12-05-2022, 09:05 | #72736 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | TECNO KD7 SPARK 5 PRO FRP RESET Done CM2 Code: Operation : Reset Settings/Format FS [ v2.37 ] Mode: FRP [ RESET PROTECTION ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port (COM8) MODE: BOOTROM PORT: 8 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 0541AC8D33A1A282FB8FCD4CF5595359 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 9F876AF7B422158B2D75BE08CF64DD5EFB9BA17D67743E87182CE36215715A70 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 150100445036384D4202399A9016C74B EMMC: VEN: Samsung : OEM: 0 : ID: 445036384D42 : PRV: 0x02 EMMC: VEN: Samsung : DP68MB EMMC: SNN: 966430742 ( 0x399A9016 ) MF: 12/2020 EMI: FireFly preloader_kd7_ with 17 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID: 150100445036384D4202399A9016C74B EMMC: VEN: Samsung : OEM: 0 : ID: 445036384D42 : PRV: 0x02 EMMC: VEN: Samsung : DP68MB EMMC: SNN: 966430742 ( 0x399A9016 ) MF: 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E839C5B4CE80F85BD3965A63592502C9 DA: USB: HIGH-SPEED Boot done Verify device config... Finished Format Ok: RESET PROTECTION Done Elapsed: 00:00:23 Reconnect Power/Cable now |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
12-05-2022, 11:09 | #72737 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | OPPO CPH2083 Format & Frp Code: Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2022-01-05 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Manfct : OPPO SW : full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20220118.230000 release-keys Build Time : 18.01.2022 Product Brand : OPPO Product Model : CPH2083 Product Info : CPH2083 Product Name : CPH2083 Product Device : OP4BFB SW OTA Version : CPH2083PUEX_11.A.67_0670_202201182155 Display ID : CPH2083EX_11_A.67 Display ID : CPH2083EX_11_A.67_220118 Kernel Info : 4.9.117 Device UID: MT6765__CPH2083_11_A.11_200321_764f439c USERDATA : FILESYSTEM : EXT4 with FBE ( File-Base Encryption ) Verify device config... Finished NVRAM: OPPO6765_19451_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_PIE_P35_PR1_TC16_SP_V1_P112 NVRAM: Items: 0xBC Size: 0x0AFB20 NVRAM: State: Ok INFO : WiFi MAC: F06728CECE33 INFO : BlTh MAC: F06728CECE32 STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Scan preloader... Preloader: EMI: MT6765 preloader_oppo6765_19451.bin with 10 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 150100444436384D42 : Ven: Samsung | Dev: DD68MB : RAM: [ 3.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 3.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 90014A684339615033 : Ven: Hynix | Dev: hC9aP3 : RAM: [ 4.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[04] : eMMC : DDR3 : ID: 90014A484147346132 : Ven: Hynix | Dev: HAG4a2 : RAM: [ 2.00 GB ] EMI[05] : eMMC : DDR3 : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 3.00 GB ] EMI[06] : eMMC : DDR3 : ID: 90014A484347386134 : Ven: Hynix | Dev: HCG8a4 : RAM: [ 4.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 13014E47314A395238 : Ven: Micron | Dev: G1J9R8 : RAM: [ 4.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 1501003458364B4D42 : Ven: Samsung | Dev: 4X6KMB : RAM: [ 2.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 2.00 GB ] Preloader saved to: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_oppo6765_19451.bin Verify backup\PRELOADER\preloader_oppo6765_19451.bin [9b7e53c5]... Finished Done Elapsed: 00:01:16 Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET EXTRA 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 5E6651CD9AB59943BB27364A352030CD BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 61D46E2077C66DC04CAF559E38789D95763D4F08204A206BDF647E53814C0351 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 150100444436384D4202CB7FC473B6FD EMMC: VEN: Samsung : OEM: 0 : ID: 444436384D42 : PRV: 0x02 EMMC: VEN: Samsung : DD68MB EMMC: SNN: 3414148211 ( 0xCB7FC473 ) MF: 11/2019 EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID: 150100444436384D4202CB7FC473B6FD EMMC: VEN: Samsung : OEM: 0 : ID: 444436384D42 : PRV: 0x02 EMMC: VEN: Samsung : DD68MB EMMC: SNN: 3414148211 ( 0xCB7FC473 ) MF: 11/2019 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 6A97631DC77B6B2ACE2E8EE90CE8F3 DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Finished Format Ok: RESET PROTECTION Format Ok: USERDATA Format Ok: CACHE Format Ok: USERDATA Done Elapsed: 00:00:49 Reconnect Power/Cable now |
12-05-2022, 11:11 | #72738 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix X688B Frp Code: SW : Infinix/X688B-GL/Infinix-X688B:10/QP1A.190711.020/210618V335:user/release-keys Product Brand : Infinix Product Device : Infinix-X688B Product Model : Infinix X688B Product Name : X688B-GL Patch Level : QP1A.190711.020 Display ID : X688B-H659ABCEFGHI-Q-GL-210618V335 SW Version : 210618V335 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-06-05 Build Time : 18.06.2021 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Info : x688b_h659 SW : vnd_x688b_h659-user 10 QP1A.190711.020 119979 release-keys Product Board : Infinix-X688B Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) Verify device config... Ok No loaders to verify NVRAM: TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V118_11_P31 NVRAM: Items: 0xA2 Size: 0x08C02F NVRAM: State: Ok INFO : WiFi MAC: AA0036004400 INFO : BlTh MAC: 04F99320C8EC INFO : IMEI[1]: INFO : IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Scan preloader... Preloader: EMI: MT6765 preloader_x688b_h659.bin with 20 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 90014A684445615033 : Ven: Hynix | Dev: hDEaP3 : RAM: [ 6.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 150100444836444D42 : Ven: Samsung | Dev: DH6DMB : RAM: [ 4.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100334836434142 : Ven: Samsung | Dev: 3H6CAB : RAM: [ 6.00 GB ] EMI[04] : eMMC : LP_DDR4X : ID: 150100335636434D42 : Ven: Samsung | Dev: 3V6CMB : RAM: [ 6.00 GB ] EMI[05] : eMMC : LP_DDR4X : ID: 90014A484347386134 : Ven: Hynix | Dev: HCG8a4 : RAM: [ 4.00 GB ] EMI[06] : eMMC : LP_DDR4X : ID: 90014A484347386134 : Ven: Hynix | Dev: HCG8a4 : RAM: [ 6.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 4.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 6.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 90014A684339615033 : Ven: Hynix | Dev: hC9aP3 : RAM: [ 4.00 GB ] EMI[0A] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 3.00 GB ] EMI[0B] : eMMC : LP_DDR4X : ID: 150100445036384D42 : Ven: Samsung | Dev: DP68MB : RAM: [ 3.00 GB ] EMI[0C] : eMMC : LP_DDR4X : ID: 13014E53304A394B39 : Ven: Micron | Dev: S0J9K9 : RAM: [ 4.00 GB ] EMI[0D] : eMMC : LP_DDR4X : ID: 150100445636444142 : Ven: Samsung | Dev: DV6DAB : RAM: [ 4.00 GB ] EMI[0E] : eMMC : LP_DDR4X : ID: 150100445036444142 : Ven: Samsung | Dev: DP6DAB : RAM: [ 4.00 GB ] EMI[0F] : eMMC : LP_DDR4X : ID: 150100445636444D42 : Ven: Samsung | Dev: DV6DMB : RAM: [ 4.00 GB ] EMI[10] : eMMC : LP_DDR4X : ID: 150100444436384D42 : Ven: Samsung | Dev: DD68MB : RAM: [ 3.00 GB ] EMI[11] : eMMC : LP_DDR4X : ID: 13014E47314A395238 : Ven: Micron | Dev: G1J9R8 : RAM: [ 4.00 GB ] EMI[12] : eMMC : LP_DDR4X : ID: 150100445836384D42 : Ven: Samsung | Dev: DX68MB : RAM: [ 3.00 GB ] EMI[13] : eMMC : LP_DDR4X : ID: 90014A68423861503E : Ven: Hynix | Dev: hB8aP> : RAM: [ 3.00 GB ] Preloader exist: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_x688b_h659.bin Verify backup\PRELOADER\preloader_x688b_h659.bin [44fdda7f]... Exist Ok Done Elapsed: 00:00:27 Operation : Reset Settings/Format FS [ v2.37 ] Mode: FRP [ RESET PROTECTION ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 2D95D1069F364B44F67ED6FC24897B07 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: B513C80E3C3DC0F9884C861EEA0D3C7557B528354A68E4A45394AF383EDD0C7A BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 90014A6843396150330100184F751869 EMMC: VEN: Hynix : OEM: 74 : ID: 684339615033 : PRV: 0x01 EMMC: VEN: Hynix : hC9aP3 EMMC: SNN: 1593205 ( 0x00184F75 ) MF: 1/2021 EMI: INFINITY PRELOADER_INFINITY_0 with 3 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 90014A6843396150330100184F751869 EMMC: VEN: Hynix : OEM: 74 : ID: 684339615033 : PRV: 0x01 EMMC: VEN: Hynix : hC9aP3 EMMC: SNN: 1593205 ( 0x00184F75 ) MF: 1/2021 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 91ED64AE4848C29B17EEFA798A83B3B4 DA: USB: HIGH-SPEED Boot done Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Done Elapsed: 00:00:24 Reconnect Power/Cable now |
12-05-2022, 11:12 | #72739 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | TECNO-BD2p Frp Code: Product Brand : TECNO Product Name : BD2p-OP Product Device : TECNO-BD2p Product Model : TECNO BD2p Product Board : BD2p Patch Level : RP1A.201005.001 Display ID : BD2p-SP613DEF-RGo-OP-220719V13 Ver. Incmt : 220719V13 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-07-05 Build Time : 19.07.2022 Product Info : sp7731e_1h10 Product Board : sp7731e_1h10 Board Platform : sp7731e Product Manfct : TECNO MOBILE LIMITED NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W21.07.2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.07.2 HW Version: sc7731e_modem CMP_Time : 02-09-2021 04:49:59 MODEM TAG : MOCORTM_17C_W21.07.2_Debug_FM_BASE_17C_W21.07.2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:19 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BD2-OP Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:22 |
12-05-2022, 11:12 | #72740 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix-X680B Format & Frp Code: SW : Infinix/X680B-OP/Infinix-X680B:10/QP1A.190711.020/EFIJ-OP-220505V281:user/release-keys Product Brand : Infinix Product Device : Infinix-X680B Product Model : Infinix X680B Product Name : X680B-OP Patch Level : QP1A.190711.020 Display ID : X680B-H6215EFIJ-Q-OP-220505V281 SW Version : EFIJ-OP-220505V281 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-04-05 Build Time : 05.05.2022 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Info : x680b_h6215 SW : full_x680b_h6215-user 10 QP1A.190711.020 292143 release-keys Product Board : Infinix-X680B Board Platform : mt6765 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) Verify device config... Ok No loaders to verify NVRAM: TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V107_4_P31 NVRAM: Items: 0xA2 Size: 0x08BFE5 NVRAM: State: Ok INFO : WiFi MAC: AC2334081C97 INFO : BlTh MAC: AC2334081C96 INFO : IMEI[1]: INFO : IMEI[2]: STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Scan preloader... Preloader: EMI: MT6765 preloader_x680b_h6215.bin with 17 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 90014A684445615033 : Ven: Hynix | Dev: hDEaP3 : RAM: [ 6.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 150100444836444D42 : Ven: Samsung | Dev: DH6DMB : RAM: [ 4.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100334836434142 : Ven: Samsung | Dev: 3H6CAB : RAM: [ 6.00 GB ] EMI[04] : eMMC : LP_DDR4X : ID: 150100335636434D42 : Ven: Samsung | Dev: 3V6CMB : RAM: [ 6.00 GB ] EMI[05] : eMMC : LP_DDR4X : ID: 90014A484347386134 : Ven: Hynix | Dev: HCG8a4 : RAM: [ 4.00 GB ] EMI[06] : eMMC : LP_DDR4X : ID: 90014A484347386134 : Ven: Hynix | Dev: HCG8a4 : RAM: [ 6.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 4.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 6.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 90014A684339615033 : Ven: Hynix | Dev: hC9aP3 : RAM: [ 4.00 GB ] EMI[0A] : eMMC : LP_DDR4X : ID: 90014A68433861503E : Ven: Hynix | Dev: hC8aP> : RAM: [ 3.00 GB ] EMI[0B] : eMMC : LP_DDR4X : ID: 150100445036384D42 : Ven: Samsung | Dev: DP68MB : RAM: [ 3.00 GB ] EMI[0C] : eMMC : LP_DDR4X : ID: 13014E53304A394B39 : Ven: Micron | Dev: S0J9K9 : RAM: [ 4.00 GB ] EMI[0D] : eMMC : LP_DDR4X : ID: 150100445636444142 : Ven: Samsung | Dev: DV6DAB : RAM: [ 4.00 GB ] EMI[0E] : eMMC : LP_DDR4X : ID: 150100445036444142 : Ven: Samsung | Dev: DP6DAB : RAM: [ 4.00 GB ] EMI[0F] : eMMC : LP_DDR4X : ID: 150100445636444D42 : Ven: Samsung | Dev: DV6DMB : RAM: [ 4.00 GB ] EMI[10] : eMMC : LP_DDR4X : ID: 150100444436384D42 : Ven: Samsung | Dev: DD68MB : RAM: [ 3.00 GB ] Preloader exist: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_x680b_h6215.bin Verify backup\PRELOADER\preloader_x680b_h6215.bin [1ffc5155]... Exist Ok Done Elapsed: 00:00:43 Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 269BEBC3DBCC54CB318AA211567AC515 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 64721F95D19904AAFE66C4964BBCA4CD0975DAF2E4E7DB0AA588F023506626D2 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 150100445036444142038EE8DC3B57C1 EMMC: VEN: Samsung : OEM: 0 : ID: 445036444142 : PRV: 0x03 EMMC: VEN: Samsung : DP6DAB EMMC: SNN: 2397625403 ( 0x8EE8DC3B ) MF: 5/2020 EMI: FireFly preloader_x680b_h6215.bin with 17 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 150100445036444142038EE8DC3B57C1 EMMC: VEN: Samsung : OEM: 0 : ID: 445036444142 : PRV: 0x03 EMMC: VEN: Samsung : DP6DAB EMMC: SNN: 2397625403 ( 0x8EE8DC3B ) MF: 5/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 33945422B326ED5D10EDAF571C9A1594 DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 10 UserDataFS: 0x03 CacheFS: 0x02 Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Format Ok: USERDATA Format Ok: CACHE Format Ok: USERDATA Format Ok: USERDATA Done Elapsed: 00:00:44 Reconnect Power/Cable now |
12-05-2022, 11:13 | #72741 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile Fire Frp Code: Patch Level : OPM2.171019.012 Display ID : QMobileFire_MP_22_09 Ver. Incmt : 38611 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-09-05 Build Time : 22.09.2018 Product Model : Fire Product Brand : QMobile Product Name : Fire Product Device : Fire Product Manfct : QMobile Product Info : Fire Product Board : sp7731e_1h10 Board Platform : sp7731e NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W18.23.4_P2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P2 HW Version: sc7731e_modem MODEM TAG : MOCORTM_17C_W18.23.4_P2_Debug_FM_BASE_17C_W18.23.4_P2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:47 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_0S Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
12-05-2022, 11:18 | #72742 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | TECNO RB6S SP UNLOCK Done CM2 Code: Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : RB6S-SU335-8.1-ZA-Voda-LC-V011-20201030 Platform Version: MOCORTM_17B_Release_W18.26.1_P25_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_17B_Release_W18.26.1_P25 HW Version: sc9832e_modem CMP_Time : 08-27-2020 14:37:04 MODEM TAG : MOCORTM_17B_Release_W18.26.1_P25_Debug_FM_BASE_17B_Release_W18.26.1_P25_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 355189103639250 IMEI[2] : 354648020000004 WIFIMAC : CC3B2765BD63 BT_MAC : CC3B2765BD62 SEC : SLS:0, SKS:0, SKV:3 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:45 |
12-05-2022, 13:14 | #72743 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Infinix Hot 12 Smart Reset Done v2.38c5 Operation: Reset Settings/Format FS [ v2.38c5 ] Platform: Infinity FireFly SmartPhone - MT67xx, MT65xx | Helio G/P Mode: SMART RESET Wait... Proceed Format operation? That will DESTROY ALL USER DATA! Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM9) MODE: BOOTROM; PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: F987E3F4ADE600B9C616CF566FA8AB4C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 40782EF1DB9477252BF9DBE669DE4012379C69E68BC5A6B555 9DEA1936E9BCFA BROM: Sending FireFly FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running : v05.05.05 on MT6768 FireFly: eMMC init passed Stored: C:\InfinityBox\CM2MT2\backup\EXT_CSD\MT6768__Hynix _hDEaP3_5.1_extcsd_05122022.bin EMMC: CID: 90014A68444561503303103188BBC881 Ven: Hynix OEM: 74 ID: 684445615033 [hDEaP3] PRV: 0x03 SNN: 271681723 [0x103188BB] MF: 12/2021 CSD: D02700328F5903FFFFFFFFEF8E400043 CSD: TEMP_WRITE_PROTECT: Off CSD: PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 EXTCSD [CONFIG]: 0x48 0x02 0x01 EXTCSD [PARTITION_CONFIG]: 0x48 EXTCSD [BOOT_BUS_WIDTH]: 0x02 EXTCSD [RST_N_FUNCTION]: 0x01 EXTCSD [PART_S_COMPLETED]: Off EXTCSD [SIZE]: Market: 128 GB EXTCSD [SIZE]: Actual: 0x1D1F000000 [ 116.48 GB ] EXTCSD [EOL]: EOL status : Normal ( Less than 80% reserved blocks used ) EXTCSD [EOL_A]: SLC status : Not defined EXTCSD [EOL_B]: MLC status : 0% - 10% used BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] USER: 0x1D1F000000 [ 116.48 GB ] DA: USB: HIGH-SPEED Boot done [2] Reading... Ok Reading... Scan memory... Found region: 27032 [12|27032|964] Scan filesystem... SmartInfo: AndroidVer: 12 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__F987E3F4ADE60 0B9C616CF566FA8AB4C Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Done: 00:01:14 Reconnect Power/Cable now |
12-05-2022, 13:30 | #72744 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Itel L5006s SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : L5006S-F3212MZ-10.0-MZ-Vodacom-V016-20220505 Platform Version: MOCORTM_18A_W20.23.2_P8_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W20.23.2_P8 HW Version: sc9832e_modem CMP_Time : 12-29-2020 18:41:45 MODEM TAG : MOCORTM_18A_W20.23.2_P8_Debug_FM_BASE_18A_W20.23.2_P8_sc9832e_modem_sharkle_Smart_Phone NVMng : SecurityInfo IMEI[1] : 357068263098424 IMEI[2] : 354648020000004 WIFIMAC : C81EC23A437E BT_MAC : C81EC23A437D SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:22 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
12-05-2022, 13:32 | #72745 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | iTEL P681LM FRP RESET DONE CM2 Code: Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : P681LM-F0615-P37-Pro Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:53 |
12-05-2022, 13:33 | #72746 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | A013G KG Completed Done Code: Card found : 46828B86 , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! UserName and/or Password not set! Can't continue! Load IDBase v312457 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C5245FE01F415441B204C94B3FD0F800 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BCDA4B989966E7AFEAE817B3F8FA718C34CA5C5EF5E790D8EFD7197D0558086F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k39tv1_bsp_1g_titan.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4200D0E2BCF5B715 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 3504520437 ( 0xD0E2BCF5 ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0021B0870404C82A43CCC472F6097E DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A013G Product Name : a01corejx Product Device : a01core Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A013GJXU4AVC5 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-01-01 Build Time : 10.03.2022 Product Info : a01core Product Board : k39tv1_bsp_1g_titan Board Platform : mt6739 Product Manfct : samsung NVRAM : TITAN_A01CORE_Q0MP1_K39TV1_BSP_1G_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R3_TC10_6M_PR_A01_SP_V2_P15 NVRAM : 0xA108B91F NVRAM : State : Ok! INFO : WiFi MAC : 000000000000 INFO : BlTh MAC : 000046000001 INFO : IMEI[1] : DE3504E7380D653 INFO : IMEI[2] : 142E8D5189733B2 Backup sensetive data [ 18 ] Backup path : Backup\MT6739__C5245FE01F415441B204C94B3FD0F800\ [31] Read : NVRAM [12] Read : NVDATA [25] Read : PROINFO [34] Read : LK [11] Read : NVCFG [14] Read : PROTECT1 [1] Read : PGPT [17] Read : PERSIST [0] Read : PRELOADER [4] Read : EFS [5] Read : SEC_EFS [18] Read : PERSISTENT Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Done! Elapsed: 00:01:11 Code: Operation : Unlock BootLoader [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C5245FE01F415441B204C94B3FD0F800 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BCDA4B989966E7AFEAE817B3F8FA718C34CA5C5EF5E790D8EFD7197D0558086F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k39tv1_bsp_1g_titan.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4200D0E2BCF5B715 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 3504520437 ( 0xD0E2BCF5 ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0021B0870404C82A43CCC472F6097E DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A013G Product Name : a01corejx Product Device : a01core Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A013GJXU4AVC5 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-01-01 Build Time : 10.03.2022 Product Info : a01core Product Board : k39tv1_bsp_1g_titan Board Platform : mt6739 Product Manfct : samsung BootLoader State : Locked! BootLoader State : Unlocked! Done! Elapsed: 00:00:41 Code: Operation : Memory Tool Init [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C5245FE01F415441B204C94B3FD0F800 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BCDA4B989966E7AFEAE817B3F8FA718C34CA5C5EF5E790D8EFD7197D0558086F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k39tv1_bsp_1g_titan.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4200D0E2BCF5B715 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 3504520437 ( 0xD0E2BCF5 ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0021B0870404C82A43CCC472F6097E DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Code: MemoryTool Operation : RPMB : Read RPMB : WriteCounter : 0x00004FA6 Read now ... File Size : 0x01000000 File Name : rpmb.bin File Path : C:\InfinityBox\CM2MT2\Backup\MT6739__C5245FE01F415441B204C94B3FD0F800\ Read partition Ok! Operation finished! Code: MemoryTool Operation : RPMB : Erase RPMB : WriteCounter : 0x00004FA6 Erase now ... Erase partition Ok! Operation finished! Code: MemoryTool Operation : RPMB : Write RPMB : WriteCounter : 0x00014FA6 File Size : 0x01000000 File Name : rpmb.bin File Path : C:\InfinityBox\CM2MT2\Backup\MT6739__C5245FE01F415441B204C94B3FD0F800\ Write now ... Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:02:58 Code: Operation : Change KG state [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C5245FE01F415441B204C94B3FD0F800 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BCDA4B989966E7AFEAE817B3F8FA718C34CA5C5EF5E790D8EFD7197D0558086F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k39tv1_bsp_1g_titan.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4200D0E2BCF5B715 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 3504520437 ( 0xD0E2BCF5 ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0021B0870404C82A43CCC472F6097E DA : USB : HIGH-SPEED Boot done! SAMSUNG : KG : State is Prenormal SAMSUNG : KG : Update to Completed State change Ok! Done! Elapsed: 00:00:27 Code: Operation : Unlock BootLoader [ v2.34 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM5) MODE : BOOTROM PORT : 5 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 CODE : Zion TYPE : MODERN [RAPHAEL] BROM : MEID : C5245FE01F415441B204C94B3FD0F800 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : BCDA4B989966E7AFEAE817B3F8FA718C34CA5C5EF5E790D8EFD7197D0558086F BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k39tv1_bsp_1g_titan.bin EMI : CNT : 0007 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID : 150100464536324D4200D0E2BCF5B715 EMMC: VEN : SAMSUNG : OEM : 0 : ID : 464536324D42 : PRV : 0x00 EMMC: VEN : SAMSUNG : FE62MB EMMC: SNN : 3504520437 ( 0xD0E2BCF5 ) , MF : 11/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D0021B0870404C82A43CCC472F6097E DA : USB : HIGH-SPEED Boot done! Product Brand : samsung Product Model : SM-A013G Product Name : a01corejx Product Device : a01core Patch Level : QP1A.190711.020 Display ID : QP1A.190711.020.A013GJXU4AVC5 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2022-01-01 Build Time : 10.03.2022 Product Info : a01core Product Board : k39tv1_bsp_1g_titan Board Platform : mt6739 Product Manfct : samsung BootLoader State : Unlocked! BootLoader State : Locked! Done! Elapsed: 00:00:48 |
12-05-2022, 19:45 | #72747 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | CONDOR L2PRO FULL FACTOY FORCED+FRP done original poster ALICHAIMA DZGSM |
The Following User Says Thank You to profkefah For This Useful Post: |
12-06-2022, 09:24 | #72748 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | REDMI 9A MTK6765 AND:10 STUCK ON MTK PORT Done STUCK ON MTK PORT NOT BOOTING SUCCESSFULLY RECOVER DONE(REDMI 9A MTK6765 AND:10) THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
12-06-2022, 10:08 | #72749 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,202 | Nokia C20 New Security SP Unlock Done Code: Card found : 46828B86 , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.840_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P22_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P22 HW Version: sc9863A_modem CMP_Time : 05-07-2022 15:16:37 MODEM TAG : MOCORTM_20A_W21.15.3_P22_Debug_4G_MODEM_20A_W21.15.3_P22_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 350266787410722 IMEI[2] : 350266787410730 WIFIMAC : 44917C3F5B7D BT_MAC : 44917C3F5B7C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 20, price:5 Process... Process : Operation may took 10-15 minutes! >>> Repeat unlock/repair procedure after requested time again! Code: Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : Cosmo_00WW-user 11 RP1A.201005.001 V1.840_B01 release-keys Platform Version: MOCORTM_20A_W21.15.3_P22_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P22 HW Version: sc9863A_modem CMP_Time : 05-07-2022 15:16:37 MODEM TAG : MOCORTM_20A_W21.15.3_P22_Debug_4G_MODEM_20A_W21.15.3_P22_sc9863A_modem_sharkl3_pub NVMng : SecurityInfo IMEI[1] : 350266787410722 IMEI[2] : 350266787410730 WIFIMAC : 44917C3F5B7D BT_MAC : 44917C3F5B7C SEC : SLS:2, SKS:0, SKV:4 SLStatus : 2C Status : Locked! Server unlock required! Connecting to server... Connected Init... Init: Ok Authenticating... Authenticated Checking Client version... Client version Ok Balance: 15, price:5 Process... Finished Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:43 |
The Following 2 Users Say Thank You to tayobjoy1 For This Useful Post: |
12-06-2022, 11:32 | #72750 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | ViVo S1 Smart Reset Done Operation: Reset Settings/Format FS [ v2.38c5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... Proceed Format operation? That will DESTROY ALL USER DATA! Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM; PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: A7739A05B394BEEA0B2B147E6646F1E6 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 92EFECF5D6DDE8AC8D0D14CCC518FA92D82A017699AE629594 FF1708808BA742 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100445636444D42020CEE68AEA6DF Ven: Samsung OEM: 0 ID: 445636444D42 [DV6DMB] PRV: 0x02 SNN: 216950958 [0x0CEE68AE] MF: 10/2019 EMI: INFINITY PRELOADER_INFINITY_0 with 1 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00070000 [ 448.00 KB ] DRAM 0x100000000 [ 4.00 GB ] EMMC: CID: 150100445636444D42020CEE68AEA6DF Ven: Samsung OEM: 0 ID: 445636444D42 [DV6DMB] PRV: 0x02 SNN: 216950958 [0x0CEE68AE] MF: 10/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x1D1EC00000 [ 116.48 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 4929C22F51915107D453C4CAA6AAC8FB MEID: A7739A05B394BEEA0B2B147E6646F1E6 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 22020 [12|22020|0] Scan filesystem... SmartInfo: AndroidVer: 11 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6768__A7739A05B394B EEA0B2B147E6646F1E6\ [23] Read: NVRAM [14] Read: NVDATA [20] Read: PROINFO [33] Read: LK [13] Read: NVCFG [16] Read: PROTECT1 [1] Read: PGPT [15] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__A7739A05B394B EEA0B2B147E6646F1E6\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__A7739A05B394B EEA0B2B147E6646F1E6.7z Verified Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: CACHE... Format Ok: CACHE Process: USERDATA... Format Ok: USERDATA Done: 00:01:38 Reconnect Power/Cable now |
