01-29-2023, 09:38 | #73201 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | Quote:
01-29-2023, 11:00 | #73202 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Infinix X663 MT6768 FRP/Pattren Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.39a5 Firmware files: G:\Jazz Firmware\Jazz Digit 4G Music\ Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 116 dirs: 1 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... You have latest version [2.39] installed Telegram Channel: @InfinityBox Telegram Group: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM38) MODE: PRELOADER PORT; PORT: 38 Waiting BOOT ack... PRELOADER: ACK confirm FAIL BROM: Init BROM BROM: Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: 0x00007024 : DA SEND ERROR ERROR: SECURE BOOT: SELECTED DA NOT SUPPORTED IN CURRENT DEVICE STATE! PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC Retrieve device config... => Try loaders: 1. 0_base/BASE_v2112/MTK_AllInOne_DA.bin read manual - https://infinity-box.com/?r=100189 get test-point - https://infinity-box.com/?r=100216 Error: Fail to init protocol Disconnect battery and cable - Check USB drivers - Change cable - Change USB port - Do not use USB-hub - Select another base|model|DA Try again Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM161) MODE: BOOTROM; PORT: 161 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 5DB4F1FBECCBD57A4701752810FC83A8 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 00CD9F0453D475DF679998219D62FAD56FBA163B237C6C16AF025B8FF48C9BD1 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v2112 | Manual: Off [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v2112\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 150100445636444142025675F21E8805 VEN: Samsung OEM: 0 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 1450570270 [0x5675F21E] MF: 8/2021 EMI: FireFly preloader_x663_h6915 with 16 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 150100445636444142025675F21E8805 VEN: Samsung OEM: 0 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 1450570270 [0x5675F21E] MF: 8/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x1D1EC00000 [ 116.48 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: E066FE72C00B712EDA0FFC5831AFFC58 MEID: 5DB4F1FBECCBD57A4701752810FC83A8 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6768__5DB4F1FBECCBD57A4701752810FC83A8\ [34] Read: NVRAM [17] Read: NVDATA ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6768__5DB4F1FBECCBD57A4701752810FC83A8\nvdata.bin [3] Read: PROINFO [16] Read: NVCFG [19] Read: PROTECT1 [1] Read: PGPT [18] Read: PERSIST [0] Read: PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__5DB4F1FBECCBD57A4701752810FC83A8\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__5DB4F1FBECCBD57A4701752810FC83A8.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [1] Verified [2] Verified Done: 00:01:16 Reconnect Power/Cable now |
01-29-2023, 11:30 | #73203 (permalink) | |
Member: 1189561 Status: Offline Thanks Meter: 743 | infinix x612b reset frp and patren done king cm2 Quote:
01-29-2023, 13:53 | #73204 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | ITEL A58 A661W PATTERN,,FRP,,IMEI REPAIR DONE Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : A661W Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:24 Operation : Repair Security [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : A661W Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! NVMng : SecurityInfo IMEI[1] : 351............ IMEI[2] : 351............. IMEI[3] : 86740............ WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 New SecInfo : IMEI[1] : 3500................ IMEI[2] : 3500................. NVMng : Item updated! NVMng : Post-Process Ok! Done! Elapsed: 00:00:54 |
01-29-2023, 13:58 | #73205 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Eurostar onyx 2 lte reset frp done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017045434148E21101387BEFBEFF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8ECAH [eMMC] : FLASH_CID : 7001004548414345380111E2FFBEA37B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DE7DAAB8E49BC12EAB927A6C41 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : EUROSTAR ProdName : Onyx-2_LTE ProdModel : Onyx-2+LTE Device : Onyx-2_LTE AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_len6735m.35u.m_P34 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P11_1_lwg _n EXTRA : LCD : Not info available LCD Res : 854x480 TOUCH [0] : ftxxx_m CAM [0] : gc5005_mipi_raw CAM [1] : sp2509_mipi_raw CAM [2] : gc0409_mipi_raw CAM [3] : gc2355_mipi_raw CAM [4] : sp0a09_mipi_raw CAM [5] : gc2365_mipi_raw MODEM : ZH086V20_G4W18L13720_EUROSTAR LOCALE : K_PRODUCT_LOCALES =en_US ru_RU zh_CN zh_TW es_ES pt_BR fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU ar_IL tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4500017045434148E21101387BEFBEFF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8ECAH [eMMC] : FLASH_CID : 7001004548414345380111E2FFBEA37B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DE7DAAB8E49BC12EAB927A6C41 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:48 Reconnect Power/Cable! |
01-29-2023, 13:59 | #73206 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile i6 meatel 2017 reset frp done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D420117CBE478244D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D420117CBE478244D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB9E2EB77200A5215D5AB5ACA854F94C5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
01-29-2023, 14:03 | #73207 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Vivo y65 reset pattern done by cm2 Card found : 73CA70CC , v0154 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 425 [MSM8917] ID_BLOCK_S : 90F08057 ID_BLOCK_L : C01F04DF4ACD0240DC1C5CBE5A41F58E ID_BLOCK_L : A9EE649B6999D86968E51B2483093C7E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GE6BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
01-30-2023, 09:51 | #73208 (permalink) | |
Member: 1189561 Status: Offline Thanks Meter: 743 | jazz digit classic reset codes Quote:
01-30-2023, 09:52 | #73209 (permalink) | |
Member: 1189561 Status: Offline Thanks Meter: 743 | jazz digit classic read firmwear Quote:
01-30-2023, 11:12 | #73210 (permalink) |
Registered User Join Date: Aug 2016 Location: Multan Pakistan
Member: 2608490 Status: Offline Thanks Meter: 921 | Jazz Digit 4G Crown SP Unlock Success By CM2 Identify Code: Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Identify [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9820e_1h10ll_native-user 4.4.4 KTU84P eng.sz1002.20220121.145338 test-keys MemoryInfo : EMMC : 4 MB ; DRAM : 512 MB Platform Version: MOCORTM_19A_W19.39.5_P2_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_19A_W19.39.5_P2 HW Version: sc9820e_modem CMP_Time : 12-04-2019 16:52:39 MODEM TAG : MOCORTM_19A_W19.39.5_P2_Debug_FM_BASE_19A_W19.39.5_P2_sc9820e_modem_sharkle_Feature_Phone PSN1 : 16335194420352 Done! Elapsed: 00:00:33 SP Unlock Code: Operation : SP Unlock [ v2.14 ] BootMode : SVC 1. Power off device, wait 10-15 seconds 2. Not hold any key on device ( OLD devices - 1 : VOL+ , 2 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! SOC GEN : UniSoc ( E-family and Modern ) BuildInfo : sp9820e_1h10ll_native-user 4.4.4 KTU84P eng.sz1002.20220121.145338 test-keys Platform Version: MOCORTM_19A_W19.39.5_P2_Debug Project Version: sharkle_Feature_Phone BASE Version: FM_BASE_19A_W19.39.5_P2 HW Version: sc9820e_modem CMP_Time : 12-04-2019 16:52:39 MODEM TAG : MOCORTM_19A_W19.39.5_P2_Debug_FM_BASE_19A_W19.39.5_P2_sc9820e_modem_sharkle_Feature_Phone NVMng : SecurityInfo IMEI[1] : 3533921xxxxxxxxx IMEI[2] : 3533921xxxxxxxxx WIFIMAC : F05111013997 BT_MAC : B05111013997 SEC : SLS:0, SKS:0, SKV:4 SLStatus : 31 Unlocking device ... Sync data ... Device unlocked! Done! Elapsed: 00:00:21 |
01-30-2023, 12:51 | #73211 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,362 | Nokia C01 Plus TA-1383 password remove done easy method Nokia C01 Plus TA-1383 password remove done easy method no need isp Reset [ALL USER DATA] + [Security Code] but NOT FRP! Continue? Yes Loading config from server... 1. Power device Off 2. Connect cable Looking for device... Device found PTFN: SPRD U2S Diag (COM95) vid:1782 pid:4D00 Enter Diag Mode[1]... Reset Interface... Verify... Diag Mode On Reading... Platform Version: MOCORTM_20A_W21.15.3_P17_Debug Project Version: sharkl3_pub BASE Version: 4G_MODEM_20A_W21.15.3_P17 HW Version: sc9863A_modem 10-29-2021 19:45:33 SW_T19545AA1_V071_M10_NF_NOKIA_Iris_USR_PR1.3 CHIP: SC9863A Done Verify device config... Verified Ok Completed Wipe... Wipe Ok. Device will reboot now... Thanks infinity team |
The Following 2 Users Say Thank You to pintu_das For This Useful Post: |
01-30-2023, 13:27 | #73212 (permalink) |
No Life Poster Join Date: Aug 2020 Location: Mozambique Age: 20
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,193 | KGtel K2190 Format FileSystem Done Code: ard found : S/N : 46828B86 , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0F85D0DDA5FAB473FC8D32A389729154 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x003A7000-0x003FDFFF , LEN : 0x00057000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:55 |
The Following User Says Thank You to tayobjoy1 For This Useful Post: |
01-30-2023, 13:32 | #73213 (permalink) |
Member: 2965136 Status: Offline Sonork: 58846 Thanks Meter: 1,193 | A013G KG Update To Complete Done Code: /SN: 46828B86 v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.39a5 Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 0 dirs: 0 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... You have latest version [2.39] installed Telegram Channel: @InfinityBox Telegram Group: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Operation: Identify Device [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FLASH PORT: BOTH [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] AutoEMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE: BOOTROM; PORT: 5 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: C9DF533E3202F4F220EABEE21637F58BB3815B9ECDFE9D20FD89369BA84AF175 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID: 150100464536324142002816E41C58BB VEN: Samsung OEM: 0 ID: 464536324142 [FE62AB] PRV: 0x00 SNN: 672588828 [0x2816E41C] MF: 5/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 1F5C7CC5A176BDC1841C24189450890B MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE DA: USB: HIGH-SPEED Boot done [1] Reading... Ok SW : samsung/a01corejx/a01core:10/QP1A.190711.020/A013GJXU4AVC5:user/release-keys Product Brand: samsung Product Model: SM-A013G Product Name: a01corejx Product Device: a01core Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020.A013GJXU4AVC5 SW Version: A013GJXU4AVC5 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-01-01 Build Time: 3/10/2022 5:48:03 AM CPU : armeabi-v7a,armeabi Product Info: a01core SW : a01corejx-user 10 QP1A.190711.020 A013GJXU4AVC5 release-keys Product Board: k39tv1_bsp_1g_titan Board Platform: mt6739 Product Manfct: samsung Strategy: 3 Firmware ID: MT6739_samsung_SM-A013G_10_QP1A.190711.020.A013GJXU4AVC5_QP1A.190711.020_a01core Verify firmware [MT6739_samsung_SM-A013G_10_QP1A.190711.020.A013GJXU4AVC5_QP1A.190711.020_a01core]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 NVRAM: TITAN_A01CORE_Q0MP1_K39TV1_BSP_1G_MDBIN_PCB01_MT6739_S00.MOLY_LR12A_R3_TC10_6M_PR_A01_SP_V2_P15 NVRAM: Items: 0xA0 Size: 0x08B8C6 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 000046000001 IMEI[1]: 5FCA600409E0388 IMEI[2]: 3F7888C5EFAA9CF Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE\ [31] Read: NVRAM [12] Read: NVDATA [25] Read: PROINFO ZERO CONTENT file [3.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE\proinfo.bin [34] Read: LK [11] Read: NVCFG [14] Read: PROTECT1 [1] Read: PGPT [17] Read: PERSIST [0] Read: PRELOADER [4] Read: EFS [5] Read: SEC_EFS [18] Read: PERSISTENT Done 11 files Compress: C:\InfinityBox\CM2MT2\backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE.7z Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Scan preloader... Preloader: EMI: MT6739 preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported [00] eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: [ 2.00 GB ] [01] eMMC DDR3 ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: [ 1.00 GB ] [02] eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: [ 2.00 GB ] [03] eMMC DDR3 ID: 150100464536324142 Ven: Samsung | Dev: FE62AB RAM: [ 1.00 GB ] [04] eMMC DDR3 ID: 150100514536334242 Ven: Samsung | Dev: QE63BB RAM: [ 2.00 GB ] [05] eMMC DDR3 ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: [ 2.00 GB ] [06] eMMC DDR3 ID: 150100515836334D42 Ven: Samsung | Dev: QX63MB RAM: [ 2.00 GB ] Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k39tv1_bsp_1g_titan.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k39tv1_bsp_1g_titan.bin [fe86ad9a]... Exist Done: 00:01:22 Code: Operation: Bootloader unlock [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE: BOOTROM; PORT: 5 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: C9DF533E3202F4F220EABEE21637F58BB3815B9ECDFE9D20FD89369BA84AF175 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID: 150100464536324142002816E41C58BB VEN: Samsung OEM: 0 ID: 464536324142 [FE62AB] PRV: 0x00 SNN: 672588828 [0x2816E41C] MF: 5/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 1F5C7CC5A176BDC1841C24189450890B MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE DA: USB: HIGH-SPEED Boot done [1] Reading... Ok SW : samsung/a01corejx/a01core:10/QP1A.190711.020/A013GJXU4AVC5:user/release-keys Product Brand: samsung Product Model: SM-A013G Product Name: a01corejx Product Device: a01core Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020.A013GJXU4AVC5 SW Version: A013GJXU4AVC5 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-01-01 Build Time: 3/10/2022 5:48:03 AM CPU : armeabi-v7a,armeabi Product Info: a01core SW : a01corejx-user 10 QP1A.190711.020 A013GJXU4AVC5 release-keys Product Board: k39tv1_bsp_1g_titan Board Platform: mt6739 Product Manfct: samsung Verify device config... Ok Loaders Ok Bootloader State: Locked Bootloader State: Unlocked Done: 00:00:25 Code: Operation: Memory Tool Init [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE: BOOTROM; PORT: 5 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: C9DF533E3202F4F220EABEE21637F58BB3815B9ECDFE9D20FD89369BA84AF175 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID: 150100464536324142002816E41C58BB VEN: Samsung OEM: 0 ID: 464536324142 [FE62AB] PRV: 0x00 SNN: 672588828 [0x2816E41C] MF: 5/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 1F5C7CC5A176BDC1841C24189450890B MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Reading... MemTool storage: C:\InfinityBox\CM2MT2\phdata\ Ready Code: MemoryTool Operation: RPMB : Read Wait... RPMB: WriteCounter : 0x000227E4 Read... Read partition: Ok File Size: 0x01000000 File: C:\InfinityBox\CM2MT2\backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE\rpmb.bin Operation finished Code: MemoryTool Operation: RPMB : Erase Wait... WARNING! Write or Erase operation(s) may brick device! Make sure you select correct partitions and data! Continue? Yes RPMB: WriteCounter : 0x000227E4 Erase... Erase partition Ok Operation finished Code: MemoryTool Operation: RPMB : Write Wait... WARNING! Write or Erase operation(s) may brick device! Make sure you select correct partitions and data! Continue? Yes RPMB: WriteCounter : 0x000327E4 File Size: 0x01000000 File: C:\InfinityBox\CM2MT2\Backup\MT6739__FCDFF4173F28AB91A11AB8A5EFAFC3EE\rpmb.bin Write... Write partition Ok Operation finished Close MemoryTool session Done: 00:02:15 Code: Operation: Change KG state [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE: BOOTROM; PORT: 5 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: C9DF533E3202F4F220EABEE21637F58BB3815B9ECDFE9D20FD89369BA84AF175 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID: 150100464536324142002816E41C58BB VEN: Samsung OEM: 0 ID: 464536324142 [FE62AB] PRV: 0x00 SNN: 672588828 [0x2816E41C] MF: 5/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 1F5C7CC5A176BDC1841C24189450890B MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Strategy: 3 Knox Guard [KG]: State is Prenormal Update to Completed State change Ok Done: 00:00:28 Code: Operation: Bootloader lock [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE: BOOTROM; PORT: 5 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: C9DF533E3202F4F220EABEE21637F58BB3815B9ECDFE9D20FD89369BA84AF175 BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMI: FireFly preloader_k39tv1_bsp_1g_titan.bin with 7 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: CID: 150100464536324142002816E41C58BB VEN: Samsung OEM: 0 ID: 464536324142 [FE62AB] PRV: 0x00 SNN: 672588828 [0x2816E41C] MF: 5/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 1F5C7CC5A176BDC1841C24189450890B MEID: FCDFF4173F28AB91A11AB8A5EFAFC3EE DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Lock BootLoader ... BootLoader State: Locked |
01-30-2023, 14:13 | #73214 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Qmobile i10 reset frp done by cm2 Card found : 73CA70CC , v0154 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:18 |
01-30-2023, 14:21 | #73215 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,772 | Infinix x650c reset frp done by cm2 S/N: 73CA70CC v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.39a5 Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 0 dirs: 0 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... You have latest version [2.39] installed Telegram Channel: @InfinityBox Telegram Group: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.39a5 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM10) MODE: BOOTROM; PORT: 10 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] MEID: B95347D412F22213F2B1D2D782C27652 BROM: Sec Level: 0x00000005 Mode: SBC+SDA BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x00000001 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND eMMC: OK eMMC: 510001154D3336446E380142CFC6DEF2 DAInf: v4.2.156 DA: EXT_RAM NOT initialized eMMC: OK eMMC: 150100514436334D4201386EF2DEC6CF NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_x650_h8029.bin with 7 memory type(s) supported [00] ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: [ 0 B ] [01] ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: [ 0 B ] [02] ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: [ 2.00 GB ] [03] ID: 700100464D41454538 Ven: Kingston | Dev: FMAEE8 RAM: [ 1.00 GB ] [04] ID: 700100464D42434541 Ven: Kingston | Dev: FMBCEA RAM: [ 0 B ] [05] ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: [ 0 B ] [06] ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: [ 0 B ] EMI: Init EMI from PRELOADER INIT: 0xBC DRAM [ 0x00000000 [ 0 B ] ] DRAM: DRAM: 0x80000000 [ 2.00 GB ] DA: DRAM ready DA: BOOT to 2nd DA... DA: Receiving HW info EMMC: CID: 150100514436334D4201386EF2DEC6CF VEN: Samsung OEM: 0 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 946795230 [0x386EF2DE] MF: 12/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x747C00000 [ 29.12 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 6AAB21F04522591E9C9311E2E6967DF8 MEID: B95347D412F22213F2B1D2D782C27652 DA: STATUS: BLANK FLASH; BSTYLE: EMMC FLASH BOOT DA: USB: FULL-SPEED DA: USB: Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM15) MODE: PRELOADER PORT; PORT: 15 Boot done [0] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6580__B95347D412F22 213F2B1D2D782C27652\ [19] Read: NVRAM [13] Read: NVDATA [2] Read: PROINFO [15] Read: LK [9] Read: PROTECT1 [11] Read: PERSIST [0] Read: PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6580__B95347D412F22 213F2B1D2D782C27652\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6580__B95347D412F22 213F2B1D2D782C27652.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified Done: 00:01:03 Reconnect Power/Cable now |
