![]() | #74716 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,437 | ![]() Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Tecno : tecno-kg5k.16071f6e.f6b4eaf9 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
![]() | #74717 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,437 | ![]() Operation: Reset Settings/Format FS [ v2.47a3 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 5B3B0F043C5C82D3E386C61ED56EFD79 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: D8EB234941A07B75DC357E3E9DD1B5D8181C6DB16C72949CE4 A8E506332AE41C FireFly: Init FireFly: Start Auth Ok FireFly: Continue Auth Ok FireFly: Start Ok FireFly: Init Core Ok FireFly: Running: v06.05.06 on MT6765 eMMC init passed Stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6765__Samsu ng_DH6DMB_5.1_extcsd_15082023.bin EMMC CID: 150100444836444D4205EA7B9095B4F1 Ven: Samsung OEM: 256 ID: 444836444D42 [DH6DMB] PRV: 0x05 SNN: 3933966485 [0xEA7B9095] MM/YY: 11/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CSD: D02701320F5903FFF6DBFFEF8E40400D TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: Off EXTCSD: rev1.8 eMMC 5.1 [CONFIG]: 0x48 0x02 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x02 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 64 GB [SIZE]: Actual: 0xE8F800000 [ 58.24 GB ] [EOL]: EOL status : Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status : 40% - 50% used [EOL_B]: MLC status : 40% - 50% used USB: HIGH-SPEED Boot done FireFly Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 43 Select info source... Ok Patch Level: O11019 Display ID: O11019 release-keys SW Version: 1573876683 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2019-11-05 Build Time: 16-Nov-19 3:57:55 AM Product Model: vivo 1802 Product Brand: vivo Product Name: PD1803BF_EX Product Device: PD1803BF_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 8.1.0 O11019 1573876683 release-keys Product Model: PD1803BF_EX Product Board: k62v1_64_bsp Board Platform: mt6765 Strategy: [vivo] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP Stage: SMART Format Vendor Extra Ok Done: 00:01:45 Reconnect Power/Cable now |
![]() | #74718 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,156 | vivo y15s boot done in preloader mode :) Code: Operation: Identify Device [ v2.47a3 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM7) MODE [0]: PRELOADER PORT; PORT: 7 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Vivo: SEC_2022 [ae9c7ba6] c:\InfinityBox\CM2MT2\boot\Vivo\SEC_2022\MTK_AllInOne_DA.6677b6ce.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 15010047583642414209DD6007C718B1 Ven: Samsung OEM: 256 ID: 475836424142 [GX6BAB] PRV: 0x09 SNN: 3714058183 [0xDD6007C7] MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: C01EE4C2A6AF8DF02906A20044289EB9 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Select info source... Ok SW: vivo/2020_TR/2120:11/RP1A.200720.012/compiler0119174946:user/release-keys Product Brand: vivo Product Device: 2120 Product Model: V2120 Product Name: 2020_TR Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_32_bsp_2g_ago SW: full_k65v1_32_bsp_2g_ago-user 11 RP1A.200720.012 eng.compil.20220119.175105 release-keys SW Version: eng.compil.20220119.175105 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2022-01-01 Build Time: 19-01-2022 09:49:46 CPU: armeabi-v7a,armeabi Product Board: k65v1_32_bsp_2g_ago Board Platform: mt6765 Product Manfct: vivo Strategy: [vivo] Firmware ID: MT6765_vivo_V2120_OSv11_RP1A.200720.012_k65v1_32_bsp_2g_ago Verify firmware [MT6765_vivo_V2120_OSv11_RP1A.200720.012_k65v1_32_bsp_2g_ago]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... BBK_R0MP1_K65V1_64_BSP_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V136_6_P122 Analyze nvram... NVRAM: Items: 0xB4 Size: 0x0AF781 State: Ok WiFi MAC: AA0036004400 BlTh MAC: 28A53F35042B IMEI[1]: 8xxxxxxxxxxxxxx IMEI[2]: 8xxxxxxxxxxxxxx Verify device config... Ok Loaders Ok Backup to d:\InfinityBox\backup\MT6765__5D4540A44161A8EC0C2CA79F220763BE\ Items to check: 22 Read [35] NVRAM Read [10] NVDATA Read [25] PROINFO Read [36] LK Read [9] NVCFG Read [20] PROTECT1 Read [21] PROTECT2 Read [1] PGPT Read [23] PERSIST Read [0] PRELOADER Done 10 files Compress: d:\InfinityBox\backup\MT6765__5D4540A44161A8EC0C2CA79F220763BE\ Cleanup... Ok Verify d:\InfinityBox\backup\MT6765__5D4540A44161A8EC0C2CA79F220763BE.7z Verified STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_k65v1_32_bsp_2g_ago.bin with 9 memory type(s) 1. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 512.00 Mb 2. eMMC LP_DDR4X ID: 1501003458364B4D42 Samsung 4X6KMB RAM: 2.00 Gb 3. eMMC LP_DDR4X ID: 150100445836384D42 Samsung DX68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100475836424142 Samsung GX6BAB RAM: 3.00 Gb 6. eMMC DDR3 ID: 150100475036424D42 Samsung GP6BMB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 13014E47314A395238 Micron G1J9R8 RAM: 4.00 Gb 8. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 2.00 Gb 9. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 3.00 Gb Preloader saved: d:\InfinityBox\backup\preloader\preloader_k65v1_32_bsp_2g_ago.bin Verify d:\InfinityBox\backup\preloader\preloader_k65v1_32_bsp_2g_ago.bin [fe90a430]... Exist Done: 00:00:39 Reconnect Power/Cable now |
The Following 2 Users Say Thank You to kamal_singla For This Useful Post: |
![]() | #74719 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 47 | oppo A1k smart reset done Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM96) MODE [0]: BOOTROM; PORT: 96 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 7D10D5F36A2704BE21D10381EA00004B BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CC1A378060C58D9AB96724793BD40A8F9C9F76991D4387F46B 2120C660F2AD44 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4203F593C60A16A3 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 4120102410 [0xF593C60A] MM/YY: 1/2019 EMI: Init [0] via Internal database EMI: Init Ok EMI: INFINITY PRELOADER_INFINITY_0 with 3 memory type(s) EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4203F593C60A16A3 VEN: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x03 SNN: 4120102410 [0xF593C60A] MM/YY: 1/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 3837E9382C8B6178865DFB63D28531D3 MEID: 7D10D5F36A2704BE21D10381EA00004B USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210506.165532 release-keys Build Time: 5/6/2021 9:00:08 AM SW Version: 1620291608 Product Brand: OPPO Product Model: CPH1923 Product Info: CPH1923 Product Name: CPH1923 Product Device: OP486C SW OTA Version: CPH1923EX_11.A.40_0400_202105061633 Display ID: CPH1923EX_11_A.40 Kernel Info: 4.9.117 Strategy: [oppo] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__7D10D5F36A270 4BE21D10381EA00004B\ Items to check: 20 Read [29] NVRAM Read [13] NVDATA Read [20] PROINFO Read [30] LK Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__7D10D5F36A270 4BE21D10381EA00004B\opporeserve3.bin Read [8] OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__7D10D5F36A270 4BE21D10381EA00004B\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__7D10D5F36A270 4BE21D10381EA00004B.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:01:01 Reconnect Power/Cable now |
![]() | #74720 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | vgotel i500 format done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 96 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : DD229C28EA9AF0DFF398E2E4221C47D3 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x0039E000-0x003FDFFF , LEN : 0x00060000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
![]() | #74721 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 3,004 | TECNO-CH6h Format & Frp Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM25) MODE [0]: BOOTROM; PORT: 25 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 3D34D7B4A7FA8EC878F5C3AC34D1FD1C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 17A33CD084C96816F9DF180A942F736A4FE3561E8B35BC36A8C21E7F521BCC79 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 3D34D7B4A7FA8EC878F5C3AC34D1FD1C AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010044563644414202CB31E4AE88DD VEN: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 3409044654 [0xCB31E4AE] MM/YY: 8/2021 EMI: Init Ok EMI: FireFly preloader_ch6h_h698.bin with 7 memory type(s) 1. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 3. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044563644414202CB31E4AE88DD VEN: Samsung OEM: 256 ID: 445636444142 [DV6DAB] PRV: 0x02 SNN: 3409044654 [0xCB31E4AE] MM/YY: 8/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 6E34B8E1EF0B5D13194B3E3E182DD616 MEID: 3D34D7B4A7FA8EC878F5C3AC34D1FD1C USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Select info source... Ok Product Brand: TECNO Product Device: TECNO-CH6h Product Model: TECNO CH6h Product Name: CH6h-AS SW: TECNO/CH6h-AS/TECNO-CH6h:12/SP1A.210812.016/230609V535:user/release-keys Patch Level: SP1A.210812.016 Display ID: CH6h-H698I-S-AS-230609V535 SW Version: 230609V535 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-06-05 Build Time: 6/9/2023 6:53:07 PM Product Info: ch6h_h698 SW: vnd_ch6h_h698-user 12 SP1A.210812.016 349947 release-keys Product Manfct: TECNO MOBILE LIMITED Product Board: TECNO-CH6h Board Platform: mt6768 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:00:45 Reconnect Power/Cable now |
![]() | #74722 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | QTab_V500 Frp Code: Patch Level: NRD90M Display ID: QMobile_V500_MP_26_07_V8 SW Version: 1499846048 Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2017-06-01 Build Time: 7/26/2017 6:39:37 AM Product Model: V500 Product Brand: QTab Product Name: QTab_V500 Product Device: QTab_V500 CPU: armeabi-v7a,armeabi Product Manfct: QTab Board Platform: mt6737m Product Info: QTab_V500 SW: full_along8735b_p3h_801-user 7.0 NRD90M 1501051193 release-keys Strategy: [none|generic] Firmware ID: MT6737M_QTab_V500_OSv7.0_QMobile_V500_MP_26_07_V8_NRD90M_QTab_V500 Verify firmware [MT6737M_QTab_V500_OSv7.0_QMobile_V500_MP_26_07_V8_NRD90M_QTab_V500]... Finished Analyze userdata... userData: fileSystem [ext4] with FDE [forced encrypt] Analyze modem... Nothing Analyze nvram... NVRAM: Items: 0x12F Size: 0x06772C State: Ok WiFi MAC: 9C0E4A13C647 BlTh MAC: FE9F4603350A IMEI[1]: IMEI[2]: Verify device config... Finished Analyze preloader... EMI: MT6752 preloader_along8735b_p3h_801.bin with 1 memory type(s) 1. DRAM DDR3 ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_along8735b_p3h_801.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_along8735b_p3h_801.bin [10f724b8]... Finished Done: 00:00:24 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM3) MODE [0]: PRELOADER PORT; PORT: 3 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x01 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6735 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started NAND: DEVICE NOT FOUND EMMC: OK CID: 8801034E436172642043843E1A579551 DA v4.2.155 DA: DRAM ready Boot to 2nd DA... Ok Load HW info... EMMC CID: 8801034E436172642043843E1A571451 VEN: Foresee OEM: 259 ID: 4E4361726420 [NCard ] PRV: 0x43 SNN: 2218662487 [0x843E1A57] MM/YY: 1/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x39D000000 [ 14.45 Gb ] RAM: SRAM: 0x00020000 [ 128.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] CHIP: MT6735 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0335 TYPE: LEGACY [MTK] RNID: E6FDCC9E34E9AAD04EFF1C603F50D430 DA: Status: BLANK FLASH; Boot Style: EMMC FLASH BOOT USB: HIGH-SPEED Boot done LEGACY [MTK] Analyze PMT... Ok PMT: LGPT [0x06] Records: 26 Strategy: [none|generic] Verify device config... Finished Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Done: 00:00:18 Reconnect Power/Cable now |
![]() | #74723 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | OPPO CPH2083 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 0000E8CFB7410930DE3A006F7A754631 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 57CB69811221DAE51F23DA3DDCFE2D42814480603B01CBA6D50C81E13167FB00 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 0000E8CFB7410930DE3A006F7A754631 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E0300879531773F VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 8885553 [0x00879531] MM/YY: 7/2020 EMI: Init Ok EMI: FireFly preloader_oppo6765_19451.bin with 10 memory type(s) 1. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 7. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E0300879531773F VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 8885553 [0x00879531] MM/YY: 7/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 1261495258B395CEAEEFDB5E9989BAB6 MEID: 0000E8CFB7410930DE3A006F7A754631 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2022-01-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_19451-user 9 PPR1.180610.011 eng.root.20220118.230000 release-keys Build Time: 1/18/2022 3:07:30 PM Product Brand: OPPO Product Model: CPH2083 Product Info: CPH2083 Product Name: CPH2083 Product Device: OP4BFB SW OTA Version: CPH2083PUEX_11.A.67_0670_202201182155 Display ID: CPH2083EX_11_A.67 Display ID: CPH2083EX_11_A.67_220118 Kernel Info: 4.9.117 Strategy: [oppo] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Finished Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:00:41 Reconnect Power/Cable now |
![]() | #74724 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Realme RMX3171 Flash Code: Operation: Write Flash [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [-] Backup [-] UserData Safe [-] FLASH ERASE Files: 25 [FL]: G:\OPPO File\RMX\RMX3171_11_A.13_210309_cc40237c_GsmMafia.Com\RMX3171_11_A.13_210309_cc40237c\RMX3171_11_A.13_210309_cc40237c.ofp2bin\ preloader_oppo6769.bin [ 297.50 Kb ] recovery.img [ 98.00 Mb ] opporeserve2.img [ 5.05 Mb ] vbmeta.img [ 4.00 Kb ] vbmeta_system.img [ 4.00 Kb ] vbmeta_vendor.img [ 4.00 Kb ] cdt_engineering.img [ 1.00 Mb ] logo.bin [ 1.90 Mb ] md1img.img [ 56.74 Mb ] special_preload.img [ 448.00 Mb ] my_custom.img [ 1.07 Mb ] spmfw.img [ 37.09 Kb ] scp.img [ 729.59 Kb ] scp.img [ 729.59 Kb ] sspm.img [ 490.23 Kb ] sspm.img [ 490.23 Kb ] lk.img [ 1.69 Mb ] lk.img [ 1.69 Mb ] boot.img [ 32.00 Mb ] dtbo.img [ 299.33 Kb ] tee.img [ 498.72 Kb ] tee.img [ 498.72 Kb ] super.img [ 6.29 Gb ] cache.img [ 176.19 Kb ] userdata.img [ 3.73 Gb ] Total size: 0x2AA225BAC [ 10.66 Gb ] Patch Level: QP1A.190711.020 Display ID: QP1A.190711.020 release-keys Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2021-02-05 Build Time: 3/8/2021 5:56:31 PM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: oppo6769 SW: full_oppo6769-user 10 QP1A.190711.020 d54e398b2564fe22 release-keys Firmware ID: MT0000_OSv10_QP1A.190711.020_oppo6769 Verify firmware [RMX3171_11_A.13_210309_cc40237c.ofp2bin]... Finished Verify firmware [MT0000_OSv10_QP1A.190711.020_oppo6769]... Finished 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM25) MODE [0]: BOOTROM; PORT: 25 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 30EEF85850DEAFA81ED5C3BC14CBC880 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 5EDEF37AF5CE22887BCBFF2E7699A7D6E3A7ED8960B7B3BFF93EC73ED45550F5 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 30EEF85850DEAFA81ED5C3BC14CBC880 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin [8e720447] G:\OPPO File\RMX\RMX3171_11_A.13_210309_cc40237c_GsmMafia.Com\RMX3171_11_A.13_210309_cc40237c\RMX3171_11_A.13_210309_cc40237c.ofp2bin\preloader_oppo6769.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E47314A395238100EA585B118EF VEN: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 SNN: 245728689 [0x0EA585B1] MM/YY: 1/2021 EMI: Init via preloader_oppo6769.bin EMI: Init Ok EMI: MT6752 preloader_oppo6769.bin with 17 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444436384D42 Ven: Samsung | Dev: DD68MB RAM: 3.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 8. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 9. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Ven: Sandisk | Dev: DA4128 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 12. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 17. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E47314A395238100EA585B118EF VEN: Micron OEM: 334 ID: 47314A395238 [G1J9R8] PRV: 0x10 SNN: 245728689 [0x0EA585B1] MM/YY: 1/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 8D8D6CEC1453B2AAC190FDEED74D0722 MEID: 30EEF85850DEAFA81ED5C3BC14CBC880 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Verify device config... Finished Verify PMT... Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000006308000 Erase: 0x000000000EC08000 0x000000000639A000 Erase: 0x0000000016FA2000 0x0000000004000000 Erase: 0x000000001F000000 0x0000000000A00000 Erase: 0x000000001FD00000 0x0000000001A00000 Erase: 0x0000000025700000 0x0000000517100000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Flash write... Write: PRELOADER [ 297.50 Kb ] Update bootloader backup copy... Ok Write: RECOVERY [ 98.00 Mb ] Ok Write: OPPORESERVE2 [ 5.05 Mb ] Write: VBMETA [ 4.00 Kb ] Ok Write: VBMETA_SYSTEM [ 4.00 Kb ] Ok Write: VBMETA_VENDOR [ 4.00 Kb ] Ok Write: CDT_ENGINEERING [ 1.00 Mb ] Write: LOGO [ 1.90 Mb ] Ok Write: MD1IMG [ 56.74 Mb ] Write: SPECIAL_PRELOAD [ 448.00 Mb ] Write: MY_CUSTOM [ 1.07 Mb ] Write: SPMFW [ 37.09 Kb ] Ok Write: SCP1 [ 729.59 Kb ] Ok Write: SCP2 [ 729.59 Kb ] Ok Write: SSPM_1 [ 490.23 Kb ] Ok Write: SSPM_2 [ 490.23 Kb ] Ok Write: LK [ 1.69 Mb ] Ok Write: LK2 [ 1.69 Mb ] Ok Write: BOOT [ 32.00 Mb ] Ok Write: DTBO [ 299.33 Kb ] Ok Write: TEE1 [ 498.72 Kb ] Ok Write: TEE2 [ 498.72 Kb ] Ok Write: SUPER [ 6.29 Gb ] Ok Write: CACHE [ 176.19 Kb ] Ok Write: USERDATA [ 3.73 Gb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:07:58 Reconnect Power/Cable now |
![]() | #74725 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | LG VS835 Frp Code: Patch Level: NRD90U Display ID: NRD90U SW Version: 18053185727ee Ver. CodeName: REL Ver. Release: 7.0 Sec. Patch: 2018-03-01 Build Time: 2/22/2018 9:57:56 AM Product Model: VS835 Product Brand: lge Product Name: mph1_vzw Product Device: mph1 CPU: armeabi-v7a,armeabi Product Manfct: LGE Board Platform: mt6755 Product Info: mph1 SW: mph1_vzw-user 7.0 NRD90U 18053185727ee release-keys Strategy: [none|generic] Firmware ID: MT6755_LGE_VS835_OSv7.0_18053185727ee_NRD90U_mph1_lge Verify firmware [MT6755_LGE_VS835_OSv7.0_18053185727ee_NRD90U_mph1_lge]... Finished Analyze userdata... userData: fileSystem [ext4] Analyze modem... MUSE6755M_PH1_SP_MDBIN_PCB01_MT6755_S00.MOLY_LR11_W1552_MD_TC01_PH1K6PNA_SP_V4_3_P9 Analyze nvram... NVRAM: Items: 0x3FF Size: 0x21B794 State: Ok WiFi MAC: 000000000000 BlTh MAC: EAB9E8E3C071 Verify device config... Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6755 preloader_muse6755m_mph1_n.bin with 3 memory type(s) 1. eMMC DDR3 ID: 90014A484147326505 Ven: Hynix | Dev: HAG2e RAM: 2.00 Gb 2. eMMC DDR3 ID: 150100513331334D42 Ven: Samsung | Dev: Q313MB RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_muse6755m_mph1_n.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_muse6755m_mph1_n.bin [b3e82fee]... Finished Done: 00:00:34 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: LGE Mobile USB Serial Port (COM117) MODE [0]: PRELOADER PORT; PORT: 117 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x02 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MTK USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] MEID: 3CC200602A220931BE7792FF22393A58 BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth libusb exec warn ctrl_msg1 v1.2.6.0 0x0A Ok FF: Looking for EMI Not Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x00000001 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init [0] via Internal database EMI: Init Ok EMI: INFINITY PRELOADER_INFINITY_0 with 4 memory type(s) EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 90014A4841473265050804446D123411 VEN: Hynix OEM: 330 ID: 484147326505 [HAG2e] PRV: 0x08 SNN: 71593234 [0x04446D12] MM/YY: 3/2017 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3AB800000 [ 14.68 Gb ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6755 TYPE: LEGACY [MTK] RNID: BF957D275E3FD87ED8167BB90FBD5EED MEID: 3CC200602A220931BE7792FF22393A58 USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM4) MODE: PRELOADER PORT; PORT: 4 Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:33 Reconnect Power/Cable now |
![]() | #74726 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: May 2022 Location: Germiston
Member: 3013514 Status: Offline Thanks Meter: 12 | DOOGEE S40 PRO ANDROID 10 PRIVACYLOCK PROTECTION REMOVED S/N: 5D460AE2 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\Tumelo\Desktop\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 98 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Reset PrivacyLock [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM40) MODE [0]: PRELOADER PORT; PORT: 40 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100524331344D42070A9ED0AF83F3 VEN: Samsung OEM: 256 ID: 524331344D42 [RC14MB] PRV: 0x07 SNN: 178180271 [0x0A9ED0AF] MM/YY: 8/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: E6B31096D488D654F3FABDE8367508AE USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__E6B31096D488D 654F3FABDE8367508AE Process Block #2 Process Block #3 [2] PrivacyLock reset done Done: 00:00:33 Reconnect Power/Cable now |
![]() | #74727 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: Khushab Punjab Pakistan
Member: 1857951 Status: Offline Sonork: 100.1638512 Thanks Meter: 261 | Telenor condor infinity E5 Flashing done with cm2 by .::Mustafa::. Load: C:\Users\MYPC\DOWNLO~1\COMPRE~1\MT6739~1.011\MT673 9~1.011\MT6739_Android_scatter.txt Created by Infinity-Box (c) 2020 Chinese Miracle II : MediaTek Service Module Device Info file : _Android_info.txt Display ID : Infinity e5_V6.0_20190320 Product Model : Infinity E5 Product Name : Infinity_E5 Product Device : Infinity_E5 Product Board : Infinity_E5 Product Info : Infinity_E5 Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-03-05 Build Time : 20.03.2019 Product Brand : Condor Product Manfct : SPA Condor Electronics Product Board : ww860_39_p0_2g Board Platform : mt6739 Preloader [HW DEV] Info: EMI: MT6739 preloader_ww860_39_p0_2g.bin with 8 memory type(s) supported 00: eMMC DDR3 ID: 90014A484147326505 Ven: Hynix | Dev: HAG2e RAM: [ 2.00 GB ] 01: eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: [ 2.00 GB ] 02: eMMC DDR3 ID: 150100513832334D42 Ven: Samsung | Dev: Q823MB RAM: [ 2.00 GB ] 03: eMMC DDR3 ID: 150100514531334D42 Ven: Samsung | Dev: QE13MB RAM: [ 2.00 GB ] 04: eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: [ 2.00 GB ] 05: eMMC DDR3 ID: F40122426977696E20 Ven: Biwin | Dev: Biwin RAM: [ 2.00 GB ] 06: eMMC DDR3 ID: 150100523331314D42 Ven: Samsung | Dev: R311MB RAM: [ 2.00 GB ] 07: eMMC DDR3 ID: 150100513331334D42 Ven: Samsung | Dev: Q313MB RAM: [ 2.00 GB ] Operation: Write Flash [ v2.38c9 ] Platform: MTK SmartPhone - MT65/67/68/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [+] Backup [-] UserData Safe [-] FLASH FORMAT Files: 19 [FL]: C:\Users\MYPC\DOWNLO~1\COMPRE~1\MT6739~1.011\MT673 9~1.011\ [FL]: Set: preloader_ww860_39_p0_2g.bin [FL]: Set: recovery.img [FL]: Set: md1rom.img [FL]: Set: md1dsp.img [FL]: Set: spmfw.img [FL]: Set: mcupmfw.img [FL]: Set: lk.bin [FL]: Set: lk.bin [FL]: Set: loader_ext.img [FL]: Set: loader_ext.img [FL]: Set: boot.img [FL]: Set: logo.bin [FL]: Set: dtbo.img [FL]: Set: tz.img [FL]: Set: tz.img [FL]: Set: vendor.img [FL]: Set: system.img [FL]: Set: cache.img [FL]: Set: userdata.img [FL]: Total size: 0x87F5F248 [ 2.12 GB ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM18) MODE: PRELOADER PORT; PORT: 18 Waiting BOOT ack... PRELOADER: ACK confirmed BROM: Init BROM BROM: Init passed CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0002 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000000 Mode: PLAIN BROM: BROM|BL : 0xFF|0x03 [PRELOADER PORT] AGENT: 0_base: base_v2216 | Manual: Off [3365c4d2] K:\Box setup\CM2\CM2\CM2MT2\CM2MT2\boot\0_base\base_v2216 \MTK_AllInOne_DA.bin [a57d4274] C:\Users\MYPC\DOWNLO~1\COMPRE~1\MT6739~1.011\MT673 9~1.011\preloader_ww860_39_p0_2g.bin Looking for suitable BootChain in DA... Found MT6739 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... BROM: DA sent BROM: Transfer control to DA... DA: AGENT started DA: SYNC DA: MODE: PRELOADER DA: EXT_RAM initialized DA: BOOT to 2nd DA... DA: 2ND stage confirmed DA: SYNC with DA passed DA: Receiving HW info SRAM 0x00020000 [ 128.00 KB ] DRAM 0x80000000 [ 2.00 GB ] EMMC: CID: 90014A484147326505075200227976D9 VEN: Hynix OEM: 74 ID: 484147326505 [HAG2e] PRV: 0x07 SNN: 1375740537 [0x52002279] MF: 7/2019 BOOT1: 0x00400000 [ 4.00 MB ] BOOT2: 0x00400000 [ 4.00 MB ] RPMB: 0x00400000 [ 4.00 MB ] USER: 0x3AB800000 [ 14.68 GB ] CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] RNID: 959A88E141F9E7AB9FC0A74FA32FCA36 DA: USB: HIGH-SPEED Boot done [1] [FL]: HW verification passed Reading... Ok Verify device config... Ok Loaders Ok [FL]: Pre-Flash backup Backup exist: K:\Box setup\CM2\CM2\CM2MT2\CM2MT2\backup\MT6739__959A88E 141F9E7AB9FC0A74FA32FCA36 [FL]: Pre-Flash backup passed SEC_DL: Off[RAPHAEL] SEC_ID: 0x494E46494E495459424F584245535432 [FL]: Pre-Erase Erase: 0x0000000000000000 0x0000000002E88000 Erase: 0x0000000003688000 0x0000000004000000 Erase: 0x0000000008800000 0x0000000000800000 Erase: 0x000000000C000000 0x0000000000200000 Erase: 0x000000000C500000 0x0000000007200000 Erase: 0x0000000013C00000 0x0000000000200000 Erase: 0x0000000013E20000 0x000000019D9E0000 [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing now... Write: PRELOADER Update bootloader backup copy... Update bootloader backup copy Ok Write: RECOVERY Write: MD1IMG Write: MD1DSP Write: SPMFW Write: MCUPMFW Write: LK Write: LK2 Write: LOADER_EXT1 Write: LOADER_EXT2 Write: BOOT Write: LOGO Write: DTBO Write: TEE1 Write: TEE2 Write: VENDOR Write: SYSTEM Write: CACHE Write: USERDATA [FL]: RePartition [FL]: RePartition Ok [FL]: Flashing finished Done: 00:02:36 Reconnect Power/Cable now |
The Following User Says Thank You to .::Mustafa::. For This Useful Post: |
![]() | #74728 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: lullipapi
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,369 | Tecno LG6n MT6768 One Click Frp/PattrenReset Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\AzherGoGa\Desktop\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 62 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok DA selected: Ibrit | Alpha-AF51 | MTK_AllInOne_DA.bin DA selected: Infinix | 2023-05 | MTK_AllInOne_DA.bin Preloader Mode without testpoint/disassembly MT6739, MT6761, MT6763, MT6765, MT6768, MT6781, MT6785, MT6833, MT6877, MT6893 Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM_V1632 (Android) (COM208) MODE [0]: PRELOADER PORT; PORT: 208 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010044563644424202015DCE6E1A5D VEN: Samsung OEM: 256 ID: 445636444242 [DV6DBB] PRV: 0x02 SNN: 22924910 [0x015DCE6E] MM/YY: 1/2023 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 284E3A102BB9FAB02D4ECAC00EC66627 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 51 Select info source... Ok Product Brand: TECNO Product Device: TECNO-LG6n Product Model: TECNO LG6n Product Name: LG6n-OP SW: TECNO/LG6n-OP/TECNO-LG6n:12/SP1A.210812.016/230201V743:user/release-keys Patch Level: SP1A.210812.016 Display ID: LG6n-H6924CDEFRS-S-OP-230201V743 SW Version: 230201V743 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-01-05 Build Time: 01/02/2023 2:51:52 pm Product Info: lg6n_h6924 SW: vnd_lg6n_h6924-user 12 SP1A.210812.016 232798 release-keys Product Manfct: TECNO Product Board: TECNO-LG6n Board Platform: mt6768 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6768__284E3A102BB9FAB02D4ECAC00EC66627\ Items to check: 20 Read [36] NVRAM Read [19] NVDATA Read [3] PROINFO Read [18] NVCFG Read [21] PROTECT1 Read [1] PGPT Read [20] PERSIST Read [0] PRELOADER Done 8 files Compress: C:\InfinityBox\CM2MT2\backup\MT6768__284E3A102BB9FAB02D4ECAC00EC66627\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6768__284E3A102BB9FAB02D4ECAC00EC66627.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:00:57 Reconnect Power/Cable now |
![]() | #74729 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,369 | Relme RMX3085 MTK6785 One Click FRP Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Firmware files: C:\Users\AzherGoGa\Desktop\ Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 63 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM209) MODE [0]: BOOTROM; PORT: 209 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6785 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0813 CODE: Krug TYPE: MODERN [RAPHAEL] MEID: 19492DF48CF23A20CEAC259FFDFB4009 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: AC368FE2BAD9EBC99C18D28E351CF34BDE54BD38789F23CB7B83D498CDF2FB3D SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth libusb exec warn ctrl_msg1 v1.2.7.3 0x0A Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 19492DF48CF23A20CEAC259FFDFB4009 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6785 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized UFS CID: CE014B4D3856383030314A4D2D423831 VEN: 0x01CE VID: KM8V8001JM-B81 IFW: 1900 EMI: Init Ok EMI: FireFly preloader_k85v1_64.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 2. eUFS LP_DDR4X Dev: MT128GASAO4U21 RAM: 4.00 Gb 3. eUFS LP_DDR4X Dev: H9HQ53AECMMDAR RAM: 6.00 Gb 4. eUFS LP_DDR4X Dev: MT064GASAO2U21 RAM: 4.00 Gb 5. eUFS LP_DDR4X Dev: KM8V7001JM-B810 RAM: 8.00 Gb 6. eUFS LP_DDR4X Dev: KM2H7001CM-B518 RAM: 6.00 Gb 7. eUFS LP_DDR4X Dev: KM5H7001DM-B424 RAM: 4.00 Gb 8. eUFS LP_DDR4X Dev: KM5V7001DM-B621 RAM: 4.00 Gb 9. eUFS LP_DDR4X Dev: KM8V8001JM-B813 RAM: 8.00 Gb 10. eUFS LP_DDR4X Dev: H9HQ16AFAMMDAR RAM: 8.00 Gb 11. eUFS LP_DDR4X Dev: H9HQ16AECMMDAR RAM: 6.00 Gb 12. eUFS LP_DDR4X Dev: KM2V8001CM-B707 RAM: 6.00 Gb 13. eUFS LP_DDR4X Dev: H9HQ53ACPMMDAR RAM: 4.00 Gb 14. eUFS LP_DDR4X Dev: H9HQ15AECMBDAR RAM: 6.00 Gb 15. eUFS LP_DDR4X Dev: KM8V9001JM-B813 RAM: 8.00 Gb 16. eUFS LP_DDR4X Dev: H9HQ15ACPMBDAR RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00080000 [ 512.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] UFS CID: CE014B4D3856383030314A4D2D423831 VEN: 0x01CE VID: KM8V8001JM-B81 IFW: 1900 LU0: 0x00400000 [ 4.00 Mb ] LU1: 0x00400000 [ 4.00 Mb ] LU2: 0x1DCB000000 [ 119.17 Gb ] FSN: 536ad5344a53 REG: 0x202010000 CHIP: MT6785 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0813 CODE: Krug TYPE: MODERN [RAPHAEL] RNID: F9FC6E2C7A195C8DD988FB509205B290 MEID: 19492DF48CF23A20CEAC259FFDFB4009 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 50 Select info source... Strategy: [none|generic] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6785__19492DF48CF23A20CEAC259FFDFB4009\ Items to check: 20 Read [25] NVRAM Read [15] NVDATA Read [24] PROINFO Read [41] LK Read [14] NVCFG Read [19] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 Read [8] OPPO_CUSTOM Read [26] OCDT Read [38] CDT_ENGINEERING Done 13 files Compress: C:\InfinityBox\CM2MT2\backup\MT6785__19492DF48CF23A20CEAC259FFDFB4009\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6785__19492DF48CF23A20CEAC259FFDFB4009.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:01:06 Reconnect Power/Cable now |
![]() | #74730 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,369 | Infinix X625c MT6757 One Click FRP/Pattren Reset Done With King Infinity CM2 Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM293) MODE [0]: BOOTROM; PORT: 293 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6757 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0551 CODE: Kibo TYPE: MODERN [RAPHAEL] MEID: B0B4164FEB6F7BCB2F0318B765679FB1 BROM: Sec Level: 0x000000E0 Mode: EXT VER: 0x05 BL: 0xFE [BOOTROM] EMI loaded by MEID: B0B4164FEB6F7BCB2F0318B765679FB1 AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Switch to v2216 Found MT6757 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init Ok EMI: FireFly preloader_x625c64_h576.bin with 4 memory type(s) 1. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 2. eMMC LP_DDR4X ID: 150100575831364D42 Ven: Samsung | Dev: WX16MB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100574331364D42 Ven: Samsung | Dev: WC16MB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x200000000 [ 8.00 Gb ] EMMC CID: 90014A484347386134A216007785B531 VEN: Hynix OEM: 330 ID: 484347386134 [HCG8a4] PRV: 0xA2 SNN: 369129349 [0x16007785] MM/YY: 11/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6757 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0551 CODE: Kibo TYPE: MODERN [RAPHAEL] RNID: E01F56E1BA01682693C07D30AE083CAB MEID: B0B4164FEB6F7BCB2F0318B765679FB1 USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM294) MODE: PRELOADER PORT; PORT: 294 Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 33 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: X625C-H576CD-P-200528V131 SW Version: CD-200528V131 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-06-05 Build Time: 27/05/2020 6:22:10 pm Product Model: Infinix X625C Product Brand: Infinix Product Name: H576CD Product Device: Infinix-X625C CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: alps Product Info: x625c64_h576 SW: full_x625c64_h576-user 9 PPR1.180610.011 60319 release-keys Product Board: Infinix-X625C Board Platform: mt6757 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6757__B0B4164FEB6F7BCB2F0318B765679FB1\ Items to check: 20 Read [8] NVRAM Read [32] NVDATA Read [24] PROINFO Read [9] LK Read [31] NVCFG Read [19] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6757__B0B4164FEB6F7BCB2F0318B765679FB1\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6757__B0B4164FEB6F7BCB2F0318B765679FB1.7z Verified Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:00:40 Reconnect Power/Cable now |
