12-06-2022, 11:38 | #72751 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Oppo A1K Smart Reset Done v2.38c5 Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... Proceed Format operation? That will DESTROY ALL USER DATA! Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM3) MODE: BOOTROM; PORT: 3 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: AD99340E06D73CCEE6758D556568142A BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 4997C8753F2B7E11074BCFAAEA274136DACE44A519E48FA004 6DDC0634A6BB37 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: Oppo: A1K-A12-A31-A32 | Manual: Off [27da5d71] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2044\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100514436334D4203C033F27776D5 Ven: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 3224629879 [0xC033F277] MF: 7/2019 EMI: INFINITY PRELOADER_INFINITY_0 with 3 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x0003A000 [ 232.00 KB ] DRAM 0x80000000 [ 2.00 GB ] EMMC: CID: 150100514436334D4203C033F27776D5 Ven: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 3224629879 [0xC033F277] MF: 7/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 28E0D6F034FB0E7AF08526DDE6A1C6EE MEID: AD99340E06D73CCEE6758D556568142A DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 8496 [16|8496|0] Scan filesystem... SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__AD99340E06D73 CCEE6758D556568142A\ [29] Read: NVRAM [13] Read: NVDATA [20] Read: PROINFO [30] Read: LK [12] Read: NVCFG [15] Read: PROTECT1 [1] Read: PGPT [18] Read: PERSIST [0] Read: PRELOADER [7] Read: OPPORESERVE3 Warning: ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__AD99340E06D73 CCEE6758D556568142A\opporeserve3.bin [8] Read: OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__AD99340E06D73 CCEE6758D556568142A\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__AD99340E06D73 CCEE6758D556568142A.7z Verified Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: CACHE... Format Ok: CACHE Process: USERDATA... Format Ok: USERDATA Done: 00:01:28 Reconnect Power/Cable now |
12-07-2022, 06:24 | #72752 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Cherry Mobile Aqua S9 Pattern Cherry Mobile Aqua S9 Pattern Code: Card found : 12345678 v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863A_eMMC_3GB_0S Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_1S Sending Init Boot ... Boot sent! Kick FDL ... >>> ERROR : FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Device info : Product Brand : Cherry_Mobile Product Device : Aqua_S9 Product Model : Aqua S9 Product Name : Aqua_S9 Patch Level : Q00711 Display ID : Cherry_Mobile_Aqua_S9_V03_06182021 Ver. Incmt : 1602209066 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-05 Build Time : 09.10.2020 Product Info : Aqua_S9 Product Manfct : Cherry_Mobile Board Platform : sp9863a Product Board : sp9863a_1h10 NVMng : SecurityInfo IMEI[1] : 357665078305074 IMEI[2] : 357665078305082 IMEI[3] : 867400020316638 SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_18B_W20.40.2_Debug Project Version: sharkl3_pub BASE Version: FM_BASE_18B_W20.40.2 HW Version: sc9863A_modem CMP_Time : 09-29-2020 02:31:05 MODEM TAG : MOCORTM_18B_W20.40.2_Debug_FM_BASE_18B_W20.40.2_sc9863A_modem_sharkl3_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:02:11 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_3GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
The Following User Says Thank You to xerraco For This Useful Post: |
12-07-2022, 07:07 | #72753 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Faisalabad
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | X657B-H6117EIKL flashing don gui: Default S/N: 0DA21111 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.37 Load IDBase v723487 Ok Update configuration... Configuration [12060] updated Load IDBase v723487 Ok Operation : Identify Device [ v2.37 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH [+] SecureData Backup [+] AutoBoot [+] Read Deep Info: PRL, HW, DEBUG [+] FireFly : AutoEMI [+] FireFly : FireFly UNI-Proto [+] Smart Service [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM48) MODE: BOOTROM PORT: 48 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: MEID: 7659EC9CF20D8E82FF896B3B7C0CE9D2 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: CE600C2C8C2A42F068439A2C148F1A2470FBAED7A80438E6BD 8B50283AB1F55B BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMI: FireFly preloader_x657b_h6117.bin with 11 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x750000000 [ 29.25 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 80521BCF642BFF8CC8B5081C8E822018 DA: USB: HIGH-SPEED Boot done SW : Infinix/X657B-OP-S2/Infinix-X657B:11/RP1A.200720.011/220820V756:user/release-keys Product Brand : Infinix Product Device : Infinix-X657B Product Model : Infinix X657B Product Name : X657B-OP-S2 Patch Level : RP1A.200720.011 Display ID : X657B-H6117EIKL-RGo-OP-S2-220820V756 SW Version : 220820V756 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-08-01 Build Time : 20.08.2022 CPU : armeabi-v7a,armeabi Product Info : x657b_h6117 SW : vnd_x657b_h6117-user 11 RP1A.200720.011 61713 release-keys Product Board : Infinix-X657B Board Platform : mt6761 Product Manfct : INFINIX MOBILITY LIMITED USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) Verify device config... Ok No loaders to verify NVRAM: TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V149_4_P57 NVRAM: Items: 0xA3 Size: 0x101A3C NVRAM: State: Ok INFO : WiFi MAC: 04F9938F1C77 INFO : BlTh MAC: 04F9938F1C76 INFO : IMEI[1]: 355705606045206 INFO : IMEI[2]: 355705606045214 Backup critical data [18] to C:\InfinityBox\CM2MT2\backup\MT6761__7659EC9CF20D8 E82FF896B3B7C0CE9D2\ [26] Read: NVRAM [10] Read: NVDATA [3] Read: PROINFO [27] Read: LK [9] Read: NVCFG [12] Read: PROTECT1 [1] Read: PGPT [11] Read: PERSIST [0] Read: PRELOADER Done STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Scan preloader... Preloader: EMI: MT6761 preloader_x657b_h6117.bin with 11 memory type(s) supported EMI[00] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[02] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[03] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[04] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 1.00 GB ] EMI[05] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[06] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[07] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[08] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[09] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[0A] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] Preloader exist: C:\InfinityBox\CM2MT2\backup\PRELOADER\preloader_x 657b_h6117.bin Verify backup\PRELOADER\preloader_x657b_h6117.bin [c9e47395]... Exist Ok Done Elapsed: 00:01:15 Operation : Read Firmware [ v2.37 ] [+] ExtSparse [-] ForceRead 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM48) MODE: BOOTROM PORT: 48 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: MEID: 7659EC9CF20D8E82FF896B3B7C0CE9D2 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: CE600C2C8C2A42F068439A2C148F1A2470FBAED7A80438E6BD 8B50283AB1F55B BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMI: FireFly preloader_x657b_h6117.bin with 11 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x750000000 [ 29.25 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 80521BCF642BFF8CC8B5081C8E822018 DA: USB: HIGH-SPEED Boot done SW : Infinix/X657B-OP-S2/Infinix-X657B:11/RP1A.200720.011/220820V756:user/release-keys Product Brand : Infinix Product Device : Infinix-X657B Product Model : Infinix X657B Product Name : X657B-OP-S2 Patch Level : RP1A.200720.011 Display ID : X657B-H6117EIKL-RGo-OP-S2-220820V756 SW Version : 220820V756 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-08-01 Build Time : 20.08.2022 CPU : armeabi-v7a,armeabi Product Info : x657b_h6117 SW : vnd_x657b_h6117-user 11 RP1A.200720.011 61713 release-keys Product Board : Infinix-X657B Board Platform : mt6761 Product Manfct : INFINIX MOBILITY LIMITED MT6761__INFINIX_MOBILITY_LIMITED__nfinix_X657B__B-H6117EIKL-RGo-OP-S2-220820V756__A.200720.011__57b_h6117 Read: preloader.bin Read: proinfo.img Read: persist.img ExtSparse : Compression ratio : 92% Read: tkv.img Read: recovery.img Read: md1rom.img Read: spmfw.img Read: tinysys-scp.bin Read: sspm.img Read: nvram.bin Read: lk.bin Read: boot.img Read: logo.bin Read: dtbo.img Read: tz.img Read: vbmeta.img Read: vbmeta_system.img Read: vbmeta_vendor.img Read: super.img ExtSparse : Compression ratio : 1% Read: cache.img Read: tranfs.img Read: userdata.img FW Size: 3.38 GB Android Info saved: _Android_info.txt Scatter: MT6761_Android_scatter.txt Saved to: C:\Users\Ali mobile\Desktop\MT6761__INFINIX_MOBILITY_LIMITED__n finix_X657B__B-H6117EIKL-RGo-OP-S2-220820V756__A.200720.011__57b_h6117\ Verify firmware [MT6761__INFINIX_MOBILITY_LIMITED__nfinix_X657B__B-H6117EIKL-RGo-OP-S2-220820V756__A.200720.011__57b_h6117]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Verify device config... Ok No loaders to verify Done Elapsed: 00:04:50 Load: C:\Users\Ali mobile\Desktop\New folder\MT6761_Android_scatter.txt Preloader [HW DEV] Info: EMI: MT6761 preloader_x657b_h6117.bin with 11 memory type(s) supported EMI[00] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[02] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[03] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[04] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 1.00 GB ] EMI[05] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[06] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[07] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[08] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[09] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[0A] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] Operation : Write Flash [ v2.37 ] [+] Repartition [-] Flash Verify [+] Reg.Pre-Erase [+] Verify HW/SW [+] SData Backup [-] Safe UserData [-] Flash Format Files: 23 [FL]: C:\Users\Ali mobile\Desktop\New folder\ [FL]: Set: preloader_x657b_h6117.bin [FL]: Set: tkv.img [FL]: Set: recovery.img [FL]: Set: md1img.img [FL]: Set: spmfw.img [FL]: Set: scp.img [FL]: Set: scp.img [FL]: Set: sspm.img [FL]: Set: sspm.img [FL]: Set: lk.img [FL]: Set: lk.img [FL]: Set: boot.img [FL]: Set: logo.bin [FL]: Set: dtbo.img [FL]: Set: tee.img [FL]: Set: tee.img [FL]: Set: vbmeta.img [FL]: Set: vbmeta_system.img [FL]: Set: vbmeta_vendor.img [FL]: Set: super.img [FL]: Set: cache.img [FL]: Set: tranfs.img [FL]: Set: userdata.img [FL]: Total size: 0xD2900FC4 [ 3.29 GB ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM48) MODE: BOOTROM PORT: 48 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] BROM: MEID: 7659EC9CF20D8E82FF896B3B7C0CE9D2 BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: CE600C2C8C2A42F068439A2C148F1A2470FBAED7A80438E6BD 8B50283AB1F55B BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : [1723e63e] C:\Users\Ali mobile\Desktop\New folder\preloader_x657b_h6117.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMI: MT6761 preloader_x657b_h6117.bin with 11 memory type(s) supported EMI[00] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 512.00 MB ] EMI[01] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[02] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[03] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[04] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 1.00 GB ] EMI[05] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[06] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[07] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[08] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI[09] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 2.00 GB ] EMI[0A] : DRAM : LP_DDR4 : ID: NOT_DEFINED : Ven: Unknown 0x0000 | Dev: : RAM: [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A400 [ 233.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 7001004432363033321025BFB8C9C729 EMMC: VEN: Kingston : OEM: 0 : ID: 443236303332 : PRV: 0x10 EMMC: VEN: Kingston : D26032 EMMC: SNN: 633321673 ( 0x25BFB8C9 ) MF: 12/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x750000000 [ 29.25 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 80521BCF642BFF8CC8B5081C8E822018 DA: USB: HIGH-SPEED Boot done [FL]: HW verification passed Verify device config... Ok No loaders to verify [FL]: Pre-Flash backup Backup critical data [18] to C:\InfinityBox\CM2MT2\backup\MT6761__7659EC9CF20D8 E82FF896B3B7C0CE9D2\ Done [FL]: Pre-Flash backup passed SEC_DL: False (RAPHAEL) SEC_ID: 0x494E46494E495459424F584245535432 [FL]: Pre-Erase Erase: 0x0000000000000000 0x0000000000108000 Erase: 0x0000000000408000 0x0000000004C1A000 Erase: 0x0000000007022000 0x00000000047DE000 Erase: 0x000000000F800000 0x000000000BB00000 Erase: 0x000000001F300000 0x00000001B7D00000 [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing now... Write: PRELOADER Update bootloader backup copy... Update bootloader backup copy Ok Write: TKV Write: RECOVERY Write: MD1IMG Write: SPMFW Write: SCP1 Write: SCP2 Write: SSPM_1 Write: SSPM_2 Write: LK Write: LK2 Write: BOOT Write: LOGO Write: DTBO Write: TEE1 Write: TEE2 Write: VBMETA Write: VBMETA_SYSTEM Write: VBMETA_VENDOR Write: SUPER Write: CACHE Write: TRANFS Write: USERDATA UltraFlash: OK SEC_DL: False (RAPHAEL) SEC_ID: 0x494E46494E495459424F584245535432 [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing finished Done Elapsed: 00:03:09 Reconnect Power/Cable now |
The Following User Says Thank You to alimobile279 For This Useful Post: |
12-07-2022, 08:53 | #72754 (permalink) |
Member: 1527968 Status: Offline Sonork: 100.1651182 Thanks Meter: 483 | u5582 firmware upload gui: Default S/N: 0DA21111 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.37 Load IDBase v723487 Ok Update configuration... Configuration [12060] updated Load IDBase v723487 Ok Operation : Read Firmware [ v2.37 ] [+] ExtSparse [-] ForceRead 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM49) MODE: PRELOADER PORT PORT: 49 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0321 BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x01 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started NAND: DEVICE NOT FOUND NAND: 000000000000000000000000 eMMC: OK eMMC: 150100463832324D42002643D330CCBD DAInf: 4 : 2 : 155 DA: DRAM ready DA: BOOT to 2nd DA... DA : Receiving HW info EMMC: CID: 150100463832324D42002643D33083BD EMMC: VEN: Samsung : OEM: 0 : ID: 463832324D42 : PRV: 0x00 EMMC: VEN: Samsung : F822MB EMMC: SNN: 641979184 ( 0x2643D330 ) MF: 8/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0321 RNID: 8ED22CB621B419F3864E2F83E2F24CAC STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA: USB: HIGH-SPEED Boot done Patch Level : LMY47D Display ID : A961CP.HOZ.U5582.B3.HB.H.SUSVKM.0913.V3.03 SW Version : 1473757786 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-01-01 Build Time : 13.09.2016 Product Model : U5582 Product Brand : EBEST Product Name : full_pri6735_66t_v_l1 Product Device : pri6735_66t_v_l1 CPU : arm64-v8a,armeabi-v7a,armeabi CPU : armeabi-v7a,armeabi CPU : arm64-v8a Product Manfct : EBEST Board Platform : mt6735 Product Info : pri6735_66t_v_l1 SW : full_pri6735_66t_v_l1-user 5.1 LMY47D 1473757786 test-keys MT6735__EBEST__5582__1__CP.HOZ.U5582.B3.HB.H.SUSVK M.0913.V3.03__47D__i6735_66t_v_l1 Read: preloader.bin Read: proinfo.img Read: nvram.bin Read: lk.bin Read: boot.img Read: recovery.img Read: logo.bin Read: secro.img Read: tz.img Read: system.img ExtSparse : Compression ratio : 36% Read: cache.img Read: userdata.img FW Size: 1.35 GB Android Info saved: _Android_info.txt Scatter: MT6735_Android_scatter.txt Saved to: C:\Users\Ali mobile\Desktop\MT6735__EBEST__5582__1__CP.HOZ.U558 2.B3.HB.H.SUSVKM.0913.V3.03__47D__i6735_66t_v_l1\ Verify firmware [MT6735__EBEST__5582__1__CP.HOZ.U5582.B3.HB.H.SUSVK M.0913.V3.03__47D__i6735_66t_v_l1]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Verify device config... Ok No loaders to verify Done Elapsed: 00:03:43 Operation: Upload File: C:\Users\Ali mobile\Desktop\MT6735__EBEST__5582__1__CP.HOZ.U558 2.B3.HB.H.SUSVKM.0913.V3.03__47D__i6735_66t_v_l1.r ar Verify file: MT6735__EBEST__5582__1__CP.HOZ.U5582.B3.HB.H.SUSVK M.0913.V3.03__47D__i6735_66t_v_l1 Authentication... Initialization... Upload file 637.11 Mb Uploading 637.11 Mb... |
12-07-2022, 14:01 | #72755 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Vipro C1 Read Flash File Done Operation: Read Firmware [ v2.38c5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Destination: C:\Users\AkhtarAli\Desktop\ Free space: 11.14 Gb Wait... [+] Pack FW [Sparse] [-] Forced Read 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN BROM: BROM|BL : 0xFF|0x01 [PRELOADER PORT] AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND eMMC: OK eMMC: 5100011541535837A0AE0142171265E7 DAInf: v4.2.156 DA: DRAM ready DA: BOOT to 2nd DA... DA: Receiving HW info EMMC: CID: 15010051375853414201AEA0E7651217 Ven: Samsung OEM: 0 ID: 513758534142 [Q7XSAB] PRV: 0x01 SNN: 2929780581 [0xAEA0E765] MF: 1/2015 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00080000 [ 512.00 KB ] USER: 0x1D2000000 [ 7.28 GB ] SRAM 0x00020000 [ 128.00 KB ] DRAM 0x40000000 [ 1.00 GB ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 1DFB3D49EB325BB050DE60788854A4B0 DA: STATUS: BLANK FLASH; BSTYLE: EMMC FLASH BOOT DA: USB: HIGH-SPEED Boot done [0] Reading... Ok Reading... Scan memory... Found region: 7340 [7340|0|0] Scan filesystem... Patch Level: MRA58K Display ID: C1_A536HC_Q5_20200511-113258 SW Version: 1589167858 Ver. CodeName: REL Ver. Release: 6.0 Sec. Patch: 05112020 Build Time: 11.05.2020 Product Model: U2 Product Brand: Vipro Product Name: C1 Product Device: C1 Product Board: MTK CPU : armeabi-v7a,armeabi Product Manfct: Vipro Board Platform: mt6580 Product Info: nb6580_we_m SW : full_nb6580_we_m-user 6.0 MRA58K 1589167858 release-keys Startegy: 7 Firmware ID: MT6580_Vipro_U2_6.0_C1_A536HC_Q5_20200511-113258_MRA58K_nb6580_we_m Read: preloader.bin Read: cm2pit.bin Read: proinfo.img Read: nvram.bin Read: protect.img Read: protect.img Read: seccfg.img Read: lk.bin Read: boot.img Read: recovery.img Read: para.img Read: logo.bin Read: expdb.img Read: frp.img Read: nvdata.img Read: metadata.img Read: oemkeystore.img Read: secro.img Read: keystore.img Read: system.img ExtSparse: Compression ratio: 10% Read: cache.img Read: userdata.img Read: flashinfo.img Read: sgpt.img FW Size: 1.69 GB Android Info saved: _Android_info.txt Scatter: MT6580_Android_scatter.txt Saved: C:\Users\AkhtarAli\Desktop\MT6580_Vipro_U2_6.0_C1_ A536HC_Q5_20200511-113258_MRA58K_nb6580_we_m\ Verify device config... Ok Loaders Ok Verify firmware [MT6580_Vipro_U2_6.0_C1_A536HC_Q5_20200511-113258_MRA58K_nb6580_we_m]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Done: 00:08:10 |
12-08-2022, 07:47 | #72756 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,053 | Infinix Smart 5 PIN Code: Operation: Identify Device [ v2.38c7 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BOTH [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] AutoEMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE: BOOTROM; PORT: 4 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 601DB67BF4C530CFB9F84C7159830D2B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 9E234B73A1FAA2EBDC59BD6B04270A89C4E202766B272368A49802EAC0FFDF7F BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: Infinix: SEC_NEW | Manual: Off [c7992f8b] C:\InfinityBox\CM2MT2\boot\Infinix\SEC_NEW\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 700100443236303332101E06A583B70F VEN: Kingston OEM: 0 ID: 443236303332 [D26032] PRV: 0x10 SNN: 503752067 [0x1E06A583] MF: 11/2020 EMI: FireFly preloader_x657c_h6117.bin with 11 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00080000 [ 512.00 KB ] DRAM 0x80000000 [ 2.00 GB ] EMMC: CID: 700100443236303332101E06A583B70F VEN: Kingston OEM: 0 ID: 443236303332 [D26032] PRV: 0x10 SNN: 503752067 [0x1E06A583] MF: 11/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x750000000 [ 29.25 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 1A5756B10CDFB18ACCB798B2027C62BE MEID: 601DB67BF4C530CFB9F84C7159830D2B DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 30768 [12|30768|0] Scan filesystem... SW : Infinix/X657C-GL/Infinix-X657C:10/QP1A.190711.020/GH-GL-210701V233:user/release-keys Product Brand: Infinix Product Device: Infinix-X657C Product Model: Infinix X657C Product Name: X657C-GL Patch Level: QP1A.190711.020 Display ID: X657C-H6117GH-QGo-GL-210701V233 SW Version: GH-GL-210701V233 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-06-05 Build Time: 01.07.2021 CPU : armeabi-v7a,armeabi Product Info: x657c_h6117 SW : full_x657c_h6117-user 10 QP1A.190711.020 125041 release-keys Product Board: Infinix-X657C Board Platform: mt6761 Product Manfct: INFINIX MOBILITY LIMITED Startegy: 7 Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X657C_10_X657C-H6117GH-QGo-GL-210701V233_QP1A.190711.020_x657c_h6117 Verify firmware [MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X657C_10_X657C-H6117GH-QGo-GL-210701V233_QP1A.190711.020_x657c_h6117]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) NVRAM: TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V114_9_P17 NVRAM: Items: 0xA3 Size: 0x101A3C State: Ok WiFi MAC: AA0036004400 BlTh MAC: E8C2DDA46846 IMEI[1]: 356439462716929 IMEI[2]: 356439462716937 Verify device config... Ok Verify loader[a5e2c43f]... Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6761__601DB67BF4C530CFB9F84C7159830D2B\ [26] Read: NVRAM [10] Read: NVDATA [3] Read: PROINFO [27] Read: LK [9] Read: NVCFG [12] Read: PROTECT1 [1] Read: PGPT [11] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6761__601DB67BF4C530CFB9F84C7159830D2B\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6761__601DB67BF4C530CFB9F84C7159830D2B.7z Verified STORAGE : Life Status : eMMC : NOT implemented in selected DA! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Scan preloader... Preloader: EMI: MT6761 preloader_x657c_h6117.bin with 11 memory type(s) supported 00: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 512.00 MB ] 01: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 3.00 GB ] 02: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 03: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 04: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 1.00 GB ] 05: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 3.00 GB ] 06: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 07: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 08: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 3.00 GB ] 09: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 2.00 GB ] 0A: DRAM LP_DDR4 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: [ 3.00 GB ] Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x657c_h6117.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x657c_h6117.bin [c9422a50]... Exist Done: 00:01:07 Operation: Reset Settings/Format FS [ v2.38c7 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE: BOOTROM; PORT: 4 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 601DB67BF4C530CFB9F84C7159830D2B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 9E234B73A1FAA2EBDC59BD6B04270A89C4E202766B272368A49802EAC0FFDF7F BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: Infinix: SEC_NEW | Manual: Off [c7992f8b] C:\InfinityBox\CM2MT2\boot\Infinix\SEC_NEW\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 700100443236303332101E06A583B70F VEN: Kingston OEM: 0 ID: 443236303332 [D26032] PRV: 0x10 SNN: 503752067 [0x1E06A583] MF: 11/2020 EMI: FireFly preloader_x657c_h6117.bin with 11 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00080000 [ 512.00 KB ] DRAM 0x80000000 [ 2.00 GB ] EMMC: CID: 700100443236303332101E06A583B70F VEN: Kingston OEM: 0 ID: 443236303332 [D26032] PRV: 0x10 SNN: 503752067 [0x1E06A583] MF: 11/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x750000000 [ 29.25 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 1A5756B10CDFB18ACCB798B2027C62BE MEID: 601DB67BF4C530CFB9F84C7159830D2B DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 30768 [12|30768|0] Scan filesystem... SmartInfo: AndroidVer: 10 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__601DB67BF4C530CFB9F84C7159830D2B Process: RESET PROTECTION... Format Ok: RESET PROTECTION Process: USERDATA... Format Ok: USERDATA Process: CACHE... Format Ok: CACHE Process: USERDATA... Format Ok: USERDATA Process: USERDATA... Format Ok: USERDATA Done: 00:00:35 Reconnect Power/Cable now |
12-08-2022, 07:50 | #72757 (permalink) |
Member: 890926 Status: Offline Thanks Meter: 2,053 | iTel W5006X Pattern Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : W5006X-F3112_A17 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Device info : Product Brand : Itel Product Device : W5006X Product Model : itel W5006X Product Name : W5006X Patch Level : QP1A.190711.020 Display ID : W5006X-F3112-10.0-OP-V033-20211227 Ver. Incmt : OP-V033-20211227 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-12-05 Build Time : 27.12.2021 Product Name : F3112 Product Device : itel-W5006X Product Info : W5006X Product Board : W5006X Board Platform : sp7731e Product Manfct : itel NVMng : SecurityInfo IMEI[1] : 350309032934284 IMEI[2] : 350309032934292 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W20.21.2_P9_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W20.21.2_P9 HW Version: sc7731e_modem CMP_Time : 01-28-2021 11:10:37 MODEM TAG : MOCORTM_17C_W20.21.2_P9_Debug_FM_BASE_17C_W20.21.2_P9_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FDE ( Full Disk Encryption ***) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:47 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : W5006X-F3112_A17 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:23 |
12-08-2022, 08:51 | #72758 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo F1s MT6750 FRP/Pattren Reset Done With King Infinity CM2 Code: gui: Default S/N: A19EC787 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.37 Load IDBase v312457 Ok Server unavailable Username or Password is wrong - set it via Settings https://infinity-box.com/?r=100166 Load IDBase v312457 Ok Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... Device not found >>> Check cable, battery, connection and drivers! Reconnect Power/Cable now Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM18) MODE: BOOTROM PORT: 18 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 BROM: MEID: 25DA6779A5ACCE69D97E60875CBCA1F4 BROM: SecLevel: 0x00000001 BROM: SecMode : SBC BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: EMI : Search BROM: EMI : Found AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMI: FireFly preloader_oppo6750_15131.bin with 8 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 150100525831344D4207284EDA84C32F EMMC: VEN: Samsung : OEM: 0 : ID: 525831344D42 : PRV: 0x07 EMMC: VEN: Samsung : RX14MB EMMC: SNN: 676256388 ( 0x284EDA84 ) MF: 12/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6750 RNID: B36417ACFA2926147AE4296F84829890 DA: USB: FULL-SPEED DA: USB: Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM62) MODE: PRELOADER PORT PORT: 62 Boot done SmartInfo: AndroidVer: 5 UserDataFS: 0x01 CacheFS: 0x01 Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Format Ok: USERDATA Format Ok: CACHE Format Ok: USERDATA Done Elapsed: 00:01:00 Reconnect Power/Cable now |
12-08-2022, 10:16 | #72759 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A1K MT6765 FRP/Pattren Reset Done With King Infinity CM2 Code: gui: Default S/N: A19EC787 v0153 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.37 Load IDBase v312457 Ok Server unavailable Username or Password is wrong - set it via Settings https://infinity-box.com/?r=100166 Load IDBase v312457 Ok Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM18) MODE: BOOTROM PORT: 18 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: MEID: 20852BDDD00EC3E950A0EA848443638A BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: 622AE6942A216561110039DDD142FAD87C9D966B9C368EAD98D275D6D694F55B BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 150100444436384D4202080FCCEF17C9 EMMC: VEN: Samsung : OEM: 0 : ID: 444436384D42 : PRV: 0x02 EMMC: VEN: Samsung : DD68MB EMMC: SNN: 135253231 ( 0x080FCCEF ) MF: 1/2020 EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) supported EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID: 150100444436384D4202080FCCEF17C9 EMMC: VEN: Samsung : OEM: 0 : ID: 444436384D42 : PRV: 0x02 EMMC: VEN: Samsung : DD68MB EMMC: SNN: 135253231 ( 0x080FCCEF ) MF: 1/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E695F954F7C5B1E31F69BC0A1CA2B97E DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 9 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Format Ok: USERDATA Format Ok: CACHE Format Ok: USERDATA Done Elapsed: 00:01:04 Reconnect Power/Cable now |
12-08-2022, 10:19 | #72760 (permalink) |
No Life Poster Join Date: Sep 2021 Location: Germany
Member: 2996196 Status: Offline Thanks Meter: 632 | iTEL A16 PLUS BOOTLOOP FIXED BY CM2 Code: Open : A16Plus-SA332Q-10-OP-V014-20210831.pac VER : BP_R1.0.0 LEN : 2.26 GiB CPU : sp7731e_1h10 VER : A16Plus-SA332Q-10-OP-V014-20210831 Reading package ... Read package finished! Product Brand : Itel Product Device : itel-A16-Plus Product Model : itel A16 Plus Product Name : SA332Q Patch Level : QP1A.190711.020 Display ID : A16Plus-SA332Q-10-OP-V014-20210831 Ver. Incmt : OP-V014-20210831 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2021-09-05 Build Time : 31.08.2021 Product Manfct : ITEL MOBILE LIMITED Product Info : SA332Q Product Board : sp7731e_1h10 Board Platform : sp7731e Operation : Flash Firmware [ v2.14 ] Setting : Update NVRAM : True Setting : Force NVRAM : False Setting : SlowSparse Fix : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : A16Plus-SA332Q-10-OP-V014-20210831.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x26 PMTMng : Update PMT Ok! NVRM : pike2_pubcp_PLD_base_nv_nvitem.bin NVMng : Load 0x17 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 351628222438304 IMEI[2] : 351628222438312 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 NVMng : Backup Ok , 0x00066B28 NVMng : Init DST NVMng : Rx11 : Wx10 NVMng : NVM block updated! Prepare target ... Prepare Ok! CODE : PM_pike2_cm4_v2.bin CODE : vbmeta-sign.img FSIMG : odmko.img CODE : gnssmodem.bin FSIMG : userdata.img CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat UBOOT : u-boot-spl-16k-sign.bin ERASE : SYSDUMPDB CODE : PIKE2_DM_DSP.bin UBOOT : u-boot-sign.bin ERASE : METADATA CODE : logo.bmp(1) CODE : pike2_cm4.bin ERASE : UBOOT_LOG CODE : boot.img CODE : tos-sign.bin FSIMG : super.img ERASE : MISC FSIMG : socko.img CODE : logo.bmp CODE : gnssbdmodem.bin CODE : pike2_pubcp_PLD_base_nv_deltanv.bin CODE : prodnv.img CODE : vbmeta_system.img FSIMG : persist.img FSIMG : cache.img ERASE : W_RUNTIMENV1 CODE : vbmeta_vendor.img CODE : recovery.img CODE : dtbo.img CODE : sml-sign.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:02:36 |
The Following User Says Thank You to Jacobkamudyariw For This Useful Post: |
12-08-2022, 11:12 | #72761 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Popo 4G MT6592 FRP/Pattren Reset Done With King Infinity CM2 Code: Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM38) MODE: PRELOADER PORT PORT: 38 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM init passed CHIP: MT6592 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6592 BROM: SecLevel: 0x00000000 BROM: SecMode : PLAIN BROM: BROM|BL : 0xFF|0x01 BROM: PRELOADER PORT AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : CHANGE : v1724 AGENT : Found MT6592 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started NAND: DEVICE NOT FOUND NAND: 000000000000000000000000 eMMC: OK eMMC: 520001154D4231586C41074277C316C4 DAInf: 4 : 2 : 138 DA: DRAM ready DA: BOOT to 2nd DA... DA : Receiving HW info EMMC: CID: 150100525831424D4207416CC416C377 EMMC: VEN: Samsung : OEM: 0 : ID: 525831424D42 : PRV: 0x07 EMMC: VEN: Samsung : RX1BMB EMMC: SNN: 1097647126 ( 0x416CC416 ) MF: 12/2016 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP: MT6592 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6592 RNID: 4FA29081D9342EA11826A0916E8840BE STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 5 UserDataFS: 0x01 CacheFS: 0x01 Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Format Ok: CACHE Format Ok: USRDATA Done Elapsed: 00:00:38 Reconnect Power/Cable now |
12-08-2022, 15:19 | #72762 (permalink) |
Member: 2996196 Status: Offline Thanks Meter: 632 | MOVITEL M9110 NETWORK UNLOCK Done CM2 Code: Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9832e_1h10_go2g-user 11 RP1A.201005.001 1628476487 release-keys MemoryInfo : EMMC : 16 GB ; DRAM : 2 GB Platform Version: MOCORTM_20A_W20.51.6_P1_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.51.6_P1 HW Version: sc9832e_modem CMP_Time : 12-29-2020 21:38:25 MODEM TAG : MOCORTM_20A_W20.51.6_P1_Debug_4G_MODEM_20A_W20.51.6_P1_sc9832e_modem_sharklp PSN1 : M911021082607105 NVMng : SecurityInfo IMEI[1] : 861637051633441 IMEI[2] : 867400020316620 WIFIMAC : E0D01293153B BT_MAC : E0D01292C311 SEC : SLS:0, SKS:0, SKV:3 Done! Elapsed: 00:00:34 Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9832e_1h10_go2g-user 11 RP1A.201005.001 1628476487 release-keys Platform Version: MOCORTM_20A_W20.51.6_P1_Debug Project Version: sharklp BASE Version: 4G_MODEM_20A_W20.51.6_P1 HW Version: sc9832e_modem CMP_Time : 12-29-2020 21:38:25 MODEM TAG : MOCORTM_20A_W20.51.6_P1_Debug_4G_MODEM_20A_W20.51.6_P1_sc9832e_modem_sharklp NVMng : SecurityInfo IMEI[1] : 861637051633441 IMEI[2] : 867400020316620 WIFIMAC : E0D01293153B BT_MAC : E0D01292C311 SEC : SLS:0, SKS:0, SKV:3 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:23 |
The Following 2 Users Say Thank You to Jacobkamudyariw For This Useful Post: |
12-08-2022, 16:42 | #72763 (permalink) |
Freak Poster Join Date: Sep 2019 Location: Mozambique
Member: 2927861 Status: Offline Thanks Meter: 47 | Smart reset extra done Card found : XXXXXXXXX , v0153 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.34 Load IDBase v312457 Ok! Update configuration ... Load IDBase v723487 Ok! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... Device not found! >>> Check cable, battery, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v2.34 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Dispositivo de Série USB (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : EDB5AA870DA3F75A9BCEA54FBBD6FCC8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 28DBABB950BFF244F8D0F50329739DA04A3DD70EF725B10D06 BAFDE7F0D1B6B0 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 13014E47314A39533910184E4248A8F3 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 : PRV : 0x10 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 407781960 ( 0x184E4248 ) , MF : 10/2021 EMI : DEV : FireFly EMI : SRC : preloader_cg6_h696.bin EMI : CNT : 0012 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 13014E47314A39533910184E4248A8F3 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 : PRV : 0x10 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 407781960 ( 0x184E4248 ) , MF : 10/2021 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x1D1F000000 [ 116,48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : F5AFCD85DFF5B3AE65CF2885AB982711 DA : USB : HIGH-SPEED Boot done! USERDATA : ENCRYPTED NVRAM : 0xB8122373 NVRAM : State : Ok! INFO : WiFi MAC : XXXXXXXXXXXX INFO : BlTh MAC : XXXXXXXXXXXX INFO : IMEI[1] : XXXXXXXXXXXXXX INFO : IMEI[2] : XXXXXXXXXXXXXX Backup sensetive data [ 18 ] Backup path : Backup\MT6768__EDB5AA870DA3F75A9BCEA54FBBD6FCC8\ [36] Read : NVRAM [19] Read : NVDATA [3] Read : PROINFO [18] Read : NVCFG [21] Read : PROTECT1 [1] Read : PGPT ERR : 0xC0010002 ERR : ABORT ERR : 0x00007E00|0x00008000 [20] Read : PERSIST [0] Read : PRELOADER Backup done! STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] PRELOADER : DEVICE : DEV : MT6752 NME : preloader_cg6_h696.bin CNT : 0012 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512,00 MB ] EMI : [01] : eMMC : DDR3 : ID : 90014A68423861503E : VEN : HYNIX | DEV : hB8aP> : RAM : [ 3,00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6,00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3,00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4,00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4,00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100445036384D42 : VEN : SAMSUNG | DEV : DP68MB : RAM : [ 3,00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4,00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6,00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4,00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4,00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4,00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6,00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6,00 GB ] EMI : [0E] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4,00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 150100445636444242 : VEN : SAMSUNG | DEV : DV6DBB : RAM : [ 4,00 GB ] EMI : [10] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8,00 GB ] EMI : [11] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 8,00 GB ] PRELOADER saved to : Backup\PRELOADER\preloader_cg6_h696.bin Done! Elapsed: 00:01:42 Operation : Reset Settings/Format FS [ v2.34 ] Mode : SMART RESET EXTRA 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Dispositivo de Série USB (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : EDB5AA870DA3F75A9BCEA54FBBD6FCC8 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 28DBABB950BFF244F8D0F50329739DA04A3DD70EF725B10D06 BAFDE7F0D1B6B0 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 13014E47314A39533910184E4248A8F3 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 : PRV : 0x10 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 407781960 ( 0x184E4248 ) , MF : 10/2021 EMI : DEV : FireFly EMI : SRC : preloader_cg6_h696.bin EMI : CNT : 0012 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448,00 KB ] DRAM: 0x100000000 [ 4,00 GB ] EMMC: CID : 13014E47314A39533910184E4248A8F3 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 : PRV : 0x10 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 407781960 ( 0x184E4248 ) , MF : 10/2021 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x01000000 [ 16,00 MB ] USER : 0x1D1F000000 [ 116,48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : F5AFCD85DFF5B3AE65CF2885AB982711 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x845657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Khadaff_papillo For This Useful Post: |
12-08-2022, 17:58 | #72764 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Pakistan
Member: 2276949 Status: Offline Thanks Meter: 160 | Samsung A13 A137F Read Info FRP and Read Firmware Done Code: Product Brand : samsung Product Device : a13ve Product Model : SM-A137F Product Name : a13vensxx SW : samsung/a13vensxx/a13ve:12/SP1A.210812.016/A137FXXU1AVE7:user/release-keys Patch Level : SP1A.210812.016 Display ID : SP1A.210812.016.A137FXXU1AVE7 SW Version : A137FXXU1AVE7 Ver. CodeName : REL Ver. Release : 12 Sec. Patch : 2022-06-01 Build Time : 24.05.2022 Product Info : a13ve SW : a13vensxx-user 12 SP1A.210812.016 A137FXXU1AVE7 release-keys Product Manfct : samsung Product Board : a13ve Board Platform : mt6768 Code: Operation : Read Firmware [ v2.37 ] [+] ExtSparse [-] ForceRead 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM8) MODE: BOOTROM PORT: 8 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: MEID: 2379D5A26420AD3786370E5D8735B20F BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: A792FB5686C1D547AABE4A1A44FBFB7925ADE3293953936D1503BF5442C49098 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI not found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : [88a9400e] C:\Users\CGS\preloader_k69v1_64_titan_bengal_tiger.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 15010044503644424200FD8FD328493D EMMC: VEN: Samsung : OEM: 0 : ID: 445036444242 : PRV: 0x00 EMMC: VEN: Samsung : DP6DBB EMMC: SNN: 4254061352 ( 0xFD8FD328 ) MF: 4/2022 EMI: MT6752 preloader_k69v1_64_titan_bengal_tiger.bin with 17 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 150100335636434142 : Ven: Samsung | Dev: 3V6CAB : RAM: [ 6.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 150100445036444142 : Ven: Samsung | Dev: DP6DAB : RAM: [ 4.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100445636444142 : Ven: Samsung | Dev: DV6DAB : RAM: [ 4.00 GB ] EMI[04] : eMMC : LP_DDR4X : ID: 13014E47314331324C : Ven: Micron | Dev: G1C12L : RAM: [ 8.00 GB ] EMI[05] : eMMC : LP_DDR4X : ID: 13014E47314A395139 : Ven: Micron | Dev: G1J9Q9 : RAM: [ 6.00 GB ] EMI[06] : eMMC : LP_DDR4X : ID: 13014E47314A395339 : Ven: Micron | Dev: G1J9S9 : RAM: [ 4.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 13014E47314A395238 : Ven: Micron | Dev: G1J9R8 : RAM: [ 4.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 150100444336444D42 : Ven: Samsung | Dev: DC6DMB : RAM: [ 4.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 150100445836384D42 : Ven: Samsung | Dev: DX68MB : RAM: [ 3.00 GB ] EMI[0A] : eMMC : LP_DDR4X : ID: 150100335636434242 : Ven: Samsung | Dev: 3V6CBB : RAM: [ 6.00 GB ] EMI[0B] : eMMC : LP_DDR4X : ID: 150100445636444242 : Ven: Samsung | Dev: DV6DBB : RAM: [ 4.00 GB ] EMI[0C] : eMMC : LP_DDR4X : ID: 150100445036444242 : Ven: Samsung | Dev: DP6DBB : RAM: [ 4.00 GB ] EMI[0D] : eMMC : LP_DDR4X : ID: 150100345836324D42 : Ven: Samsung | Dev: 4X62MB : RAM: [ 3.00 GB ] EMI[0E] : eMMC : LP_DDR4X : ID: 13014E473243323139 : Ven: Micron | Dev: G2C219 : RAM: [ 4.00 GB ] EMI[0F] : eMMC : LP_DDR4X : ID: 13014E473243323133 : Ven: Micron | Dev: G2C213 : RAM: [ 4.00 GB ] EMI[10] : eMMC : LP_DDR4X : ID: 13014E473243323135 : Ven: Micron | Dev: G2C215 : RAM: [ 8.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 15010044503644424200FD8FD328493D EMMC: VEN: Samsung : OEM: 0 : ID: 445036444242 : PRV: 0x00 EMMC: VEN: Samsung : DP6DBB EMMC: SNN: 4254061352 ( 0xFD8FD328 ) MF: 4/2022 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 6E19677CB06EA4BAC1FCB139EFE0DDCA DA: USB: HIGH-SPEED Boot done Product Brand : samsung Product Device : a13ve Product Model : SM-A137F Product Name : a13vensxx SW : samsung/a13vensxx/a13ve:12/SP1A.210812.016/A137FXXU1AVE7:user/release-keys Patch Level : SP1A.210812.016 Display ID : SP1A.210812.016.A137FXXU1AVE7 SW Version : A137FXXU1AVE7 Ver. CodeName : REL Ver. Release : 12 Sec. Patch : 2022-06-01 Build Time : 24.05.2022 Product Info : a13ve SW : a13vensxx-user 12 SP1A.210812.016 A137FXXU1AVE7 release-keys Product Manfct : samsung Product Board : a13ve Board Platform : mt6768 MT6768__samsung__M-A137F__.210812.016.A137FXXU1AVE7__A.210812.016__3ve Read: preloader.bin Read: efs.img Read: sec_efs.img Read: steady.img Read: nvram.bin Read: spmfw.img Read: tinysys-scp.bin Read: sspm.img Read: tz.img Read: tzar.img Read: gz.img Read: lk.bin Read: dtbo.img Read: vbmeta.img Read: btd.img Read: persistent.img Read: md1rom.img Read: param.img Read: up_param.img Read: boot.img Read: recovery.img Read: vbmeta_system.img Read: efuse.img Read: super.img ExtSparse : Compression ratio : 22% Read: prism.img ExtSparse : Compression ratio : 85% Read: optics.img ExtSparse : Compression ratio : 95% Read: cache.img Read: omr.img Read: spu.img Read: userdata.img FW Size: 5.15 GB Android Info saved: _Android_info.txt Scatter: MT6768_Android_scatter.txt Saved to: C:\InfinityBox\CM2MT2\Flash\MT6768__samsung__M-A137F__.210812.016.A137FXXU1AVE7__A.210812.016__3ve\ Verify firmware [MT6768__samsung__M-A137F__.210812.016.A137FXXU1AVE7__A.210812.016__3ve]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Verify device config... Ok No loaders to verify Done Elapsed: 00:09:37 Code: Operation : Reset Settings/Format FS [ v2.37 ] Mode: SMART RESET EXTRA 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM8) MODE: BOOTROM PORT: 8 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: MEID: 2379D5A26420AD3786370E5D8735B20F BROM: SecLevel: 0x000000E5 BROM: SecMode : SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE BROM: BOOTROM BROM: SOCID: A792FB5686C1D547AABE4A1A44FBFB7925ADE3293953936D1503BF5442C49098 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI not found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Looking for suitable BootChain in DA... AGENT : [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin AGENT : [88a9400e] C:\Users\CGS\preloader_k69v1_64_titan_bengal_tiger.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA : AGENT started DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized EMMC: CID: 15010044503644424200FD8FD328493D EMMC: VEN: Samsung : OEM: 0 : ID: 445036444242 : PRV: 0x00 EMMC: VEN: Samsung : DP6DBB EMMC: SNN: 4254061352 ( 0xFD8FD328 ) MF: 4/2022 EMI: MT6752 preloader_k69v1_64_titan_bengal_tiger.bin with 17 memory type(s) supported EMI[00] : eMMC : LP_DDR4X : ID: 150100335636434142 : Ven: Samsung | Dev: 3V6CAB : RAM: [ 6.00 GB ] EMI[01] : eMMC : LP_DDR4X : ID: 150100444836444142 : Ven: Samsung | Dev: DH6DAB : RAM: [ 4.00 GB ] EMI[02] : eMMC : LP_DDR4X : ID: 150100445036444142 : Ven: Samsung | Dev: DP6DAB : RAM: [ 4.00 GB ] EMI[03] : eMMC : LP_DDR4X : ID: 150100445636444142 : Ven: Samsung | Dev: DV6DAB : RAM: [ 4.00 GB ] EMI[04] : eMMC : LP_DDR4X : ID: 13014E47314331324C : Ven: Micron | Dev: G1C12L : RAM: [ 8.00 GB ] EMI[05] : eMMC : LP_DDR4X : ID: 13014E47314A395139 : Ven: Micron | Dev: G1J9Q9 : RAM: [ 6.00 GB ] EMI[06] : eMMC : LP_DDR4X : ID: 13014E47314A395339 : Ven: Micron | Dev: G1J9S9 : RAM: [ 4.00 GB ] EMI[07] : eMMC : LP_DDR4X : ID: 13014E47314A395238 : Ven: Micron | Dev: G1J9R8 : RAM: [ 4.00 GB ] EMI[08] : eMMC : LP_DDR4X : ID: 150100444336444D42 : Ven: Samsung | Dev: DC6DMB : RAM: [ 4.00 GB ] EMI[09] : eMMC : LP_DDR4X : ID: 150100445836384D42 : Ven: Samsung | Dev: DX68MB : RAM: [ 3.00 GB ] EMI[0A] : eMMC : LP_DDR4X : ID: 150100335636434242 : Ven: Samsung | Dev: 3V6CBB : RAM: [ 6.00 GB ] EMI[0B] : eMMC : LP_DDR4X : ID: 150100445636444242 : Ven: Samsung | Dev: DV6DBB : RAM: [ 4.00 GB ] EMI[0C] : eMMC : LP_DDR4X : ID: 150100445036444242 : Ven: Samsung | Dev: DP6DBB : RAM: [ 4.00 GB ] EMI[0D] : eMMC : LP_DDR4X : ID: 150100345836324D42 : Ven: Samsung | Dev: 4X62MB : RAM: [ 3.00 GB ] EMI[0E] : eMMC : LP_DDR4X : ID: 13014E473243323139 : Ven: Micron | Dev: G2C219 : RAM: [ 4.00 GB ] EMI[0F] : eMMC : LP_DDR4X : ID: 13014E473243323133 : Ven: Micron | Dev: G2C213 : RAM: [ 4.00 GB ] EMI[10] : eMMC : LP_DDR4X : ID: 13014E473243323135 : Ven: Micron | Dev: G2C215 : RAM: [ 8.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed DA : BOOT to 2nd DA... DA : 2ND stage confirmed DA : SYNC with DA passed DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 15010044503644424200FD8FD328493D EMMC: VEN: Samsung : OEM: 0 : ID: 445036444242 : PRV: 0x00 EMMC: VEN: Samsung : DP6DBB EMMC: SNN: 4254061352 ( 0xFD8FD328 ) MF: 4/2022 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0xE8F800000 [ 58.24 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 6E19677CB06EA4BAC1FCB139EFE0DDCA DA: USB: HIGH-SPEED Boot done SmartInfo: AndroidVer: 12 UserDataFS: 0x02 CacheFS: 0x02 Verify device config... Ok No loaders to verify Format Ok: RESET PROTECTION Format Ok: USERDATA Format Ok: CACHE Format Ok: USERDATA Format Ok: USERDATA Format Ok: Vendor Extra Knox Guard [KG]: Update to Completed Format Ok: Knox Guard [KG] reset Done Elapsed: 00:01:57 |
12-09-2022, 06:00 | #72765 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Vivo Y20 frp remove done with cm2 Operation: Reset Settings/Format FS [ v2.38c7 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM61) MODE: PRELOADER PORT; PORT: 61 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: Vivo: SEC_MT6765 | Manual: Off [d05d9b7e] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_MT6765\MTK_All InOne_DA.bin [766cb13d] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_MT6765\auth_sv 5.auth Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00040000 [ 256.00 KB ] DRAM 0x30000000 [ 768.00 MB ] EMMC: CID: 15010044483644414202BEC9CEE1A73B VEN: Samsung OEM: 0 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 3200896737 [0xBEC9CEE1] MF: 10/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 03AA39A62FB8F99550382F1AEBD7C4D5 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Reading... Scan memory... Found region: 21660 [12|21660|0] Scan filesystem... Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__03AA39A62FB8F 99550382F1AEBD7C4D5\ [35] Read: NVRAM [10] Read: NVDATA [25] Read: PROINFO [36] Read: LK [9] Read: NVCFG [20] Read: PROTECT1 [1] Read: PGPT [23] Read: PERSIST [0] Read: PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__03AA39A62FB8F 99550382F1AEBD7C4D5\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__03AA39A62FB8F 99550382F1AEBD7C4D5.7z Verified Process: RESET PROTECTION... Format Ok: RESET PROTECTION Done: 00:01:02 Reconnect Power/Cable now |
