Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Mark Forums Read |
![]() | #74026 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 2,988 | TECNO-KG5k Frp Code: Product Brand : TECNO Product Device : TECNO-KG5k Product Model : TECNO KG5k Product Name : KG5k Patch Level : RP1A.201005.001 Display ID : KG5k-F062-11.0-GL-V154-20221018 Ver. Incmt : GL-V154-20221018 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-09-05 Build Time : 18.10.2022 Product Name : F062 Product Info : KG5k Product Board : KG5k Board Platform : ums9230 Product Manfct : TECNO MOBILE LIMITED USERDATA : FILESYSTEM : F2FS - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:44 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : KG5k Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:17 |
![]() | #74027 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,988 | TECNO-BD2p Frp & Format Code: Product Brand : TECNO Product Name : BD2p-OP Product Device : TECNO-BD2p Product Model : TECNO BD2p Product Board : BD2p Patch Level : RP1A.201005.001 Display ID : BD2p-SP613DEF-RGo-OP-230202V17 Ver. Incmt : 230202V17 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2023-02-05 Build Time : 02.02.2023 Product Info : sp7731e_1h10 Product Board : sp7731e_1h10 Board Platform : sp7731e Product Manfct : TECNO MOBILE LIMITED NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_17C_W21.07.2_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W21.07.2 HW Version: sc7731e_modem CMP_Time : 02-09-2021 04:49:59 MODEM TAG : MOCORTM_17C_W21.07.2_Debug_FM_BASE_17C_W21.07.2_sc7731e_modem_pike2_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:53 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : TECNO : BC2c-OP Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:22 |
![]() | #74028 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,988 | TECNO-KE5j Format & Frp Code: SW: TECNO/KE5j-OP/TECNO-KE5j:10/QP1A.190711.020/AB-OP-220830V262:user/release-keys Product Brand: TECNO Product Device: TECNO-KE5j Product Model: TECNO KE5j Product Name: KE5j-OP Patch Level: QP1A.190711.020 Display ID: KE5j-H6122AB-Q-OP-220830V262 SW Version: AB-OP-220830V262 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-08-01 Build Time: 30/08/2022 5:43:47 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: ke5j_h6122 SW: full_ke5j_h6122-user 10 QP1A.190711.020 74396 release-keys Product Board: TECNO-KE5j Board Platform: mt6761 Product Manfct: TECNO MOBILE LIMITED Strategy: 7 [none|generic] Firmware ID: MT6761_TECNO_MOBILE_LIMITED_TECNO_KE5j_10_KE5j-H6122AB-Q-OP-220830V262_QP1A.190711.020_ke5j_h6122 Verify firmware [MT6761_TECNO_MOBILE_LIMITED_TECNO_KE5j_10_KE5j-H6122AB-Q-OP-220830V262_QP1A.190711.020_ke5j_h6122]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_MP_V118_11_P53 Analyze nvram... NVRAM: Items: 0xA3 Size: 0x101A86 State: Ok WiFi MAC: C4BF6016B65B BlTh MAC: C4BF6016B65A IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok Analyze preloader... EMI: MT6761 preloader_ke5j_h6122.bin with 2 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_ke5j_h6122.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_ke5j_h6122.bin [400219b9]... Exist Done: 00:02:00 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.43b2 ] Platform: FireFly SmartPhone - MT6580/6735-39|52|53|61-65|68|71/6983, Helio G/P Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE[0]: BOOTROM; PORT: 4 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed MODE[0] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: A02C544745D374D900EF89670D266774 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 3FB12E91B57806FDBEF6A4411EBCC5A049FD2E5EB7C0F65051DC7A8EE67AB57E Sending FireFly... FireFly: Starting... FireFly: Init Core FireFly: Core init done FireFly: Running: v06.05.06 on MT6761 eMMC init passed File exist, skip: C:\InfinityBox\CM2MT2\backup\EXT_CSD\MT6761__Hynix_hC8aP_5.1_extcsd_10042023.bin EMMC CID: 90014A68433861503E03008B075A97D1 VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 9111386 [0x008B075A] MM/YY: 9/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CSD: D02700328F5903FFFFFFFFEF8E400043 TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 [CONFIG]: 0x48 0x02 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE8F800000 [ 58.24 GB ] [EOL]: EOL status : Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status : Not defined [EOL_B]: MLC status : 0% - 10% used USB: HIGH-SPEED Boot done [3] Reading... Ok Select info source... SmartInfo: AndroidVer: 10 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Strategy: 7 [none|generic] Verify device config... Ok Loaders Ok Method [6] [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Method [6] Method [6] Done: 00:00:59 Reconnect Power/Cable now |
![]() | #74029 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,988 | DANY Technologies Frp Code: Patch Level : NRD90M Display ID : DANY-*******4GXX-20180627-V Ver. Incmt : ZED_LXS_1564795857 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-04-05 Build Time : 03.08.2019 Product Model : SP9832A Product Brand : SPRD Product Name : sg7067ka Product Device : sp9832a_2h11 Product Board : sp9832a_2h11_volte Product Manfct : DANY Technologies (HK) LTD. Board Platform : sc8830 Product Info : sp9832a_2h11 NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF SEC : SLS:0, SKS:0, SKV:0 Platform Version: MOCORTM_15C_W17.39.2_P1_Debug Project Version: sc983x_cp1 BASE Version: FM_BASE_15C_W17.39.2_P1 HW Version: sc983x_modem CMP_Time : 10-02-2017 21:25:59 MODEM TAG : MOCORTM_15C_W17.39.2_P1_Debug_FM_BASE_15C_W17.39.2_P1_sc983x_modem_sc983x_cp1 - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:01 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC983x_BASE : SC9832A_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:22 |
![]() | #74030 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,988 | Infinix X6816C Frp Code: Product Device : Infinix-X6816C Product Name : X6816C-GL Product Model : Infinix X6816C Product Brand : Infinix Ver. Incmt : 221112V12 Display ID : X6816C-ST683SBCDS-R-GL-221112V12 Patch Level : RP1A.201005.001 Display ID : RP1A.201005.001 release-keys Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2022-11-05 Build Time : 12.11.2022 Product Info : X6816C Product Board : X6816C Board Platform : ums512 Product Manfct : INFINIX MOBILITY LIMITED NVMng : SecurityInfo IMEI[1] : IMEI[2] : IMEI[3] : SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_20A_W22.28.2_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W22.28.2 HW Version: sharkl5pro_modem CMP_Time : 07-12-2022 03:26:58 MODEM TAG : MOCORTM_20A_W22.28.2_Debug_4G_MODEM_20A_W22.28.2_sharkl5pro_modem_sharkl5pro_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:21 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Infinix : infinix-x6816c.81880790.ab5e687d Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:22 |
![]() | #74031 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Qmobile e4 2020 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 19 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : AE4035C391CAD4AFD445B9DE5445C419 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS_INFO : 0x002FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002A9000-0x002FDFFF , LEN : 0x00055000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
![]() | #74032 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo f1s smart reset done with cm2 Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] MEID: 0798574CC6314B3BAF3A0A9736F4012C BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] BROM: EMI: Search EMI: Found AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init Ok EMI: FireFly preloader_oppo6750_15131.bin with 6 memory type(s) 1. eMMC DDR3 ID: 150100524531424D42 Ven: Samsung | Dev: RE1BMB RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 3.00 Gb 3. eMMC DDR3 ID: 150100525831424D42 Ven: Samsung | Dev: RX1BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 13014E51334A393756 Ven: Micron | Dev: Q3J97V RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100525831344D42 Ven: Samsung | Dev: RX14MB RAM: 4.00 Gb 6. DRAM DDR3 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00038000 [ 224.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100525831344D42078DAD967A9427 VEN: Samsung OEM: 256 ID: 525831344D42 [RX14MB] PRV: 0x07 SNN: 2376963706 [0x8DAD967A] MM/YY: 9/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6750 TYPE: LEGACY [MTK] RNID: 871CBCA6D02AD8D82A983D08213C175B MEID: 0798574CC6314B3BAF3A0A9736F4012C USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM67) MODE: PRELOADER PORT; PORT: 67 Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 36 Select info source... Ok Product Model: A1601 Product Brand: OPPO Product Name: A1601 Product Device: A1601 Product Board: full_oppo6750_15331 Product Info: oppo6750_15331 SW Version: A.28 SW OTA Version: A1601EX_11.A.28_INT_028_201702102025 SW OTA Name: A1601EX_11_A.28_170210 Display ID: A1601EX_11_A.28_170210 Kernel Info: 3.10.72-G201702102025 Patch Level: LMY47I SW Version: 1486731722 Ver. CodeName: REL Ver. Release: 5.1 Sec. Patch: 2017-02-05 Build Time: 2/10/2017 1:04:43 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO Board Platform: mt6750 SW: full_oppo6750_15331-user 5.1 LMY47I 1486731722 release-keys Strategy: [none|generic] SmartInfo: Android Ver: 5 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6755__0798574CC6314 B3BAF3A0A9736F4012C\ Items to check: 20 Read [22] NVRAM Read [11] NVDATA Read [17] PROINFO ZERO CONTENT file [3.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6755__0798574CC6314 B3BAF3A0A9736F4012C\proinfo.bin Read [23] LK Read [13] PROTECT1 Read [1] PGPT Read [0] PRELOADER Read [8] OPPO_CUSTOM ZERO CONTENT file [1024.00 Kb] deleted: C:\InfinityBox\CM2MT2\backup\MT6755__0798574CC6314 B3BAF3A0A9736F4012C\oppo_custom.bin Done 6 files Compress: C:\InfinityBox\CM2MT2\backup\MT6755__0798574CC6314 B3BAF3A0A9736F4012C\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6755__0798574CC6314 B3BAF3A0A9736F4012C.7z Verified Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:52 Reconnect Power/Cable now |
![]() | #74033 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,761 | Qmobile g30 reset password done by cm2 Card found : 73CA70CC , v0155 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] Operation : Identify [ v1.07 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR SC6531 Loader v 1.2 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_006 F3CC4A22C_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
![]() | #74034 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 356 ![]() | vivo Y12 password and frp successfull removed with tP Operation: Reset Settings/Format FS [ v2.43 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed MODE [0] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 7E0D933A88A8C59C24DDCA7FF21F7097 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 3EB86DB47EF1B301E48F89E2440841743527D22B7DCCF9CB9A 4CF7B5F5DA7947 SLA: Sending Auth SLA: Auth accepted SLA: Challenge not used AGENT: AUTO: Vivo: Y12 [1cd5e51e] C:\InfinityBox\CM2MT2\boot\Vivo\Y12\MTK_AllInOne_D A_20180320.2108_402229_403250.bin [c6920528] C:\InfinityBox\CM2MT2\boot\Vivo\Y12\VIVO_Y12.auth [451279b7] C:\InfinityBox\CM2MT2\boot\Vivo\Y12\preloader_k62v 1_64_bsp_b.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init via preloader_k62v1_64_bsp_b.bin EMI: Init Ok EMI: MT6765 preloader_k62v1_64_bsp.bin with 15 memory type(s) 1. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 4.00 Gb 3. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100474536424D42 Ven: Samsung | Dev: GE6BMB RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 7. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 9. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 13. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 14. eMMC DDR3 ID: 150100525036344D42 Ven: Samsung | Dev: RP64MB RAM: 4.00 Gb 15. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00040000 [ 256.00 Kb ] DRAM: 0x30000000 [ 768.00 Mb ] EMMC CID: 90014A68433861503E036737D9A2565B VEN: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1731713442 [0x6737D9A2] MM/YY: 5/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: AC17E60D649B7D22A1D71E64A1968A23 MEID: 7E0D933A88A8C59C24DDCA7FF21F7097 USB: HIGH-SPEED Boot done [Raphael] Analyze PT... Loaded 0x8000 bytes PT: 0x64 Items: 42 Select info source... SmartInfo: Android Ver: 11 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Strategy: 7 [none|generic] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__7E0D933A88A8C 59C24DDCA7FF21F7097 Method [6] [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Method [6] [1] Verified [2] Verified Method [6] Method [6] Done: 00:02:43 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to skyulock For This Useful Post: |
![]() | #74035 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | vgotel i710 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 4 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 32AAACC24555D407C57D9E3B050448C4 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup exists , skip Executing FFS FORMAT now... FAT_RANGE : 0x00391000-0x003FDFFF , LEN : 0x0006D000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
![]() | #74036 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | oppo A1k smart reset done Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Format FS WILL RESET ALL USER DATA! Make sure about correct format mode selection! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 61293F1D29CCBB628278DC43737CCB7C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 0D3076B37FE97C207862E38D80B486ACEA817EAE31EA756EE3 6EC4C607B7B14E SLA: Local Auth SLA: Starting Auth SLA: Continue Auth FF: Looking for EMI FF: EMI found SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 61293F1D29CCBB628278DC43737CCB7C AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D42031663D29C8637 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 375640732 [0x1663D29C] MM/YY: 8/2019 EMI: Init Ok EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Ven: Micron | Dev: S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x0003A000 [ 232.00 Kb ] DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D42031663D29C8637 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 375640732 [0x1663D29C] MM/YY: 8/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 15BB03ADBB8AC8EAAB322BFEF9013758 MEID: 61293F1D29CCBB628278DC43737CCB7C USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210506.165532 release-keys Build Time: 5/6/2021 9:00:08 AM SW Version: 1620291608 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.40_0400_202105061633 Display ID: CPH1923EX_11_A.40 Kernel Info: 4.9.117 Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__61293F1D29CCB B628278DC43737CCB7C\ Items to check: 20 Read [29] NVRAM Read [13] NVDATA Read [20] PROINFO Read [30] LK Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__61293F1D29CCB B628278DC43737CCB7C\opporeserve3.bin Read [8] OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__61293F1D29CCB B628278DC43737CCB7C\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__61293F1D29CCB B628278DC43737CCB7C.7z Verified Stage a: SMART RESET [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage b: SMART RESET [1] Verified [2] Verified Stage c: SMART RESET Stage d: SMART RESET Done: 00:00:54 Reconnect Power/Cable now |
![]() | #74037 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,665 | iKU V400 booting and reading firmware done origibal poster حسين كساب واكد GEM FLASH |
The Following User Says Thank You to profkefah For This Useful Post: |
![]() | #74038 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2010 Location: Uganda
Member: 1340870 Status: Offline Sonork: 1611357 Thanks Meter: 143 | ![]() Infinity [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.44 Verify directories tree... Ok Firmware files: K:\SAMUNG FIRMWARE\ Backup files: C:\InfinityBox\CM2MT2\backup\ Compact backup files... Backup files: 44 dirs: 2 Build device list... Ok Scan 74 profiles... Ok Init environment... Load IDBase v418494 Ok Check for updates... You have latest version [2.44] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12192] updated Load IDBase v418494 Ok DA selected: TECNO | 2023-05 | MTK_AllInOne_DA.bin Preloader Mode without testpoint/disassembly MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893 Operation: Identify Device [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read Deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly UNI-Proto [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 76B42463265AEC2ECCF13C2E514E6EBB BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 097D60C5F63326DD296E14DBA2CF654FEFB4A1D1C447BF4032 AF33E6FDC66916 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth FF: Looking for EMI FF: EMI found SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 76B42463265AEC2ECCF13C2E514E6EBB AGENT: AUTO: TECNO: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\INFINIX\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 EMI: Init Ok EMI: FireFly preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A40A00000 [ 233.01 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 04DA4DFBEF1B166705B315F1E6E7A7B9 MEID: 76B42463265AEC2ECCF13C2E514E6EBB USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 53 Get slot info... Select info source... Ok Product Brand: TECNO Product Device: TECNO-KI7 Product Model: TECNO KI7 Product Name: KI7-GL SW: TECNO/KI7-GL/TECNO-KI7:12/SP1A.210812.016/230214V964:user/release-keys Patch Level: SP1A.210812.016 Display ID: KI7-V7510AACDEGHJKLMN-S-GL-230214V964 SW Version: 230214V964 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-01-05 Build Time: 2/14/2023 10:46:00 AM Product Info: ki7_v7510 SW: vnd_ki7_v7510-user 12 SP1A.210812.016 244888 release-keys Product Manfct: TECNO Product Board: TECNO-KI7 Board Platform: mt6768 Strategy: [none|generic] Firmware ID: MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230214V964_SP1A.210812.016_ki7_v7510 Verify firmware [MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230214V964_SP1A.210812.016_ki7_v7510]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0xA3 Size: 0x08C64F State: Ok WiFi MAC: 503CCA05670A BlTh MAC: 503CCA05670B IMEI[1]: 352524291799404 IMEI[2]: 352524291799412 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6768__76B42463265AE C2ECCF13C2E514E6EBB\ Items to check: 20 Read [37] NVRAM Read [19] NVDATA Read [3] PROINFO Read [18] NVCFG Read [21] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__76B42463265AE C2ECCF13C2E514E6EBB\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__76B42463265AE C2ECCF13C2E514E6EBB.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6752 preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k i7_v7510.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k i7_v7510.bin [1767c386]... Exist Done: 00:00:53 Reconnect Power/Cable now Operation: Read Firmware [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Destination: K:\TECNO FIRMWARE\ Disk free space: 162.92 Gb Wait... [+] Pack FW [Sparse] [-] Forced Read 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 76B42463265AEC2ECCF13C2E514E6EBB BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 097D60C5F63326DD296E14DBA2CF654FEFB4A1D1C447BF4032 AF33E6FDC66916 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 76B42463265AEC2ECCF13C2E514E6EBB AGENT: AUTO: TECNO: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\INFINIX\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 EMI: Init Ok EMI: FireFly preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A40A00000 [ 233.01 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 04DA4DFBEF1B166705B315F1E6E7A7B9 MEID: 76B42463265AEC2ECCF13C2E514E6EBB USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 53 Device support slots: slotScheme v2 Get slot info... Active slot: a Select info source... Ok Product Brand: TECNO Product Device: TECNO-KI7 Product Model: TECNO KI7 Product Name: KI7-GL SW: TECNO/KI7-GL/TECNO-KI7:12/SP1A.210812.016/230214V964:user/release-keys Patch Level: SP1A.210812.016 Display ID: KI7-V7510AACDEGHJKLMN-S-GL-230214V964 SW Version: 230214V964 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-01-05 Build Time: 2/14/2023 10:46:00 AM Product Info: ki7_v7510 SW: vnd_ki7_v7510-user 12 SP1A.210812.016 244888 release-keys Product Manfct: TECNO Product Board: TECNO-KI7 Board Platform: mt6768 Strategy: [none|generic] Firmware ID: MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230214V964_SP1A.210812.016_ki7_v7510 Read: preloader.bin 4.00 Mb Read: proinfo.img 3.00 Mb Read: tkv_a.img 1.00 Mb Read: vbmeta_a.img 8.00 Mb Read: vbmeta_system_a.img 8.00 Mb Read: vbmeta_vendor_a.img 8.00 Mb Read: tkv_b.img 1.00 Mb Read: vbmeta_b.img 8.00 Mb Read: vbmeta_system_b.img 8.00 Mb Read: vbmeta_vendor_b.img 8.00 Mb Read: persist.img 48.00 Mb ExtSparse: Compression ratio: 84% Read: md1rom_a.img 128.00 Mb Read: spmfw_a.img 1.00 Mb Read: tinysys-scp_a.bin 6.00 Mb Read: sspm_a.img 1.00 Mb Read: gz_a.img 16.00 Mb Read: lk_a.bin 2.00 Mb Read: logo_a.bin 8.00 Mb Read: boot_a.img 32.00 Mb Read: vendor_boot_a.img 64.00 Mb Read: init_boot_a.img 8.00 Mb Read: dtbo_a.img 8.00 Mb Read: tz_a.img 6.00 Mb Read: sec.img 2.00 Mb Read: nvram.bin 70.00 Mb Read: md1rom_b.img 128.00 Mb Read: spmfw_b.img 1.00 Mb Read: tinysys-scp_b.bin 6.00 Mb Read: sspm_b.img 1.00 Mb Read: gz_b.img 16.00 Mb Read: lk_b.bin 2.00 Mb Read: logo_b.bin 8.00 Mb Read: boot_b.img 32.00 Mb Read: vendor_boot_b.img 64.00 Mb Read: init_boot_b.img 8.00 Mb Read: dtbo_b.img 8.00 Mb Read: tz_b.img 6.00 Mb Read: super.img 9.80 Gb ExtSparse: Compression ratio: 1% Read: tranfs.img 300.80 Mb Read: userdata.img 221.92 Gb FW Size: 10.01 Gb Android Info saved: _Android_info.txt Scatter: MT6768_Android_scatter.txt Saved: K:\TECNO FIRMWARE\MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230214V964_SP1A.210812.016_ki7_v7510\ Verify device config... Ok Loaders Ok Verify firmware [MT6768_TECNO_TECNO_KI7_OSv12_KI7-V7510AACDEGHJKLMN-S-GL-230214V964_SP1A.210812.016_ki7_v7510]... Firmware is unknown Please upload file https://infinity-box.com/?r=100020 Upload file to server? No Done: 00:12:25 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.44 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting BOOT ACK... BROM: Skip ACK verify BROM: Init... Init passed CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 76B42463265AEC2ECCF13C2E514E6EBB BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 097D60C5F63326DD296E14DBA2CF654FEFB4A1D1C447BF4032 AF33E6FDC66916 SLA: Local Auth SLA: Starting Auth SLA: Continue Auth SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 76B42463265AEC2ECCF13C2E514E6EBB AGENT: AUTO: TECNO: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\INFINIX\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Transfer control to DA... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 EMI: Init Ok EMI: FireFly preloader_ki7_v7510.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 512.00 Mb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 4. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 5. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 6. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb 7. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 8.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... SRAM: 0x00070000 [ 448.00 Kb ] DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: D62D004D4D43323536510B5C4FAB1AE3 VEN: Foresee OEM: 11520 ID: 4D4D43323536 [MMC256] PRV: 0x51 SNN: 190599083 [0x0B5C4FAB] MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A40A00000 [ 233.01 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 04DA4DFBEF1B166705B315F1E6E7A7B9 MEID: 76B42463265AEC2ECCF13C2E514E6EBB USB: HIGH-SPEED Boot done [Raphael] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 53 Select info source... Ok Product Brand: TECNO Product Device: TECNO-KI7 Product Model: TECNO KI7 Product Name: KI7-GL SW: TECNO/KI7-GL/TECNO-KI7:12/SP1A.210812.016/230214V964:user/release-keys Patch Level: SP1A.210812.016 Display ID: KI7-V7510AACDEGHJKLMN-S-GL-230214V964 SW Version: 230214V964 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-01-05 Build Time: 2/14/2023 10:46:00 AM Product Info: ki7_v7510 SW: vnd_ki7_v7510-user 12 SP1A.210812.016 244888 release-keys Product Manfct: TECNO Product Board: TECNO-KI7 Board Platform: mt6768 Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6768__76B42463265AE C2ECCF13C2E514E6EBB Stage a: FRP [ RESET PROTECTION ] [1] Process RESET PROTECTION... Ok [2] Verified Stage b: FRP [ RESET PROTECTION ] [1] Verified [2] Verified Stage d: FRP [ RESET PROTECTION ] Done: 00:00:29 Reconnect Power/Cable now |
The Following User Says Thank You to FREDDIE GTY For This Useful Post: |
![]() | #74039 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 316 | ![]() after flashing redmi note 12 pro (ruby) with chi...ra and unlockt... and cheee.. and miby... many many tool flash done but phone still restart at logo!!! only when flash with infinity, phone alive again ![]() thank you and good work ![]() Quote:
The Following 2 Users Say Thank You to Steve-1 For This Useful Post: |
![]() | #74040 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | DANY ******* 4g Frp remove done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0002 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
