![]() | #74776 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Realme c21y reset frp done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : C21Y_C25Y_RMX3261_RMX3262_RMX3263 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:20 |
![]() | #74777 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Infinix hot 10i reset frp done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Infinix : PR652B Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:57 |
![]() | #74778 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Vivo y12s v2026 frp reset frp done by cm2 S/N: 73CA70CC v0156 Chinese Miracle II - MT2 Service Tool v2.47 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 0 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device User break 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: C624EB52B0A0237EAB789B8E1E9B86F2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 442071C0F20F4244C5C0FE8CE34A041F555DA3FF638CA5B54E 72407E9669D1A5 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Not Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100444836444142022118CA639799 VEN: Samsung OEM: 256 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 555272803 [0x2118CA63] MM/YY: 9/2020 EMI: Init [0] via Internal database EMI: Init Ok EMI: INFINITY PRELOADER_INFINITY_0 with 1 memory type(s) EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100444836444142022118CA639799 VEN: Samsung OEM: 256 ID: 444836444142 [DH6DAB] PRV: 0x02 SNN: 555272803 [0x2118CA63] MM/YY: 9/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: FD74A761D6A0876ACA88E7E6337C90E1 MEID: C624EB52B0A0237EAB789B8E1E9B86F2 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Select info source... Ok SW: vivo/2026/2026:11/RP1A.200720.012/compiler0504145542:user/release-keys Product Brand: vivo Product Device: 2026 Product Model: V2026 Product Name: 2026 Patch Level: RP1A.200720.012 Display ID: RP1A.200720.012 release-keys Product Info: k65v1_64_bsp SW: full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20230504.145730 release-keys SW Version: eng.compil.20230504.145730 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2023-05-01 Build Time: 5/4/2023 6:55:42 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Board: k65v1_64_bsp Board Platform: mt6765 Product Manfct: vivo Strategy: [vivo] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__C624EB52B0A02 37EAB789B8E1E9B86F2 Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:34 Reconnect Power/Cable now |
![]() | #74779 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 47 | oppo A59s smart reset done Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM33) MODE [0]: BOOTROM; PORT: 33 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] MEID: 930DA257C8D1C403FB7239D57DE54000 BROM: Sec Level: 0x00000001 Mode: SBC VER: 0x05 BL: 0xFE [BOOTROM] AGENT: AUTO: 0_base: base_v2112 [0656ff20] C:\InfinityBox\CM2MT2\boot\0_base\base_v2112\MTK_A llInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init [0] via Internal database EMI: Init Ok EMI: INFINITY PRELOADER_INFINITY_0 with 2 memory type(s) EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100525831344D42077D70D47CC305 Ven: Samsung OEM: 256 ID: 525831344D42 [RX14MB] PRV: 0x07 SNN: 2104546428 [0x7D70D47C] MM/YY: 12/2016 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6750 TYPE: LEGACY [MTK] RNID: AC46EF83D4093BB5FBF6EBEC77234B68 MEID: 930DA257C8D1C403FB7239D57DE54000 USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM15) MODE: PRELOADER PORT; PORT: 15 Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 33 Select info source... Ok Product Model: OPPO A59s Product Brand: OPPO Product Name: A59 Product Device: A59 Product Board: full_oppo6750_15131 Product Info: oppo6750_15131 SW Version: A.18 SW OTA Version: A59s_11.A.18_0180_201909301821 SW OTA Name: A59s_11_A.18_190930 Display ID: A59s_11_A.18_190930 Kernel Info: 3.10.72-G201909301821 Sec. Patch: 2018-03-05 Patch Level: LMY47I SW Version: 1569840696 Ver. CodeName: REL Ver. Release: 5.1 Build Time: 9/30/2019 10:54:54 AM CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO Board Platform: mt6750 SW: full_oppo6750_15131-user 5.1 LMY47I 1569840696 dev-keys Strategy: [oppo] SmartInfo: Android Ver: 5 UserDataFS: 0x01 [ext4|4+] CacheFS: 0x01 [ext4|4+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6755__930DA257C8D1C 403FB7239D57DE54000 Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP Stage: SMART Done: 00:01:09 Reconnect Power/Cable now |
![]() | #74780 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,088 | Vivo 1820 Password done by TP Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM6) MODE [0]: BOOTROM; PORT: 6 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 41B4BDDAC1093DD693B9F27278033069 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 25FF327D3436EF4C1C8E51400935265B2AB1C2EF152145CFF7 1318A336548642 SLA: Sending Auth SLA: Auth accepted SLA: Challenge not used AGENT: AUTO: Vivo: SEC_MT6765 [d05d9b7e] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_MT6765\MTK_All InOne_DA.af91cc0b.bin [766cb13d] C:\InfinityBox\CM2MT2\boot\Vivo\SEC_MT6765\auth_sv 5.auth Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init [0] via Internal database EMI: Init Ok EMI: INFINITY PRELOADER_INFINITY_0 with 3 memory type(s) EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x20000000 [ 512.00 Mb ] EMMC CID: 150100514436334D42011D1A6A8437BF Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 488270468 [0x1D1A6A84] MM/YY: 3/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: AB9D0AC6842406C22B625D860A8FBDC0 MEID: 41B4BDDAC1093DD693B9F27278033069 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: O11019 Display ID: O11019 release-keys SW Version: 1673598274 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-10-01 Build Time: 1/13/2023 8:24:28 AM Product Model: vivo 1820 Product Brand: vivo Product Name: PD1818HF_EX Product Device: PD1818HF_EX CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: vivo Product Info: k62v1_64_bsp SW: full_k62v1_64_bsp-user 8.1.0 O11019 1673598274 release-keys Product Board: k62v1_64_bsp Board Platform: mt6765 Strategy: [vivo] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Finished Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__41B4BDDAC1093 DD693B9F27278033069 Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP Stage: SMART Format Vendor Extra Ok Done: 00:00:29 Reconnect Power/Cable now |
![]() | #74781 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 3,004 | TECNO-KD7 Frp Code: SW: TECNO/KD7-GL/TECNO-KD7:10/QP1A.190711.020/FQRSTU-GL-220311V417:user/release-keys Product Brand: TECNO Product Device: TECNO-KD7 Product Model: TECNO KD7 Product Name: KD7-GL Patch Level: QP1A.190711.020 Display ID: KD7-H6211FQRSTU-Q-GL-220311V417 SW Version: FQRSTU-GL-220311V417 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-03-05 Build Time: 10/03/2022 6:15:24 pm CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: kd7_h6211 SW: full_kd7_h6211-user 10 QP1A.190711.020 255194 release-keys Product Board: TECNO-KD7 Board Platform: mt6765 Product Manfct: TECNO MOBILE LIMITED Strategy: [none|generic] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KD7_OSv10_KD7-H6211FQRSTU-Q-GL-220311V417_QP1A.190711.020_kd7_h6211 Verify firmware [MT6765_TECNO_MOBILE_LIMITED_TECNO_KD7_OSv10_KD7-H6211FQRSTU-Q-GL-220311V417_QP1A.190711.020_kd7_h6211]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_MP_V94_4_P52 Analyze nvram... NVRAM: Items: 0xA3 Size: 0x101A3C State: Ok WiFi MAC: 08ED9DB66DD2 BlTh MAC: 08ED9DB66DD1 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_kd7_h6211.bin with 17 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 90014A68433861652E Ven: Hynix | Dev: hC8ae. RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_kd7_h6211.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_kd7_h6211.bin [4704871a]... Exist Done: 00:00:37 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM8) MODE [0]: PRELOADER PORT; PORT: 8 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: 4DEDE37BEAC9BCFE615B368FE4590C68 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 5D3B9A6CCC56FBFA56BBE9715CCBE389A3496E885F2B63C7B363D3A8DF99E8D5 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 4DEDE37BEAC9BCFE615B368FE4590C68 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100445036444142021244CE0F77A5 VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 306499087 [0x1244CE0F] MM/YY: 7/2020 EMI: Init Ok EMI: FireFly preloader_kd7_h6211.bin with 17 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 150100444836444D42 Ven: Samsung | Dev: DH6DMB RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 5. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 6.00 Gb 10. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 12. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 17. eMMC LP_DDR4X ID: 90014A68433861652E Ven: Hynix | Dev: hC8ae. RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100445036444142021244CE0F77A5 VEN: Samsung OEM: 256 ID: 445036444142 [DP6DAB] PRV: 0x02 SNN: 306499087 [0x1244CE0F] MM/YY: 7/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: 2D881937891BD069B5FE59E71FCF92C7 MEID: 4DEDE37BEAC9BCFE615B368FE4590C68 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 41 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:28 Reconnect Power/Cable now |
![]() | #74782 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Infinix-X693 Flash Code: Operation: Write Flash [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [-] Safe Erase [Upgrade] [+] Check compatibility [-] Backup [-] UserData Safe [+] FLASH ERASE Files: 18 [FL]: C:\Users\Farhan\Downloads\Compressed\INFINIX-NOTE-10-X693-H697BCDEFTU-R-GL-211102V736\ preloader_x693_h697.bin [ 301.26 Kb ] tkv.img [ 1.00 Mb ] vbmeta.img [ 4.00 Kb ] vbmeta_system.img [ 4.00 Kb ] vbmeta_vendor.img [ 4.00 Kb ] md1img.img [ 54.68 Mb ] spmfw.img [ 37.09 Kb ] scp.img [ 558.45 Kb ] sspm.img [ 493.06 Kb ] gz.img [ 2.47 Mb ] lk.img [ 1.08 Mb ] logo.bin [ 1.30 Mb ] boot.img [ 32.00 Mb ] dtbo.img [ 8.00 Mb ] tee.img [ 1.99 Mb ] super.img [ 5.78 Gb ] tranfs.img [ 60.14 Kb ] userdata.img [ 2.23 Mb ] Total size: 0x1786AD56C [ 5.88 Gb ] SW: Infinix/X693-GL/Infinix-X693:11/RP1A.200720.011/211102V601:user/release-keys Product Brand: Infinix Product Device: Infinix-X693 Product Model: Infinix X693 Product Name: X693-GL Patch Level: RP1A.200720.011 Display ID: X693-H697BCDEFTU-R-GL-211102V601 SW Version: 211102V601 Ver. CodeName: REL Ver. Release: 11 Sec. Patch: 2021-10-05 Build Time: 02/11/2021 2:28:11 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x693_h697 SW: vnd_x693_h697-user 11 RP1A.200720.011 183543 release-keys Product Board: Infinix-X693 Board Platform: mt6768 Product Manfct: INFINIX MOBILITY LIMITED Firmware ID: MT6768_INFINIX_MOBILITY_LIMITED_Infinix_X693_OSv11_X693-H697BCDEFTU-R-GL-211102V601_RP1A.200720.011_x693_h697 Verify firmware [INFINIX-NOTE-10-X693-H697BCDEFTU-R-GL-211102V736]... Verify firmware [MT6768_INFINIX_MOBILITY_LIMITED_Infinix_X693_OSv11_X693-H697BCDEFTU-R-GL-211102V601_RP1A.200720.011_x693_h697]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 7862721615C526F171516153886F5C4A BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: C783B5C2BEEC49466C91A6F12DA6B53D14E6C395412C44C0B60290BBF340623B SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 7862721615C526F171516153886F5C4A AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin [a36465bd] C:\Users\Farhan\Downloads\Compressed\INFINIX-NOTE-10-X693-H697BCDEFTU-R-GL-211102V736\preloader_x693_h697.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100335636434142027029D4885857 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 1881789576 [0x7029D488] MM/YY: 5/2021 EMI: Init via preloader_x693_h697.bin EMI: Init Ok EMI: MT6752 preloader_x693_h697.bin with 15 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 150100335036434D42 Ven: Samsung | Dev: 3P6CMB RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 150100335636434242 Ven: Samsung | Dev: 3V6CBB RAM: 6.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 150100335636434142027029D4885857 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 1881789576 [0x7029D488] MM/YY: 5/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 9B2B1BFD24936925FC2DC054E385608B MEID: 7862721615C526F171516153886F5C4A USB: HIGH-SPEED Boot done MODERN [RAPHAEL] HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 51 Verify device config... Ok Loaders Ok Verify PMT... Ok Verify SEC DL... Pre-Erase... Whole Flash Erase: On Erase: 0x0000000000000000 0x0000001D1EC00000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 51 Flash write... Write: PRELOADER [ 301.26 Kb ] Update bootloader backup copy... Ok Write: TKV_A [ 1.00 Mb ] Ok Write: VBMETA_A [ 4.00 Kb ] Ok Write: VBMETA_SYSTEM_A [ 4.00 Kb ] Ok Write: VBMETA_VENDOR_A [ 4.00 Kb ] Ok Write: MD1IMG_A [ 54.68 Mb ] Write: SPMFW_A [ 37.09 Kb ] Ok Write: SCP_A [ 558.45 Kb ] Ok Write: SSPM_A [ 493.06 Kb ] Ok Write: GZ_A [ 2.47 Mb ] Ok Write: LK_A [ 1.08 Mb ] Ok Write: LOGO_A [ 1.30 Mb ] Ok Write: BOOT_A [ 32.00 Mb ] Ok Write: DTBO_A [ 8.00 Mb ] Ok Write: TEE_A [ 1.99 Mb ] Ok Write: SUPER [ 5.78 Gb ] Ok Write: TRANFS [ 60.14 Kb ] Ok Write: USERDATA [ 2.23 Mb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:05:24 Reconnect Power/Cable now |
![]() | #74783 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Infinix-X690 Frp Code: SW: Infinix/X690-GL/Infinix-X690:10/QP1A.190711.020/BCFG-GL-220215V382:user/release-keys Product Brand: Infinix Product Device: Infinix-X690 Product Model: Infinix X690 Product Name: X690-GL Patch Level: QP1A.190711.020 Display ID: X690-H691BCFG-Q-GL-220215V382 SW Version: BCFG-GL-220215V382 Ver. CodeName: REL Ver. Release: 10 Sec. Patch: 2022-02-05 Build Time: 15/02/2022 8:02:46 am CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Info: x690_h691 SW: full_x690_h691-user 10 QP1A.190711.020 240291 release-keys Product Board: Infinix-X690 Board Platform: mt6768 Product Manfct: INFINIX MOBILITY LIMITED Strategy: [none|generic] Firmware ID: MT6768_INFINIX_MOBILITY_LIMITED_Infinix_X690_OSv10_X690-H691BCFG-Q-GL-220215V382_QP1A.190711.020_x690_h691 Verify firmware [MT6768_INFINIX_MOBILITY_LIMITED_Infinix_X690_OSv10_X690-H691BCFG-Q-GL-220215V382_QP1A.190711.020_x690_h691]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FBE [file based encryption] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6768_S00.MOLY_LR12A_R3_MP_V94_4_P48 Analyze nvram... NVRAM: Items: 0xB9 Size: 0x1221EF State: Ok WiFi MAC: AA0036004400 BlTh MAC: 80795DCD9716 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6752 preloader_x690_h691.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x690_h691.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x690_h691.bin [e1d26880]... Exist Done: 00:00:33 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: ADECA2DBF23FF2F889D19C098F60A945 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 480C4DCAEF2797868F9A4C7E9E30F346CBE70D7BA1034D2A3BF8EFE2BAD61A1F SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: ADECA2DBF23FF2F889D19C098F60A945 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 13014E53304A394B39101B45073757C7 VEN: Micron OEM: 334 ID: 53304A394B39 [S0J9K9] PRV: 0x10 SNN: 457508663 [0x1B450737] MM/YY: 5/2020 EMI: Init Ok EMI: FireFly preloader_x690_h691.bin with 6 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 13014E53304A394B39101B45073757C7 VEN: Micron OEM: 334 ID: 53304A394B39 [S0J9K9] PRV: 0x10 SNN: 457508663 [0x1B450737] MM/YY: 5/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1F000000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: 9B7995A1B9668E8A0E1ABEB783C457A6 MEID: ADECA2DBF23FF2F889D19C098F60A945 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:00:22 Reconnect Power/Cable now |
![]() | #74784 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | LG-SP320 Frp Code: Patch Level: NMF26X Display ID: NMF26X SW Version: 1925219375c23 Ver. CodeName: REL Ver. Release: 7.1.1 Sec. Patch: 2019-09-01 Build Time: 09/09/2019 10:37:23 am Product Model: LG-SP320 Product Brand: lge Product Name: mlv7_spr_us Product Device: mlv7 Product Board: mt6755 CPU: armeabi-v7a,armeabi Product Manfct: LGE Board Platform: mt6750 Product Info: mlv7 SW: mlv7_spr_us-user 7.1.1 NMF26X 1925219375c23 release-keys Strategy: [none|generic] Firmware ID: MT6750_LGE_LG-SP320_OSv7.1.1_1925219375c23_NMF26X_mlv7_lge Verify firmware [MT6750_LGE_LG-SP320_OSv7.1.1_1925219375c23_NMF26X_mlv7_lge]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem [ext4] Analyze modem... MLV7_SPR_US_MDBIN_PCB01_MT6750_S00.MOLY_LR11_W1552_MD_TC01_SPRT_SP_V1_P2_T11 Analyze nvram... NVRAM: Items: 0x3F9 Size: 0x21B254 State: Ok WiFi MAC: 000000000000 BlTh MAC: 76EADB40292D Verify device config... Ok Loaders Ok STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : NOT Enabled! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6755 preloader_muse6750_lv7_n.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100514531334D42 Ven: Samsung | Dev: QE13MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A483847316505 Ven: Hynix | Dev: H8G1e RAM: 1.50 Gb 4. eMMC DDR3 ID: 90014A484247346505 Ven: Hynix | Dev: HBG4e RAM: 3.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 3.00 Gb 6. eMMC DDR3 ID: 150100513331334D42 Ven: Samsung | Dev: Q313MB RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100523231424D42 Ven: Samsung | Dev: R21BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_muse6750_lv7_n.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_muse6750_lv7_n.bin [a3df8018]... Stored Done: 00:00:46 Reconnect Power/Cable now Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: USB Serial Device (COM28) MODE [0]: PRELOADER PORT; PORT: 28 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x02 [PRELOADER PORT] AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... Reset Interface PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0326 TYPE: MODERN [RAPHAEL] MEID: 90117812E413BA8DEAA9532316AF9C92 BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0x05 BL: 0xFE [BOOTROM] SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth libusb exec warn ctrl_msg1 v1.2.6.0 0x0A Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x00000001 EMI loaded by MEID: 90117812E413BA8DEAA9532316AF9C92 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6755 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMI: Init Ok EMI: FireFly preloader_muse6750_lv7_n.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100514531334D42 Ven: Samsung | Dev: QE13MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A483847316505 Ven: Hynix | Dev: H8G1e RAM: 1.50 Gb 4. eMMC DDR3 ID: 90014A484247346505 Ven: Hynix | Dev: HBG4e RAM: 3.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Ven: Hynix | Dev: HBG4a2 RAM: 3.00 Gb 6. eMMC DDR3 ID: 150100513331334D42 Ven: Samsung | Dev: Q313MB RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100523231424D42 Ven: Samsung | Dev: R21BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00038000 [ 224.00 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514536334D420361D1F05D7583 VEN: Samsung OEM: 256 ID: 514536334D42 [QE63MB] PRV: 0x03 SNN: 1641148509 [0x61D1F05D] MM/YY: 7/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x3A3E00000 [ 14.56 Gb ] CHIP: MT6755 SBID: 0x8A00 HWVR: 0xCB00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x6750 TYPE: LEGACY [MTK] RNID: 57D6008F02E2993CA357FCA710F03C6C MEID: 90117812E413BA8DEAA9532316AF9C92 USB: FULL-SPEED Change Port Speed PTFN: MediaTek DA USB VCOM (Android) (COM6) MODE: PRELOADER PORT; PORT: 6 Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:01:11 Reconnect Power/Cable now |
![]() | #74785 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Infinix-X6817 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek PreLoader USB VCOM (Android) (COM8) MODE [0]: PRELOADER PORT; PORT: 8 Waiting for BOOT ACK... PRELOADER ACK Ok BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] BROM: Sec Level: 0x00000005 Mode: SBC+SDA VER: 0xFF BL: 0x03 [PRELOADER PORT] AGENT: AUTO: Tecno: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: PRELOADER EXT_RAM initialized DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010033563643424202FDD0DCF829EF VEN: Samsung OEM: 256 ID: 335636434242 [3V6CBB] PRV: 0x02 SNN: 4258323704 [0xFDD0DCF8] MM/YY: 2/2022 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: EBA514B3A45B0E401E954F220E74A78E USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Select info source... Ok Product Brand: Infinix Product Device: Infinix-X6817 Product Model: Infinix X6817 Product Name: X6817-OP SW: Infinix/X6817-OP/Infinix-X6817:12/SP1A.210812.016/230416V1460:user/release-keys Patch Level: SP1A.210812.016 Display ID: X6817-H6920ABCDEFHIJ-S-OP-230416V1460 SW Version: 230416V1460 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-04-05 Build Time: 15/04/2023 6:05:07 pm Product Info: x6817_h6920 SW: vnd_x6817_h6920-user 12 SP1A.210812.016 302007 release-keys Product Manfct: INFINIX Product Board: Infinix-X6817 Board Platform: mt6768 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:01:01 Reconnect Power/Cable now |
![]() | #74786 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: lullipapi
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,369 | Relme C2 RMX1941 One Click FRP/Pattren Reset Done With King Infinity CM2 Code: S/N: A19EC787 v0155 Chinese Miracle II - MT2 Service Tool v2.46 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 73 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 76 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM217) MODE [0]: BOOTROM; PORT: 217 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: AA2C9CFD95718C3AE928D469EBCB735C BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 86AA14343CE9ED20FB2BE2587AF57EC3788C05310DC00B23A734B6A862A1856B SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: AA2C9CFD95718C3AE928D469EBCB735C AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100474436424D42017EA668B6566B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2124834998 [0x7EA668B6] MM/YY: 5/2019 EMI: Init Ok EMI: FireFly preloader_oppo6762_18540.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100515836334142 Ven: Samsung | Dev: QX63AB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 4. eMMC DDR3 ID: 13014E53304A394237 Ven: Micron | Dev: S0J9B7 RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 6. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb 9. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100474436424D42017EA668B6566B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 2124834998 [0x7EA668B6] MM/YY: 5/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B840AFDE13D3D173EF22680B9EA9A417 MEID: AA2C9CFD95718C3AE928D469EBCB735C USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 42 Select info source... Ok Patch Level: PPR1.180610.011 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-05-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: Realme SW: full_oppo6762_18540-user 9 PPR1.180610.011 eng.root.20210508.122048 release-keys Build Time: 08/05/2021 4:23:54 am Product Brand: Realme Product Model: RMX1941 Product Info: RMX1941 Product Name: RMX1941 Product Device: RMX1941 SW OTA Version: RMX1941EX_11.A.34_0340_202105081158 Display ID: RMX1941EX_11_A.34 Kernel Info: 4.9.117 Strategy: [oppo] SmartInfo: Android Ver: 9 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__AA2C9CFD95718C3AE928D469EBCB735C\ Items to check: 20 Read [29] NVRAM Read [13] NVDATA Read [20] PROINFO Read [30] LK Read [12] NVCFG Read [15] PROTECT1 Read [1] PGPT Read [18] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6765__AA2C9CFD95718C3AE928D469EBCB735C\opporeserve3.bin Read [8] OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__AA2C9CFD95718C3AE928D469EBCB735C\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__AA2C9CFD95718C3AE928D469EBCB735C.7z Finished Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:01:16 Reconnect Power/Cable now |
![]() | #74787 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Qmobile i6 metal one reset frp done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:53 |
![]() | #74788 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Gfive 3 sim king reset password done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Format FFS Done! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
![]() | #74789 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Qmobile night club 2020 reset password done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.07 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.07 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1E7 D065E871C_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
![]() | #74790 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Vgo tel super jumbo hang on logo done by cm2 Card found : S/N : 73CA70CC , v0156 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 184F96DABB9D629899D2A7ADBEC6D7A6 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x0039A000-0x003FDFFF , LEN : 0x00064000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
