08-09-2009, 09:21 | #721 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 38
Member: 171512 Status: Offline Thanks Meter: 1,034 | COM3 [VCP0] selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:6A41:64C8 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.87, database date: 30.07.2009): HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_08B _W09_08_MP_V2.BIN ver. sw 2: MAUI.08B.W09.08.MP.V2, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98004900000002:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 143 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
08-09-2009, 10:44 | #722 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Sanyo-S750 unlocked COM13 [JWMDM-VID_0474&PID_0708&MDM-0] selected Device: Sanyo-S750 Checking data, wait... Action: unlock Connect... Phone must be Powered-On Connect Done Read phone info... software compiled: Feb 19 200510:03:47 software released: Feb 19 200507:40:00 software version: TMQZ Feb build id: 2.130 imei: 353845005231221 Read phone info Done Verify access... Verify access Done Decode data... file saved: C:\Program Files\InfinityBox\QCModule\sanyo_s750_log_35384500 5231221_20090809-024002.B2X.bin Decode data Done Finished, time used: 32 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
08-09-2009, 13:04 | #723 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Samsung B309 unlock success Just Unlocked 10 units. Infintity software works perfact. Code: COM7 [VCP0] selected module v1.08 Device: Samsung-SCH-B309 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1/1 done step-1/2 done step-1/3 done step-1/4 done step-1/5 done step-2 done step-3 done operation finished Finished, time used: 26 sec Remove/Install battery now ! Regards: KK Mobile |
The Following User Says Thank You to KK Mobile For This Useful Post: |
08-09-2009, 17:40 | #724 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 57
Member: 78744 Status: Offline Thanks Meter: 29 | unlock alcatel s210 COM7 [VCP0] selected module v1.34 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090809-183750.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 80 sec Remove/Install battery now ! |
The Following User Says Thank You to mosbah For This Useful Post: |
08-09-2009, 18:23 | #726 (permalink) |
Banned Join Date: Mar 2008 Location: PLANET GSM
Member: 717046 Status: Offline Thanks Meter: 237 | Good unlock sfr 341 noir COM14 [VCP0] selected module v2.83 Operation: déverrouiller méthode déverrouillage: Smart rapide Modèle: SFR-341 Contrôle des données, attendre ... téléphone doit être éteint! Appuyez et restez appuiez sur le bouton "Power" dès maintenant! 19200 autodetect Initialisation [6225:8A03:8A00]... CPU: MT6225 chip: 0001:8B03:0000 status: FF Connecting at 19200, wait... lachez bouton d'alimentation maintenant! Téléphone détecté, attendre ... Matériel: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: X760_Z3_EFPSY_B07A106 Version: ZTEMT25_07A_HW_A 44 byte(s) read IMEI: 356720020¤¤¤¤¤ connexion Ok 157 byte(s) read lecture des données en cours ... reading data #2... la construction de nouvelles données ... écriture de données ... 145 byte(s) read lecture des données en cours ... la construction de nouvelles données ... écriture de données ... verifying... vérification Ok bien Terminé, temps utilisé: 16 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to nejm For This Useful Post: |
08-10-2009, 04:23 | #727 (permalink) |
No Life Poster Join Date: Apr 2007 Location: United Harvard Paris Age: 34
Member: 492345 Status: Offline Sonork: 100.1594007 Thanks Meter: 161 | Alcatel OT-363 Unlocked Succes! I Love you Infinity! this phone is lock from Orange: Heres the Instructions that i followed: Code: How to make sp-unlock: 1. download "simfree" firmware from support area 2. go to software "Flash" page 3. load "simfree" flash file 4. make "format ffs" box checked 5. flash phone with "simfree" firmware 6. if phone can not Power-On: make "Format ffs" in "complete" mode 7. if phone can not Power-On: make "Repair security area" operation 8. if phone has problems with LCD: select newer firmware for flashing (select by date) How to write flash: 1. make full flash backup before any operation for emergency case ! 2. select firmware and write flash 3. press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format 4. if phone can not Power-On: make "Format ffs" in "complete" mode 5. if phone can not Power-On: make "Repair security area" operation 6. if phone has problems with LCD: select newer firmware for flashing (select by date) Bucking up in progress: Flashing Simfree file in progress: Flashing Done (Take a look my settings) : Whaaaaaaaaa!....... my phone is Dead when i try to switch on!... hehehehehe... Don't panic guys..... as what i mentioned above the Instructions from Lovely Infinity Team.... Code: 1. make full flash backup before any operation for emergency case ! 2. select firmware and write flash 3. press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format 4. if phone can not Power-On: make "Format ffs" in "complete" mode 5. if phone can not Power-On: make "Repair security area" operation And heres the full logs: Code: ==== log opened: [8/10/2009 8:50:56 AM] ==== Application: G:\CrUel_AttAcK\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v2.83 S/N: Euan Wait... Device: Alcatel-363X Done ==== log: [8/10/2009 8:51:18 AM] ==== COM7 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\id.DCDE2812.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_92EE7E58].rpl ==================== New firmware detected (v.2.83, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: DCDE2812 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, A781116D ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__fullflash_part_1_of_1... file saved: C:\Documents and Settings\Euan\Desktop\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__fullflash_part_1_of_1_20090810-090257.B0X.bin file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_92EE7E58_20090810-090346.B0X.bin Finished, time used: 730 sec Remove/Install battery now ! ==== log: [8/10/2009 9:04:08 AM] ==== COM7 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: read ffs/eeprom Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\id.DCDE2812.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_92EE7E58].rpl ==================== New firmware detected (v.2.83, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: DCDE2812 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, A781116D ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__ffs... file saved: C:\Documents and Settings\Euan\Desktop\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__ffs_20090810-090732.B0E.bin file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_92EE7E58_20090810-090739.B0X.bin Finished, time used: 205 sec Remove/Install battery now ! ==== log opened: [8/10/2009 9:20:38 AM] ==== Application: G:\CrUel_AttAcK\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] MModule v2.83 S/N: 3D0F:0112 Wait... Device: Alcatel-363X Done Loading file v.04... 363X-2AALCN1-230_XI23BJ00_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9_2009-03-05_En_CnS_CnT_simfree.B0M.bin loaded identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, 14DB5C7E Loaded file w/protection: security area (code #1) ==== log: [8/10/2009 9:22:17 AM] ==== COM7 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware 363X-2AALCN1-230_XI23BJ00_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9_2009-03-05_En_CnS_CnT_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\id.DCDE2812.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_92EE7E58].rpl ==================== New firmware detected (v.2.83, database date: unknown): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: DCDE2812 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, A781116D ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... security area (code #1) check... security area (code #1) calculation... security area (code #1) fixed file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_92EE7E58_20090810-092314.B0X.bin Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CI23BJ00 done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... error: security area (code #3, part #1) size is incorrect: 01C0 instead of 0374 Write Done Finalization ... formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_92EE7E58_20090810-093352.B0X.bin Finished, time used: 674 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! How to make sp-unlock: 1. download "simfree" firmware from support area 2. go to software "Flash" page 3. load "simfree" flash file 4. make "format ffs" box checked 5. flash phone with "simfree" firmware 6. if phone can not Power-On: make "Format ffs" in "complete" mode 7. if phone can not Power-On: make "Repair security area" operation 8. if phone has problems with LCD: select newer firmware for flashing (select by date) How to write flash: 1. make full flash backup before any operation for emergency case ! 2. select firmware and write flash 3. press and hold phone "Power" button for a long time (up to 1-2 min) to make phone Powered-On after flash/format 4. if phone can not Power-On: make "Format ffs" in "complete" mode 5. if phone can not Power-On: make "Repair security area" operation 6. if phone has problems with LCD: select newer firmware for flashing (select by date) WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [8/10/2009 9:52:52 AM] ==== COM7 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\id.DCDE2812.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_81A324EB].rpl identification#1 detection finished device-id: DCDE2812 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, 14DB5C7E ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_81A324EB_20090810-095359.B0X.bin Finished, time used: 62 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [8/10/2009 9:57:14 AM] ==== COM7 [VCP0] selected module v2.83 Device: Alcatel-363X Checking data, wait... advanced flash detection enabled Action: repair security area Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:9F73:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\id.DCDE2812.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN_81A324EB].rpl identification#1 detection finished device-id: DCDE2812 identification#1 protocol ver: 05 ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V9, 14DB5C7E ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 security area (code #1) check... security area (code #1) fixed detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: disabled security area (code #3, part #2) calculation... customization: CI23BJ00 done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000001:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done file saved: G:\CrUel_AttAcK\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_SP1_V9__system_log_DCDE2812_81A324EB_20090810-095926.B0X.bin Finished, time used: 129 sec Remove/Install battery now ! And heres the finished Product: TM simcard: Talk en Text simcard: The simfree file that i used: (you can download it from support site) 363X-2AALCN1-230_XI23BJ00_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V9_2009-03-05_En_CnS_CnT_simfree.B0M.bin Heres the full buck up readed from infinity software: http://www.uploadmb.com/dw.php?id=1249871690 heres the eeprom also readed from infinity: http://www.uploadmb.com/dw.php?id=1249873685 at the back label: Bluetooth QD ID B013793 OT-363 TCT Mobile Limited N 269- 9GAB 09 RJS 363X-2ARGFR1 BR Euan From Free Country |
The Following 2 Users Say Thank You to Euan For This Useful Post: |
08-10-2009, 05:58 | #728 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.35 Device: Motorola-C168 "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 406250 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1490-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20090810-105432.69E.bin reading Motorola-C168_ffs... file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20090810-105527.69E.bin Read data done Check data ... Check data done Write ... flash: 89886400010001:89886400000000 Erase: ffs Write done Finished, time used: 83 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to cel_phon For This Useful Post: |
08-10-2009, 06:06 | #729 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM3 [VCP0] selected module v1.35 Device: Motorola-C168 "advanced chip detection" active Action: flash write "format ffs" active write: Firmware C168_Main_9-1490-000.69M.bin skip: Flex/Customization skip: Language Pack skip: FFS/File system skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 406250 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 1490-000 software version: TCT-9- Check hardware done Read data ... reading Motorola-C168_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_eeprom_calibration-1_20090810-110031.69E.bin reading Motorola-C168_ffs... file saved: C:\Program Files\InfinityBox\HModule\Motorola-C168_ffs_20090810-110125.69E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware flash: 89886400000000:89886400000000 Erase: ffs ffs format done Write done Finished, time used: 271 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
08-10-2009, 06:56 | #731 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 399228 Status: Offline Thanks Meter: 66 | Micromax X414 user code successfully removed by infinity Micromax X414 user code sucessfully removed by infinity.Simply formatted phone in safe mode. Here is detail of X414. Cpu type : MT6225 Connector type: 1x18 Pinouts : Rx :14 , Tx :13. Image of phone in attachment. Flashbackup sent to support. Hope this model will get supported by infinity team. |
The Following User Says Thank You to amit_varietymob For This Useful Post: |
08-10-2009, 07:53 | #733 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6303:0004 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: MAUI.GEMINI.W08.12 Version: KCM25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35356201004332 connection Ok detecting structure #5 (mode-4)... 0 2 3 4 5 7 8 9error: detection failed (8 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! |
08-10-2009, 08:07 | #734 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | sandas p908 repaie ok COM3 [VCP0] selected module v2.87 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:F3C1:F856 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B9FDE374.[SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN_104FDD37].rpl identification#1 detection finished device-id: B9FDE374 identification#1 protocol ver: 04 ver. sw 1: SKYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_ 16_MP_V7.BIN ver. sw 2: MAUI.05C.W06.16.MP.V7, C822B0EF ffs offset/size: 00F00000/00100000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00F00000 flash: 98004900000002:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:29EA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\S KYWORTH26_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_1 6_MP_V7__system_log_B9FDE374_104FDD37_20090810-111302.B0X.bin Finished, time used: 144 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-10-2009, 11:41 | #735 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM7 [VCP0] selected module v2.87 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:B903:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.06B.W07.12.21 Version: MTK25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35830801161671 connection Ok building list... done items to clear: 199 warning: wrong packet cs items cleared: 199 of 199 building list... done items remains: 0 Finished, time used: 35 sec Remove/Install battery now ! |
