![]() | #74791 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,778 | QMOBILE SP1000 RESET PASSWORD DONE BY CM2 Card found : S/N : 73CA70CC , v0156 Chinese Miracle II [MTK module] v 1.58 Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 3 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 087CD88939EDF6F71A765D51257CB74C BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
![]() | #74792 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Itel l5006 a23 pro reset frp done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : MANUAL LDR Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:26 |
![]() | #74793 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Tecno kc3 reset pattern & frp done by cm2 S/N: 73CA70CC v0156 Chinese Miracle II - MT2 Service Tool v2.47 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 1 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Check for updates [boot-pack]... You have latest version [2.43] installed Check for updates [CM2MT2]... You have latest version [2.47] installed Telegram Channel: @InfinityBox Telegram Chat: @InfinityBoxTalks Account: https://infinity-box.com/service/ Update configuration... Configuration [12192] updated Load IDBase v418494 Ok Operation: Identify Device [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 07005FB9CE523C0789442BE5B47C25A686659D46D864193522 B9E090D275E87F SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok FF: Looking for EMI Found SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433961503301094A3AFF86FF Ven: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 155859711 [0x094A3AFF] MM/YY: 8/2019 EMI: Init Ok EMI: FireFly preloader_kc3_h627mt62.bin with 8 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525836344D42 Samsung RX64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433961503301094A3AFF86FF Ven: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 155859711 [0x094A3AFF] MM/YY: 8/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B455E5FA8E0C5B284013C81C4FDF0E04 MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: KC3-H627G-P-200925V311 SW Version: G-200925V311 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-10-05 Build Time: 9/25/2020 4:33:38 AM Product Model: TECNO KC3 Product Brand: TECNO Product Name: H627 Product Device: TECNO-KC3 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: TECNO MOBILE LIMITED Product Info: kc3_h627mt62 SW: full_kc3_h627mt62-user 9 PPR1.180610.011 42095 release-keys Product Board: TECNO-KC3 Board Platform: mt6765 Strategy: [none|generic] Firmware ID: MT6765_TECNO_MOBILE_LIMITED_TECNO_KC3_OSv9_KC3-H627G-P-200925V311_PPR1.180610.011_kc3_h627mt62 Verify firmware [MT6765_TECNO_MOBILE_LIMITED_TECNO_KC3_OSv9_KC3-H627G-P-200925V311_PPR1.180610.011_kc3_h627mt62]... Firmware is unknown Please upload https://infinity-box.com/?r=100020 Analyze userdata... userData: fileSystem : [f2fs] with FDE [forced encrypt] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R3_M P_V71_11_P23 Analyze nvram... NVRAM: Items: 0xA1 Size: 0x08BF71 State: Ok WiFi MAC: 783A6CA29D07 BlTh MAC: 783A6CA29D06 IMEI[1]: 359070101656668 IMEI[2]: 359070101656676 Verify device config... Ok Loaders Ok Backup to C:\InfinityBox\CM2MT2\backup\MT6765__AC0FFC9C2A5E1 C2A56E6C51E56A58FC3\ Items to check: 20 Read [12] NVRAM Read [37] NVDATA Read [29] PROINFO Read [13] LK Read [36] NVCFG Read [24] PROTECT1 Read [1] PGPT Read [23] PERSIST Read [0] PRELOADER Done 9 files Compress: C:\InfinityBox\CM2MT2\backup\MT6765__AC0FFC9C2A5E1 C2A56E6C51E56A58FC3\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6765__AC0FFC9C2A5E1 C2A56E6C51E56A58FC3.7z Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6765 preloader_kc3_h627mt62.bin with 8 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525836344D42 Samsung RX64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_k c3_h627mt62.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_k c3_h627mt62.bin [2faaf7d7]... Exist Done: 00:00:57 Reconnect Power/Cable now Reset Mode: Safe Reset by device requirements: UserData + FRP + Account(s) Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 07005FB9CE523C0789442BE5B47C25A686659D46D864193522 B9E090D275E87F SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433961503301094A3AFF86FF Ven: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 155859711 [0x094A3AFF] MM/YY: 8/2019 EMI: Init Ok EMI: FireFly preloader_kc3_h627mt62.bin with 8 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 3. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 5. eMMC DDR3 ID: 90014A484247346132 Hynix HBG4a2 RAM: 4.00 Gb 6. eMMC DDR3 ID: 150100525836344D42 Samsung RX64MB RAM: 4.00 Gb 7. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 8. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433961503301094A3AFF86FF Ven: Hynix OEM: 330 ID: 684339615033 [hC9aP3] PRV: 0x01 SNN: 155859711 [0x094A3AFF] MM/YY: 8/2019 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B455E5FA8E0C5B284013C81C4FDF0E04 MEID: AC0FFC9C2A5E1C2A56E6C51E56A58FC3 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 39 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: KC3-H627G-P-200925V311 SW Version: G-200925V311 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2020-10-05 Build Time: 9/25/2020 4:33:38 AM Product Model: TECNO KC3 Product Brand: TECNO Product Name: H627 Product Device: TECNO-KC3 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: TECNO MOBILE LIMITED Product Info: kc3_h627mt62 SW: full_kc3_h627mt62-user 9 PPR1.180610.011 42095 release-keys Product Board: TECNO-KC3 Board Platform: mt6765 Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6765__AC0FFC9C2A5E1 C2A56E6C51E56A58FC3 Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP Stage: SMART Done: 00:00:36 Reconnect Power/Cable now |
![]() | #74794 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 47 | oppo f11 flash done with cm2 Operation: Write Flash [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Wait... [+] Update PMT [re-Part] [-] Checksum Verify [+] Safe Erase [Upgrade] [+] Check compatibility [+] Backup [-] FLASH ERASE Files: 24 [FL]: C:\Users\Ahmed gsm\Downloads\Compressed\CPH1911_11_F.19_202202132 0390949_GsmMafia.Com\CPH1911_11_F.19_2022021320390 949_GsmMafia.Com\CPH1911_11_F.19_2022021320390949. ofp2bin\ preloader_oppo6771.bin [ 293.90 Kb ] recovery.img [ 64.00 Mb ] opporeserve2.img [ 5.05 Mb ] md1img.img [ 84.55 Mb ] spmfw.img [ 51.47 Kb ] scp.img [ 604.16 Kb ] scp.img [ 604.16 Kb ] sspm.img [ 484.47 Kb ] sspm.img [ 484.47 Kb ] cam_vpu1.img [ 1.58 Mb ] cam_vpu2.img [ 12.28 Mb ] cam_vpu3.img [ 7.66 Mb ] lk.img [ 2.35 Mb ] lk.img [ 2.35 Mb ] boot.img [ 32.00 Mb ] logo.bin [ 4.83 Mb ] dtbo.img [ 703.27 Kb ] tee.img [ 891.83 Kb ] tee.img [ 891.83 Kb ] odm.img [ 125.50 Mb ] vendor.img [ 853.44 Mb ] system.img [ 4.94 Gb ] cache.img [ 68.17 Kb ] userdata.img [ 303.82 Mb ] Total size: 0x199DF9418 [ 6.40 Gb ] 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM33) MODE [0]: BOOTROM; PORT: 33 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6771 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0788 CODE: Sylvia TYPE: MODERN [RAPHAEL] MEID: 280D886B01C5EC267297C8C8331BBFF2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 18EDF95DF50E15A6FB1247EBD5EDD8F7EECDC24802CFC5E8C2 45AFF304115DBF SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth libusb exec warn ctrl_msg1 v1.2.7.3 0x0A Ok SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.bin [4430c4a4] C:\Users\Ahmed gsm\Downloads\Compressed\CPH1911_11_F.19_202202132 0390949_GsmMafia.Com\CPH1911_11_F.19_2022021320390 949_GsmMafia.Com\CPH1911_11_F.19_2022021320390949. ofp2bin\preloader_oppo6771.bin Looking for suitable BootChain in DA... Found MT6771 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68433861503E0349706D38C54F Ven: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1232104760 [0x49706D38] MM/YY: 12/2018 EMI: Init via preloader_oppo6771.bin EMI: Init Ok EMI: MT6752 preloader_oppo6771.bin with 26 memory type(s) 1. eMMC LP_DDR4X ID: 150100445636444D42 Samsung DV6DMB RAM: 4.00 Gb 2. eUFS LP_DDR4X Dev: KM5V8001DM-B622 RAM: 4.00 Gb 3. eMMC LP_DDR4X ID: 150100335636434D42 Samsung 3V6CMB RAM: 6.00 Gb 4. eUFS LP_DDR4X Dev: KM5V7001DM-B621 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100334836434142 Samsung 3H6CAB RAM: 6.00 Gb 6. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 6.00 Gb 7. eMMC LP_DDR4X ID: 13014E53304A394B39 Micron S0J9K9 RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 150100444836444142 Samsung DH6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 90014A68433861503E Hynix hC8aP> RAM: 4.00 Gb 10. eUFS LP_DDR4X Dev: MT128GASAO4U21 RAM: 6.00 Gb 11. eUFS LP_DDR4X Dev: MT128GASAO4U21 RAM: 8.00 Gb 12. eMMC LP_DDR4X ID: 13014E53304A394B38 Micron S0J9K8 RAM: 4.00 Gb 13. eMMC LP_DDR4X ID: 13014E53304A394D39 Micron S0J9M9 RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 13014E53304A394438 Micron S0J9D8 RAM: 4.00 Gb 15. eUFS LP_DDR4X Dev: KM2B8001CM-BB01 RAM: 6.00 Gb 16. eMMC LP_DDR4X ID: 450100444134313238 Sandisk DA4128 RAM: 4.00 Gb 17. eUFS LP_DDR4X Dev: KM8V7001JM-B810 RAM: 8.00 Gb 18. eUFS LP_DDR4X Dev: KM2V8001CM-B707 RAM: 6.00 Gb 19. eUFS LP_DDR4X Dev: KM8B8001JM-BC01 RAM: 8.00 Gb 20. eUFS LP_DDR4X Dev: H9HQ22AECMMDAR RAM: 6.00 Gb 21. eUFS LP_DDR4X Dev: KM8V8001JM-B813 RAM: 8.00 Gb 22. eUFS LP_DDR4X Dev: MT128GASAO4U21 RAM: 4.00 Gb 23. eUFS LP_DDR4X Dev: H28S8Q302CMR RAM: 6.00 Gb 24. eUFS LP_DDR4X Dev: H9HQ16AFAMMDAR RAM: 8.00 Gb 25. eUFS LP_DDR4X Dev: H9HQ22AFAMMDAR RAM: 8.00 Gb 26. DRAM LP_DDR4X ID: NOT_DEFINED Unknown 0x0000 RAM: 6.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00040000 [ 256.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 90014A68433861503E0349706D38C54F Ven: Hynix OEM: 330 ID: 68433861503E [hC8aP>] PRV: 0x03 SNN: 1232104760 [0x49706D38] MM/YY: 12/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0xE8F800000 [ 58.24 Gb ] CHIP: MT6771 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0788 CODE: Sylvia TYPE: MODERN [RAPHAEL] RNID: 2C0B7ECA28D6DD62980D84412A7426F7 MEID: 280D886B01C5EC267297C8C8331BBFF2 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] [FL]: COMBO scatter! Update settings to eMMC [FL]: Set: preloader_oppo6771.bin [FL]: Set: recovery.img [FL]: Set: opporeserve2.img [FL]: Set: md1img.img [FL]: Set: spmfw.img [FL]: Set: scp.img [FL]: Set: scp.img [FL]: Set: sspm.img [FL]: Set: sspm.img [FL]: Set: cam_vpu1.img [FL]: Set: cam_vpu2.img [FL]: Set: cam_vpu3.img [FL]: Set: lk.img [FL]: Set: lk.img [FL]: Set: boot.img [FL]: Set: logo.bin [FL]: Set: dtbo.img [FL]: Set: tee.img [FL]: Set: tee.img [FL]: Set: odm.img [FL]: Set: vendor.img [FL]: Set: system.img [FL]: Set: cache.img [FL]: Set: userdata.img HW verification... HW verification Pass Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 44 Verify device config... Ok Loaders Ok Pre-Flash backup... Backup to C:\InfinityBox\CM2MT2\backup\MT6771__280D886B01C5E C267297C8C8331BBFF2\ Items to check: 20 Read [31] NVRAM Read [12] NVDATA Read [19] PROINFO Read [32] LK Read [11] NVCFG Read [14] PROTECT1 Read [1] PGPT Read [17] PERSIST Read [0] PRELOADER Read [7] OPPORESERVE3 ZERO CONTENT file [64.00 Mb] deleted: C:\InfinityBox\CM2MT2\backup\MT6771__280D886B01C5E C267297C8C8331BBFF2\opporeserve3.bin Read [8] OPPO_CUSTOM Done 10 files Compress: C:\InfinityBox\CM2MT2\backup\MT6771__280D886B01C5E C267297C8C8331BBFF2\ Cleanup... Ok Verify C:\InfinityBox\CM2MT2\backup\MT6771__280D886B01C5E C267297C8C8331BBFF2.7z Finished Verify PMT... Ok Verify SEC DL... Pre-Erase... Erase: 0x0000000000000000 0x0000000004188000 Erase: 0x000000000CA88000 0x0000000001500000 Erase: 0x000000000FF88000 0x0000000006000000 Erase: 0x0000000017000000 0x0000000000800000 Erase: 0x000000001A800000 0x0000000000200000 Erase: 0x000000001AD00000 0x000000000C000000 Erase: 0x000000002AD00000 0x00000003C0B00000 RePartition... RePartition: Ok Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 44 Flash write... Write: PRELOADER [ 293.90 Kb ] Update bootloader backup copy... Ok Write: RECOVERY [ 64.00 Mb ] Ok Write: OPPORESERVE2 [ 5.05 Mb ] Write: MD1IMG [ 84.55 Mb ] Write: SPMFW [ 51.47 Kb ] Ok Write: SCP1 [ 604.16 Kb ] Ok Write: SCP2 [ 604.16 Kb ] Ok Write: SSPM_1 [ 484.47 Kb ] Ok Write: SSPM_2 [ 484.47 Kb ] Ok Write: CAM_VPU1 [ 1.58 Mb ] Ok Write: CAM_VPU2 [ 12.28 Mb ] Ok Write: CAM_VPU3 [ 7.66 Mb ] Ok Write: LK [ 2.35 Mb ] Ok Write: LK2 [ 2.35 Mb ] Ok Write: BOOT [ 32.00 Mb ] Ok Write: LOGO [ 4.83 Mb ] Ok Write: DTBO [ 703.27 Kb ] Ok Write: TEE1 [ 891.83 Kb ] Ok Write: TEE2 [ 891.83 Kb ] Ok Write: ODM [ 125.50 Mb ] Ok Write: VENDOR [ 853.44 Mb ] Ok Write: SYSTEM [ 4.94 Gb ] Ok Write: CACHE [ 68.17 Kb ] Ok Write: USERDATA [ 303.82 Mb ] Ok RePartition... RePartition: Ok Flashing finished Done: 00:06:12 Reconnect Power/Cable now |
![]() | #74795 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: Sindh Pakistan
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,437 | ![]() Operation: Reset Settings/Format FS [ v2.47 ] Platform: FireFly SmartPhone - MT6580/67:35|39|52|53|61|65|68|71 Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port_V1632 (COM4) MODE [0]: BOOTROM; PORT: 4 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6739 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0699 CODE: Zion TYPE: MODERN [RAPHAEL] MEID: 4AC8C610647499F72EC0072832F4E584 BROM: Sec Level: 0x00000000 Mode: PLAIN VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 8DFB65D49483A1179CE4D8C7685B08E25190C902A7E68FD4C0 29D45EDA3CC7E3 FireFly: Init FireFly: Start Auth Ok FireFly: Continue Auth Ok FireFly: Start Ok FireFly: Init Core Ok FireFly: Running: v06.05.06 on MT6739 eMMC init passed Stored: C:\InfinityBox\CM2MT2\backup\ext_csd\MT6739__Samsu ng_F722MB_5.0_extcsd_23082023.bin EMMC CID: 150100463732324D420099931167B733 Ven: Samsung OEM: 256 ID: 463732324D42 [F722MB] PRV: 0x00 SNN: 2576552295 [0x99931167] MM/YY: 11/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] USER: 0x1D2000000 [ 7.28 Gb ] CSD: D02701320F5903FFF6DBFFEF8E406069 TEMP_WRITE_PROTECT: Off PERM_WRITE_PROTECT: On EXTCSD: rev1.7 eMMC 5.0 [CONFIG]: 0x48 0x00 0x01 [PARTITION_CONFIG]: 0x48 [BOOT_BUS_WIDTH]: 0x00 [RST_N_FUNCTION]: 0x01 [PART_S_COMPLETED]: Off [SIZE]: Market: 8 GB [SIZE]: Actual: 0x1D2000000 [ 7.28 GB ] [EOL]: EOL status : Normal (Less than 80% reserved blocks used) [EOL_A]: SLC status : 0% - 10% used [EOL_B]: MLC status : 0% - 10% used USB: HIGH-SPEED Boot done FireFly Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 34 Select info source... Ok Patch Level: O11019 Display ID: DigitOS-0821-M42868DG-V13-20211224-2145 SW Version: 1640353562 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-08-05 Build Time: 24-Dec-21 1:45:59 PM Product Model: Digit4G Energy Product Brand: Digit Product Name: Digit4G_Energy Product Device: Digit4G_Energy CPU: armeabi-v7a,armeabi Product Manfct: Digit Product Info: k31v1_bsp_512 SW: full_k31v1_bsp_512-user 8.1.0 O11019 1640353562 release-keys Product Board: k31v1_bsp_512 Board Platform: mt6739 Strategy: [none|generic] SmartInfo: Android Ver: 8 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP [1] Process... Stage: SMART Done: 00:00:47 Reconnect Power/Cable now |
![]() | #74796 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Pakistan karachi
Member: 314003 Status: Offline Thanks Meter: 3,004 | Infinix-X663 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM9) MODE [0]: BOOTROM; PORT: 9 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] MEID: 0D95A24CBE9B643D88520B2080A3B064 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: CABB1E3A4FB2FCECE79096F662CE704F813EA610F67A23B6AEC02652A843243F SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 0D95A24CBE9B643D88520B2080A3B064 AGENT: AUTO: Infinix: 2023-05 [caf6df7e] C:\InfinityBox\CM2MT2\boot\Infinix\2023-05\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6768 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 15010033563643414202890BDC0B88D9 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 2299255819 [0x890BDC0B] MM/YY: 8/2021 EMI: Init Ok EMI: FireFly preloader_x663_h6915.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 2. eMMC LP_DDR4X ID: 90014A68433861503C Ven: Hynix | Dev: hC8aP< RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 4. eMMC LP_DDR4X ID: 13014E53304A394B39 Ven: Micron | Dev: S0J9K9 RAM: 4.00 Gb 5. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 6. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 7. eMMC LP_DDR4X ID: 150100334836434142 Ven: Samsung | Dev: 3H6CAB RAM: 6.00 Gb 8. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100335636434D42 Ven: Samsung | Dev: 3V6CMB RAM: 6.00 Gb 12. eMMC LP_DDR4X ID: 150100335636434142 Ven: Samsung | Dev: 3V6CAB RAM: 6.00 Gb 13. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 14. eMMC LP_DDR4X ID: 150100445636444242 Ven: Samsung | Dev: DV6DBB RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100335636434242 Ven: Samsung | Dev: 3V6CBB RAM: 6.00 Gb 16. eMMC LP_DDR4X ID: 150100445036444242 Ven: Samsung | Dev: DP6DBB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x00070000 [ 448.00 Kb ] RAM: DRAM: 0x100000000 [ 4.00 Gb ] EMMC CID: 15010033563643414202890BDC0B88D9 VEN: Samsung OEM: 256 ID: 335636434142 [3V6CAB] PRV: 0x02 SNN: 2299255819 [0x890BDC0B] MM/YY: 8/2021 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x1D1EC00000 [ 116.48 Gb ] CHIP: MT6768 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0001 EVOL: 0x0000 HWC: 0x0707 CODE: Talbot TYPE: MODERN [RAPHAEL] RNID: E20ABB3FD41E6D94EF8088C3FFA2C0E0 MEID: 0D95A24CBE9B643D88520B2080A3B064 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 49 Select info source... Ok Product Brand: Infinix Product Device: Infinix-X663 Product Model: Infinix X663 Product Name: X663-GL SW: Infinix/X663-GL/Infinix-X663:12/SP1A.210812.016/230517V377:user/release-keys Patch Level: SP1A.210812.016 Display ID: X663-H6915ABCEFGHIO-S-GL-230517V377 SW Version: 230517V377 Ver. CodeName: REL Ver. Release: 12 Sec. Patch: 2023-05-05 Build Time: 17/05/2023 8:48:18 am Product Info: x663_h6915 SW: vnd_x663_h6915-user 12 SP1A.210812.016 329071 release-keys Product Manfct: INFINIX MOBILITY LIMITED Product Board: Infinix-X663 Board Platform: mt6768 Strategy: [none|generic] SmartInfo: Android Ver: 12 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Verified [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Process USERDATA... Ok Stage : FRP Stage : SMART Done: 00:01:32 Reconnect Power/Cable now |
![]() | #74797 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Infinix X6816C Format & Frp Code: Product Device : Infinix-X6816C Product Name : X6816C-GL Product Model : Infinix X6816C Product Brand : Infinix Ver. Incmt : 230216V14 Display ID : X6816C-ST683SBCDS-R-GL-230216V14 Patch Level : RP1A.201005.001 Display ID : RP1A.201005.001 release-keys Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2023-02-05 Build Time : 16.02.2023 Product Info : X6816C Product Board : X6816C Board Platform : ums512 Product Manfct : INFINIX MOBILITY LIMITED Platform Version: MOCORTM_20A_W22.28.2_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W22.28.2 HW Version: sharkl5pro_modem CMP_Time : 07-12-2022 03:26:58 MODEM TAG : MOCORTM_20A_W22.28.2_Debug_4G_MODEM_20A_W22.28.2_sharkl5pro_modem_sharkl5pro_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:13 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Infinix : infinix-x6816c.18ee29a2.f012a983 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
![]() | #74798 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | VGO_TEL Smart_Hi-Fi Format & Frp Code: Brand : VGO_TEL ProdName : Smart_Hi-Fi ProdModel : Smart Hi-Fi Device : Smart_Hi-Fi AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : alps-mp-k0.kaios.mp1-V3.108_fise6572.kaia.k_P1 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110213014174B429 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110213014174B429 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD5229C25CD7184CCE5688F7D45CCCB19 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:27 Reconnect Power/Cable! |
![]() | #74799 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | OPPO CPH1909 Format & Frp Code: Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: C50C74E528E3A65B3DC672447F2C83B0 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: E4305DF7EB946B92AE509B374338C5CED0B019290FAE899A1DFD3CDA5892C6D6 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: C50C74E528E3A65B3DC672447F2C83B0 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100474436424D4201CE729A14B53B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 3463617044 [0xCE729A14] MM/YY: 11/2018 EMI: Init Ok EMI: FireFly preloader_oppo6765_18511.bin with 9 memory type(s) 1. eMMC DDR3 ID: 150100514536334D42 Ven: Samsung | Dev: QE63MB RAM: 2.00 Gb 2. eMMC DDR3 ID: 90014A484147346132 Ven: Hynix | Dev: HAG4a2 RAM: 2.00 Gb 3. eMMC DDR3 ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 4. eMMC DDR3 ID: 150100474436424D42 Ven: Samsung | Dev: GD6BMB RAM: 3.00 Gb 5. eMMC DDR3 ID: 150100524436344D42 Ven: Samsung | Dev: RD64MB RAM: 4.00 Gb 6. eMMC DDR3 ID: 90014A484347386134 Ven: Hynix | Dev: HCG8a4 RAM: 4.00 Gb 7. eMMC DDR3 ID: 150100475036424D42 Ven: Samsung | Dev: GP6BMB RAM: 3.00 Gb 8. eMMC DDR3 ID: 150100524836344142 Ven: Samsung | Dev: RH64AB RAM: 4.00 Gb 9. eMMC DDR3 ID: 150100514436334D42 Ven: Samsung | Dev: QD63MB RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 150100474436424D4201CE729A14B53B VEN: Samsung OEM: 256 ID: 474436424D42 [GD6BMB] PRV: 0x01 SNN: 3463617044 [0xCE729A14] MM/YY: 11/2018 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x00400000 [ 4.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: B62F48C2BC6D7F68F3E1CD193D416F29 MEID: C50C74E528E3A65B3DC672447F2C83B0 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 40 Select info source... Ok Patch Level: O11019 Ver. CodeName: REL Ver. Release: 8.1.0 Sec. Patch: 2021-04-05 CPU: arm64-v8a,armeabi-v7a,armeabi CPU: armeabi-v7a,armeabi CPU: arm64-v8a Product Manfct: OPPO SW: full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys Build Time: 19/03/2021 11:50:27 am SW Version: 1616154627 Product Brand: OPPO Product Model: CPH1909 Product Info: CPH1909 Product Device: CPH1909 Product Name: CPH1909 SW OTA Version: CPH1909EX_11.A.46_0460_202103191930 Display ID: CPH1909EX_11_A.46 Kernel Info: 4.9.77 Strategy: [oppo] SmartInfo: Android Ver: 8 UserDataFS: 0x02 [ext4|8+] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage : FRP Stage : SMART Done: 00:00:44 Reconnect Power/Cable now |
![]() | #74800 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 3,004 | Realme C12 Frp Code: Product Board: oppo6765 Board Platform: mt6765 Product Brand: alps Product Device: oppo6765 Product Manfct: alps Product Model: oppo6765 Product Name: vnd_oppo6765 Strategy: [oppo] Firmware ID: MT6765_alps_oppo6765.MT6765_RMX2189_11_A.71_200825_81a0eb21 Verify firmware [MT6765_alps_oppo6765.MT6765_RMX2189_11_A.71_200825_81a0eb21]... Finished Analyze userdata... userData: fileSystem [ext4] with FBE [file based encryption] Analyze modem... OPPO6765_206A1_MDBIN_PCB01_MT6765_S00.MOLY_LR12A_R2_TC16_PR11_SP_V1_P42 Analyze nvram... NVRAM: Items: 0xAB Size: 0x08F8BF State: Ok WiFi MAC: C816DA69066B BlTh MAC: C816DA69066A Verify device config... Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY PROGRAMMED [UNUSABLE] Analyze preloader... EMI: MT6765 preloader_oppo6765.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Ven: Sandisk | Dev: DA4128 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 13. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb Preloader saved: C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_oppo6765.bin [99737696]... Exist Done: 00:00:32 Reconnect Power/Cable now Reset Mode: Reset FRP only Operation: Reset Settings/Format FS [ v2.46 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: FRP [ RESET PROTECTION ] Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MediaTek USB Port (COM5) MODE [0]: BOOTROM; PORT: 5 Waiting for BOOT ACK... BROM: Skip ACK verication BROM: Init... Ok CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] MEID: D93EC7626C5D8E242AF1E270EFAC1D44 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: 7DE36831F71193E38E29D86CC75378B94415170297A3163CBFD2C8B3634C9C46 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: D93EC7626C5D8E242AF1E270EFAC1D44 AGENT: AUTO: 0_base: base_v1712 [e600c7d1] C:\InfinityBox\CM2MT2\boot\0_base\base_v1712\MTK_AllInOne_DA.bin Looking for suitable BootChain in DA... Switch to v2216 Found MT6765 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 90014A68423861503E0300D291F86751 VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 13799928 [0x00D291F8] MM/YY: 6/2020 EMI: Init Ok EMI: FireFly preloader_oppo6765.bin with 16 memory type(s) 1. eMMC LP_DDR4X ID: 1501003458364B4D42 Ven: Samsung | Dev: 4X6KMB RAM: 2.00 Gb 2. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 3.00 Gb 3. eMMC LP_DDR4X ID: 90014A68423861503E Ven: Hynix | Dev: hB8aP> RAM: 2.00 Gb 4. eMMC LP_DDR4X ID: 150100445036384D42 Ven: Samsung | Dev: DP68MB RAM: 3.00 Gb 5. eMMC LP_DDR4X ID: 13014E47314A395238 Ven: Micron | Dev: G1J9R8 RAM: 4.00 Gb 6. eMMC LP_DDR4X ID: 150100445836384D42 Ven: Samsung | Dev: DX68MB RAM: 3.00 Gb 7. eMMC LP_DDR4X ID: 150100444836444142 Ven: Samsung | Dev: DH6DAB RAM: 4.00 Gb 8. eMMC LP_DDR4X ID: 13014E47314A395339 Ven: Micron | Dev: G1J9S9 RAM: 4.00 Gb 9. eMMC LP_DDR4X ID: 150100445636444D42 Ven: Samsung | Dev: DV6DMB RAM: 4.00 Gb 10. eMMC LP_DDR4X ID: 450100444134313238 Ven: Sandisk | Dev: DA4128 RAM: 4.00 Gb 11. eMMC LP_DDR4X ID: 150100445636444142 Ven: Samsung | Dev: DV6DAB RAM: 4.00 Gb 12. eMMC LP_DDR4X ID: 90014A68433861503E Ven: Hynix | Dev: hC8aP> RAM: 4.00 Gb 13. eMMC LP_DDR4X ID: 90014A684445615033 Ven: Hynix | Dev: hDEaP3 RAM: 6.00 Gb 14. eMMC LP_DDR4X ID: 90014A684339615033 Ven: Hynix | Dev: hC9aP3 RAM: 4.00 Gb 15. eMMC LP_DDR4X ID: 150100445036444142 Ven: Samsung | Dev: DP6DAB RAM: 4.00 Gb 16. DRAM LP_DDR4X ID: NOT_DEFINED Ven: Unknown 0x0000 | Dev: RAM: 2.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A000 [ 232.00 Kb ] RAM: DRAM: 0xC0000000 [ 3.00 Gb ] EMMC CID: 90014A68423861503E0300D291F86751 VEN: Hynix OEM: 330 ID: 68423861503E [hB8aP>] PRV: 0x03 SNN: 13799928 [0x00D291F8] MM/YY: 6/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6765 SBID: 0x8A00 HWVR: 0xCA00 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0766 CODE: Cervino TYPE: MODERN [RAPHAEL] RNID: C1F65225640D84A81424B78B19B09216 MEID: D93EC7626C5D8E242AF1E270EFAC1D44 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 47 Strategy: [none|generic] Verify device config... Ok Loaders Ok Stage : ANDROID OS [1] Process RESET PROTECTION... Ok [2] Verified Stage : FRP Done: 00:01:23 Reconnect Power/Cable now |
![]() | #74801 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,437 | ![]() Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : itel-L5006c.a895ce65.3ea52a0b Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:49 |
![]() | #74802 (permalink) |
Member: 2072265 Status: Offline Thanks Meter: 47 | s66il frp remove done Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : S661L_Vision-3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
![]() | #74803 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Infinix X653C Reset Frp Done By CM2 S/N: 73CA70CC v0156 Chinese Miracle II - MT2 Service Tool v2.47 Init log engine... Ok Build directories tree... Ok Backup files: C:\InfinityBox\CM2MT2\backup\ Backup files: 3 dirs: 0 Verify device database... BuiltIn: 28 Custom: 0 Build device list... Ok Scan 81 profiles... Ok Init environment... Ok Load IDBase v418494 Ok Operation: Identify Device [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Mode: FLASH Port: Both [ B + P ] [+] Read deep info: PRL, HW, DEBUG [+] Auto-EMI [+] FireFly-Over-DA extended protocol [+] Vendor-Specific Analyzer [-] Local SLA [-] Force BROM Wait... 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 3F1507A67AE904EFEE24CC8B45876ED2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B179024D7F50608FBDEF0A5122B4668B6197A2AC749312F761 D57BEBEE4073A0 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 3F1507A67AE904EFEE24CC8B45876ED2 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4201B5636ADA575D Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 3043191514 [0xB5636ADA] MM/YY: 5/2020 EMI: Init Ok EMI: FireFly preloader_x653c_h6114go.bin with 14 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Micron 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4201B5636ADA575D Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 3043191514 [0xB5636ADA] MM/YY: 5/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 5E5F0AF1C057EB026113D74A21D1F7C8 MEID: 3F1507A67AE904EFEE24CC8B45876ED2 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 38 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: X653C-H6114GH-PGo-210831V271 SW Version: GH-210831V271 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-09-05 Build Time: 8/31/2021 9:00:38 AM Product Model: Infinix X653C Product Brand: Infinix Product Name: H6114 Product Device: Infinix-X653C CPU: armeabi-v7a,armeabi Product Manfct: INFINIX MOBILITY LIMITED Product Info: x653c_h6114go SW: full_x653c_h6114go-user 9 PPR1.180610.011 153046 release-keys Product Board: Infinix-X653C Board Platform: mt6761 Strategy: [none|generic] Firmware ID: MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X653C_OSv9 _X653C-H6114GH-PGo-210831V271_PPR1.180610.011_x653c_h6114go Verify firmware [MT6761_INFINIX_MOBILITY_LIMITED_Infinix_X653C_OSv9 _X653C-H6114GH-PGo-210831V271_PPR1.180610.011_x653c_h6114go]... Exist Analyze userdata... userData: fileSystem : [f2fs] with FDE [forced fde or fbe] Analyze modem... TK_MD_BASIC_MDBIN_PCB01_MT6761_S00.MOLY_LR12A_R3_M P_V71_11_P24 Analyze nvram... NVRAM: Items: 0xA2 Size: 0x101934 State: Ok WiFi MAC: AA0036004400 BlTh MAC: AC2334041F20 IMEI[1]: IMEI[2]: Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__3F1507A67AE90 4EFEE24CC8B45876ED2 Backup already exist. Overwrite? No Verify C:\InfinityBox\CM2MT2\backup\MT6761__3F1507A67AE90 4EFEE24CC8B45876ED2.7z Finished STORAGE : Life Status : eMMC : OK! STORAGE : OTP Status : UNLOCKED! STORAGE : RPMB Status : eMMC : RPMB KEY NOT PROGRAMMED [USABLE] Analyze preloader... EMI: MT6761 preloader_x653c_h6114go.bin with 14 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Micron 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb Preloader exist: C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 653c_h6114go.bin Verify C:\InfinityBox\CM2MT2\backup\preloader\preloader_x 653c_h6114go.bin [16407d24]... Exist Done: 00:00:37 Reconnect Power/Cable now Reset Mode: Safe Reset by device requirements: UserData + FRP + Account(s) Reset Mode: Safe Reset by device requirements: UserData + FRP + Account(s) Operation: Reset Settings/Format FS [ v2.47 ] Platform: MTK SmartPhone - MT65/67/68/69/81/83/87 | Helio G/P/X Format: SMART RESET Wait... WARNING: Reset may clear ALL USER DATA! Continue? Yes 1. Power Off the device 2. Wait 20 seconds 3. Connect USB cable to device [remember Vol+ | Vol-] Waiting for device connection... PTFN: MTK USB Port (COM10) MODE [0]: BOOTROM; PORT: 10 Waiting for BOOT ACK... BROM: Init... Ok CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0200 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] MEID: 3F1507A67AE904EFEE24CC8B45876ED2 BROM: Sec Level: 0x000000E5 Mode: SBC+SDA+EXT VER: 0x05 BL: 0xFE [BOOTROM] SOCID: B179024D7F50608FBDEF0A5122B4668B6197A2AC749312F761 D57BEBEE4073A0 SLA: Local Auth SLA: Start Auth Ok SLA: Continue Auth Ok EMI known SLA: Start 0x15 SLA: Auth Passed; SEC: 0x000000E0 EMI loaded by MEID: 3F1507A67AE904EFEE24CC8B45876ED2 AGENT: AUTO: 0_base: base_v2216 [3365c4d2] C:\InfinityBox\CM2MT2\boot\0_base\base_v2216\MTK_A llInOne_DA.2022-04-10.3365c4d2.bin Looking for suitable BootChain in DA... Found MT6761 AGENT: MTK_DOWNLOAD_AGENT BROM: Sending 1st DA... DA sent Jump to DA... Ok DA: Sync... DA: AGENT started DA: SYNC MODE: BROM EXT_RAM NOT initialized EMMC CID: 150100514436334D4201B5636ADA575D Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 3043191514 [0xB5636ADA] MM/YY: 5/2020 EMI: Init Ok EMI: FireFly preloader_x653c_h6114go.bin with 14 memory type(s) 1. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 3.00 Gb 2. eMMC DDR3 ID: FE014A333232344433 Micron 3224D3 RAM: 3.00 Gb 3. eMMC DDR3 ID: 90014A484347386134 Hynix HCG8a4 RAM: 4.00 Gb 4. eMMC DDR3 ID: 150100514536334D42 Samsung QE63MB RAM: 2.00 Gb 5. eMMC DDR3 ID: 150100464536324D42 Samsung FE62MB RAM: 1.00 Gb 6. eMMC DDR3 ID: 90014A484147346132 Hynix HAG4a2 RAM: 2.00 Gb 7. eMMC DDR3 ID: 150100514436334D42 Samsung QD63MB RAM: 2.00 Gb 8. eMMC DDR3 ID: 90014A68423861503E Hynix hB8aP> RAM: 2.00 Gb 9. eMMC DDR3 ID: 700100464D42434541 Kingston FMBCEA RAM: 2.00 Gb 10. eMMC DDR3 ID: 150100524836344142 Samsung RH64AB RAM: 4.00 Gb 11. eMMC DDR3 ID: 700100464D41454538 Kingston FMAEE8 RAM: 1.00 Gb 12. eMMC DDR3 ID: 150100474436424D42 Samsung GD6BMB RAM: 3.00 Gb 13. eMMC DDR3 ID: 90014A684339615033 Hynix hC9aP3 RAM: 4.00 Gb 14. eMMC DDR3 ID: 150100525036344D42 Samsung RP64MB RAM: 4.00 Gb EMI: EXT_RAM CFG Passed DA: Boot to 2nd DA... 2nd stage confirmed DA: SYNC passed Load HW info... RAM: SRAM: 0x0003A500 [ 233.25 Kb ] RAM: DRAM: 0x80000000 [ 2.00 Gb ] EMMC CID: 150100514436334D4201B5636ADA575D Ven: Samsung OEM: 256 ID: 514436334D42 [QD63MB] PRV: 0x01 SNN: 3043191514 [0xB5636ADA] MM/YY: 5/2020 BOOT1: 0x00400000 [ 4.00 Mb ] BOOT2: 0x00400000 [ 4.00 Mb ] RPMB: 0x01000000 [ 16.00 Mb ] USER: 0x747C00000 [ 29.12 Gb ] CHIP: MT6761 SBID: 0x8A00 HWVR: 0xCA01 SWVR: 0x0000 EVOL: 0x0000 HWC: 0x0717 CODE: Merlot TYPE: MODERN [RAPHAEL] RNID: 5E5F0AF1C057EB026113D74A21D1F7C8 MEID: 3F1507A67AE904EFEE24CC8B45876ED2 USB: HIGH-SPEED Boot done MODERN [RAPHAEL] Analyze PMT... Loaded 0x8000 bytes PMT: PGPT [0x64] Records: 38 Select info source... Ok Patch Level: PPR1.180610.011 Display ID: X653C-H6114GH-PGo-210831V271 SW Version: GH-210831V271 Ver. CodeName: REL Ver. Release: 9 Sec. Patch: 2021-09-05 Build Time: 8/31/2021 9:00:38 AM Product Model: Infinix X653C Product Brand: Infinix Product Name: H6114 Product Device: Infinix-X653C CPU: armeabi-v7a,armeabi Product Manfct: INFINIX MOBILITY LIMITED Product Info: x653c_h6114go SW: full_x653c_h6114go-user 9 PPR1.180610.011 153046 release-keys Product Board: Infinix-X653C Board Platform: mt6761 Strategy: [none|generic] SmartInfo: Android Ver: 9 UserDataFS: 0x03 [f2fs] CacheFS: 0x02 [ext4|8+] Verify device config... Ok Loaders Ok Backup exist: C:\InfinityBox\CM2MT2\backup\MT6761__3F1507A67AE90 4EFEE24CC8B45876ED2 Stage: ANDROID OS [1] Process RESET PROTECTION... Ok [2] Process USERDATA... Ok [3] Process CACHE... Ok [4] Verified [5] Verified [6] Process USERDATA... Ok [7] Verified Stage: FRP Stage: SMART Done: 00:00:35 Reconnect Power/Cable now |
![]() | #74804 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,778 | Itel vision 3 reset frp done by cm2 Card found : 73CA70CC , v0156 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! Operation : Format FS / Reset Settings [ v2.14 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : iTel : S661L_Vision-3 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : False FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : SEC : RSA auth required! FDL : Process authentification ... FDL : SEC : RSA auth passed! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 |
![]() | #74805 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,088 | Realme C21y FRP Code: Operation : Identify [ v2.14 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : realme-c21y.e4e4acc6.94108091 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Device info : Product Brand : realme Product Device : RMX3261 Product Model : RMX3261 Product Name : RMX3261 Patch Level : RP1A.201005.001 Display ID : RMX3261_11_A.103 Ver. Incmt : 1681499885000 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2023-04-05 Build Time : 14.04.2023 SW OTA Version : RMX3261_11_A.103_20230415014942 Product Info : S19610AA1 Product Board : RMX3261 Board Platform : ums512 Product Manfct : realme NVMng : SecurityInfo IMEI[1] : 867400020316612 IMEI[2] : 867400020316620 IMEI[3] : 867400020316638 SEC : SLS:0, SKS:0, SKV:4 Platform Version: MOCORTM_20A_W22.43.5_Debug Project Version: sharkl5pro_pub BASE Version: 4G_MODEM_20A_W22.43.5 HW Version: sharkl5pro_modem CMP_Time : 10-28-2022 04:04:10 MODEM TAG : MOCORTM_20A_W22.43.5_Debug_4G_MODEM_20A_W22.43.5_sharkl5pro_modem_sharkl5pro_pub USERDATA : FILESYSTEM : F2FS with FBE ( File-Base Encryption ) - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:01:04 Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Realme : realme-c21y.e4e4acc6.94108091 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0020 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:15 |
