02-24-2023, 13:30 | #73426 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel L6503 frp remove done Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Itel : L6503 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
02-24-2023, 15:31 | #73427 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Calme cl66 reset password done by cm2 Card found : 73CA70CC , v0154 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version(Auto): SC6531EFM_BAR SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : 820415104301 Done! Elapsed: 00:00:22 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
02-24-2023, 15:35 | #73428 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Tecno camon 19 reset frp done by cm2 S/N: 73CA70CC v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.40a3 Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 2 dirs: 0 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... Infinity Chinese Miracle-2 #CM2MT2 v2.42 Required firmware v0154 Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM10) MODE: BOOTROM; PORT: 10 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 7ECFB91F5053B12B27ECF6B7898C05E4 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 878DCED770834D858277416485FE7400BA4A11D185A27DBC2A 65F627C7083FFD BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: FF : Look for EMI BROM: FF : EMI found BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: BASE_v1712 | Manual: Off [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\BASE_v1712\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... CHANGE: v2216 Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 1501003356364342420285D7D4122909 VEN: Samsung OEM: 0 ID: 335636434242 [3V6CBB] PRV: 0x02 SNN: 2245514258 [0x85D7D412] MF: 2/2022 EMI: FireFly preloader_ch6i_h6921.bin with 1 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID: 1501003356364342420285D7D4122909 VEN: Samsung OEM: 0 ID: 335636434242 [3V6CBB] PRV: 0x02 SNN: 2245514258 [0x85D7D412] MF: 2/2022 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0x1D1EC00000 [ 116.48 GB ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: EE6474D6DDA750DE58BEB445930513F0 MEID: 7ECFB91F5053B12B27ECF6B7898C05E4 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6768__7ECFB91F5053B 12B27ECF6B7898C05E4\ [36] Read: NVRAM [19] Read: NVDATA [3] Read: PROINFO [18] Read: NVCFG [21] Read: PROTECT1 [1] Read: PGPT [20] Read: PERSIST [0] Read: PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__7ECFB91F5053B 12B27ECF6B7898C05E4\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__7ECFB91F5053B 12B27ECF6B7898C05E4.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified [1] Verified [2] Verified Done: 00:00:47 Reconnect Power/Cable now |
02-24-2023, 15:39 | #73429 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel new 7 reset frp done by cm2 S/N: 73CA70CC v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.40a3 Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 3 dirs: 0 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... Infinity Chinese Miracle-2 #CM2MT2 v2.42 Required firmware v0154 Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (COM11) MODE: PRELOADER PORT; PORT: 11 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN BROM: BROM|BL : 0xFF|0x01 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND eMMC: OK eMMC: 44000145313034465B7F0136B5460CAC DAInf: v4.2.156 DA: DRAM ready DA: BOOT to 2nd DA... DA: Receiving HW info EMMC: CID: 450100444634303136017F5BAC0C46B5 VEN: Sandisk OEM: 0 ID: 444634303136 [DF4016] PRV: 0x01 SNN: 2136714252 [0x7F5BAC0C] MF: 4/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: F6726634512C7DEFEABB9E81596948B3 DA: STATUS: BLANK FLASH; BSTYLE: EMMC FLASH BOOT DA: USB: HIGH-SPEED Boot done [0] Reading... Ok Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6580__F6726634512C7 DEFEABB9E81596948B3\ [3] Read: NVRAM [20] Read: NVDATA [2] Read: PROINFO [8] Read: LK [4] Read: PROTECT1 [6] Read: PERSIST [0] Read: PRELOADER Done 7 files Compress: C:\InfinityBox\CM2MT2\backup\MT6580__F6726634512C7 DEFEABB9E81596948B3\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6580__F6726634512C7 DEFEABB9E81596948B3.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified Done: 00:00:49 Reconnect Power/Cable now |
02-25-2023, 06:41 | #73430 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S6 Plus MT6580 FRP/Pattren Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D4207B894D48793FF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D4207B894D48793FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395500E584A7B37A420BE750E25 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:01:00 Reconnect Power/Cable! |
02-25-2023, 07:05 | #73431 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile i8i 2018 hnag on logo done With cm2 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:22 |
02-25-2023, 08:00 | #73432 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | tecno pop 3 frp remove done Operation: Reset Settings/Format FS [ v2.42 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM240) MODE: PRELOADER PORT; PORT: 240 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init... Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port_V1632 (COM30) MODE: BOOTROM; PORT: 30 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] MEID: 00324E696CB1D8B508538F0018DC3CC5 BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x00000001 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D32364548FF0342C33771D3 DA v4.2.156 DA: EXT_RAM NOT initialized EMMC: OK CID: 150100464536324D4203FF48D37137C3 NAND: DEVICE NOT FOUND DRAM: 0x00BC EMI: FireFly preloader_k80_bsp.bin with 3 memory type(s) supported 1. ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: 1.00 GB 2. ID: 700100464D41454538 Ven: Kingston | Dev: FMAEE8 RAM: 1.00 GB 3. ID: 150100464536324142 Ven: Samsung | Dev: FE62AB RAM: 1.00 GB EMI: Init EMI by PRELOADER INIT: 0xBC DRAM [ 0x00000000 [ 0 B ] ] DRAM: DRAM: 0x40000000 [ 1.00 GB ] DA: DRAM ready Boot to 2nd DA... Load HW info... EMMC CID: 150100464536324D4203FF48D37137C3 VEN: Samsung OEM: 0 ID: 464536324D42 [FE62MB] PRV: 0x03 SNN: 4282962801 [0xFF48D371] MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 96E1E66B083B7B0B52F6BBB1A7DBAED6 MEID: 00324E696CB1D8B508538F0018DC3CC5 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM59) MODE: PRELOADER PORT; PORT: 59 Boot done [0] Reading... Ok Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6580__00324E696CB1D 8B508538F0018DC3CC5 [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Verified Done: 00:00:26 Reconnect Power/Cable now |
02-25-2023, 08:41 | #73433 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A5s Smart Reset done With king cm2 Operation: Reset Settings/Format FS [ v2.42 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM30) MODE: BOOTROM; PORT: 30 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 9621BAF3660409C104AFF6B95FBC7F38 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 259E811D82430987B2DBBC97C74AD2E2DE3D3935D13DE5746F B5A2E704725689 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth FF: Looking for EMI FF: EMI found SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100474436424D420191D86A84B6F1 VEN: Samsung OEM: 0 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2446879364 [0x91D86A84] MM/YY: 11/2019 EMI: Init EMI by INTERNAL Database EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s) supported 1. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 GB 2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 GB 3. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 GB 4. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 GB 5. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 GB 6. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 GB 7. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 GB 8. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 GB 9. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 GB EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC CID: 150100474436424D420191D86A84B6F1 VEN: Samsung OEM: 0 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2446879364 [0x91D86A84] MM/YY: 11/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x747C00000 [ 29.12 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 15B776022BAC63D6D46D507BA4F4ECE1 MEID: 9621BAF3660409C104AFF6B95FBC7F38 USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 8 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup [20] to C:\InfinityBox\CM2MT2\backup\MT6765__9621BAF366040 9C104AFF6B95FBC7F38\ [27] Read: NVRAM [11] Read: NVDATA [18] Read: PROINFO [28] Read: LK [10] Read: NVCFG [13] Read: PROTECT1 [1] Read: PGPT [16] Read: PERSIST [0] Read: PRELOADER [7] Read: OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__9621BAF366040 9C104AFF6B95FBC7F38\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__9621BAF366040 9C104AFF6B95FBC7F38.7z Verified [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Verified [1] Verified [2] Verified Done: 00:02:59 Reconnect Power/Cable now |
02-25-2023, 13:10 | #73434 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Realme C25 Smart Reset Done Operation: Reset Settings/Format FS [ v2.43a2 ] Platform: FireFly SmartPhone - MT6580/6735-39|52|53|61-65|68|71/6983, Helio G/P Format: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM25) MODE: PRELOADER PORT; PORT: 25 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init... Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] PTFN: MediaTek USB Port_V1633 (COM13) MODE: BOOTROM; PORT: 13 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 23867102EC55B8F54B1ACD7207072C02 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 64F770CD189E1D520D03FF3529A6F003ED6DC2E5779CA20334 CC2C72BA983652 Sending FireFly... FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running: v06.05.06 on MT6768 eMMC init passed Stored: C:\InfinityBox\CM2MT2\backup\EXT_CSD\MT6768__Micro n_G1J9S9_5.1_extcsd_25022023.bin EMMC CID: 13014E47314A39533910101654EE28BF VEN: Micron OEM: 78 ID: 47314A395339 [G1J9S9] PRV: 0x10 SNN: 269898990 [0x101654EE] MM/YY: 2/2021 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] USER: 0x1D1F000000 [ 116.48 GB ] CSD: D04F01328F5913FFFFFFFFEF8A400083 TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 [CONFIG]: 0x48 0x02 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 128 GB [SIZE]: Actual: 0x1D1F000000 [ 116.48 GB ] [EOL]: EOL status : Normal ( Less than 80% reserved blocks used ) [EOL_A]: SLC status : 0% - 10% used [EOL_B]: MLC status : 0% - 10% used USB: HIGH-SPEED Boot done [3] Reading... Ok SmartInfo: AndroidVer: 12 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Process: USERDATA... Format Ok: USERDATA Done: 00:02:48 Reconnect Power/Cable now |
02-25-2023, 15:10 | #73435 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Infinix x653c reset frp done by cm2 S/N: 73CA70CC v0154 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.40a3 Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 3 dirs: 0 Build device list... Init environment... Load IDBase v124493 Ok Check for updates... Infinity Chinese Miracle-2 #CM2MT2 v2.42 Required firmware v0154 Update configuration... Configuration [12170] updated Load IDBase v124493 Ok Operation: Reset Settings/Format FS [ v2.40a3 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM10) MODE: BOOTROM; PORT: 10 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init BROM BROM: Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 0A4F096362998FE2A78EDCED4E2C5578 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT BROM: BROM|BL : 0x05|0xFE [BOOTROM] BROM: SOCID: 781E1D550335A2ECA1C67A76B7052F35835E0BDC9CCBE5F8BD 91E91E4549F9DC BROM: SLA: Local Auth BROM: SLA: Starting Auth BROM: SLA: Auth Passed BROM: SEC: 0x000000E0 AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: BROM DA: EXT_RAM NOT initialized EMMC: CID: 700100464D424345412022038CD3A611 VEN: Kingston OEM: 0 ID: 464D42434541 [FMBCEA] PRV: 0x20 SNN: 570658003 [0x22038CD3] MF: 10/2019 EMI: FireFly preloader_x653c_h6114go.bin with 14 memory type(s) supported EMI: Init EMI from INTERNAL DB EMI: EXT_RAM CFG Passed DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM: 0x0003A500 [ 233.25 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: CID: 700100464D424345412022038CD3A611 VEN: Kingston OEM: 0 ID: 464D42434541 [FMBCEA] PRV: 0x20 SNN: 570658003 [0x22038CD3] MF: 10/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x74A000000 [ 29.16 GB ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: FF9EB23CC5C7435A500720327EAB8A92 MEID: 0A4F096362998FE2A78EDCED4E2C5578 DA: USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 9 UserDataFS: 0x03 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__0A4F096362998 FE2A78EDCED4E2C5578 [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Verified [1] Verified [2] Verified Done: 00:00:34 Reconnect Power/Cable now |
02-25-2023, 15:12 | #73436 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgotel s20 read password done by cm2 Card found : S/N : 73CA70CC , v0154 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 9 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 5B3129363734C06A1A2ED878CC4FB7CB BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00396000-0x003FDFFF , LEN : 0x00068000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
02-25-2023, 18:39 | #73437 (permalink) |
Banned Join Date: Oct 2016 Location: In Your Heart
Member: 2636401 Status: Offline Thanks Meter: 2,332 | Itel Vision 1 Pro Reset Frp Just One Click With KING CM2 Card found : 768E9180 , v0154 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Open : L6502-F3208-10.0-IN-V020-20201012_1434_user.pac VER : BP_R1.0.0 LEN : 3.10 GiB CPU : sp9832e_1h10 VER : L6502-F3208-10.0-IN-V020-20201012_1434-user Reading package ... Read package finished! Product Brand : Itel Product Device : L6502 Product Model : itel L6502 Product Name : L6502 Patch Level : QP1A.190711.020 Display ID : L6502-F3208-10.0-IN-V020-20201012 Ver. Incmt : IN-V020-20201012 Ver. CodeName : REL Ver. Release : 10 Sec. Patch : 2020-09-01 Build Time : 12.10.2020 Product Name : F3208 Product Device : itel-L6502 Product Info : L6502 Product Board : L6502 Board Platform : sp9832e Product Manfct : itel Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : L6502-F3208-10.0-IN-V020-20201012_1434_user.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:34 |
The Following User Says Thank You to kk3 For This Useful Post: |
02-26-2023, 04:55 | #73438 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pakistan
Member: 1189561 Status: Offline Thanks Meter: 743 | Wait for phone... Phone found! [ 31 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : AE32F37CDDB56097ADDE325C5CC88A77 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:17 Reconnect Power/Cable! Finish at : [25/02/2023 / 6:41:26 pm] |
02-26-2023, 05:06 | #73439 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM15) MODE : BOOTROM PORT : 15 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN [RAPHAEL] BROM : MEID : 9D17E1C22E1889F0CB369FE8D65CEB61 BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 9470D9DF184BAF85B46E2285A26405A0BE825700D2734F8060 D21D9C4EDEE3C5 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : FF : Look for EMI BROM : FF : EMI found! BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_x695_h854.bin EMI : CNT : 000A EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: AD014839485131354146414D42444152 UFS: VEN : 0x01AD VID : H9HQ15AFAMBDAR IFW : A002 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 2000e70aeaa0000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E18267C5502BF90C38E32DEADA0A4ED4 DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x835657 Format Ok : RESET PROTECTION Format Ok : USERDATA Format Ok : USERDATA Format Ok : USERDATA Done! Elapsed: 00:00:20 |
02-26-2023, 05:07 | #73440 (permalink) |
Member: 1189561 Status: Offline Thanks Meter: 743 | [FL] : Total size : 0x14E541764 [ 5.22 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM17) MODE : BOOTROM PORT : 17 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Talbot TYPE : MODERN [RAPHAEL] BROM : MEID : 2FE0A315D8CD98F780047BEE5505FB0D BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : E5E834817D7817EE3CE648CC9D8DD6D41177C0332C17F5E4E4 CC7E2C4198F507 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2044 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6768 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_x682c_h694.bin EMI : CNT : 000E EMI : [00] : eMMC : LP_DDR4X : ID : 90014A684445615033 : VEN : HYNIX | DEV : hDEaP3 : RAM : [ 6.00 GB ] EMI : [01] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 3.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 90014A684339615033 : VEN : HYNIX | DEV : hC9aP3 : RAM : [ 4.00 GB ] EMI : [03] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100445036384D42 : VEN : SAMSUNG | DEV : DP68MB : RAM : [ 3.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100445636444142 : VEN : SAMSUNG | DEV : DV6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 150100445036444142 : VEN : SAMSUNG | DEV : DP6DAB : RAM : [ 4.00 GB ] EMI : [09] : eMMC : LP_DDR4X : ID : 13014E47314A395339 : VEN : MICRON | DEV : G1J9S9 : RAM : [ 4.00 GB ] EMI : [0A] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 150100335636434142 : VEN : SAMSUNG | DEV : 3V6CAB : RAM : [ 6.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC: CID : 13014E47314A395339100927600B87E7 EMMC: VEN : MICRON : OEM : 78 : ID : 47314A395339 EMMC: VEN : MICRON : G1J9S9 EMMC: SNN : 153575435 ( 0x0927600B) , MF : 8/2020 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x1D1F000000 [ 116.48 GB ] CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000 RNID : BE49C76B9F6BDA8B247C684715922771 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000001A08000 Erase : 0x0000000001D08000 : 0x0000000004C1A000 Erase : 0x0000000008922000 : 0x0000000004000000 Erase : 0x0000000010922000 : 0x000000000DFDE000 Erase : 0x0000000022900000 : 0x0000000247F00000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : TKV Write : RECOVERY Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : LOGO Write : BOOT Write : DTBO Write : TEE1 Write : TEE2 Write : VBMETA Write : VBMETA_SYSTEM Write : VBMETA_VENDOR Write : SUPER Write : CACHE Write : TRANFS Write : USERDATA UltraFlash : OK! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:21 |
