Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #73966 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Tecno bd4 reset frp done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BD4_Pop-5-LTE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
![]() | #73967 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Oppo a37 reset frp done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2687E70E ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159 ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
![]() | #73968 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile e6 codeunlock done Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : BF7275DBE214AE9710DFD463A96AEC74 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
![]() | #73969 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile e6 formate done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 30 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : BF7275DBE214AE9710DFD463A96AEC74 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x003B5000-0x003FFFFF , LEN : 0x0004B000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
![]() | #73970 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel s12 format done with cm2 Reset Mode: Safe (OnDevice) FactoryReset via WIPE and reset FRP Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FULL FACTORY: WIPE + FRP Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting BOOT ACK... PRELOADER: ACK Ok BROM: Init... Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\Program Files\cm2\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D32584EDB900142DF645ADA DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100464E58324D420190DBDA5A64DF VEN: Samsung OEM: 256 ID: 464E58324D42 [FNX2MB] PRV: 0x01 SNN: 2430327386 [0x90DBDA5A] MM/YY: 6/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00080000 [ 512.00 Kb ] USER: 0x1D2000000 [ 7.28 Gb ] SRAM: 0x00020000 [ 128.00 Kb ] DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 503DAD80B93E5F02B6A57D3BE939AE16 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done [Legacy] Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Select info source... Ok Patch Level: NRD90M SW Version: 1509606329 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-09-05 Build Time: 11/2/2017 7:05:27 AM Product Model: itel S12 Product Brand: Itel Product Name: I805 Product Device: itel-S12 CPU: armeabi-v7a,armeabi Product Manfct: itel Board Platform: mt6580 Product Info: S12 SW: S12-user 7.0 NRD90M 1509606329 release-keys Display ID: S12-I805-7.0-OP-V033-20171102 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\Program Files\cm2\CM2MT2\backup\MT6580__503DAD80B93E5F02B6 A57D3BE939AE16\ Items to check: 20 Read [3] NVRAM Read [16] NVDATA Read [2] PROINFO Read [7] LK Read [4] PROTECT1 lda-pt: pgpt Read [0] PRELOADER Done 6 files Compress: C:\Program Files\cm2\CM2MT2\backup\MT6580__503DAD80B93E5F02B6 A57D3BE939AE16\ Cleanup... Ok Verify C:\Program Files\cm2\CM2MT2\backup\MT6580__503DAD80B93E5F02B6 A57D3BE939AE16.7z Verified Stage a: FULL FACTORY: WIPE + FRP [1] Process RESET PROTECTION... Ok [2] Verified [3] Process USERDATA... Ok [4] Verified [5] Process USERDATA... Ok Stage d: FULL FACTORY: WIPE + FRP Done: 00:00:42 Reconnect Power/Cable now |
![]() | #73971 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel S12 smart reset done with cm2 peration: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1633 (Android) (COM9) MODE [0]: PRELOADER PORT; PORT: 9 Waiting BOOT ACK... PRELOADER: ACK Ok BROM: Init... Init passed CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\Program Files\cm2\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6580 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 460001154D32584EDB900142DF645ADA DA v4.2.156 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 150100464E58324D420190DBDA5A64DF VEN: Samsung OEM: 256 ID: 464E58324D42 [FNX2MB] PRV: 0x01 SNN: 2430327386 [0x90DBDA5A] MM/YY: 6/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00080000 [ 512.00 Kb ] USER: 0x1D2000000 [ 7.28 Gb ] SRAM: 0x00020000 [ 128.00 Kb ] DRAM: 0x40000000 [ 1.00 Gb ] CHIP: MT6580 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6580 TYPE: LEGACY [MTK] RNID: 503DAD80B93E5F02B6A57D3BE939AE16 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done [Legacy] Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Select info source... Ok Patch Level: NRD90M SW Version: 1509606329 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-09-05 Build Time: 11/2/2017 7:05:27 AM Product Model: itel S12 Product Brand: Itel Product Name: I805 Product Device: itel-S12 CPU: armeabi-v7a,armeabi Product Manfct: itel Board Platform: mt6580 Product Info: S12 SW: S12-user 7.0 NRD90M 1509606329 release-keys Display ID: S12-I805-7.0-OP-V033-20171102 Strategy: [none|generic] SmartInfo: Android Ver: 7 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] Verify device config... Ok Loaders Ok Backup exist: C:\Program Files\cm2\CM2MT2\backup\MT6580__503DAD80B93E5F02B6 A57D3BE939AE16 Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:33 Reconnect Power/Cable now |
![]() | #73972 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | tecno kc2 format done with cm2 Reset Mode: Safe (OnDevice) FactoryReset via WIPE and reset FRP Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FULL FACTORY: WIPE + FRP Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM11) MODE [0]: BOOTROM; PORT: 11 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: EEFF006E53B28DA7008FF4C1234C8D1E BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 550334D0DE2B388234D19E4D61D185658F0091A8FF0B6CDC42 D5F133844E25E1 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth FF: Looking for EMI FF: EMI found SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: EEFF006E53B28DA7008FF4C1234C8D1E AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\Program Files\cm2\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100474436424D42019CF5E4BEC69B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2633360574 [0x9CF5E4BE] MM/YY: 12/2019 EMI: Init Ok EMI: FireFly preloader_kc2_h6113.bin with 13 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Ven: Micron | Dev: 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Ven: Samsung | Dev: FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Ven: Kingston | Dev: FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A500 [ 233.25 Kb ] DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100474436424D42019CF5E4BEC69B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2633360574 [0x9CF5E4BE] MM/YY: 12/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 3C6B4A05E492EE259135A5EE064BD5A0 MEID: EEFF006E53B28DA7008FF4C1234C8D1E USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: KC2-H6113AI-P-210705V320 SW Version: AI-210705V320 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-07-05 Build Time: 7/5/2021 9:54:12 AM Product Model: TECNO KC2 Product Brand: TECNO Product Name: H6113 Product Device: TECNO-KC2 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: TECNO MOBILE LIMITED Product Info: kc2_h6113 SW: full_kc2_h6113-user 9 PPR1.180610.011 126295 release-keys Product Board: TECNO-KC2 Board Platform: mt6761 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\Program Files\cm2\CM2MT2\backup\MT6761__EEFF006E53B28DA700 8FF4C1234C8D1E\ Items to check: 20 Read [12] NVRAM Read [37] NVDATA Read [29] PROINFO Read [13] LK Read [36] NVCFG Read [24] PROTECT1 Read [1] PGPT Read [23] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\Program Files\cm2\CM2MT2\backup\MT6761__EEFF006E53B28DA700 8FF4C1234C8D1E\ Cleanup... Ok Verify C:\Program Files\cm2\CM2MT2\backup\MT6761__EEFF006E53B28DA700 8FF4C1234C8D1E.7z Verified Stage a: FULL FACTORY: WIPE + FRP [1] Process RESET PROTECTION... Ok [2] Verified [3] Process USERDATA... Ok [4] Verified [5] Process USERDATA... Ok Stage d: FULL FACTORY: WIPE + FRP Done: 00:00:59 Reconnect Power/Cable now |
![]() | #73973 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | itel S12 privacy lock rewmove done Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464E58324D420190DBDA5A64DF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM2XN [eMMC] : FLASH_CID : 150100464E58324D420190DBDA5A64DF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x033C521780AD3D50025F3EB93B7DA5B6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
![]() | #73974 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A12 smart reset done with cm2 Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1633 (COM11) MODE [0]: BOOTROM; PORT: 11 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 386AFCC18A84F2E521C2BC077A7F961B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D88B134CE492C5CE16C202DC1FB66B716DB8FF89266EF833DD BCFC5A8FD09B6E SLA: Local Auth SLA: Starting Auth SLA: Continue Auth FF: Looking for EMI FF: EMI found SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 386AFCC18A84F2E521C2BC077A7F961B AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\Program Files\cm2\CM2MT2\boot\0_base\base_v2216\MTK_AllInO ne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E03004A11E5972D VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 4854245 [0x004A11E5] MM/YY: 9/2020 EMI: Init Ok EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E03004A11E5972D VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 4854245 [0x004A11E5] MM/YY: 9/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E258CEB5DBC26D6534A216CE60F977C5 MEID: 386AFCC18A84F2E521C2BC077A7F961B USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2022-01-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20220118.230000 release-keys Build Time: 1/18/2022 3:07:30 PM Product Brand: OPPO Product Model: CPH2083 Product Info: CPH2083 Product Name: CPH2083 Product Device: OP4BFB SW OTA Version: CPH2083PUEX_11.A.67_0670_202201182155 Display ID: CPH2083EX_11_A.67 Display ID: CPH2083EX_11_A.67_220118 Kernel Info: 4.9.117 Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\Program Files\cm2\CM2MT2\backup\MT6765__386AFCC18A84F2E521 C2BC077A7F961B\ Items to check: 20 Read [28] NVRAM Read [12] NVDATA Read [19] PROINFO Read [29] LK Read [11] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Done 11 files Compress: C:\Program Files\cm2\CM2MT2\backup\MT6765__386AFCC18A84F2E521 C2BC077A7F961B\ Cleanup... Ok Verify C:\Program Files\cm2\CM2MT2\backup\MT6765__386AFCC18A84F2E521 C2BC077A7F961B.7z Verified Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:55 Reconnect Power/Cable now |
![]() | #73975 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Calme e1000 reset password done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.07 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! ModemInfo : Project Version: SC6531EFM_BAR BASE Version: BASE_SVN HW Version(Auto): SC6531EFM_BAR SecInfo : IMEI[1] : IMEI[2] : IMEI[3] : 000000000000000 WIFIMAC : FFFFFFFFFFFF BT_MAC : 0027150862A1 Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
![]() | #73976 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Qmobile xl40 reset password done by cm2 Card found : S/N : 73CA70CC , v0155 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 38F2C4DE77CCAF07620848EB32341CED BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
![]() | #73977 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Infinix Note 12 X663 Reset Frp Done BY CM2 S/N: 73CA70CC v0155 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.44 Verify directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 0 dirs: 0 Build device list... Ok Scan 74 profiles... Ok Init environment... Load IDBase v418494 Ok Check for updates... You have latest version [2.44] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12192] updated Load IDBase v418494 Ok Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed MODE [0] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: E22AEADCC3F6E93E204D350FCE29E04F BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 2176E8440B77F0AE4076C5F942EB8C2637AD20E7AA42FF9563 90D0C7549AC664 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501003356364341420259B26AEDB841 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 1504865005 [0x59B26AED] MM/YY: 11/2021 EMI: Init Ok EMI: FireFly preloader_x663_h6915 with 16 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503C Ven: Hynix | Dev: hC8aP< RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100335636434242 Ven: Samsung | Dev: 3V6CBB RAM: 6.00 Gb 16. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 1501003356364341420259B26AEDB841 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 1504865005 [0x59B26AED] MM/YY: 11/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 6CE413E48A18D8AB9E3E977072B0AD10 MEID: E22AEADCC3F6E93E204D350FCE29E04F USB: HIGH-SPEED Boot done [Raphael] Analyze PT... Loaded 0x8000 bytes PT: 0x64 Items: 49 Select info source... Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__E22AEADCC3F6E 93E204D350FCE29E04F Method [2] [1] Process RESET PROTECTION... Ok [2] Verified Method [2] [1] Verified [2] Verified Method [2] Done: 00:00:25 Reconnect Power/Cable now |
![]() | #73978 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Vivo y20 2021 v2043 reset frp done by cm2 S/N: 73CA70CC v0155 Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.44 Verify directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 1 dirs: 0 Build device list... Ok Scan 74 profiles... Ok Init environment... Load IDBase v418494 Ok Check for updates... You have latest version [2.44] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12192] updated Load IDBase v418494 Ok Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Mode: SMART RESET Wait... WARNING! Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-]Waiting for device connection... PTFN: MTK USB Port (COM9) MODE: BOOTROM; PORT: 9 Waiting BOOT ack... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 89BA85903F793069478EB81E899A0D74 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 9822243F9A1739C6B2074E8822CE97283E971CB8E571B63F14 73C604FB488333 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 1501004448364441420217EED4C8C79F VEN: Samsung OEM: 0 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 401528008 [0x17EED4C8] MM/YY: 12/2020 EMI: Init EMI by INTERNAL Database EMI: FireFly preloader_k65v1_64_bsp.bin with 9 memory type(s) supported 1. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 GB 2. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 GB 3. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 GB 4. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 GB 5. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 GB 6. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 GB 7. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 GB 8. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 GB 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 3.00 GB EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0x100000000 [ 4.00 GB ] EMMC CID: 1501004448364441420217EED4C8C79F VEN: Samsung OEM: 0 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 401528008 [0x17EED4C8] MM/YY: 12/2020 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x01000000 [ 16.00 MB ] USER: 0xE8F800000 [ 58.24 GB ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 11FBD98D99456C9E2DA69AAB85E60026 MEID: 89BA85903F793069478EB81E899A0D74 USB: HIGH-SPEED Boot done [1] Reading... Ok SmartInfo: AndroidVer: 11 UserDataFS: 0x02 CacheFS: 0x02 Strategy: 7 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__89BA85903F793 069478EB81E899A0D74 [1] Process: RESET PROTECTION... Format Ok: RESET PROTECTION [2] Process: USERDATA... Format Ok: USERDATA [3] Process: CACHE... Format Ok: CACHE [4] Verified [5] Verified [6] Process: USERDATA... Format Ok: USERDATA [7] Process: USERDATA... Format Ok: USERDATA [1] Verified [2] Verified Done: 00:00:42 Reconnect Power/Cable now |
![]() | #73979 (permalink) |
Junior Member Join Date: Aug 2022 Location: Titan
Member: 3019483 Status: Offline Thanks Meter: 7 | Bf7 done Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Select info source... Ok Product Brand: TECNO Product Device: TECNO-BF7 Product Model: TECNO BF7 Product Name: BF7-GL SW: TECNO/BF7-GL/TECNO-BF7:12/SP1A.210812.016/230315V839:user/release-keys Patch Level: SP1A.210812.016 Display ID: BF7-H6127ABCDSTUAdAeAfArAs-S-GL-230315V839 SW Version: 230315V839 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-03-05 Build Time: 14/3/2023 22:52:08 Product Info: bf7_h6127 SW: vnd_bf7_h6127-user 12 SP1A.210812.016 274334 release-keys Product Manfct: TECNO Product Board: TECNO-BF7 Board Platform: mt6761 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__118CD6CC120F9 0BEACC39A3F093A168B Stage a: FRP [ RESET PROTECTION ] [1] Process RESET PROTECTION... Ok [2] Verified Stage b: FRP [ RESET PROTECTION ] [1] Verified [2] Verified Stage d: FRP [ RESET PROTECTION ] Done: 00:00:20 Reconnect Power/Cable now while others fail in the attempt ![]() |
The Following 2 Users Say Thank You to batmateam For This Useful Post: |
![]() | #73980 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2012 Location: Pakistan Panjab, Sahiwal
Member: 1758871 Status: Offline Sonork: Zaka Ullah Bhatti Thanks Meter: 143 | Oppo A37m MTK6755 Hang in Logo Fix Cm2 infinity 100% Done Oppo A37m MTK6755 & Mt6750 Hang-in Logo Fix Cm2 infinity Dongle Done ![]() ![]() Code: Operation : Identify [ v2.16 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 254B108E8504149EC21473F08377FF6E BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : base_v2216 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_oppo6750_15127.bin EMI : CNT : 0004 EMI : [00] : eMMC : DDR3 : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E51324A393652 : VEN : MICRON | DEV : Q2J96R : RAM : [ 2.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 13014E51324A39365210033D10DB3F1 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 11C01BB6E9FBF6C5870BAF4545A42982 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Boot done! Patch Level : LMY47I Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-09-05 Build Time : 02.03.2017 Product Manfct : OPPO Board Platform : mt6750 Product Model : OPPO A37m Product Brand : OPPO Product Name : A37m Product Device : A37 Product Board : full_oppo6750_15127 Product Info : oppo6750_15127 SW Version : A.18 SW OTA Version : A37m_11.A.18_0180_201703021729 SW OTA Name : A37m_11_A.18_170302 Display ID : A37m_11_A.18_170302 Kernel Info : 3.10.72-G201703021729 IMEI[0] : 35xxxxxxxxxxxxxx IMEI[1] : 3xxxxxxxxxxxxxxx NVRAM check : Passed! NVRAM : SEC ENCRYPT [ IMEI ENCRYPTED ] Backup sensetive data [ 18 ] Backup path : Backup\MT6755__11C01BB6E9FBF6C5870BAF4545A42982\ Backup done! Code: 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1633 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : MEID : 254B108E8504149EC21473F08377FF6E BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : base_v2216 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6755 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6755 EMI : SRC : preloader_oppo6750_15127.bin EMI : CNT : 0004 EMI : [00] : eMMC : DDR3 : ID : 150100514531334D42 : VEN : SAMSUNG | DEV : QE13MB : RAM : [ 2.00 GB ] EMI : [01] : eMMC : DDR3 : ID : 90014A484147346132 : VEN : HYNIX | DEV : HAG4a2 : RAM : [ 2.00 GB ] EMI : [02] : eMMC : DDR3 : ID : 13014E51324A393652 : VEN : MICRON | DEV : Q2J96R : RAM : [ 2.00 GB ] EMI : [03] : eMMC : DDR3 : ID : 150100524531424D42 : VEN : SAMSUNG | DEV : RE1BMB : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00038000 [ 224.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 13014E51324A39365210033D10DB3F1 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 11C01BB6E9FBF6C5870BAF4545A42982 DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM30) MODE : PRELOADER PORT PORT : 30 Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000008000 Erase : 0x0000000001008000 : 0x0000000000080000 Erase : 0x0000000003588000 : 0x0000000004B00000 Erase : 0x0000000009800000 : 0x0000000001000000 Erase : 0x000000000FE00000 : 0x0000000000A00000 Erase : 0x00000000A0800000 : 0x0000000100000000 [FL] : Flashing now ... Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:00:33 Reconnect Power/Cable! ![]() By Zaka Ullah Bhatti |
The Following 3 Users Say Thank You to bhatti123 For This Useful Post: |
