 Board Platform : mt6768 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM : 0xB80AC92A NVRAM : State : Ok! INFO : WiFi MAC : AA0036004400 INFO : BlTh MAC : FC29E38FEBBA INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Done! Elapsed: 00:00:41 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : E15C5075D92A2122CA54FE99DAB15ECF BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : E41E4FFA58311A2A39073AEAC5B085DB41EA5490A5FEE9A053859F598A73BA6D BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 15010033563643414202A955D4A998CD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 335636434142 : PRV : 0x02 EMMC: VEN : SAMSUNG : 3V6CAB EMMC: SNN : 2840974505 ( 0xA955D4A9 ) , MF : 9/2021 EMI : DEV : FireFly EMI : SRC : preloader_x663_h6915.bin EMI : CNT : 0010 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 15010033563643414202A955D4A998CD EMMC: VEN : SAMSUNG : OEM : 0 : ID : 335636434142 : PRV : 0x02 EMMC: VEN : SAMSUNG : 3V6CAB EMMC: SNN : 2840974505 ( 0xA955D4A9 ) , MF : 9/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1EC00000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : F6E3CBF8A91AAA2034AA50CAF7E748D5 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:49 Reconnect Power/Cable! |
![]() | #71859 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,955 | TECNO-B1f Format & Frp Code: Patch Level : O11019 Display ID : B1f-F8018I-OGo-200430V106 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-05-05 Build Time : 30.04.2020 Product Brand : TECNO Product Name : F8018 Product Device : TECNO-B1f Product Info : TECNO-B1f Product Model : TECNO B1f Product Manfct : TECNO MOBILE LIMITED Product Board : TECNO-B1f Board Platform : mt6580 USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) NVRAM : 0x75029750 NVRAM : State : Ok! INFO : WiFi MAC : AA0037003600 INFO : BlTh MAC : 2026817C491B INFO : IMEI[1] : INFO : IMEI[2] : Done! Elapsed: 00:00:37 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : 833D912B0489556CA2EDF79C97FC6FCB BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 460001704545414D551D2338DF86025B DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 700100464D41454538231D555B0286DF NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_b1_f8018.bin EMI : CNT : 0006 EMI : [00] : ID : 150100513732534D42 : VEN : SAMSUNG | DEV : Q72SMB : RAM : [ 1.00 GB ] EMI : [01] : ID : 90014A483847316505 : VEN : HYNIX | DEV : H8G1e : RAM : [ 1.00 GB ] EMI : [02] : ID : ADDE14A7424AAD : VEN : UNKNOWN | DEV : §BJ* : RAM : [ 512.00 MB ] EMI : [03] : ID : 150100464E36324D42 : VEN : SAMSUNG | DEV : FN62MB : RAM : [ 1.00 GB ] EMI : [04] : ID : 700100464D41454538 : VEN : KINGSTON | DEV : FMAEE8 : RAM : [ 1.00 GB ] EMI : [05] : ID : 150100464536324D42 : VEN : SAMSUNG | DEV : FE62MB : RAM : [ 1.00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 700100464D41454538231D555B0286DF EMMC: VEN : KINGSTON : OEM : 0 : ID : 464D41454538 : PRV : 0x23 EMMC: VEN : KINGSTON : FMAEE8 EMMC: SNN : 492133122 ( 0x1D555B02 ) , MF : 8/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A8000000 [ 14.63 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C59CA4AA30CCF6BAE06B8287E66E0399 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Boot done! SmartInfo : 0x805657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
![]() | #71860 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,955 | TECNO PR651 Format & Frp Code: Product Brand : TECNO Product Device : PR651 Product Model : TECNO PR651 Product Name : PR651 Patch Level : RP1A.201005.001 Display ID : PR651-F6317-11.0-OP-V061-20220427 Ver. Incmt : OP-V061-20220427 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-03-05 Build Time : 27.04.2022 Product Name : F6317 Product Device : TECNO-PR651 Product Info : PR651 Product Board : PR651 Board Platform : sp9863a Product Manfct : TECNO NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_20A_W21.42.2_P1_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.42.2_P1 HW Version: sc9863A_modem CMP_Time : 11-16-2021 12:37:59 MODEM TAG : MOCORTM_20A_W21.42.2_P1_Debug_4G_MODEM_20A_W21.42.2_P1_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:54 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : PR651 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
![]() | #71861 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,955 | Vivo PD1612 Flash Code: Patch Level : MRA58K Display ID : MRA58K release-keys Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2016-06-01 Build Time : 01.01.1970 Product Brand : vivo Product Board : mt6755 Product Manfct : vivo Board Platform : mt6755 Product Info : bbk6750_66_m Product Model : PD1612 Product Name : PD1612 Product Device : PD1612 USERDATA : FILESYSTEM : EXT4 with FDE ( Full Disk Encryption ***) NVRAM : BBK6750_66_M_MDBIN_PCB01_MT6750_S00.MOLY_LR11_W1603_MD_MP_V17_P211 NVRAM : 0x3FD21B716 NVRAM : State : Ok! INFO : WiFi MAC : 6091F3284066 INFO : BlTh MAC : 6091F3284065 INFO : IMEI[1] : INFO : IMEI[2] : STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:00:27 Preloader [HW DEV] Info : EMI : DEV : MT6755 EMI : SRC : preloader_bbk6750_66_m.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] Operation : Write Flash [ v2.34 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :19 [FL] : Set : preloader_bbk6750_66_m.bin [FL] : Set : recovery-verified.img [FL] : Set : survival-verified.img [FL] : Set : oem.img [FL] : Set : apps.img [FL] : Set : md1rom-verified.img [FL] : Set : md1dsp-verified.img [FL] : Set : md1arm7-verified.img [FL] : Set : md3rom-verified.img [FL] : Set : lk-verified.bin [FL] : Set : lk-verified.bin [FL] : Set : boot-verified.img [FL] : Set : logo-verified.bin [FL] : Set : trustzone-verified.bin [FL] : Set : trustzone-verified.bin [FL] : Set : secro.img [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xFD222868 [ 3.96 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port_V1632 (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN [RAPHAEL] BROM : MEID : BF17F0F99B1D7870C570996EC3E2EAFD BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x00000001 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_bbk6750_66_m.bin EMI : CNT : 0006 EMI : [00] : eMMC : DDR3 : ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 3.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : DDR3 : ID : 150100525831344D42 : VEN : SAMSUNG | DEV : RX14MB : RAM : [ 4.00 GB ] EMI : [05] : eMMC : DDR3 : ID : 150100524331344D42 : VEN : SAMSUNG | DEV : RC14MB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 150100525831344D420744A3DAB3C3BB EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525831344D42 : PRV : 0x07 EMMC: VEN : SAMSUNG : RX14MB EMMC: SNN : 1151589043 ( 0x44A3DAB3 ) , MF : 12/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B5719768FD1D9FEFCE9FFE82AEC8BA7C DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM7) MODE : PRELOADER PORT PORT : 7 Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000004BC8000 Erase : 0x00000000055C8000 : 0x0000000028A00000 Erase : 0x000000002F000000 : 0x0000000001000000 Erase : 0x0000000030300000 : 0x0000000002400000 Erase : 0x0000000032C00000 : 0x00000001D3C00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : SURVIVAL Write : CUST Write : APPS Write : MD1IMG Write : MD1DSP Write : MD1ARM7 Write : MD3IMG Write : LK Write : LK2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SECRO Write : SYSTEM Write : CACHE Write : USERDATA UltraFlash : OK! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:16 Reconnect Power/Cable! |
![]() | #71862 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,955 | Lenovo A606 Format Code: Patch Level : KOT49H Display ID : A606_S040_150702_ROW Display ID : Lenovo A606_S100_140305 Ver. CodeName : REL Ver. Release : 4.4.2 Build Time : 02.07.2015 Product Model : Lenovo A606 Product Brand : Lenovo Product Name : A606 Product Device : A606 Product Board : lcsh82_slw_cu_kk Product Manfct : Lenovo Product Info : A606 USERDATA : FILESYSTEM : EXT4 NVRAM : 0xE70482E6 NVRAM : State : Ok! INFO : WiFi MAC : 1436C6A5FA75 INFO : BlTh MAC : 1436C694FA75 INFO : IMEI[1] : INFO : IMEI[2] : FFFFFFFFFFFFFFF Done! Elapsed: 00:00:17 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY [MTK] BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN BROM : BROM|BL : 0xFF|0x01 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : CHANGE : v1844 AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4B0001154D5658373B43014255C164D6 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 1501004B3758564D4201433BD664C155 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 4B3758564D42 : PRV : 0x01 EMMC: VEN : SAMSUNG : K7XVMB EMMC: SNN : 1127994980 ( 0x433BD664 ) , MF : 12/2014 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 185201F58B1BCF96CEC6F4D089F1F7CD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x8C5454 Format Ok : CACHE Format Ok : USRDATA Done! Elapsed: 00:00:42 Reconnect Power/Cable! |
![]() | #71863 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2021 Location: Karoi , Zimbabwe 🇿 Age: 27
Member: 2996196 Status: Offline Thanks Meter: 465 | ![]() Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM5) MODE : PRELOADER PORT PORT : 5 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : Reset Interface! PTFN : MediaTek USB Port (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 909F521B361D39533690988272DB34EA BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4C3D1D53C31F8957D96572A80C62F08A6BA36687D4B4DCD042 ED216D4667214A BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 150100515836334D42000103E88F5785 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : QX63MB EMMC: SNN : 17033359 ( 0x0103E88F ) , MF : 5/2020 EMI : DEV : FireFly EMI : SRC : preloader_s96116ca1.bin EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID : 150100515836334D42000103E88F5785 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 515836334D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : QX63MB EMMC: SNN : 17033359 ( 0x0103E88F ) , MF : 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B17D120F7298657A3CF384DFA2E9395F DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! MemoryTool Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : PERSISTENT Erase partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
![]() | #71864 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,353 | Vivo Y20 MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM14) MODE : PRELOADER PORT PORT : 14 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : BROM|BL : 0xFF|0x03 BROM : PRELOADER PORT AGENT : Vivo : SEC_MT6765 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: CID : 90014A684339615033011014A653482D EMMC: VEN : HYNIX : OEM : 74 : ID : 684339615033 : PRV : 0x01 EMMC: VEN : HYNIX : hC9aP3 EMMC: SNN : 269788755 ( 0x1014A653 ) , MF : 4/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 9D79FF0DC1168BC530D21F49497BC293 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835757 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : CACHE Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
![]() | #71865 (permalink) |
Member: 2199727 Status: Offline Thanks Meter: 217 | lenovo phab2 plus (pb2-670n) imei repair ok Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Repair Security [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY [MTK] BROM : MEID : CB6EF1597AC6ECC162D0AA2B9A6169B7 BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : EMI : Search BROM : EMI : Found! AGENT : 0_base : BASE_v1724 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100525831424D420710C9AC8C2329 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 520001154D423158C910074229238CAC NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 DRAM : 0x0178 EMI : DEV : FireFly EMI : SRC : preloader_lcsh8783_ttb_m.bin EMI : CNT : 0003 EMI : [00] : ID : 150100525831424D42 : VEN : SAMSUNG | DEV : RX1BMB : RAM : [ 3,00 GB ] EMI : [01] : ID : 150100524331424D42 : VEN : SAMSUNG | DEV : RC1BMB : RAM : [ 3,00 GB ] EMI : [02] : ID : 90014A484247346132 : VEN : HYNIX | DEV : HBG4a2 : RAM : [ 3,00 GB ] EMI : Init EMI from PRELOADER INIT : 0xBC : DRAM [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0xC0000000 [ 3,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: CID : 150100525831424D420710C9AC8C7329 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 525831424D42 : PRV : 0x07 EMMC: VEN : SAMSUNG : RX1BMB EMMC: SNN : 281652364 ( 0x10C9AC8C ) , MF : 7/2016 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 64181C75737E17B630AAE98311CBF01C STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM6) MODE : PRELOADER PORT PORT : 6 Boot done! NVRAM : 0x13E06A294 NVRAM : State : Ok! INFO : WiFi MAC : 980CA56B3050 INFO : BlTh MAC : 980CA5683050 INFO : IMEI[1] : 35067337******* INFO : IMEI[2] : 35067337******* INFO : set IMEI[1] : 35581306******* INFO : set IMEI[2] : 35581306******* Update NVRAM ... Update NVRAM Ok! Update dependencies ... Update dependencies Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
